Is cured JB Weld 100% gasoline proof?
JB Weld
There are more than one JB Weld formulation. I'm not where I can check, but I believe I have a couple of the different packages. Also, there are offerings that cure faster or slower when catalyzed. Perhaps you could pull up their website and learn what would be best for what you have in mind.
So...after typing the above paragraph, I went to their website in which they claim for gasoline applications, to use "Water Weld," or the "Steel Stick" products.
Google is your friend. Since you have an internet connection, 15 seconds on Google would have gotten you this: "When fully cured, J-B Weld is completely resistant to water, gasoline, and about every other petroleum product or automotive chemical. For wet-surface or submerged water or gasoline repairs, try our SteelStik or WaterWeld."Paul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1lark
Friend of mine cracked his hemi engine drag racing (legal sanctioned track; not outlaw ). Put it back together with JB Weld, machined it, ran several more seasons and finally sold the engine to an up-and-comer.Brad Johnson,
'56 Sky Hawk in process
Originally posted by 345 DeSoto View PostThe reason I ask, is because I have to put my gas tank sending unit back together, after repairing it.John Clary
JCLARY - When I took my gas tank out this week, I removed the sending unit. The solder seal on the tube coming out of the unit was broken, and the unit itself was covered with some sort of grunge. I took the sending unit apart and cleaned it, and it works. Now I have to refasten the tube to the unit, and seal the two halves of the unit back together..thus, my question on JB Weld. I have a gasket for the sender to the tank.
I only use PC-7. I have used it in restoring a steering wheel to fuel tanks. My last project was rebuilding the inside of my pitted calipers on the '63 Avanti. I have found PC-7 to be much better to work with then J-B Weld. And PC-7 goes along ways. My two cents.Jim Kaufman
Kearney NE
1952 2R10
1953 Champion (sold it and still kicking myself)
1962 GT Hawk
1963 R3984 Avanti R1
Originally posted by 345 DeSoto View PostIs cured JB Weld 100% gasoline proof?
I have a '73 Pinto I converted to the Turbo 2.3 out of the T-Bird Turbo Coupe. Being the engine is fuel injectioned I needed a return line back to the tank. I drilled and soldered a section of gas line to the sending unit as it was far easier to remove than the whole tank (sender is on the side, not top). Unfortunately the soldering process melted the nylon insulator where the wire connects. I liberally applied JB Weld to both sides and nearly 10 years later I have no leak.'64 Lark Type, powered by '85 Corvette L-98 (carburetor), 700R4, - CASO to the Max.
Another product I have used to seal the jet wells in Quadrajet carburetors is: MARINE TEX Probably more available in areas with lots of boating facilities. Just don't breath the fumes while it cures as I'm sure it must have "cancer" written all over it.
Bill
Originally posted by Buzzard View PostJust don't breath the fumes while it cures as I'm sure it must have "cancer" written all over it.
Bill
That's a bit more of a throwaway line than I think is fair to Marine Tex. It's epoxy resin no more no less. It's not mother's milk but it's a product used safely everyday by the general public.
Bob
