View Full Version : Tech Talk
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
  1. 10 % Ethanol in the Gas
  2. 1950 rear spring lube
  3. Carb rebuild kits
  4. rough idle
  5. Need '60 Lark Interior
  6. Need 44 Dana Flanged Rear Axle Assembly
  7. REAL nice P/U on ebay
  8. Avanti II Question
  9. Brake Problem
  10. WCFB Intake Modification
  11. Using Chevy VC Gaskets
  12. De-rusting tank
  13. Hood stuck/52 Champion
  14. Need wiper motor
  15. 1950 champ frnt hubs
  16. 12 volt conversion on 1950 champ
  17. # 1 position on the cap
  18. hydrovac bleeding
  19. Jet Thrust Engine FS
  20. 1959 or 1960 Lark?
  21. 47 pickup
  22. Can air filter be modified?
  23. Water pump on 57 Silver Hawk
  24. 63 stude steering wheel remove
  25. front fender patch panels
  26. Installing Catwhiskers and Weatherstripping
  27. Automatic transmission
  28. body parts
  29. rims and tires
  30. Rebuilding a v8 - how to avoid leaks?
  31. Grinding trans gears
  32. Colors
  33. Phantom Auto Works suspension upgrade
  34. Clutch problems
  35. Master Cyl. help
  36. 44 Dana axle needed
  37. gears grind
  38. uphills
  39. carberattor
  40. windows
  41. 1952 champion front spring
  42. Found,1948 3/4 Ton Truck
  43. new toy
  44. Ford V8 in 1 1/2 ton Stude?
  45. 63 Champ
  46. Wheel Lug Nuts
  47. Speedometer gear -- Help
  48. 1963 Champ Conversion
  49. Turner Brake Conversion
  50. distributor
  51. idle speed
  52. Truck Wheels
  53. V8 Rod Interchange?
  54. Overdrive Fuse Blows
  55. steering column removal
  56. starter drive-bendix
  57. water pump rebuilding
  58. 5-speed conversion
  59. Automatic transmission locked in Park; HELP
  60. Throttle Body Fuel Injection
  61. parts
  62. Crank pulley bolt
  63. front brakes
  64. IN NEED OF:53 champ front grill chrome
  65. Frame repair suggestions?
  66. Stude V8 Identification
  67. Pictures here?
  68. Studebaker bell housing patterns
  69. Fluid Leaks
  70. transmition queston
  71. Brake Hose
  72. Dwell tach for 6v positive ground
  73. Pre War Engines
  74. 50 Studebaker Starlite Coupe
  75. more brake & bolt pattern conversion questions
  76. rear end swaps
  77. one-piece side glass for 49 to 55 trucks
  78. transmition
  79. Window Channel
  80. Studebaker V8 Rebuilt Long Block Engines
  81. Jacking up front end (.....for "Dummies")
  82. Getting back on the T-cab
  83. brakes
  84. Overdrive switch
  85. Partial Flow Oil Change
  86. wheelbase
  87. valve covers
  88. 64 challenger
  89. glove box
  90. 4bbl manifold?
  91. Windshield molding confusion
  92. Chap/gap in Daytona frame, front end
  93. 1926 STUDEBAKER
  94. truck beds
  95. chattery clutch
  96. Custom Wheels for 1954 Coupe
  97. Starter motor
  98. Buying a 1950 Champion
  99. tranny swap question?
  100. Front Crossmember
  101. rear end question
  102. 1952 2R 6 transmission
  103. '55 185 into a '49 w/ 170???
  104. Champion j7 spark plugs
  105. Studebaker Wheels and Lugs
  106. Ebay parts 53-54 C/K
  107. New Keys
  108. 2bbl Carb Adapter
  109. windsheild
  110. cover conversion
  111. Engine Weight
  112. Motor Mounts
  113. alternator upgrade?
  114. How to set lifters on my 50 champ
  115. 48 jeep with a studebaker flat head
  116. Cheap 1966 Dana 44 flanged axle oil seals.
  117. Controll Arm
  118. 1950 Studebaker Champion, frame swap
  119. cool addition to my engine!!
  120. 1950's manual info needed
  121. Vin #
  122. Prestolite distributor
  123. engine id
  124. Prestolite dist. update
  125. Brakelight Switch
  126. Manifold flow in a 232
  127. Rod Information Needed
  128. 62 hawk
  129. Need engine ID clarification help
  130. Aluminum casting
  131. 51 Commander Rewire
  132. 2006 Engine Masters Competition
  133. Converting to 12 Volts
  134. truck frrames
  135. TELL ME ABOUT THE 51 COMMANDER AUTOMATIC TRANNY!
  136. Oil Pressure 1926 Standard Six
  137. Rod Bearing Change???
  138. Lowey C body vent window surround question
  139. 62 Hawk Auto Transmission Leak
  140. Questions on the New Process 5 speed truck trans
  141. Moving the fuel pump on an early V-8
  142. hawk distributor
  143. Rust killer
  144. Transmission fluid type
  145. Carb problem
  146. Landcruiser
  147. 1962 Hawk Automatic Transmission
  148. Door hinge pin replacement.
  149. Rear Axle Shaft
  150. Piston clearance
  151. Avanti Roof Repair Needed
  152. 60 hawk won't start
  153. Keep it running! 1948 Champion
  154. Brake
  155. 37 troubles
  156. Window Regulators 60 Hawk
  157. Stainless windshield mouldings
  158. Petronix ignition
  159. Pulling off brake drums
  160. York
  161. psiton clearence- Sonny
  162. 1951 Champ
  163. 37 coupe express frame
  164. Jeepers Creepers
  165. FOM Transmission
  166. T-cab booster
  167. Extra ground wire
  168. '55 C-body exhaust help!
  169. Tail-light sockets on GT Hawks
  170. Okay, Mr. Biggs, WWYD?
  171. overdrive wiring
  172. thanks to sonny
  173. need performance parts
  174. hey sonny
  175. Push-starting an Automatic Drive
  176. Bright Fins
  177. Tag on fire wall
  178. Super Charged Engine
  179. 4-speed identification
  180. Front drive shaft flange
  181. Freeze plugs, 6 cyl. 1950 Champ
  182. Thanks Sonny!!! and every one else!!
  183. Pertronix question.
  184. Rocker switches - 66 Lark types
  185. Brake booster
  186. aluminum head
  187. Clutch and pressure plate swap???
  188. Studebaker DG Trans Info Available
  189. Update on my Hawk
  190. Orphan Axle
  191. Rear Bumper
  192. Identifying TT Trans
  193. 49 pickups
  194. vent window rubber
  195. gear ratios
  196. Back glass and windshield help
  197. Edelbrock hook-up info needed
  198. Petronix ignition
  199. parts source for 56 powerhawk
  200. Moving 232 fuel pump
  201. 64 Hawk Door lock cylinders
  202. Where was the new Stude Intake??
  203. 59 Lark rear end in a 49 2R5?
  204. Epoxy primer
  205. distributor advance
  206. 49 pickups
  207. Power steering pump Temp
  208. flywheel bolts
  209. Chevy Valve Conversion
  210. 64 Challenger Brakes
  211. carb
  212. ignition problem
  213. Edelbrock carb 500 cfm vs 600cfm.
  214. Need some advice & help 1949 2R10
  215. Brake Drums again
  216. KNOCK KNOCK
  217. Hawk Parts
  218. 7.25" rims on a 2R10?
  219. 55coupe eng shuffle.
  220. Amperes gage
  221. Steering popping
  222. 63 Avanti Questions
  223. leaky brakes
  224. suspension
  225. 1963 Champ
  226. 224 to 289
  227. big bore
  228. engine color
  229. 1940 champion oil
  230. tires
  231. WCFB manifold question and TBI
  232. Original Studebaker 5" wheels
  233. trim clips and interior help needed
  234. vaccum advance
  235. Hawk Cures.
  236. Flight-o-matic parts
  237. distributor parts
  238. DECK HEIGHT?
  239. Help - Steering Wheel Color Needed
  240. Clutch release bearing
  241. looking for advice on turbo plumbing
  242. dash boards
  243. Continued Education
  244. V-8 Block Deck Thickness
  245. WTB: Cam Gear 1916 Studebaker 4cyl
  246. 1950 champ od
  247. trunk lid problems
  248. 1939 Champ interchange w/1948 brakes??
  249. Climatizer/ Heater Motor
  250. transmission
