After reading through previous posts re electric fuel pumps, I haven't seen any references to availability of an electric pump application for standby or booster service as applied to the earlier 6v. negative ground systems. I would like to discharge the electric pump through the mechanical pump.
I'd like to keep the Carter glass bowl pump on my 55 President State sedan and have the electric pump as a backup to avoid hot weather stalling and to aid starting after fuel has evaporated from the WCFB during extended layups.
The electric pump would run through a relay activated by a dash-mounted toggle switch, probably with an impact activated cutout in the curcuit.
I thoroughly understand the pitfalls involved (possible fuel leakage into engine lubeoil thru internal mechanical pump leakage) but the fuel leakage concern exists weather the electric pump is present or not.
After 38 years at sea in various engine rooms I have learned to appreciate redundant systems.
I have no plans to devolve to a 12v electrical system.
Jim
Jim
