View Full Version : McKinnon 327?
lumpy
06-09-2017, 11:11 PM
The 327 chevy that is destined for my 59 lark is a large journal 1969 327 from a camaro. I have had this engine for several years and before that my buddy Ray pulled it from a derelict camaro. It has something I have never seen on all the small block chevys I have messed with over the years . On the drivers side bell housing mounting flange , it has a square with a capitol M cast in it… Could this be a Canadian sbc? Would be kind of ironic that Im building a hot rod Stude with a Canadian engine. The numbers on the front of the block were milled off many years ago when it was decked.
sweetolbob
06-10-2017, 07:57 AM
Probably says something like hecho e Mexico on the block. I believe mexico casting.
lumpy
06-10-2017, 10:20 AM
Nope no hecho en Mexico:)
lumpy
06-10-2017, 11:12 PM
Does anyone have a way of Identifying a canadian block? Just curious not like its a #s matching deal. I have never come across a mexican block of this vintage 1969. It does not say hecho en mexico. It has some extensive machine work in the lifter valley area that is not present on all my other small blocks, and I have seen a butt load of them , but never with the particular casting symbol I mentioned in my earlier post:o
jrlemke
06-11-2017, 05:54 AM
It might be a stern-drive block from "Mercury-Marine!" I seem to remember seeing a warehouse full of Chev engines at the Merc. factory when I was a security guard there in the '70's. All the crates were marked "Mexico". Was told that they were "special" because boat motors run at a constant rpm rather than up-and down like a car. i remember Mercs where painted black! Just a thought.- Jim
DEEPNHOCK
06-11-2017, 06:55 AM
http://www.mortec.com/castnum.htm
sweetolbob
06-11-2017, 09:20 AM
Lumpy, Post a picture, that will help a ton. Bob
lumpy
06-11-2017, 09:08 PM
casting # is 386 1969 camaro 327 . Ill post pics of the unusual casting mark when I get to work tomorrow. From the research Ive done Mckinnon did build 327s in 69 and Im pretty sure Canada produced a good # of camaros.
Mohr HP
06-11-2017, 09:14 PM
For what it's worth, I have a Mercury Marine 454, and the ID pad is blank; It does have a riveted I.D. tag on the bellhousing flange near the starter. Cast in 1990. Block is painted black.
Canada did indeed produce many Camaros, but none in 1969. All were made either in Norwood, OH or Van Nuys, CA.
You can read about the "M" coded 1969 model year blocks here: http://www.camaros.org/drivetrain.shtml#BlockCast
sweetolbob
06-12-2017, 11:07 AM
Good find Lynn, Interesting. Happened just down the road about 12 miles. Bob
lumpy
06-12-2017, 12:00 PM
This is the casting symbol on the back of the block. I have probably dealt with hundreds of SBC's over the years and have never seen this symbol.
lumpy
06-12-2017, 01:51 PM
That explains it, no wonder I hadn't seen one before, Thanks guys!
dannyo
06-13-2017, 07:28 AM
did thay ever a 327 MC Kinnon engine & put it in the 65 66 lark ?? i thought i seen a brosher back in the day thay offered the 283,& the 327 ? any one know ?
thunderations
06-13-2017, 07:31 AM
No 327's, just 283, 2 barrel.
swvalcon
06-13-2017, 10:49 AM
For what it's worth most boat chev engines but not all are nothing more than a truck engine. In the 350's they are 4 bolt main with steel cranks and different cam. 327's had some steel shafts but never saw a 4 bolt main. Not sure if they even made one. Although a guy could build one with a 350 4 bolt and 327 crank and pistons. The 305's where just a car motor with minor changes.
Powered by vBulletin® Version 4.2.4 Beta 2 Copyright © 2019 vBulletin Solutions, Inc. All rights reserved.
