I am installing back up light kit (AC-2957). There is a LH and RH side. I drilled the holes according to the supplied template. The holes mounting the light body in my opinion should be parallel with the ground but the screw holes are at 8 o'clock and 2 o'clock. Also the supplied body gasket is too short to completely go around the light body and it is just one length and the manual shows it as one piece?
Does anyone have a close up picture showing the orientation of an installed light?
Thanks very much.
Thanks very much.
