Re: '64 Daytona V8 with factory T86 stick & overdrive
Lately its been getting hotter in Nevada. I drive the Daytona its first 15 minutes or so, and OD works fine. After the car gets thoroughly warmed up, combined with 85 degrees and up outside, the OD stops working. I still drive, but now I'm taching 3000 rpm at a little over 60 mph instead of my usual 2100. And when I take my foot off the gas, even at speed, I've got no engine compression. The rpms just go down to idle speed.
So, I wonder if this problem is a classic symptom of anything in particular. Maybe when a governor gets hot enough it may routinely do this ???
I'm sure I am not the only one out there who has experienced this. Any ideas?
Thanks,
Larry
Thanks,
Larry
