View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 [99] 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
  1. Wheels Mystery Rotating Hubcap????
  2. Wheels Avanti Mustang Bullitt Wheel Centers
  3. Interior: window fuzzies
  4. Transmission: 1955 Commander DG-200 Trans. slipping
  5. Electrical: Ground Locations
  6. Fuel System: Gas Filler Hose Installation
  7. Transmission: ford fmx
  8. Steering 63 Hawk R2 power steering control valve
  9. Electrical: Voltage Regulator
  10. Body: Bumper restoration
  11. Front Axle: Bolts for Front Houdaille Shocks?
  12. Wheels Welded 4 bolt wheels
  13. Cool/Heat: Lower radiator hose 1941 commander
  14. Engine: Phil Harris at Fairborn Studebaker needs V8 cam cores
  15. Body: DOOR Differences
  16. Frame/Springs Shortening a 2R17
  17. Steering Steering column replacement
  18. Transmission: how to check 63 flightomatic fluid level
  19. Wheels GH Wheel Bolt Pattern
  20. Wheels Wheel centers: sources for logo's for custom hub covers ?
  21. Transmission: gm 4 speed auto trans.
  22. Brakes: Brake hoses at hydrovac
  23. Steering Power Steering Fluid Leak
  24. Transmission: overdrive interchageable?
  25. Electrical: Steering column horn wire replacement - '55 President w/power steering
  26. Body: 1954 grille and taillight housings
  27. Body: Tightening body to frame bolts. Feedback appreciated
  28. Fuel System: Looking for opinions on Avanti gas tank options new or renew
  29. Transmission: Gear Oils
  30. Electrical: Fix for turn signals that won't hold.
  31. Rear Axle: Spicer 41-2 cover gasket
  32. Speedo/Tach/Gauges fuel and temp gauges appear to not work on my 1961 Lark
  33. Body: Will '55 front fenders work on a '53
  34. Engine: 1935 Dictator motor mounts
  35. Rear Axle: Spicer 41-2 Cover torque recommendations
  36. Electrical: Ac 3474
  37. Engine: to PCV or Not
  38. Body: Body size question
  39. Transmission: What?! Another gear oil question?
  40. Other: Radio & Clock
  41. Electrical: high beam floor switch
  42. Engine: Engine Rebuild in Central Florida
  43. Cool/Heat: Radiator Question
  44. Paint: Front trim paint for a 40 President
  45. Other: Tires for a '63 Avanti
  46. Engine: Parts book reference for SP-50098 piston rings?
  47. Other: Oilleak in valley cover
  48. Fuel System: GT Hawk Gas Tank in a Speedster?
  49. Electrical: Finding a short
  50. Steering adding power steering
  51. Engine: Type of engine
  52. Other: A Newby's 2 cents
  53. Engine: 1950 Land Cruiser 245 head question
  54. Rear Axle: Dana postive track
  55. Interior: 64 Daytona door lock knob color
  56. Electrical: 53 T/S parking light bulbs.
  57. Other: Studebaker Lock ID
  58. Engine: 40 Commander flywheel
  59. Transmission: Replacement parts for 3 on the tree
  60. Body: Avanti Paint Finishing - Finish Sanding
  61. Engine: Heads for early 62 GT Hawk
  62. Body: 64 hawk side grills
  63. Electrical: Radimeter
  64. Engine: SUCCESS! Finally
  65. Other: Gasket sealer
  66. Cool/Heat: Another thread about cooling problems. Help
  67. Electrical: 2R headlight switch
  68. Fuel System: 1935 Dictator air cleaner
  69. Rear Axle: 2 speed axle cable
  70. Paint: Studebaker Logo color
  71. Engine: 2R Truck engine mount replacement
  72. Cool/Heat: Overheating problem solved
  73. Body: Hood Spring Installation Tricks
  74. Body: 62 GT trunk pan replacement
  75. Interior: 1955 Horn Ring Installation Question
  76. Steering PS pump pressures
  77. Engine: Crank End Play
  78. Body: What attaches the "Studebaker" emblem on Fender? 59 Silver Hawk
  79. Other: Paxton supercharger dipstick
  80. Transmission: Overdrive
  81. Body: Golden Hawk body update: cart complete, body off, frame ready for winter-work!
  82. Electrical: 6 volt to 12 volt
  83. Transmission: Does anyone have a diagram showing shape/routing for tranny cooler lines (Golden Hawk)?
  84. Steering Studebaker "M" steering question
  85. Body: Which windshield wipers?
  86. Other: Parts
  87. Steering Tie rod end resizing
  88. Transmission: 51 Land Cruiser coolant and transmission problems.
  89. Body: 64 wagonaire hood torsion springs install
  90. Engine: 47-48 6-170 serial number question
  91. Electrical: Dead battery or ???
  92. Engine: Flat head cleaning before gasket
  93. Fuel System: recommendation for ONE vendor for all stainless gas, brake and cooling tubing/fittings?
  94. Exhaust How to complete a split exhaust manifold for a 1949 Champion
  95. Engine: Viscous Drive Fan with Standard Pulleys?
  96. Body: 2R16A windshield replacement C cab
  97. Wheels I love my new tires!
  98. Body: Lark/Champ windshield
  99. Brakes: SI booster working well, first drive with real working brakes
  100. Body: Avanti Cowl Induction Hood Opening With Gas Lifts
  101. Steering Steering Box Upgrade?
  102. Body: Body bolts?
  103. Body: Installing glass in 63 Cruiser
  104. Engine: 289 crankshaft undersize limits
  105. Cool/Heat: No defrost in my 62 Hawk
  106. Steering Does anybody know what this round collet is?
  107. Body: Half-ton truck hoods
  108. Fuel System: 1953 stude gas sender Ohms
  109. Cool/Heat: Water outlet pipe 63 R2
  110. Engine: Installing FI TECH EFI on a 289..... UPDATE: FIRST DRIVE VIDEO....need driveshaft
  111. Electrical: Gauges and speedometers
  112. Other: Tip of the Cap
  113. Electrical: Battery Tray
  114. Speedo/Tach/Gauges Blackout Material
  115. Frame/Springs I can't find info.
  116. Rear Axle: U-bolts for '57 Silver Hawk.
  117. Steering Parts interchange
  118. Electrical: Battery Spacer in Tray
  119. Engine: Oil Bath Air Cleaner
  120. Brakes: 61 Lark Front brake drums.
  121. Steering power steering hyd. lines
  122. Body: Rigid channel
  123. Engine: Commander Six Head Install Question
  124. Engine: ATF in the manifolds
  125. Engine: Will higher viscosity oil result in higher oil pressure?
  126. Steering Steering box
  127. Other: Wiper Arm removal trick and head replacement?
  128. Steering Horn Button Removal
  129. Fuel System: Recommendations for a 6V electric fuel pump
  130. Steering Front end lubrication
  131. Fuel System: Gas tank sender wire.
  132. Cool/Heat: Original truck lower radiator pipe/hose
  133. Engine: Oversize Champion lifters ?
  134. Engine: Vacuum Lines Arrangement for 1964 259 V8
  135. Frame/Springs Need info on use of Moog CC655 Springs.
  136. Other: Chipmunk disease....
  137. Fuel System: REAL LOUD Fuel Pump
  138. Body: window help
  139. Fuel System: Existing Gas Tank Sending Unit
  140. Fuel System: Yikes: Today's Gas / Yesterday's Hose!
  141. Paint: Color of seat rails - 1955 President State Sedan
  142. Other: My 62 Lark sounds like I put a baseball card in the spokes. Any Ideas?????
  143. Transmission: Borg-Warner Flight-O-Matic Grinding sound
  144. Electrical: Speakers for a 64 cruiser
  145. Frame/Springs Shock shopping
  146. Electrical: 1987 Avanti Electrical Problem " HELP HELP HELP "
  147. Wheels 1960 Lark wagon wheel size
  148. Brakes: c-k brake pedal lengths
  149. Engine: What Radiator Cap to use (1951 Studebaker)
  150. Brakes: Master cyclinder
  151. Frame/Springs Moog CC655 Variable Rate Coil Springs in a Avanti II ?
  152. Frame/Springs inner suspension bushings
  153. Body: So You Want To Get That Sound Deadener Off Fast?
  154. Frame/Springs Lowering a 2R6
  155. Wheels Wheel studs and lug nuts for a 1962 GT hawk
  156. Body: M16 mud flaps
  157. Engine: HELP !!! 1928 FA straight 8 parts needed
  158. Engine: 1964 power steering pump clearance
  159. Steering Noisy power steering pump
  160. Electrical: 1935 Dictator coil
  161. Fuel System: Electric fuel pump install questions
  162. Body: 64 Cowl weatherstrip install help
  163. Transmission: 700R4 shifter recommendation
  164. Electrical: Dash display lights
  165. Transmission: 1948 champion transmission overdrive problem? ?
  166. Transmission: 4-speed shifter parts 62 Hawk
  167. Other: Gas Cap and Headlamp
  168. Electrical: Regulator on the Champ
  169. Brakes: Master cylinder push rod adjustment
  170. Electrical: 48 studebaker 6v positive ground alternator
  171. Body: Fender Gaskets
  172. Body: 64 Wagon/Lark grille mounting
  173. Frame/Springs Parts Catalog error
  174. Steering How do you remove the steering wheel?
  175. Body: outside rear view mirrors
  176. Body: Is there a proper location for Twin Traction Emblem on the 59 Silver Hawk?
  177. Paint: Cadmium plated parts on '55 President State Sedan?
  178. Wheels Ford wheels on '64 Hawk and Avanti, disc-brake rims
  179. Engine: 1933 engine shipped from Massachusetts to England - the long way
  180. Electrical: Headlight switch noise
  181. Fuel System: Suggestions for a gauge set for carb passage cleaning
  182. Engine: 289 V8 into 50 Commander.
  183. Transmission: Flight-o-matic shift problems
  184. Electrical: Negative Battery Cable correct position
  185. Other: a arms
  186. Cool/Heat: Ranco heater control leak
  187. Cool/Heat: 2R truck climatizer removal
  188. Electrical: Taillight/Stoplight/Turn Signal bulb questions
  189. Ignition: Lost keys , have original code for them.
  190. Body: How do I fix this?
  191. Paint: 2R climatizer color
  192. Engine: 1961 Lark information needed
  193. Cool/Heat: 2R climatizer fan switch
  194. Paint: Engine compartment undercoating
  195. Electrical: Stude hot rod w/od
  196. Engine: Smologan Intake Performance
  197. Body: Rocker panel ??
  198. Fuel System: WCFB 4 BBL Carburetor
  199. Rear Axle: TT upgrade
  200. Interior: Wagonaire front seat relocate
  201. Transmission: DG250M Pump Needed
  202. Electrical: Officially stumped!!
  203. Engine: Spark plugs
  204. Electrical: GM style alternator
  205. Wheels What wheel is this.
  206. Paint: Painting Question
  207. Brakes: 50 vs 51 champion wheel bolt patterns
  208. Electrical: GM 10DN Alternator to Studebaker Voltage Regulator
  209. Engine: 49 flat six upgrades?
  210. Body: 4 door lark
  211. Wheels what is the largest wheels and tires that fit a 63 champ truck
  212. Speedo/Tach/Gauges 2R truck wiper motor questions
  213. Rear Axle: Leaking again
  214. Body: Will 1956 hood fit 1949 truck??
  215. Paint: Just purchased a 1957 Golden Hawk
  216. Engine: Piston suppliers and country of origin ?
  217. Brakes: Power brake nos
  218. Steering Adding Power Steering
  219. Interior: 1957 Studebaker Golden Hawk Trunk Mat
  220. Body: 1957 Studebaker Golden Hawk
  221. Wheels Modern tall and narrow rims for Champs
  222. Engine: McKinnon 283 colours
  223. Shocks Performance Shocks for Rear of '63-'66 Studes. and Avantis
  224. Other: A lot of questions after taking inventory on my newly acquired 1957 Studebaker Golden Hawk
  225. Body: 3 Point Shoulder Belts
  226. Interior: Replace Windlace - 1964 Daytona Hardtop
  227. Body: Stude Truck Grill interchangeability
  228. Speedo/Tach/Gauges Stewart Warner electric gauges for 57 President
  229. Electrical: starter motor
  230. Fuel System: Edelbrock, 289, and spacers.
  231. Body: Horn mount ?
  232. Frame/Springs Front Spring Pre-Loading
  233. Body: 57 Hood
  234. Fuel System: Fuel Drain Back - fuel pump losing prime?
  235. Drive Shaft T10 Driveshaft Yoke
  236. Steering steering wheel horn ring bolts
  237. Steering What is acceptable?
  238. Engine: Assuming arguendo.....
  239. Ignition: Mallory Unilite
  240. Other: 2r Shop and Parts Manuals
  241. Engine: champion engine from 1950 into 1951 champion?
  242. Cool/Heat: Electric water pump
  243. Body: R series rear fender and bed
  244. Frame/Springs a-arm support
  245. Cool/Heat: 1939 Commander Radiator Overflow
  246. Steering tie rod ends
  247. Engine: any reason to replace head bolts on 289 V8 rebuild?
  248. Brakes: Remote Master Clinder Reservoir
  249. Other: Bottle type windshield washer system for a 1961 Lark
  250. Brakes: 62 Studebaker Lark master cylinder for use as fluid reservoir
