View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 [97] 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
  1. Steering Bushing/Bearing depth on spindles
  2. Engine: K&N filter element for a '63 Avanti R2
  3. Engine: 327 1967 Avanti engines
  4. Electrical: starter solenoid wiring
  5. Electrical: Can anyone explain this???
  6. Fuel System: 63 Hawk with Supercharged R2, 4bbl
  7. Shocks Houdaille shocks
  8. Electrical: interchange number for a starter for a 52 champion
  9. Engine: Another Starter Question
  10. Rear Axle: Can you ID this rear axle?
  11. Steering GM Steering box for studes
  12. Steering Avanti turning radius
  13. Transmission: 59S J6 Lark Transmission Issues
  14. Transmission: Transsmisson fluid
  15. Cool/Heat: Are there bearings available....
  16. Body: 1957 Packard Hood Spring Question
  17. Engine: Wrist Pin and a Valve Adjustment
  18. Cool/Heat: need thermostat 180 for 1957 Studebaker Golden Hawk
  19. Electrical: Intermitent Wipers
  20. Frame/Springs Comparable frames.
  21. Engine: Replacement Motor Mounts for 1959 Lark Hardtop?
  22. Steering How to identify correct power steering pump
  23. Cool/Heat: Clean Radiator
  24. Body: '63 Hawk front air intake panel
  25. Clutch/Torque Converter: '63 Avanti clutch pedal adjustment
  26. Engine: Decrease Oil Pressure 1952 Hardtop
  27. Electrical: Wagonaire tailgate window problem
  28. Wheels 63 supercharged Hawk tires
  29. Shocks Houdaille shocks
  30. Cool/Heat: Can you find a forum member....
  31. Body: 53 hood saftey latch spring
  32. Electrical: Antenna Trim Pot
  33. Transmission: Transmission add OD
  34. Wheels Firestone Tire Mfr Date Code
  35. Paint: Maui Blue
  36. Ignition: Pertronix use
  37. Other: Info on options for a 1960 wagon
  38. Transmission: Where do I check tranny levels on a Golden Hawk?
  39. Rear Axle: Golden Hawk bits on Z bay
  40. Transmission: T-86 O/D, it drives normal with OD off, just whirrs when OD is pulled on?????
  41. Speedo/Tach/Gauges '63 Avanti Parts from SI
  42. Engine: Radiator Hoses
  43. Interior: Dome light housing removal
  44. Speedo/Tach/Gauges wanted speedo cable
  45. Rear Axle: Tapered Axle Hub 533901 Needed
  46. Cool/Heat: Rad Flush
  47. Ignition: What do these fit?
  48. Engine: A Hawk ate my starter
  49. Body: inside sun visor 1950 truck?
  50. Fuel System: 2R5 Carburetor Accelerator Pump
  51. Engine: 56 Champion with flathead 6 upgrades?
  52. Fuel System: Vapor lock
  53. Paint: lack of paint adhesion
  54. Interior: Upholstery screws with collars
  55. Electrical: 61 lark not charging
  56. Transmission: need Speedomter cable with correct diameter for 57 Golden Hawk Flight-o-matic
  57. Rear Axle: 2pc.-drive shaft 57 GH: how far should the support shaft be pressed on?
  58. Engine: Lost bell housing bolts
  59. Engine: Weiand intake
  60. Electrical: Battery
  61. Brakes: 2r 15 brake problem
  62. Interior: Avanti Mystery Pieces
  63. Other: 58 Scotsman Wagon
  64. Engine: Fan clutch or not
  65. Rear Axle: Best Twin Traction axle lubricant
  66. Steering Grease recommendation
  67. Body: 71 Avanti window removal
  68. Cool/Heat: 1940 President Overheats
  69. Other: Distributor oil leak
  70. Rear Axle: Dumb Question--Are Right and Left axles the same length?
  71. Cool/Heat: Champ temperature gauge slowly stopped
  72. Brakes: paparve
  73. Fuel System: WCFB carburetor replacement
  74. Body: Help to identify trunk hinge
  75. Body: Any suggestions on protecting the plastic fender spear inserts?
  76. Fuel System: Opinions on Daytona Float Valves
  77. Transmission: Does this transmission work for my 60 Lark VIII?
  78. Electrical: Interior Light
  79. Engine: OHV 6 Oil breather cap
  80. Body: 1961 Studebaker Lark Wagon: Stainless steel moulding for the gutter (drip line)
  81. Brakes: Problem Removing Backing Plate on '56 E12 Pickup
  82. Cool/Heat: Over Heating??
  83. Wheels 3 D printer
  84. Engine: need some help and some parts
  85. Other: Anyone Found A Solvent for POR15 ?
  86. Transmission: 57 Commander
  87. Engine: 1940 Commander Camshaft gear????
  88. Engine: Does bearing material break down because of age ??
  89. Transmission: 289/259 Flightomatic
  90. Steering Steering wheel puller
  91. Fuel System: Throttle Checks for Jet Thrust engines
  92. Engine: Edelbrock 1406
  93. Fuel System: FUEL PUMP REBUILDER?? Carb rebuilder? WHO?? ANYONE??
  94. Engine: 2R16A engine swap
  95. Engine: No Power
  96. Brakes: Brake issue
  97. Interior: Roll up antenna help needed
  98. Body: New pair of '64 Lark Fenders for sale
  99. Electrical: Wiring harness
  100. Wheels Disc brake-specific Lark/Hawk wheels?
  101. Cool/Heat: Thermostat housing
  102. Engine: WCFB on 224 V8
  103. Body: Wagonaire Sliding roof locking links
  104. Exhaust Mufflers fo 60 Lark Conv. 259
  105. Electrical: Starter engagement depth?
  106. Paint: Rose paint on '63 Hawk
  107. Clutch/Torque Converter: HD truck clutch
  108. Body: Wagonaire Sliding roof gasket/seal
  109. Rear Axle: 59 Lark 2DHTP Changed Rear Axle Dana 27 to 44
  110. Engine: 1960 Lark 6 cylinder to 259 V8 swap
  111. Ignition: Spark Plug Wires
  112. Cool/Heat: Running Temp for a 170
  113. Engine: Need help locating a new Oil Pan for my 52 Champion And rebuilder near Minneapolis
  114. Electrical: Need a wiring schematic for 63 Avanti AC
  115. Electrical: All Transistor Radio
  116. Front Axle: Wheel Bearing Specs
  117. Ignition: '63 Avanti ? electronic ignition problem
  118. Interior: 50 Champion Speedometer.....
  119. Transmission: '62 Champ V8 3-Speed w/ OD "Insulator-Lever" Stude Part #1551556
  120. Electrical: 63 Hawk with R2 Tachometer wiring
  121. Brakes: Hydro vac
  122. Fuel System: Carter AFB question
  123. Body: CK drivers fender space between fender and rad core support
  124. Steering 1963 champ truck
  125. Engine: Rocker Arm Oil Return Hole
  126. Brakes: Drum id help please
  127. Steering CK Saginaw box and column
  128. Body: 1949 truck cab specs
  129. Fuel System: fuel line at gas tank, 63 Hawk
  130. Rear Axle: what gear ratio does my 63 champ truck 6cyl 3 speed have?
  131. Cool/Heat: Fan switch
  132. Transmission: '63 Avanti R-2
  133. Speedo/Tach/Gauges 55 commander hardtop
  134. Engine: Engine and trans removal from 63 hawk.
  135. Body: Ground height
  136. Fuel System: 10% Ethanol in avanti II
  137. Body: Window run felt strip
  138. Fuel System: Gas Leaking out of the side of the carburetor
  139. Body: '55 President skirts
  140. Transmission: No Reverse
  141. Brakes: 50 Champion pedal goes to floor
  142. Transmission: Torque Converter
  143. Transmission: what the difference between DG250 and flightomatic?
  144. Speedo/Tach/Gauges Tach/Speedometer
  145. Steering Steering Columns and Power Steering
  146. Steering I'm stumped!
  147. Rear Axle: Dana 44 help
  148. Engine: Engine swap
  149. Frame/Springs Can a Lark front sway bar fit a '57 Hawk?
  150. Engine: Has anyone used the Wizard Cooling aluminum radiator in their '53-56?
  151. Engine: Hamilton Electronic Fuel Injection - Help
  152. Body: parts # needed
  153. Transmission: newby here on transmission swap
  154. Other: question on what modern frame and suspension will fit 1949 2r5 1/2 ton
  155. Engine: 1940 commander camshaft timing??
  156. Engine: Hawk newbie confused & needs some help
  157. Body: Fender and Door Swap
  158. Engine: 259 / 289 engine block needed
  159. Fuel System: Gas tank fitting
  160. Fuel System: 57 Sending Unit/Gas Line Connection
  161. Wheels Fabric bearing seals
  162. Brakes: wheel cyl.
  163. Cool/Heat: 55 COMMANDER v8 hardtop DRIVER'S SIDE HEAT and EXHAUST
  164. Cool/Heat: heater hose connections
  165. Brakes: Hydrovac - Adding Neatsfoot Oil
  166. Transmission: T10 throwout bearing collar/bearing & seal retainer -- part number???
  167. Engine: swapping an LS2 into an Avanti
  168. Engine: Synthetic oil use
  169. Steering Ididit column
  170. Steering Power Steering Fluid
  171. Body: Door latch repair
  172. Fuel System: stupid mistake
  173. Steering Eaton P/S Pump
  174. Body: New (to me) Product Review - 3M Ultraflex Sandpaper
  175. Drive Shaft driveline to dana 44 rearend angle in a 1950 champion five passenger coupe ????
  176. Cool/Heat: 1939 President Water Pump
  177. Other: 49 Pickup truck windshield wiper linkage arms
  178. Engine: 289 oil filter
  179. Steering P/S rerturn hose leak at control valve
  180. Other: Can some one decipher a serial number
  181. Engine: Knock in lower end
  182. Body: 55 Coupe Cowl Stainless Clips PN 308504
  183. Ignition: Ballast Resistor
  184. Frame/Springs upper a arm outer pin
  185. Other: sorry posted twice - disregard
  186. Ignition: 63 Hawk R2 spark plugs
  187. Engine: 1947 Champion Oil Filter (Cartridge) for old Fram F3-P2 / F4-P2
  188. Transmission: Flight-O-Matic rebuild in order?
  189. Brakes: resolved 50 champion brake goes to floor
  190. Body: sprung hinges from SI door seals
  191. Electrical: 02 Jetta died, possible to use alternator and ac on 62 Lark
  192. Engine: What color should a '51 Champion engine and accessories be painted?
  193. Electrical: clock repair and restoration - 1961 Lark
  194. Speedo/Tach/Gauges I finally figured out today that the amp gauge is reading backwards
  195. Wheels 1961 Hawk correct OEM wheel color???
  196. Transmission: Jars when shift to drive or reverse
  197. Rear Axle: How to grease rear wheel bearings 50 Commander
  198. Engine: Studebaker mouse motor
  199. Engine: Looking for Studebaker Memories from Freeman SD area
  200. Engine: 1954 Commander V8 Oil Filter Installation
  201. Wheels Confirm procedure for removing and replacing lug nuts
  202. Body: Gary Johnson - where are you?
  203. Brakes: Anyone Know Where To Get One Of These
  204. Engine: The legend of the thicker blocks.
  205. Body: 61 Lark Trunk Lid Lock.
  206. Engine: What is special on a 289?
  207. Front Axle: What are the wear specs?
  208. Transmission: cant find park
  209. Engine: oil light flickers when changing transmission position
  210. Engine: YCP Pistons
  211. Fuel System: Now I understand
  212. Interior: WTB
  213. Paint: 63 Hawk R2 engine bay colors
  214. Ignition: What happened to my SPARK PLUG ?
  215. Electrical: Headlamp for 1959 Lark
  216. Body: Rusted out floors on my 56 Commander
  217. Wheels What 15" rims will fit my 1962 Lark VI
  218. Engine: The engine number
  219. Transmission: No Reverse
  220. Engine: supercharger drive pulley
  221. Body: Dash In My 50 commander
  222. Electrical: '56 hawk backup lights
  223. Interior: Gauge Restoration
  224. Engine: Aluminum flywheel
  225. Engine: Front Oil Seal on 245 CI Big Six
  226. Other: 1917 Studebaker Carburetor / fuel flood
  227. Engine: 63 R2 supercharger belt removal
  228. Brakes: RTH Needed: Master Cylinder Mounting Spacers 59 Lark
  229. Engine: 2 BBLintake manifold hold down clamps
  230. Transmission: 1953 Borg Warner automatic tranny, DG200 - shifting issue
  231. Speedo/Tach/Gauges Shield Tubes
  232. Fuel System: Oil on fuel pump
  233. Body: Hood Stiffeners
  234. Body: Adjusting doors?
  235. Cool/Heat: New Tool - Freeze/Welch/Casting Plug Installer
  236. Engine: Spark Plugs ( Make)
  237. Body: Hawk Fin Fabrication
  238. Cool/Heat: which air conditioning compressor port on my 63 avanti is the low pressure
  239. Rear Axle: Conversion to an automatic Trans.
  240. Interior: SI Elk Vinyl Dye
  241. Engine: Oil Consumption/Leaking
  242. Rear Axle: 9 inch swap
  243. Frame/Springs What modern shocks will fit my 1963 Champ truck
  244. Transmission: Interchange for New Process trans?
  245. Electrical: Avanti Voltage Regulator - Will NAPA VR 32 Work?
  246. Fuel System: Strong Fuel Smell
  247. Engine: serial number
  248. Transmission: number of teeth- wide ratio vs close ratio T10
  249. Electrical: Champ wiper wiring
  250. Transmission: 1929 Studebaker gearbox and differential oil capacity
