View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 [92] 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
  1. Other: 1960 lark rear window.
  2. Engine: 1927 big six motor
  3. Interior: Radio Identification
  4. Engine: Looking for complete supercharger for R-2
  5. Cool/Heat: Ranco Valve
  6. Engine: Engine colors for a 1961 259-V-8
  7. Frame/Springs Front springs for 64 Hawk
  8. Ignition: ignition wiring
  9. Paint: please help, need paint info on 1960 Lark
  10. Transmission: Powershift ?
  11. Engine: Looking for a 289
  12. Speedo/Tach/Gauges Speedo Cable
  13. Brakes: Hill holder
  14. Electrical: 63 Avanti shutting down
  15. Rear Axle: rear axle installation problem
  16. Steering 62 Lark turns sharper to the left than right, reach rod? steering box?
  17. Fuel System: Installing a Edelbrock carb on a WCFB manifold
  18. Engine: Avanti R1 Air Filter Housing
  19. Steering Power Steering Problem
  20. Engine: What is the best way to remove the valve guides at home?
  21. Electrical: amp gauge bouncing on M16
  22. Fuel System: Car won't idle normally in this cold weather.
  23. Cool/Heat: Electric fan switch
  24. Cool/Heat: GT Hawk AC and R2
  25. Fuel System: Carb problem?
  26. Fuel System: Fuel line attachment to gas tank
  27. Steering Front Suspension
  28. Body: radiator mount
  29. Brakes: 3R6 master cyl.
  30. Wheels Wheel color for a 1961 Lark VIII
  31. Transmission: t5 conversion for an early 1962 Hawk 4 speed
  32. Speedo/Tach/Gauges Poor gauge lighting in '51 Commander.
  33. Electrical: Avanti trunk light switch
  34. Ignition: HELP!! 63 avanti coil support bracket
  35. Electrical: Wire to Oil Pressure Switch?
  36. Electrical: Dash turn signal lamps
  37. Brakes: new pads
  38. Body: Avanti parking lights
  39. Fuel System: Gasoiline Issues
  40. Cool/Heat: Engine running cold, Thermostat?
  41. Engine: How to tell if a car is numbers matching
  42. Other: Road test
  43. Paint: 62 Lark underhood paint color?
  44. Transmission: 63 Hawk, new starter ring gear, wont shift into 3rd (OD trans)
  45. Cool/Heat: Cooling problem - Cruiser 1963
  46. Frame/Springs 1962 champ
  47. Electrical: Electrical Voodoo
  48. Body: 1966 Wagonaire Rear Window Trim
  49. Interior: Avanti Window Regulator
  50. Brakes: 63 Avanti
  51. Ignition: 1956 President not starting
  52. Electrical: 1952 Comander turn signal bulb question
  53. Transmission: What auto box?
  54. Frame/Springs Replacing coils
  55. Shocks Specs for 64 Hawk
  56. Transmission: Rear Trans Mount, '63 Hawk w/ 4-spd
  57. Body: GT Hawk Hood Alignment
  58. Interior: Dashboard
  59. Body: Interchanging truck parts
  60. Body: 1956 2E5 Serial number
  61. Paint: 49 Land Cruiser correct colors for inner fender wells and firewall
  62. Engine: Lark Idle Problem
  63. Transmission: 55 bell housing
  64. Transmission: 63 Studebaker GT Hawk
  65. Transmission: 1951 V8 Commanders
  66. Cool/Heat: How do I Change the Heater Core on a 1963 Lark Cruiser?
  67. Paint: Erskine 1929
  68. Transmission: Factory Trans Cooler Question
  69. Clutch/Torque Converter: Can I Change Clutch and Pressure Plate Size?
  70. Body: Door, ignition, trunk key different ona GT Hawk?
  71. Body: 59 Lark rear gate & liftgate operation
  72. Steering T Cab Column Failure
  73. Body: Avanti windshield
  74. Brakes: Residual valve removal
  75. Other: 7" round, LED headlights
  76. Engine: Is it really a 50?
  77. Interior: I'm too short
  78. Fuel System: Gas gage/guage never shows empty
  79. Fuel System: tank flush
  80. Brakes: Emergency brake job!
  81. Cool/Heat: Question on Right Front Engine Cooling Duct
  82. Engine: Oil a Pressure-So How Much Is Too Much?
  83. Paint: Primer
  84. Transmission: New complete T5 Conversion kit available
  85. Engine: 289? engine
  86. Rear Axle: Flanged axles
  87. Wheels Rim specs for Flight Hawk
  88. Body: Hood Springs
  89. Engine: R-1 Upgrade
  90. Ignition: Looking for Stude-buddy Portland, OR 1959 Lark 6
  91. Interior: what is it called
  92. Engine: R-1 and R2 Cams
  93. Ignition: Did Studebaker ever use an HEI distributor in their V8?
  94. Drive Shaft Yoke Replacement for '63 Hawk w/T10 4-speed trans
  95. Shocks Shock mod
  96. Transmission: Flight-o-matic floor shifter
  97. Body: 64 Commander Challenger Model F (Rear Quarter Panel Removal)
  98. Engine: V8 guys - stud on top of head bolt - what years/applications?
  99. Body: 1964 Daytona Wagonaire tailgate question
  100. Body: 64 Wagonaire Mystery Part
  101. Fuel System: This forum is such a great resource!
  102. Front Axle: front wheel bearing
  103. Engine: 63 avanti tuning
  104. Engine: Oil pan gasket and rear main seal question
  105. Cool/Heat: Air Conditioning an Avanti R2
  106. Wheels Wheels & Tires under a Lark wagon
  107. Engine: Pre lubing 6 cylinder flathead
  108. Body: 55 Speedster
  109. Paint: Correct color on 1961 Power Steering Unit
  110. Steering Power steering difficulties
  111. Body: Wagonaire windshield from JRD
  112. Steering Horn wire apparatus needed for 55 President K model with manual steering {can you help?}
  113. Wheels Stock wheel specs for 1962
  114. Front Axle: control arm bushings
  115. Engine: Champion Pan Gasket
  116. Engine: 289 cylinder size
  117. Other: 1950 adjust radio push buttons
  118. Cool/Heat: '59 Eaton Underdash A/C Help
  119. Engine: motor identification
  120. Fuel System: WCFB Identification
  121. Frame/Springs 50 Champion sway bar
  122. Drive Shaft Champ Truck Puzzle
  123. Cool/Heat: Water pump reminder
  124. Engine: 245 Truck Engine Accessories Paint Colors
  125. Body: 1961 lark front parking lites
  126. Other: 1960 Lark VIII (259) man 3spd OD convertible
  127. Brakes: Part number help
  128. Transmission: Trasmission repair
  129. Engine: Piston rings
  130. Brakes: How much to hone?
  131. Engine: V8 guys - let's talk about rocker arms, adjusters, shafts and pushrods
  132. Engine: Does anyone have any close up pics of a 64 Lark R2 engine components
  133. Interior: Wanted-Spare Tire Compartment Lift Handle
  134. Steering grease and the Studebaker front end
  135. Body: Fit of lower radiator grill panel, 53 C/K
  136. Steering 52 Champion steering wheel removal
  137. Body: Rebuilding C-Cab Truck Door Latches
  138. Transmission: Flightomatic front clutch drum needed
  139. Wheels suggested tire pressure?
  140. Engine: Rare typographical error found in the Avanti Shop Manual
  141. Engine: 56J Motor Rebuild
  142. Engine: Oil leaking around breather cap
  143. Engine: Horsepower?
  144. Other: Why we should be cautious of NOS parts.
  145. Steering Need steering wheel info
  146. Body: wanted: trunk corner stiffeners 1960 Lark 2 door hardtop
  147. Interior: Speedster ash tray
  148. Body: installing the early hawk grill into a '62 hawk
  149. Speedo/Tach/Gauges replacing speedo cable core
  150. Transmission: Overdrive Cable
  151. Fuel System: Stromberg ww simularities
  152. Interior: Rplacing welt
  153. Steering Steering wheel plate, horn button switch contact
  154. Engine: Connecting Rod numbers
  155. Fuel System: Gas tank patching with JB weld
  156. Fuel System: Filler Tube Solder Joint Fail...UGH!
  157. Electrical: Unknown Circuit & mystery part.
  158. Electrical: Need help identifing 57 Hawk wiring
  159. Engine: Some interesting camshaft data
  160. Engine: Stuck motor suddenly not stuck?
  161. Engine: Rocker Shaft Plug Removal
  162. Transmission: DG 250 Needs
  163. Clutch/Torque Converter: hydraulic clutch questions
  164. Transmission: 1960 lark conv bolt pattern trans to bellhsg and bellhsg to eng.
  165. Clutch/Torque Converter: Push Rod Retaining Spring, '65 Cruiser v-8 overdrive
  166. Shocks Rear shocks
  167. Body: Avanti manual window regulators
  168. Engine: Engine ID V54I362
  169. Engine: 232 Chilled Lifters
  170. Transmission: 1947 Studebaker commander transmission stuck in second gear
  171. Frame/Springs Special coating?
  172. Electrical: 1950 Champion radio removal
  173. Electrical: '51-'52 Std./OD Back-up light switch parts sought
  174. Other: Weather strip
  175. Transmission: Three speed floor shift?
  176. Fuel System: help with edelbrock 1405
  177. Frame/Springs Do leaf springs twist when a solid axle car hits a bump?
  178. Frame/Springs rear springs
  179. Engine: Oil Filter
  180. Steering front control suspension rebuild
  181. Engine: enginen id
  182. Body: '54 fenders
  183. Transmission: How many bellcrank types were there on 59 silver hawks?
  184. Transmission: Question about transmissions
  185. Body: Inner right fender
  186. Engine: Engine ID# PL1701
  187. Interior: '64 GT Dash with A/C
  188. Ignition: Vintage Sun VAT 6 Tester
  189. Steering Lark PS on a Hawk?
  190. Body: Need part ID. #1501X35
  191. Steering Power steering bracket needed for 6 cylinder Champ
  192. Transmission: 63 avanti torque converter/ringgear
  193. Steering not for the purists
  194. Frame/Springs Sub frame
  195. Ignition: Plug wires for 50 Champion
  196. Transmission: 5 speed?
  197. Fuel System: accelerator pump
  198. Electrical: Headlight switch removal
  199. Interior: Hood release bracket 63 wagonaire
  200. Engine: 1949 2r5 six choking out when pushing gas pedal (169.9 ci)
  201. Transmission: shifter kit
  202. Electrical: Fuse Location?....
  203. Fuel System: accelerator pump
  204. Transmission: Question about overdrive cable.
  205. Transmission: 1952 w/ overdrive. Flathead 6 engine
  206. Interior: 1954 Commander coupe rear seat
  207. Electrical: Delcotron wiring
  208. Stude Wheel Sizes
  209. Ignition: 1959 Lark won't start
  210. Engine: 2bbl manifold machining
  211. Ignition: 51' 2r5 pickup coil hook up
  212. Wheels Tires for my 2R16a
  213. Fuel System: 1950 Champion Carter WE Carb?
  214. Paint: 1950 Champion Glove Box Emblem Paint
  215. Electrical: Autolite Generator Tag?
  216. Engine: 1950 Champion Carter WE Carb Choke Heat Tube?
  217. Body: 1950 Champion Arm Rests
  218. Speedo/Tach/Gauges Veneer for 63 Hawk panel
  219. Fuel System: S.I. replacement fuel pump
  220. Engine: A 1951 tech quiz! Requiring scrutiny and obscure knowledge
  221. Body: 1950 Door Panel Removal?
  222. Electrical: 1950 Autolite Generator Change?
  223. Brakes: I wonder why Studebaker penny pinched on Avanti rear brakes
  224. Cool/Heat: Virtual direct fitment Radiator for 53-54 C-K
  225. Transmission: GT transmissions
  226. Steering Front end feels loose when driving
  227. Speedo/Tach/Gauges Restoring 1950 Champion Gauges
  228. Steering Power Steering on 56 Power Hawk
  229. Ignition: '57 Silver Hawk 289 - Distributor
  230. Rear Axle: WHERE did you buy new gear sets for your model 44 ???
  231. Electrical: Power window switches ( 6 volt )
  232. Exhaust Muffler for 1950 Champion 2 Door Sedan
  233. Cool/Heat: Truck Heater Core Box Color
  234. Engine: 245 Commander Six Head Bolt Sealant?
  235. Steering outer pins
  236. Transmission: Top mounted shifter question
  237. Transmission: 1957 Golden Hawk Transmission question (+ oil cooler lines) Flight-O-Matic
  238. Wheels will 4 1/2" backspace rims fit a 1962 hawk?
  239. Engine: Mystery Bolt on Exhaust Manifold
  240. Engine: Hydraulic/Rhoads lifters in Studebaker V8s
  241. Electrical: Autolite Generator Air Gap?
  242. Electrical: Need 6 Cylinder Spark Plug Wires Loom P/N 675098
  243. Engine: "Speedster" Tune Up!
  244. Electrical: Coil Polarity in January Turning Wheels
  245. Electrical: 6 volt battery cables
  246. Engine: engine test stand & swap questions
  247. Electrical: My generator turns with the key off why?
  248. Electrical: Starter doesn't crank, no noise at all, intermittantly
  249. Fuel System: Airtex vs. S.I. fuel pump
  250. Steering Dash Swap Issue
