Has anyone used a Mustang control valve on the Studebaker power steering? If you have which year or model do you use? I was told it was same one used on Studebaker.
Control Valve
Former Posts here confirmed that the common Ford Control Valve Units DO NOT interchange to Studebaker.
I believe the early Ford Ram, and for sure the Eaton Pump WILL work.StudeRich
The spool valve is a different size, and there isn't the right end for the Studebaker reach rod. Most of the other parts of the valve can be used for parts to rebuild the proper Stude valve.Bez Auto Alchemy
