Finally got my block back from the machine shop today. Hot tanked, Bored and honed to .030 and cam bearings installed. $290. Said one hole almost didn't clean at .030 but it said after he honed it the last couple .001's it was good. Now to just get the time to put it back together. This is my first studebaker motor so should be fun. Jay at the machine shop said it was fun to work on one again. Said his dad was a big Studebaker guy.
289 block
That sounds like good News, ANY progress is always Good.
It might be time to watch the Pete's Garage Video Series of a '62 Hawk 289 Engine being rebuilt, especially the "Assembly" one or one's.
I think most of his "minor" errors were caught here.StudeRich
Originally posted by swvalcon View PostFinally got my block back from the machine shop today. Hot tanked, Bored and honed to .030 and cam bearings installed. $290. Said one hole almost didn't clean at .030 but it said after he honed it the last couple .001's it was good. Now to just get the time to put it back together. This is my first studebaker motor so should be fun. Jay at the machine shop said it was fun to work on one again. Said his dad was a big Studebaker guy.
Didn't have a lot of time to mess with it today as I have a 2016 Impala to paint the sides on. Did take a few moments to check the odd side 1-7 which is the one that was worn the most before taking to the machine shop and my end gap on the rings are now at .012-.013. Hope to get some time tomorrow to go over everything good just to be sure but I trust Jays work enough I think I could just put it together.
Mike It was a complete rebore and honed for cast rings. Crank was good standard and will just get new bearings and motor will get a valve job on the heads. Machine shop hot tanked them and checked for cracks and straightness. All was good.
I sure did Joe. Every plug and soft plug or frost plug and part was removed. Had time to check rest of block today and all ring gaps checked the same. I was using a go no go feeler gauge that is most times use for setting rocker arms. The .012-,014 gauge the .012 would slide between the ring ends but the .014 would not so they are all .012-.013. Should be able to put the cam plug and rear oil galley plugs in and get it on the engine stand so I can start putting it together.
