The trunk lid on my Sky Hawk is VERY heavy, and is quite hard to lift. All 4 springs are on both of the hinges (2 each), but when I twist the latch release I have to get my fingers under the lip and really lift. The hinges are oiled and free, and once opened, the lid stays up. Are all C/K trunk lids like this?
Sky Hawk Trunk Lid
Originally posted by 345 DeSoto View PostHydraulic struts are exactly what I had in mind. However, I haven't a CLUE on placement, length, or how to go about properly installing them...
Someday I plan to install struts on the hood of my daughter's Silver Hawk.
PS - SAFETY PRECAUTION!!!! Take a screwdriver and some pliers with you when you climb in the trunk so you don't get stuck!!!
Treblig
Originally posted by 345 DeSoto View PostTREBLIG - That is exactly the info I needed. Thanks, SO much! I'm going to do the trunk AND the hood...
Also on the Silver Hawk hood, after making many measurements, I think it will require a collapsing arm to pivot because the hood opens so high there are no struts long enough that won't end up sticking out of the bottom of the bumper. I really don't want to drill holes into the hood to attach struts on each side (hinge area), the hood is just too long and heavy and kinda weak. Still kicking it around to get the best idea!!
Treblig
Just a word of caution. You take a chance on ruining a difficult to find one year only hood if you install struts without reinforcing the hood. The Hawk hoods are notoriously weak.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
Originally posted by 41 Frank View PostJust a word of caution. You take a chance on ruining a difficult to find one year only hood if you install struts without reinforcing the hood. The Hawk hoods are notoriously weak.
treblig
Here you go:
I cut and mounted a 90 degree piece of angle iron to the underside of the seal gutter. The head of the screws are hidden by the rubber gasket. Then I drilled a hole to fit the ball stud that came with the strut:
I basically did the same thing on the trunk lid. I cut and fitted a piece of angle iron and drilled a hole in it for the ball stud.
If you only use one strut it will tend to push the lid up from one side only and even when you close the lid the strut will continue to push on that one side but it may or may not be noticeable. I guess you could put one on one side and see how it works then if it tweaks the lid too much you can install another on the other side but then you would need 2 weaker struts instead of one strong strut.
Just find the attach point for the body and the lid (with the lid at the proper height) and that will tell you the approximate extended length, then close the lid and measure the distance between the two attach points and it will give you the collapsed length. Leave yourself a 1/2" or so so that the strut doesn't bottom out when you close the lid.
Treblig
