View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 [91] 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Speedo/Tach/Gauges guage removal 63 Hawk
  2. Paint: Engine Painting question
  3. Paint: Lower scoop on GT Hawk
  4. Engine: Vacuum (?) line from oil pump (vacuum pump?) on 226 engine in '48 M16 truck
  5. Exhaust Exhaust manifold cracked
  6. Rear Axle: Fairborn axle installation
  7. Drive Shaft I.D. this part please
  8. Engine: Fix or repair daily 6 cyl Camshaft Woes
  9. Engine: Cam cover FELT gasket 536090
  10. Engine: 57 Silver Hawk blue exhaust
  11. Body: 1955 front end
  12. Fuel System: R-1 air cleaner bottom
  13. Electrical: R1 Distributor weight springs
  14. Other: Steering Wheel Paint
  15. Fuel System: Carter AFB
  16. Brakes: Brake Lights are not working, how to diagnose?
  17. Brakes: Need dimensions for 63 Avanti flexible brake lines
  18. Rear Axle: need resource for rear axle 1949 2R5 1/2 ton-help
  19. Other: Window glass/lift channel
  20. Engine: What would happen if I eliminiated it like on R3&4 engines?
  21. Fuel System: R2 Avanti hesitation
  22. Fuel System: 62 Lark Issues
  23. Ignition: 57 Commander 259 Distributor
  24. Engine: Trouble installing pistons
  25. Engine: Valve Seals
  26. Electrical: turn signal
  27. Electrical: why are the wires frying?
  28. Steering Avanti rack and pinion
  29. Engine: engine id help needed
  30. Engine: Canister Oil Filter Question
  31. Cool/Heat: Climatizer
  32. Steering Front End Parts
  33. Steering 1964 Steering Gears
  34. Frame/Springs 113" Wheelbase Wagon and Cruiser chassis the same?
  35. Engine: Socket size?
  36. Interior: Bugaboo......arm rests !
  37. Body: Doors
  38. Fuel System: 1960 Lark VI carb rebuild
  39. Wheels Do not laugh, these could save your life, maybe.............
  40. Fuel System: Carburetor questions
  41. Engine: valve cover decals for packard hawk engine
  42. Frame/Springs Springs on wrong sides?
  43. Engine: I need a set of .040 mains for V8 Stude engine, 51-64 V8. Thanks for a pm, with price.
  44. Body: 57 Hawk Door Glass
  45. Electrical: Starter brushes
  46. Transmission: Trans Swap 5 or 6 Speed in a C-Body
  47. Drive Shaft Rear end/Drive shaft "clang"
  48. Transmission: The farther I go the behinder I get: flight-o-matic headaches
  49. Other: Dad's ole '63 Avanti
  50. Other: Chassis Number
  51. Cool/Heat: Too much heat coming inside '62 Cruiser
  52. Paint: What paint for intake and exhaust
  53. Engine: Engine Size
  54. Cool/Heat: Are any / many of you using electric fans on 53-55 sedan/wagons ?
  55. Rear Axle: Pinion Seal Replacement on '54 Commander Starliner
  56. Engine: Fuel pump for a 6R235
  57. Transmission: New to this forum ' 59 Studebaker 1/2 Ton
  58. Rear Axle: swap from something else?
  59. Electrical: How to drop the steering column bracket on my 51 Champion
  60. Frame/Springs 4x4 Truck Chassis
  61. Steering Drag link clearance problems
  62. Interior: Carpet & Insulation
  63. Electrical: Avanti turn signal
  64. Interior: Loose carpeting
  65. Body: Underhood: loose paper on insulation.
  66. Fuel System: Choke Problems
  67. Fuel System: Can it be snaked????????
  68. Rear Axle: 50 Champ axles....
  69. Ignition: What are the best plugs for a 50 Champion
  70. Fuel System: The "best" fuel line hose?
  71. Fuel System: Filter size
  72. Electrical: Horn wire access on 55 Sedan
  73. Engine: Thermostat housing
  74. Clutch/Torque Converter: Clutch pedal return spring
  75. Transmission: New Shifter for Our '64 Hardtop
  76. Engine: 2 Carb balance 53 6 cyl with Offie manifold
  77. Steering Help needed on control valve rebuild
  78. Fuel System: BIG stress, time is ticking, manifold-strangenes...
  79. Speedo/Tach/Gauges Speedo Cable at Trans
  80. Body: Parts for Restauration
  81. Body: Hood springs
  82. Paint: Soda blasting vs. aluminum oxide
  83. Cool/Heat: Better heater blower motor
  84. Ignition: Prestolite Points
  85. Engine: 1949 Vacuum wiper hose questions
  86. Electrical: Tach
  87. Engine: Heat Riser Adventure
  88. Fuel System: 170 one barrel carb?
  89. Engine: Oil Leaks
  90. Cool/Heat: Hose connector
  91. Paint: Lacquer or Enamel 55 Pres C Body
  92. Brakes: Front drums & such...
  93. Interior: Dash Pad and Trim for '60 Lark Convertible?
  94. Transmission: 1963 lark transmission
  95. Fuel System: 63 Avanti need photos of fuel hose from frame to fuel pump orientation
  96. Transmission: Need another gear
  97. Brakes: Once More: Bench Bleed the Master Cylinder!
  98. Electrical: Universal Electrical Relays
  99. Fuel System: How many feet?
  100. Cool/Heat: Heater core replacement
  101. Electrical: Electric doors on 1949 Stude p u
  102. Cool/Heat: running cooler at the gas pump. (news to me)
  103. Wheels 48 Land Cruiser and radial tires
  104. Cool/Heat: 1962 Hawk Ranco Valve
  105. Fuel System: fuel to air ratio for r-2
  106. Steering Need a Ross steering box or rebuild parts for 1962 GT Hawk
  107. Cool/Heat: Blown water pump?
  108. Transmission: T96-1 input and output shaft seals
  109. Body: T Cab Hood
  110. Fuel System: Ethanol Effects On Fuel System
  111. Cool/Heat: 62 GT under seat heater core
  112. Drive Shaft hawk drive shaft
  113. Electrical: 55 President
  114. Other: mouse deterrent, winter storage
  115. Transmission: Shift lever has a lot of play
  116. Body: Stainless trim on Door
  117. Fuel System: Fuel Pressure thoughts
  118. Engine: Motor Rebuild Needed - Central California
  119. Electrical: Elect door locks 1949 Stude p u
  120. Body: M5 door weatherstrip install
  121. Engine: Rebuilt 259 runs great - exhaust volume of rt dual is much less than left side
  122. Engine: Engine from a 1962 Studebaker
  123. Body: Avanti Door Vent Assembly
  124. Fuel System: The chicken or the egg?..............fuel line protocol:-)
  125. Electrical: Avanti Gas Gauge Reads E
  126. Engine: Power Steering pump
  127. Body: Anyone got any sound deadener removal tricks ?
  128. Engine: Radiator cradle
  129. Fuel System: Stude Aluminum Intake Question (141019)
  130. Engine: WCFB Question
  131. Steering power steering problem
  132. Fuel System: 4.5 mpg?
  133. Steering Ross Type SL steering box re-seal
  134. Electrical: Why is Avanti Sending Unit Listed As 16 Volt
  135. Body: Avanti Cowl Induction Hood??!!
  136. Transmission: B/W OD 55 Stude Truck
  137. Body: 54 Sedan front vent window seals
  138. Electrical: Wagonaire Electric Tailgate Swap: Need parts list
  139. Brakes: Strong on right side front...
  140. Electrical: PH trunk light
  141. Engine: 52 Champion motor conversion ideas or stay original.
  142. Body: Dimensions of Zip Van
  143. Other: Vacuum Leak to Choke
  144. Engine: By Pass Oil Lines
  145. Body: Rocker Panel Covers
  146. Steering Adding power steering & power brakes to 50 Champion
  147. Engine: Can an early '50's 170 be used in a '60 Lark?
  148. Electrical: Wiring harness "loose ends"
  149. Wheels 1950 Champion
  150. Cool/Heat: Hose cross-reference
  151. Fuel System: R2 cuts out/heitates at 45/50 mph +
  152. Fuel System: Yes it is easier with no body!
  153. Clutch/Torque Converter: Clutch Release Bearings -- Help Needed
  154. Fuel System: Porous Carburetor Bowl
  155. Cool/Heat: A/C Evaporator Dimensions
  156. Engine: What engine do I have?
  157. Ignition: Tach Question
  158. Engine: Why two PCVs on R-1?
  159. Steering Out Of Control ???
  160. Fuel System: What is this part next to the fuel pump?
  161. Body: vacuum wiper motor
  162. Body: 1960 Lark Convertible Top Questions
  163. Electrical: OD Kickdown Switch Wiring 57 Commander 259
  164. Fuel System: 61 Lark Electric Fuel Pump.
  165. Engine: New Studebaker Owner - New Member -Bad cylinder. Options?
  166. Body: Naked Avanti
  167. Body: Core support removal question
  168. Frame/Springs Removing/Replacing rear leaf spring bushings
  169. Engine: Snail's Pace.
  170. Electrical: Grounding Turn Indicator Dash Lights 63 Hawk
  171. Electrical: Alternator v generator (someone switched me out--no pun intended)
  172. Front Axle: Dropped Axle
  173. Clutch/Torque Converter: 63 Hawk pulling the flywheel.
  174. Cool/Heat: chevy into stude radiator hoses
  175. Engine: 289 in a 1949 2R10
  176. Electrical: OD Kickdown Switch Wiring
  177. Engine: Sacramento area: Need to find a carb rebuilder
  178. Transmission: 60 lark VIII convertible
  179. Body: wiper blade recomendations
  180. Speedo/Tach/Gauges rebuild gauge cluster m5 truck
  181. Ignition: Things to use zip ties for
  182. Clutch/Torque Converter: Centerforce Clutch and Pressure Plate For Sale
  183. Engine: Questions about oil pump and valve spring cover oil leak. Pressure relief valve
  184. Ignition: Need ignition loom for 55 champion
  185. Transmission: Which Studebakers used the T85/T89 transmission prior to '58, other than the '56J?
  186. Fuel System: No way no how, not on this Avanti!
  187. Cool/Heat: Leaking Water valve leading to heater core
  188. Engine: Smoke from exhaust
  189. Electrical: Dim headlights on my 50 champion
  190. Cool/Heat: Hoses on 62 gt hawk
  191. Electrical: Alternator generator controversy
  192. Body: Another use for....
  193. Engine: crankshaft I.D.
  194. Engine: Valve Cover Gasket Installation Help *Update* Picture Heavy
  195. Exhaust 1977 Avanti II mufflers
  196. Engine: Best way to remove valve guides?
  197. Engine: Should I add sleeves to my flathead six cylinders?
  198. Fuel System: Edelbrock on R2
  199. Brakes: Need help with 1964 Champ 3/4 ton BRAKES
  200. Electrical: new wiring harness
  201. Engine: crankshaft issue.
  202. Fuel System: Help Identifying Gas Tank Sending Units
  203. Wheels tire rating, 4ply or 6ply, 1957 Golden Hawk
  204. Body: Fender well Crome 62 GT
  205. Other: 63 Champ Windshield Wipers
  206. Brakes: 2R16 Front brake adjustment
  207. Fuel System: WCFB spacer
  208. Transmission: Transmission Removal From Hawk Per Shop Manual
  209. Engine: What years 245 engine will bolt up in 39 Commander
  210. Rear Axle: Part number for axle seal
  211. Brakes: 48 Landcruiser
  212. Transmission: Views of FS powershift trans lever as guide to modification of column unit
  213. Cool/Heat: R Balancer with 55 Crank Pulley
  214. Steering Hawk Reach Rod Question
  215. Fuel System: Gas tank sending unit wires
  216. Other: towing 50 Land Cruiser with tow bar
  217. Transmission: 1951 bullet nose champion transmission linkage
  218. Cool/Heat: 1962 control valve for heater
  219. Wheels Disclaimer in Avanti glove box
  220. Brakes: Brake and fuel line routing 1950 Land Cruiser
  221. Fuel System: More Trouble With Carburetor .............
  222. Body: 1936 Dictator windshield frame interchangeable with coupe & Sedan?
  223. Ignition: Petronix part number
  224. Rear Axle: spring pack
  225. Cool/Heat: Factory air in a 56 Power Hawk?
  226. Fuel System: Fuel pump vs fuel return line
  227. Engine: OHV Six
  228. Body: Modifying early Hawk quarters to fit a GT
  229. Engine: Gawdawful noise with Bess
  230. Interior: PackardHawk trunk trim question
  231. Transmission: OD Cable
  232. Transmission: 1965 Daytona Sport Coupe
  233. Electrical: Trailer wire size?
  234. Paint: Shelf life?
  235. Steering 1957 power steering pressure
  236. Exhaust 57 Commander Sedan dual exhaust
  237. Cool/Heat: A/C Installation in Champ
  238. Engine: Pushrods on Avanti 289 R1
  239. Electrical: 51 commander generator
  240. Engine: 63 Avanti R1 power steering hoses
  241. Body: Will a '50 Champion hood fit a '51 (Champion or Commander)?
  242. Body: Avanti speedo cable routing???
  243. Body: Door lock cylinder and shaft
  244. Fuel System: WCFB Choke Connections
  245. Drive Shaft You guys with C/K, sedans and wagons...
  246. Engine: Valve cover gasket 1962 hawk
  247. Brakes: bleeder screw
  248. Engine: Thru bolt motor mounts
  249. Ignition: 1914 Studebaker 4 cyl
  250. Other: 1960 lark rear window.
