View Full Version : Studebaker at the track 4-9-17 results
shifter4
04-10-2017, 09:03 AM
Had a so-so day at the Track yesterday 4-9-17 .
Various problems on 2 of the 4 runs , so only 2 were decent .
Bright blue sky , and about 80 deg .
Running the Evans intake . Pretty sure that it will be an improvement in the long run , but a
Carb problem has interfered . The " stumble ' at the hit , which I thought was gone returned .
I'll do a total carb rebuild etc . ( I really did not want to do too much for this event , because I wanted
to compare Apples to Apples .)
Results were mixed. MPH is pretty good for this car , and the 60 ft times were good also , especially when considering the
stumble .
60 fts were 1.991 , 1.865 , 1.878 , 1.870 .
2 Best MPHs 94.80 and 94.52
2 best Ets 14.125 and 14.057
As I don't qualify to run in the fast guy lanes , I am surrounded by a horde of various Hemi powered Dodges , and new Mustangs , with a few
Turbo Subbies and the like over in the " street class " . But , I did win one out of my 4 runs , somehow .
52-fan
04-10-2017, 10:06 AM
It's always interesting to see your reports. One fine day everything will work like you want it.
t walgamuth
04-10-2017, 02:59 PM
Glad you're having fun with it!
Mike Van Veghten
04-10-2017, 03:08 PM
Bill -
As you might know, depending on the plenum size difference between your previous vs. the Evans manifold, a larger plenum will require a larger amount of fuel to enter the plenum at the hit of the throttle. A idle fuel (mixture screws) increase will also help.
A lot of times, even a couple of degrees of ignition timing help.
shifter4
04-10-2017, 04:56 PM
Bill -
I did basically anticipate that , and set the idle a little on the rich side . The Evans is a single plane , but the Morgan is a dual plane , but
I had a quite high spacer/stack on it , and a good bit of the divider was cut down also , so had a goodly volume in there . The problem was there
to an extent before the intake change , but I thought that I had tuned it away with the idle set and making sure that the stroke of the pump was the quickest .
It had not shown up , or been noticeable before late last year .
Will be ready to move the timing , depending on results .
I'm gonna do the carb , verify the metering rod movement etc etc , and go back whenever possible .
Thanks for the comment .
Buzzard
04-10-2017, 06:06 PM
Hi Bill,
What car and carburetor are you running? Air cleaner? Open exhaust or closed? Distributor? Plugs? See where I'm going?
Bill
shifter4
04-10-2017, 06:18 PM
Hi Bill,
Bill
Here is the entire story .
12 pages .
http://racingstudebakers.com/foo/viewtopic.php?f=9&t=2360
parts
04-11-2017, 12:48 AM
REAL nice ! Good times too..
Buzzard
04-11-2017, 12:39 PM
Thanks Bill H,
Nice build and I'm sure your times will just keep improving.
Cheers, Bill
