View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. Brakes: hill holder problem
  2. Engine: engine # RS H 31
  3. Body: Avanti Fender Apron
  4. Interior: Radio Delete trim- 1950 Commander 17A
  5. Fuel System: Congress considering ethanol rule changes
  6. Electrical: Solid state voltage regulator
  7. Engine: Oil filler tube
  8. Brakes: Hydrovac
  9. Engine: Double Fan / Water Pump Pulley?
  10. Exhaust Feedback needed: exhaust supplier
  11. Electrical: 12v to 6v for wiper motor
  12. Electrical: Live "key on" power source under the hood?
  13. Interior: Correct Clock for 60 Lark?
  14. Engine: INSTALLING TACHOMETER IN A 6 CYLINDER 6 VOLT Stude
  15. Engine: rings won't seat?
  16. Steering Bleeding Power Steering
  17. Rear Axle: Suggestions for rear axle ratio?
  18. Frame/Springs New Frame for 81 Avanti 11
  19. Body: Removing front door vent windows on a 1961 Wagon
  20. Brakes: Drum Fun with Fairborn Axles WITH interchange part numbers!!
  21. Interior: 1974 Avanti Progress Seats - Hood
  22. Steering BELL Crank
  23. Engine: vacuum advance part number
  24. Brakes: Hawk parts additions
  25. Interior: Question on interior light for Lark
  26. Body: Wagonaire Sliding roof rollers
  27. Interior: Avanti Rearview Mirror
  28. Clutch/Torque Converter: Clutch needed for a 55 259
  29. Electrical: 63 Lark pulsing ammeter
  30. Electrical: Speedster Tachometer issues
  31. Cool/Heat: Control Cables Locations
  32. Cool/Heat: '61 Hawk heater hoses
  33. Exhaust 1950 Champion Muffler Details?
  34. Fuel System: 1950 Champion Fuel Line Routing and Bends?
  35. Fuel System: 64 2592 bll running on 4 cylinders
  36. Transmission: Convert 3 on the tree to 3 on the floor
  37. Body: How to install K body door weather stripping
  38. Frame/Springs Need rear frame rails for 66 Daytona
  39. Steering 62 Hawk Power Steering Return Hose
  40. Engine: high oil pressure
  41. Engine: flexible oil line
  42. Body: 1950 Champion Vent Window Wiskers?
  43. Body: What are these?
  44. Cool/Heat: New water pump ??
  45. Rear Axle: tapered axle sticking out too far
  46. Engine: champion six cylinder parts
  47. Paint: GT Hawk Authenticity Question - Inner Fender Splash Aprons
  48. Brakes: Will these drums fit?
  49. Electrical: Rear wiring harness
  50. Engine: 62 GT motor mounts
  51. Fuel System: 53 oil bath air cleaner filter material
  52. Engine: Repop crankshaft timing gear - Update
  53. Engine: had wrong crankshaft 57 Golden Hawk engine rebuild
  54. Transmission: Are they the same, save for the name??
  55. Front Axle: Removing the a-arm bushings
  56. Engine: 57 SilverHawk 289 with oil coming from crankcase vent tube
  57. Other: Need keys
  58. Engine: Lean Condition WOT R3 Clone
  59. Engine: Valve Adjustment At 16,000 Miles
  60. Fuel System: Stromberg WW float
  61. Engine: Oil Pan
  62. Transmission: transmission interchange
  63. Transmission: Overdrive on my 41 Commander
  64. Fuel System: R2 Carb Accelerator Pump Seal
  65. Engine: Modern Number For Spark Plugs
  66. Fuel System: smell gas after full boost
  67. Electrical: Amp Guage
  68. Rear Axle: Rear axle id help please
  69. Other: New owner 2 cars lots parts questions. Basicly bought puzzles to put together
  70. Steering Upper control arm bushings
  71. Steering Update on Suspension Upgrade
  72. Electrical: New Battery
  73. Fuel System: 2r5 throttle return issues
  74. Electrical: Tachometer Swap
  75. Electrical: Fuse Box?
  76. Electrical: 1954 stude hdtp wiring harness
  77. Interior: Wagonaire cargo area carpet
  78. Electrical: Autolite generator or Delco Remy
  79. Cool/Heat: I need an R2 Water manifold
  80. Transmission: 62 transmission
  81. Brakes: Needed brake adjusters for a 52 commander
  82. Body: Windshield wiper drive unit
  83. Cool/Heat: Radiator
  84. Electrical: Turn signals
  85. Other: Frame vin #location 1959 silver Hawk
  86. Electrical: Gas gauge - GT Hawk
  87. Frame/Springs Vendor(s) for Silver Hawk spring bushings
  88. Interior: OK I did something stupid. Need a picture
  89. Electrical: 1941 Champion wiring harness replacement
  90. Body: 63 avanti q/window
  91. Electrical: Voltage Regulator
  92. Fuel System: Carter fuel pump
  93. Rear Axle: Rear Axle removal
  94. Interior: Radio
  95. Frame/Springs outer pins
  96. Fuel System: 259 carb
  97. Electrical: Temp gauge
  98. Body: Trunk Lid Hinges 1951 champion
  99. Steering king pins
  100. Cool/Heat: A/C info
  101. Engine: Motor Mounts
  102. Exhaust Buttercup gets exhaust passages
  103. Engine: R2 Surging/Hesitation Issues
  104. Engine: Heat soak on 78 Avanti
  105. Electrical: Wire harness part number
  106. Transmission: Has anyone tried this
  107. Transmission: Pulling the Engine
  108. Interior: '49 door panels
  109. Electrical: Horn use question
  110. Electrical: Another battery life question.
  111. Engine: Engine Test Stand
  112. Clutch/Torque Converter: Went to take my 41 out for a drive, I think I have a clutch problem
  113. Transmission: Shifting lever has too much travel
  114. Steering quick steering arm questions
  115. Body: Serial Number Tag
  116. Steering Avanti power steering leak
  117. Other: Windsheild wiper parking
  118. Fuel System: 1950 2R16A fuel pump identification
  119. Wheels chrome wheels - will they fit?
  120. Electrical: 66 Daytona Batt Cables
  121. Brakes: Bench Bleeed Master Cylinder
  122. Steering How to drain PS unit?
  123. Electrical: Two batteries
  124. Body: need special nuts for welt
  125. Steering PS fluid clarification
  126. Electrical: Generator Voltage Regulator Match
  127. Body: Question about 1961-62 Lark front windshield rubbers
  128. Rear Axle: Pinion seal, '56 Flight Hawk
  129. Steering Won't turn right
  130. Transmission: Overdrive Solenoid problems after 6 to 12 volt conversion
  131. Electrical: Where to mount aftermarket fuse box in a truck.
  132. Cool/Heat: hot radiator fix?
  133. Steering king pins
  134. Electrical: 1955 Trasnstar turn signal switch
  135. Ignition: Resistance wire.
  136. Brakes: Rare Kit available.....
  137. Electrical: 1964 champ 8e7 starter
  138. Electrical: Generator polarity
  139. Electrical: 1962 Hawk
  140. Engine: FINALLY ...engine miss ... I think I solved it!
  141. Fuel System: Tank leaks when full
  142. Wheels 41 Champ caps
  143. Transmission: Second gear 1954 standard
  144. Steering How do I troubleshoot my Power Steering failure? 63 Lark
  145. Steering King Pins/Lower pins help needed
  146. Interior: Lark Rear Seat Removal?
  147. Transmission: Overdrive will not engage
  148. Frame/Springs Bat Wing on a 1953 Commander HT
  149. Interior: 1948 Land Cruiser - Gaining space between dash and firewall
  150. Engine: 283 Dip Stick Tube
  151. Electrical: 47 Champion - overcharging
  152. Electrical: Generator Voltage Regulator Adjustments and What the Coils Do
  153. Steering Avanti Power Steering Loss
  154. Cool/Heat: Radiator question
  155. Body: Need advice on Under Hood Insulator
  156. Body: 1947 Champion Hood Rod - early model
  157. Interior: Air coming in through firewall.
  158. Engine: 1940 Commander freeze plugs
  159. Interior: Steering wheel modification?
  160. Cool/Heat: Factory A/C in 62-64 hawks and larks
  161. Other: New person and have a few questions
  162. Paint: Golden Hawk Picture request
  163. Transmission: Anyone have a source for a bushing removal...
  164. Body: Advice needed on installing reproduction inner fin mouldings - 57-61 Hawks
  165. Electrical: Electrical Question: 6V to 12V fuses ??
  166. Electrical: Yellow wire with red tracer. What is it for?
  167. Transmission: What transmission fluid to use in a '63 Lark?
  168. Electrical: Horn #1555002 Application?
  169. Engine: 1940 Commander Engine removal??
  170. Frame/Springs '61 Convertible frame
  171. Engine: V8 Valve Adjustment
  172. Brakes: Looking for Ideas, adjusters out of range?
  173. Fuel System: Vapor Lock No More
  174. Engine: 62 GT motor mounts
  175. Brakes: 1950 2R16 master cylinder replacement suggestions
  176. Cool/Heat: 1936 Dictator Water pump question......
  177. Ignition: Ignition switch aggravation
  178. Fuel System: Carter WCFB float kit needed
  179. Fuel System: 1959 Silver Hawk owners - with WCFB carb
  180. Brakes: Hydro-vac
  181. Fuel System: Is the 55 stude president v8 suppose to have a vented gas cap?
  182. Cool/Heat: What is the thinnest spacer.......
  183. Electrical: Wiring stock gauges 12 volt conversion.
  184. Body: Window info for 53 starliner ht
  185. Fuel System: Reverse Rotation McCulloch Superchargers
  186. Ignition: Set up 283 distributor
  187. Transmission: New Guy, Simple Question
  188. Transmission: T86 shift lever oil seals
  189. Speedo/Tach/Gauges Testing the Avanti Tachometer Sender
  190. Fuel System: Another Edelbrock Question
  191. Transmission: tranny troubles
  192. Fuel System: Leaking carburetor seal(s)?
  193. Cool/Heat: Engine temperature sensor
  194. Fuel System: Fuel delivery issue
  195. Transmission: Can not shift to reverse
  196. Transmission: Another OD question??
  197. Ignition: Avanti ignition shields wanted
  198. Body: Waydon
  199. Ignition: Ballast resistor
  200. Engine: Engine Block paint color
  201. Engine: Motor mnt. prep.
  202. Body: Three point seat belts
  203. Body: Anyone have one of these they'd part with ?
  204. Fuel System: carbon???
  205. Engine: Stromberg WW rebuild
  206. Engine: Puff of black smoke
  207. Engine: 1939 Champion engine color
  208. Other: Radio restoration for my 1961 Lark Wagon
  209. Cool/Heat: 66 Cruiser heater valve
  210. Fuel System: 63 Lark fuel pump help needed
  211. Speedo/Tach/Gauges 50 Champion speedometer way off
  212. Speedo/Tach/Gauges Avanti tachometer
  213. Other: VIN Decode
  214. Electrical: replace generator with modern alternator
  215. Electrical: No spark
  216. Brakes: Hill holder
  217. Clutch/Torque Converter: Asking advice about parts, flywheel, clutch disc, pressure plate for 1951 commander
  218. Wheels Trim Ring
  219. Transmission: Bell housing seems wrong
  220. Transmission: 1960 Lark to a T-5 questions
  221. Engine: Piston oversize
  222. Speedo/Tach/Gauges Need pinion gear
  223. Transmission: Column shift linkage adjustment ('53 Commander)
  224. Fuel System: Avanti: Correct Fuel Line Hose Clamp Inquiry
  225. Body: 1954 CK taillight housings
  226. Shocks Rear shocks
  227. Transmission: Auto Trans seems to lock on start
  228. Engine: Engine Numbers
  229. Cool/Heat: Mr. Gasket Thermocap
  230. Other: Differential
  231. Electrical: 12v Draw on battery
  232. Frame/Springs FIxer upper
  233. Body: Wagonaire Sliding Top Tracks
  234. Paint: 3E7 Transtar Need some template help
  235. Electrical: Generator tests good/new regulator/doesn't charge
  236. Frame/Springs 1951 Starlight suspension interchange question.
  237. Body: 1957 Golden Hawk Hood
  238. Transmission: HELP: need Canadian source of GL-1 90 mineral oil
  239. Brakes: 1940 Commander Brakes
  240. Body: Rear qtr window replacement
  241. Other: jack for 62 hawk
  242. Engine: Identifying 245 c.i engine
  243. Clutch/Torque Converter: Clutch Linkage - Doesn't Link! 1959 2dr Hardtop Lark (59S)
  244. Speedo/Tach/Gauges Disappearing post from yesterday- '55 president dash glass
  245. Rear Axle: Diff Parts
  246. Wheels 15" wheel for a '63 Avanti
  247. Electrical: Generator to Alternator Mounting Bracket
  248. Steering how/when to remove the king-pin 'tapered locking pins'?
  249. Transmission: Try this again...swapping manual for automatic questions
  250. Exhaust Exhaust problem on 1953 starliner
