View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 [94] 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Fuel System: Avanti Fuel Tank
  2. Electrical: 64 cruiser won't die
  3. Interior: Window channel
  4. Engine: Ever seen a Stude V8 with safety wired main bolts?
  5. Electrical: Seeking Fog lamp knob Pt#531719W
  6. Electrical: Reverse Lights
  7. Body: '57 Packard Clipper
  8. Engine: Totally newbie...
  9. Engine: tranny and engine swap in a 4 speed hawk
  10. Body: Hood lift struts.
  11. Other: Windshield installer in North Alabama
  12. Brakes: Turner Rear Disk Brakes clearance for 55 Speedster
  13. Frame/Springs camaro front clip on a 56 transtar
  14. Frame/Springs Moog CC655 coil spring installation question
  15. Front Axle: For those that want to update your front suspension.....
  16. Rear Axle: Rear axle tags
  17. Rear Axle: rear brake hub torque
  18. Engine: 1957 289 compression numbers
  19. Rear Axle: Adding Grease Fittings to Model 44 Rear Axle
  20. Brakes: Turner brake kit in the new Halibrand wheels
  21. Rear Axle: Axle flange gasket, yes or no?
  22. Ignition: Rockne replacement parts at local suppliers
  23. Body: Plastimake - An Easy To Use Plastic Material
  24. Transmission: did automatic cars have a Trans. cooler in the radiator?
  25. Electrical: 12 volt starter for an M5?
  26. Paint: Paint Question - Sunglow Gold
  27. Frame/Springs My GM front Sway Bar installation
  28. Engine: 299 CI R3 Reference
  29. Steering Steering Rod attachment
  30. Ignition: Trying to start a 259 v-8
  31. Other: Winching an Avanti onto a trailer
  32. Body: Cowl Supports For Lark Types?
  33. Frame/Springs Any brand x rear sway bars fit a 62 Hawks?
  34. Other: 62 Hawk Hood Release
  35. Engine: Piston help
  36. Rear Axle: Part Interchange Question
  37. Rear Axle: 1966 Wagonaire rear leafs
  38. Lark Stalling From Idle
  39. Transmission: crunchy gaskets, leaky seals, sloppy flightomatic tailshaft
  40. Engine: Variable Drive Superchargers
  41. Transmission: BW 8 transmission
  42. Transmission: Borg Warner 2 sd torque converter ?
  43. Ignition: Dist. lock ring
  44. Frame/Springs Commander Transplants to a Champion Body
  45. Transmission: 65-66 auto use
  46. Body: Hood
  47. Ignition: Ignition Shielding
  48. Fuel System: Throttle Linkage
  49. Brakes: Disc Brake upgrade
  50. Engine: Piston Knurling
  51. Body: 57/58 Hawk flipper rebuild
  52. Engine: Oil Pressure is all over the place ?
  53. Transmission: Sorting out my overdrive
  54. Rear Axle: rear wheel bearing
  55. Interior: south east studebaker
  56. Brakes: Drums
  57. Engine: Correct routing of heater hoses on 1961 Hawk
  58. Body: Identify this window trim? (Avanti)
  59. Brakes: Brakes
  60. Rear Axle: Looking for Dana 44 TT rear end
  61. Interior: Seat reinforcement springs
  62. Brakes: Flanged Brake Drum Interchange?
  63. Brakes: Brake drum stud repair
  64. Electrical: Is Extreme Cold A Battery Killer?
  65. Electrical: 6 volt alternator conversion
  66. Speedo/Tach/Gauges Quest for Gas Gauge for 1963 Gran Turismo
  67. Body: Fold over clips??
  68. Brakes: hill holder issues
  69. Interior: Wood grain trim
  70. Electrical: Bosch windshield wiper motor
  71. Engine: supercharger
  72. Electrical: Light weight Batteries
  73. Interior: instrument bezels
  74. Steering 1951 power steering
  75. Transmission: Overdrive Electrical
  76. Engine: 64 289 pcv valve question
  77. Body: Rubber & weatherstrips
  78. Steering p/s hoses - vendors
  79. Other: 1960 Lark VIII convertible top trouble
  80. Paint: Paint codes
  81. Body: Door repair detail questions
  82. Electrical: Dash light power
  83. Transmission: First Gear Starts in a Powershift?
  84. Engine: Packard V8 Fan Issue!
  85. Body: Chrome Grill 1962 Hawk
  86. Fuel System: carb kit for a 63 vintage WW 2bb
  87. Electrical: Ignition Switch Dead?
  88. Body: Help Removing Stainless A pillar outer trim on 62 Hawk
  89. Brakes: The Official Bendix Disk Brake Manual....
  90. Ignition: 289 distributor cap
  91. Cool/Heat: 63 Avanti Radiator Replacement
  92. Engine: Seized engine success
  93. Body: GT Hawk Door Latch Spring
  94. Ignition: Electronic Ignition
  95. Electrical: Ford Thunderbird Power Window Motor Interchange For Avanti 2
  96. Drive Shaft Is this supposed to be like this?
  97. Rear Axle: What is to be gained?
  98. Other: Several Restoration Questions
  99. Body: ID tag decals
  100. Electrical: Odd looking light.
  101. Steering Avanti Bellcrank
  102. Exhaust Looking for pics of Champ dual tailpipes
  103. Rear Axle: Question about the rear diff
  104. Engine: If it's not broken, should I "fix" it?
  105. Engine: Need a Class on Starters.....
  106. Ignition: Points forever??
  107. Body: Truck ID tag
  108. Frame/Springs Remove my leaf springs
  109. Electrical: Alternator Bracket For 1955 President
  110. Paint: Please Help - Astra White Formula
  111. Engine: 32hyb Allan - Coolant out the tailipipe?
  112. Wheels correct tire size for 1950 Land Cruiser?
  113. Engine: 289 cam gear alignment
  114. Rear Axle: Hawk 3.73 rear end in NW?
  115. Paint: Water based paints?
  116. Paint: Interior trim paint 50 Champion
  117. Rear Axle: Seals
  118. Electrical: tinted headlight covers
  119. Brakes: Brake shoe for a 1936 Dictator Coupe 3A
  120. Electrical: Dwell - '51 170/6
  121. Interior: Wiring Diagrams for power windows
  122. Body: Removing taillight lenses on a 2007 Avanti to access taillight bulbs
  123. Fuel System: Fuel sending unit
  124. Engine: What motor mounts will work for me?
  125. Frame/Springs Jack points on 1950 Champion front end?
  126. Body: Cat whiskers installation leaves something to be desired!
  127. Paint: Questions
  128. Engine: 1961 259 Engine rebuild - a weird gurgling/flushing noise
  129. Body: Installing Front and Rear Windshield -- No Sealant??
  130. Body: 1962 GT Hawk (LHD) Driver Side Mirror
  131. Transmission: Flightomatic Linkage Bushing
  132. Body: CE trunk pan
  133. Steering Is it just me, or is this Lark just squirrelly?
  134. Engine: Need suggestions for oilpan removal
  135. Body: Quarter Moldings for 1963 2 Dr Ht Daytona and a few other parts needed.
  136. Engine: Oil drainback question
  137. Engine: Removing Head on Champion 6 any Tips
  138. Transmission: shift linkage
  139. Body: champ hood hinges
  140. Body: 1950 Land Cruiser rocker panel stainless trim
  141. Transmission: 1950 land cruiser overdrive/ freewheeling
  142. Speedo/Tach/Gauges '56 Golden Hawk gas gauge
  143. Electrical: Distributors: 6V vs. 12V.
  144. Frame/Springs upper control arm shafts
  145. Transmission: T-10 bolt patterns
  146. Brakes: leaking brake cylinders
  147. Electrical: wiring od relay with alternator
  148. Interior: 1963 Avanti kick panel chrome strips?
  149. Paint: Paint Quote Today
  150. Cool/Heat: A/C Hose Removal
  151. Frame/Springs preparing to build a road race Wagonaire
  152. Cool/Heat: 55 stock fan
  153. Exhaust Exhaust pipe tie rod clearance
  154. Body: Stainless steel molding on the gutters of a 1961 Lark
  155. Paint: Gauge needle paint
  156. Ignition: Coil?
  157. Brakes: Rear brake shoes
  158. Ignition: Mark 10 CDI
  159. Other: Bob Johnstone
  160. Steering car drifts to the left
  161. Body: Seat Belt Mounting 2R5 Truck
  162. Frame/Springs Grease Recommendation ?
  163. Fuel System: What intake manifold did I buy?
  164. Engine: Oil pump gasket
  165. Engine: '37 President---clarification on ignition timing
  166. Rear Axle: 63 Avanti Pinion angle Photo
  167. Other: Brake pedal
  168. Electrical: Ballast Resister
  169. Rear Axle: 1955 Presient
  170. Speedo/Tach/Gauges Instrument (gauge) case
  171. Transmission: Can I hot wire the OD unit
  172. Frame/Springs Mounting Avanti body
  173. Engine: stuck oil pressure relief champion 6
  174. Ignition: Dwell, why the change?
  175. Cool/Heat: Remote Air Conditioner - Jeg's
  176. Body: Avanti vent window rubber
  177. Transmission: rear mount T10 transmission
  178. Interior: 53 Coupe Interior
  179. Engine: M5 Rad Dimensions
  180. Fuel System: McCulloch supercharger pre-load
  181. Electrical: electronic ignition problems
  182. Engine: Ideas on this issue?
  183. Body: wheel well mouldings hawk
  184. Interior: Wagonaire front bench seat
  185. Ignition: 37 coupe express with sudden no spark problem!!!!
  186. Rear Axle: Axle For 1962 Hawk
  187. Engine: Oil Pan Leaking
  188. Fuel System: Carburetor linkage/ spring mounting
  189. Wheels Wheel size for 58 President??
  190. Engine: 1962 Lark 170 3 speed...Anybody got a set of V8 Mounts for me??
  191. Transmission: T10's, Ford/Stude bolt patterns, and other possibilities
  192. Electrical: Using a 8 Volt Battery on a 6 Volt system
  193. Engine: 63 Avanti oil leak
  194. Body: 47-52 Starlight coupe trim
  195. Brakes: 1953 Starliner Champion
  196. Ignition: 63 avanti ign points
  197. Engine: Bio-Based Full Synthetic Oil - Biodegradable
  198. Body: What should I do
  199. Other: stop light switch (55 2 door president)
  200. Interior: Speedster Seats
  201. Engine: 1958 Oil bath air filter
  202. Other: 51 convertible top lift (actuator)
  203. Rear Axle: 57 Silver Hawk Axle
  204. Engine: Info on oil pan install.
  205. Other: How to identify where all Hawks were assembled
  206. Speedo/Tach/Gauges 1964 -1966 instruments and light bulbs
  207. Engine: R2 Idle Speed
  208. Steering TL Steering box
  209. Electrical: gas gauge sending unit
  210. Engine: 1959 Flat Head 6 (170)
  211. Fuel System: 2 1/4" fuel filler hose
  212. Engine: Dip stick length on M16
  213. Engine: Govenor on m16
  214. Engine: Spark Plugs for GT Hawk
  215. Frame/Springs Avanti ride height
  216. Speedo/Tach/Gauges Speedometer drive gear wear
  217. Engine: Have a 185 cu in 6 block with a 3.625 stroke
  218. Fuel System: What Kind of Carburetor does my car need?
  219. Paint: Trunk Paint color for 58 President
  220. Ignition: 63 Avanti Ignition Reliability
  221. Engine: Starter images page...
  222. Engine: Nos flathead l6 head...which model car /truck
  223. Frame/Springs Rear leaf spring bushings
  224. Fuel System: Tank vent
  225. Wheels Verifing Wheels
  226. Body: Avanti Window Regulator problems - how to fix? (Was: Gene)
  227. Brakes: steeltech brakes
  228. Wheels 5 Lug Dually wheels on 2R16A-31
  229. Rear Axle: 1950 rear axle vent hole
  230. Wheels Wheel bearings
  231. Engine: engine swap
  232. Engine: 1962 Hawk Engine
  233. Fuel System: AFB Differences on R1 vs R2 carbs
  234. Engine: Starting Up That Old Stude Engine? (video)
  235. Engine: differences in Starter Motors
  236. Steering R & R Ross "SL" Box and Need any Tips / Advice (62 GT Hawk)
  237. Speedo/Tach/Gauges Clock Rebuild 1963 Hawk
  238. Transmission: O/D cable(s)
  239. Frame/Springs Help Identifying Avanti Frame Markings
  240. Brakes: 1950 Commander Coupe Brakes
  241. Steering Bendix, Saginaw, or other?
  242. Engine: 55 commander 259 oil pressure dropping
  243. Speedo/Tach/Gauges What's the procedure for getting inside a Hawk speedo?
  244. Paint: Painting fender welt body color
  245. Transmission: 3 speed overdrive
  246. Other: proper jack position for 58 President
  247. Electrical: Ideas before I go further - gauges
  248. Electrical: Tail light ID?
  249. Electrical: Stalling - Fuel? Electrical?
  250. Cool/Heat: Avanti Firewall Grommets
