...did Studebaker use on the GT Hawks. Big puddle under mine this morning....any suggestions?
Who's differential....
Originally posted by Lou Van Anne View Post...did Studebaker use on the GT Hawks. Big puddle under mine this morning....any suggestions?Gary L.
Originally posted by studegary View PostYou don't normally get a "Big puddle" all of a sudden from a differential. Are you sure that the puddle is gear oil and not brake fluid? The rear brake lines run around the differential and out on the axle tubes. The brake lines can have a failure point all at once, especially the flex line.Lou Van Anne
62 Champ
64 R2 GT Hawk
79 Avanti II
I agree with the leaking brake line especially if it is more to the left side where the rubber hose is located, but there is also the possibility that the pinion seal on the front of the differential is leaking. The original seal was made from leather which has now turned to concrete and can no longer do its job. Fortunately new seals are available and not to difficult to replace. Anyway check both the brake fluid level and the lube level in the differential. One other thing to check is the rubber hose on the fuel line coming from the gas tank as they are also known to fail. Bud
More good ideas Bud, thanks. I'll post when I discover the actual problem. (The idea about the rubber gas line hit me in the middle of the night too).Originally posted by Bud View PostI agree with the leaking brake line especially if it is more to the left side where the rubber hose is located, but there is also the possibility that the pinion seal on the front of the differential is leaking. The original seal was made from leather which has now turned to concrete and can no longer do its job. Fortunately new seals are available and not to difficult to replace. Anyway check both the brake fluid level and the lube level in the differential. One other thing to check is the rubber hose on the fuel line coming from the gas tank as they are also known to fail. BudLou Van Anne
62 Champ
64 R2 GT Hawk
79 Avanti II
Originally posted by bensherb View PostJack, do you know if the traction lock carrier from a mid 80's Jeep dana 44 will fit the Stude dana 44 axle?David L
