What's going on with this spring?
Tags: None
To answer your question, that is how the spring is positioned normally. if it is warm, and un-choked, the link from the choke plate should move the fast idle cam back so the screw isn't on the ramp. When the choke is set like in your picture, the fast idle at the index mark like shown, you should have the primary throttle open .022 with a wire gauge.Bez Auto Alchemy
