On 4-28-2017 I wrote: “When I go to install the new wiring harness, I will need to know what alternator to buy for this truck AND how to connect it to the voltage regulator. It carried a factory DEVIATION and was equipped with an alternator, missing when I bought the truck. The wiring for this is not covered in the shop manuals.That means I will have to find out how the alternator is connected to the voltage regulator, too.
I saw a similar set-up on a Lark a few years ago. On the left side of the alternator was a wire lug (1/4") surrounded by a red disc. There was a two-wire plug with a black wire and a blue wire. On the right side was a wire lug (1/8").”
Stude Norm responded:” If you want to keep it stock let the forum know what year you have and someone should be able to get you the model number for the alternator you require.”
So, I have a ‘64 Champ 8E5 pick-up, 6-cyl, 170 OHC. Anyone know the model number I require?
I hope to become
