View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 [95] 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Speedo/Tach/Gauges quartz clock replacement
  2. Steering hard steering / tire size
  3. Rear Axle: Are Dana 23 and Dana 27 Interchangeable?
  4. Engine: 1963 170 6 cyl engine and 3speed trans for sale
  5. Engine: Oil filler tube removal
  6. Engine: Problem with felpro rear main seal
  7. Brakes: Disc Brake Pad Backing Plate Comes Loose Repair: Adhesive, Bonding, Epoxy, Tuffbond 230, ...
  8. Body: need new keys made up
  9. Fuel System: 50 comander vapor lock
  10. Electrical: Gas guage/sender: 6V to 12V ??
  11. Brakes: Installed Allstar 41006 booster
  12. Brakes: Hill Holder question
  13. Steering Leaking Saginaw Steering Box
  14. Body: 62 vs 63 lark fenders
  15. Body: Avanti Cowl Induction Hood and Gas Struts
  16. Transmission: T-10 Gear lube Follow-Up
  17. Steering Looking for a power steering pump.. rebuildable core OK
  18. Electrical: Circuit breaker polarity?
  19. Other: Tow Bar Question
  20. Transmission: Column Shift 3sp
  21. Electrical: 1963 Lark Headlight Circuit Breaker Location?
  22. Engine: Silver Hawk Major Modifications
  23. Transmission: Overdrive 101..... ?
  24. Other: Rear window install
  25. Electrical: Wagonaire relay's
  26. Steering Front Suspension Bushing Replacement
  27. Ignition: Hawk ignition switch wiring placement
  28. Body: 53 K top on a 62 K body
  29. Engine: Connecting Rod Pinch Bolt
  30. Engine: Guess that part.
  31. Steering steering wheel replacement
  32. Steering car will not keep a straight line on the highway.
  33. Frame/Springs Replacement springs Avanti 2
  34. Frame/Springs 120 1/2" frame difference
  35. Engine: Timing gear cover question
  36. Brakes: '51 Commander brakes on a '48 Commander?
  37. Ignition: 66 cruiser no power
  38. Electrical: On Of On turn signal switch
  39. Electrical: 57 studebaker president regal, lost power to everything dont know if there is fuse pannel or relay
  40. Other: Is there a mechanic in the house?
  41. Front Axle: 1963 Lark Gasser (info needed)
  42. Brakes: 64 Master Cylinder
  43. Cool/Heat: Turning Wheels story
  44. Frame/Springs Need complete rear stab setup
  45. Engine: Engine Number
  46. Engine: Praying I can break the engine loose.
  47. Engine: oil leak
  48. Ignition: Manual & Plug Gap
  49. Engine: 1947 Studebaker dump truck
  50. Body: H E L P What years are these 3 studes
  51. Engine: Valve Cover Gasket
  52. Ignition: hot coil
  53. Transmission: Flightomatic selector adjustment
  54. Body: hinge pins
  55. Body: '62 Lark Dash Top Removal
  56. Body: cleaning up stainless
  57. Front Axle: Kind of bolts?
  58. Interior: Installing Seatbelts in a C-Cab Truck
  59. Body: What is the best way to attach inner and outer fender?
  60. Other: Help with UN-sticky D/A discs?
  61. Engine: What Does This Hole Do?
  62. Cool/Heat: McCord 5F5 Radiator
  63. Electrical: GT Hawk brake lights don't work
  64. Body: Avanti Drivers Door
  65. Fuel System: Carburetor questions
  66. Other: Hawk Vent Window Challenges
  67. Transmission: 5 speed
  68. Body: Mirror placement
  69. Electrical: NO headlights or tailights, 52 Champion
  70. Speedo/Tach/Gauges Dash screws
  71. Body: VIN Data Plate
  72. Other: wiper refills
  73. Fuel System: Thin/Thick Gaskets.
  74. Ignition: vacuum advance needed
  75. Brakes: 62 GT pulls to side when brakes are applied
  76. Fuel System: Is it common for 62GT to vapor lock?
  77. Interior: radio removal
  78. Body: Windshield Differences - '64 Hardtop vs '64 Wagon
  79. Interior: Removing dash panel (1966)
  80. Ignition: Local Parts Availability
  81. Wheels 1985 Avanti
  82. Body: Inner Fender liners
  83. Interior: Strange Arm Rest Mounting for My 1950 Champion
  84. Shocks shocks and steering wheel questions
  85. Interior: Roll bar cover sources?
  86. Rear Axle: Axle Seals
  87. Body: Loud Obnoxious Noise Identified - Grommet Did It!
  88. Fuel System: 289 Fuel Pump Pressure Differences
  89. Body: Door to body screws, 63 Hawk
  90. Body: Avanti power windows
  91. Brakes: heat build up in both rear hubs
  92. Body: 62 GT vent window won't open
  93. Interior: Front seat swap in a '60 Lark?
  94. Transmission: Little Things
  95. Exhaust Heat riser valve cover
  96. Cool/Heat: Wagonaire/convertible a/c condenser
  97. Frame/Springs Bell Housing Cross Member
  98. Paint: What gold color do you use for '55 valve covers?
  99. Fuel System: Do you have to drop the gas tank ,to remove fuel sending unit? 55 ,2 dr president
  100. Electrical: Horn has a mind of its own
  101. Body: Body Mount metal shims 1950 Land Cruiser
  102. Steering As Paul Harvey would say............
  103. Rear Axle: 62 hawk rear diff
  104. Body: Alignment of front sheet metal - '63 Wagonaire ???
  105. Interior: Buying seats from a wrecking yard
  106. Rear Axle: Crazy axle damage
  107. Engine: Car or Truck
  108. Interior: 1950 Champion Arm Rests Mounting Holes and Color Change?
  109. Exhaust Don Simmons Medium Tone muffler switch.
  110. Body: 48 thru 52 front sheet metal.
  111. Wheels 62 GT Wheel covers, should I repaint them
  112. Body: Need Help with 1938 Front Fender Mounting
  113. Engine: V8 Crank Question
  114. Fuel System: VaporLock Ruminations...
  115. Steering steering questions
  116. Interior: What years fit 53?
  117. Speedo/Tach/Gauges 1964-66 ammeter
  118. Engine: 63 avanti
  119. Engine: 1950 Champion Oil Bath Air Cleaner Decal Picture?
  120. Transmission: Where's my kickdown switch
  121. Interior: source for yellow vinyl to match Speedster upholstery
  122. Fuel System: Fuel Line Size?????
  123. Shocks 1947 Champion
  124. Body: Keeping water out of the body
  125. Fuel System: 64 V8 auto choke tube
  126. Paint: Paint code
  127. Ignition: Spark Plug confirmation in July Hot Rod
  128. Brakes: switch from dot3 to dot5
  129. Brakes: rear brake shoes
  130. Engine: Help - rusty, stuck engine.
  131. Speedo/Tach/Gauges Mechanical Temp Gauge question
  132. Body: Sound deadening/Heat reducing material?
  133. Engine: Quick Question... Drain Plug Size
  134. Interior: windlace vendor
  135. Interior: Wanted '51 Stude Champion wiper knob
  136. Engine: Building a motor for a future lark
  137. Electrical: R2 Manual Starter Bendix Rebuild Lubrication Oil Grease ???
  138. Body: Rear Quarter Window GT HAWK
  139. Electrical: Is it possible to check the solenoid for my supercharger?
  140. Cool/Heat: Coolant leak.
  141. Interior: Thank You! Will & Lori Sander
  142. Speedo/Tach/Gauges looking for decent bezel for 63-66 Lark types
  143. Speedo/Tach/Gauges Temperature Gauge - How to read.
  144. Speedo/Tach/Gauges Speedo Cable Oil
  145. Body: 1951 Champion finishing
  146. Fuel System: Vapor Lock Progress Report
  147. Electrical: Source for new Avanti Windshield Wiper Switch
  148. Body: Pillar Post Chrome Piece?
  149. Body: 1964 GT Hawk Hood mounting hardware
  150. Steering Steering: Power: Bendix: Fluid: Changing, Flushing, ...
  151. Engine: Oil pressure relief valve questions
  152. Electrical: Battery for 1981 Avanti II ?
  153. Speedo/Tach/Gauges radio removal - '64 Cruiser?
  154. Cool/Heat: CJ radiator swap completed
  155. Steering 53 Coupe Reach Rod Replacement
  156. Other: '61 Lark Antenna Installation
  157. Engine: Accessory Oil Filter Installation '61 Lark
  158. Other: Installation Instructions for radios & antennas?
  159. Other: jacks
  160. Interior: 60 Lark Convertible Trim Question
  161. Cool/Heat: 1950 Champion Heater/Defroster Hose Tee Location?
  162. Interior: Headliner Installation Tip
  163. Engine: Long Term Storage
  164. Engine: Intake Clamps for a 259
  165. Fuel System: Electric fuel pump too loud
  166. Frame/Springs Suspension Upgrade for Our '53 C Body
  167. Transmission: Transmission/Steering shifter
  168. Electrical: 53 6 cyl, engine electrical dyes momentaneously
  169. Engine: Is this really a '64 engine in a '57 body?
  170. Electrical: 61 Hawk radio schematic
  171. Body: M series Hood Springs
  172. Fuel System: Issues with acceleration after a half an hour of driving
  173. Transmission: Automatic Transmission problems in my 51 land cruiser.
  174. Front Axle: '61 Lark Bad Rubber A Frame Bushings
  175. Speedo/Tach/Gauges 1952 Champion speedometer
  176. Body: 1966 Daytona Speedometer cable firewall location?
  177. Interior: Interior Door Panel Advice
  178. Engine: Engine identification, 259?
  179. Engine: R1 Pulley Needed
  180. Steering Power: Bendix: Hoses: Control Valve: Tighten: How to? 1963 V8 Lark
  181. Transmission: 1955 DG-200 Transmission missing bolts
  182. Rear Axle: Rear Axle - Help!
  183. Engine: Engine 'rolls', need help deciding what to check next.
  184. Brakes: 1948 Commander Frustration!
  185. Electrical: Installling new wiring harness in 1948 Commander
  186. Steering drag link differences
  187. Transmission: Hurst Shifter
  188. Frame/Springs 59 Lark VIII 2DHTP Wanting that "Gasser" look without cuttting
  189. Body: Front Clip, Spacer Question
  190. Cool/Heat: 63 GT Hawk overheating at idle
  191. Clutch/Torque Converter: Clutch rod bracket with T5 conversion
  192. Engine: Timing cover seal
  193. Transmission: Can I put 1951 DG150 in 1950 Land Cruiser
  194. Other: Wagonaire speaker ideas needed
  195. Steering Power Steering Hose Routing 1963 Lark V8: Rerouting to underneath like Hawk,Avanti
  196. Rear Axle: Brand 'X' Sway Bar?
  197. Engine: 1963 Avanti R2 PCV valve
  198. Transmission: W 5 borg warner
  199. Electrical: 62 GTHawk distributor
  200. Fuel System: gas tank sending unit for 64 studebaker cruiser?
  201. Body: Wagon tailgate question
  202. Transmission: 3 speed overdrive troubles
  203. Other: cracked mirror
  204. Engine: Avanti R2 carburetor bonnet
  205. Brakes: Front disc brakes on Buttercup
  206. Transmission: Overdrive Problem
  207. Steering EPAS on Buttercup
  208. Brakes: Brakes, What A Drag
  209. Electrical: radio removal
  210. Other: antenna removal
  211. Cool/Heat: Radiator - 1935 Dictator
  212. Other: Vacuum wipers - improving operation?
  213. Engine: 66 Daytona Engine Mounting Brackets
  214. Speedo/Tach/Gauges Tach cable
  215. Fuel System: Gas tank float
  216. Steering Outside Edge of Tires cupping
  217. Steering Major Power Steering Leak
  218. Brakes: 1960 Lark Front and rear brake drums and studs
  219. Fuel System: WCFB Carter Carbs
  220. Electrical: 61 Lark Tail lights not working
  221. Engine: Starter housing breaks
  222. Brakes: Remove rear brake drum from hub.
  223. Brakes: My brake lights stay on , what can I do ? 55 2 dr president
  224. Frame/Springs Lubricating Wrapped Springs
  225. Other: Repair chrome grille shell
  226. Electrical: 1950 Commander with Auto Drive Wiring Diagram
  227. Cool/Heat: Need radiator advice on Studebaker 2R with Chevy 350
  228. Rear Axle: 61 Lark
  229. Steering Bellcrank Style--How to tell without removing??
  230. Ignition: 1955 Champion distributor
  231. Drive Shaft 1963 Avanti Vibration
  232. Steering 36 Dictator horn button removal on a banjo steering wheel
  233. Fuel System: So' How did 53 studes ,get their fuel delivery ? ( Did the fuel pump ,still ride on the ecentric of?
  234. Fuel System: Fuel Injection for V8 Studebakker
  235. Electrical: 1962 Hawk Radio Speaker Removal
  236. Fuel System: Carburetor return spring
  237. Transmission: Replace steel auto transmission cooling lines with rubber?
  238. Frame/Springs frame part sandblasted
  239. Engine: oil leak
  240. Body: Avanti Package Shelf Lid
  241. Transmission: Overdrive solenoid wiring on a 1960 Lark ragtop that had a 3 pin solenoid.
  242. Steering Lark steering - help me Mr Wizard
  243. Interior: 64 Daytona dash questions..need advice
  244. Engine: Oil Pressure Readings
  245. Cool/Heat: R2 Hawk overheating at high speeds
  246. Exhaust Lark headers - what works?
  247. Engine: Can't get r Hawk to start
  248. Electrical: 1950 Commander/ Land Cruiser with Auto Drive Turn Signal Switch
  249. Frame/Springs Champion VS Land Cruiser VS Star light coupe
  250. Body: body panel 62 gt hawk
