View Full Version : doors
old fart
05-22-2017, 05:52 PM
Hey guys :
Question are the doors on a 63 HT the same as the 64's .
Old Fart
showbizkid
05-22-2017, 07:46 PM
They are vastly different.
old fart
05-22-2017, 10:29 PM
Thanks Clark wanted to make sure . I see you have a 63 F2 as your sign off , have you joined the registry for it yet ???
Old Fart
martincl
05-23-2017, 04:26 AM
63 J-L doors have the same part numbers as 64 J-L doors ....
jts359
05-23-2017, 08:55 AM
The glass is different for the Hardtops in 64 , But as Martincl stated the doors are the same , Ed
stude1964
05-23-2017, 09:42 AM
The door glass differs between the two years as do the vent windows and frames. '63 J & L and '64 L are the same vent windows for what it's worth. The door glass on a '63/4 L has a slight curve at the top whereas the J is straight. I checked the other day as I was going through my '64 conv. parts and found additional side glass for a '63 J which will be available.
Rob in PA.
candbstudebakers
05-23-2017, 11:06 AM
You can use the 63-66 2 door doors but would need to remove the upper frame that is only bolted on and add a piece of metal to hold the outer chrome top strip.
old fart
05-23-2017, 11:46 AM
Hey Guys :
Just remembered I have a parts book for 59-64 and found 1352188 and 1352189 are listed for both 63 and 64 cars , so Martincl is correct and so is Candbstudebakers . Interesting how one question brings out different opinions . thanks fellas .
Old Fart
Pauly
05-23-2017, 09:01 PM
Looks like a good enough place to chime in... I'm looking for doors for my 55 hardtop. What's the cutoff year for interchange on those?
old fart
05-24-2017, 09:09 PM
Pauly :
If you can get the part numbers check the ones I listed for 63's and that should give you more info as to when cut off is .
Old Fart
studegary
05-24-2017, 10:47 PM
1953 - 1955 K bodies (hardtop). Others will fit, but will not be correct.
Pauly
05-25-2017, 07:11 PM
Will all of the hardtop doors fit? The car is far from stock anyhow. I don't mind filling in a trim or mirror hole here and there.
Pauly
05-25-2017, 07:14 PM
Pauly :
Old Fart
Ok, I will check my 55 parts book and see what I can find. Thanks!
studegary
05-25-2017, 09:37 PM
The doors from 1953 to 1958 will fit. The difference isn't just holes to fill, but rather the swoop size and no swoop.
Pauly
05-26-2017, 10:20 AM
I can't believe I never noticed that! Thanks, Gary!
