View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Electrical: Electric Wiper motor keeps locking up?
  2. Electrical: Replacing regulator on a negative grounded car
  3. Drive Shaft replace center bearing on 1954 ck
  4. Cool/Heat: Retro Fitting Existing Pickup Radiator
  5. Body: Replacing wing vents
  6. Engine: Replace pan gasket and rear seal on a 1957 Silver hawk with a 289 engine.
  7. Body: Door Mirror on Drivers Door on 47 Champion 4 door
  8. Paint: Help finding a paint code? 1953 Chippewa Green
  9. Brakes: Master cylinder
  10. Electrical: Blowing fuses
  11. Engine: Studebaker V8 Oil Pumps - Preparation and Rebuild
  12. Other: Throttle Control Rod
  13. Electrical: Headlights
  14. Transmission: Removing trans from a stuck engine
  15. Interior: Operate power windows with original window crank handle
  16. Engine: 259 to 289 How To
  17. Transmission: Automatic Transmission cooling for 1964 Lark Daytona
  18. Body: Vent Glass Overhaul
  19. Interior: '64 Hawk Bucket Seat Question
  20. Engine: Harland Sharp rocker arm users, take note...
  21. Transmission: DG 250 M needed.
  22. Engine: Oil fill tube and plug wire clips
  23. Speedo/Tach/Gauges Swapping Avanti II speedometer
  24. Frame/Springs Chop the top off a hawk
  25. Frame/Springs How To Fix The "Sag"?
  26. Transmission: Column mounted shift linkage.
  27. Body: Question on C/K inner fenders
  28. Electrical: Turn Signal acting up.
  29. Body: Where does this small rubber seal go on Vent Window (57 GHawk)
  30. Brakes: Accidentally pulled out booster pushrod, now what?
  31. Body: Question About K body Door Front Window Liner
  32. Fuel System: Pressure
  33. Engine: stuck 259 engine
  34. Ignition: hot starts 62 Hawk
  35. Body: 1947 to 49 Moustache Chrome on top of the grille.
  36. Rear Axle: Dana 44 vent hole?
  37. Steering Steering box greese
  38. Interior: Steering column - wheel position adjusting??
  39. Electrical: '63 Avanti Battery Life
  40. Body: Radio antenna location on GT
  41. Engine: Cloverleaf 289.... WTH?
  42. Body: VIN tag location on 1949 business coupe
  43. Brakes: adjust brakes on 54 pickup
  44. Steering 1950 Champion Starlight horn ring removal
  45. Engine: Copper coat Best Fiber head gasket?
  46. Brakes: Hand / E Brake Question
  47. Fuel System: gas problem
  48. Engine: overdrive kickdown on bell crank
  49. Front Axle: Kingpin seal recess
  50. Rear Axle: swapping out 6cyl for v8 rearend
  51. Body: Need some tips or pointers on glass install
  52. Transmission: transmission shimmy
  53. Rear Axle: 44 rear end
  54. Body: Vin ID
  55. Frame/Springs Avanti ride height problem
  56. Interior: Experiences: Fiberglass Studebaker Parts Places?
  57. Rear Axle: Traction bars
  58. Rear Axle: Flanged Axle Shafts
  59. Engine: engine oil in coolant
  60. Transmission: OD Solenoids..... 6V vs. 12V.....
  61. Fuel System: Passing Gas
  62. Transmission: Kick down switch and accelerator linkage install
  63. Rear Axle: Now What?
  64. Interior: Sun Visors
  65. Engine: Clearance tolerance?
  66. Front Axle: Help!!
  67. Body: 53 Champion frame upgrade
  68. Transmission: Clutch chatter/transmission removal
  69. Body: what is best rubber lubricant for the vent window shafts in a hardtop Hawk?
  70. Electrical: Wipers have wigged out....
  71. Interior: Will Sebring bucket seats fit the 63 Avanti?
  72. Body: Does anyone sell rebuilt trunk hinges? 57 Golden Hawk needs some
  73. Engine: 224 engine in 56 transtar
  74. Engine: R1 fuel line to filter issue
  75. Body: Hawk Bumper Bracket Question
  76. Fuel System: kinked copper line, fuel pump to carburetor
  77. Electrical: Need enLIGHTenment :)
  78. Transmission: help with O/D cable install
  79. Interior: Lighter knob color
  80. Fuel System: 232 V8 Fuel Pump Rebuild-Rebuild
  81. Electrical: Head light lens
  82. Fuel System: 1950 Champion gas tank
  83. Cool/Heat: Fan wiring diagram
  84. Body: Speedster hood spear
  85. Fuel System: Vacuum advance issue
  86. Electrical: Removing sockets from tailight housings?
  87. Interior: Avanti seats
  88. Exhaust 1955 Champion Coupe
  89. Brakes: Anyone tried the new Bendix Clone booster for MOPARS
  90. Steering 1978 Avanti II power steering control valve pressure hose positions
  91. Paint: 63 Hawk touch up paint
  92. Wheels Tire"s for 63 Hawk
  93. Brakes: How to remove brake drums???
  94. Transmission: 62 GT Hawk 4 speed chattering on take off
  95. Fuel System: Routing Charcoal Vapor Canister to Air Cleaner
  96. Transmission: 1959 3spd with OD replace a 1960 3spd w/o OD?
  97. Frame/Springs Coil springs in a 1960 Lark
  98. Fuel System: AFB identification
  99. Body: Avanti Power window motor gear, worm. Available? Furd interchange?
  100. Engine: Swap 259 cranksft short nose to later long nose.
  101. Brakes: master cylinder filler plug
  102. Engine: Timing and Vacuum Advance 101
  103. Rear Axle: 63 Daytona 259 w/4 speed
  104. Fuel System: ' nother AFB question
  105. Exhaust Removing old exhaust Manifold Right
  106. Frame/Springs What are these slots for?
  107. Brakes: Installing power/dual master cylinder on 2R5 trucks
  108. Brakes: brake pedal bushings for 54' car
  109. Frame/Springs 39 stude id# locations
  110. Body: 1954 Conestoga grill surrounds
  111. Engine: Optimal Ignition Timing
  112. Interior: Headrests, seatbelts and safety, oh my!
  113. Other: Tools needed for restoration ??
  114. Body: Windshield/Back window Rubber 47 Champion 4 door - Vendor experience
  115. Other: Headlights for 64 Daytona
  116. Engine: High pitched whine.
  117. Frame/Springs rear spring
  118. Brakes: manual brake pedal
  119. Engine: 6 volt timing ?
  120. Other: New Champ owner and first time poster!
  121. Frame/Springs Question on front/rear springs, 50 champion
  122. Fuel System: 1949 2R5 Fuel Tank
  123. Interior: Headliner glue Question
  124. Fuel System: Avanti II Fuel Tank
  125. Drive Shaft 1954 Commander front drive shaft adjustment(?)
  126. Engine: ReTorque Heads?
  127. Cool/Heat: pulley size for AC
  128. Electrical: Alternator cable size
  129. Engine: Dwell Setting Question
  130. Engine: 289 Valve Tap? Things to check?
  131. Fuel System: '56 President Fuel Pump
  132. Engine: Engine Colors 58 transtar V8
  133. Engine: 58 Silver Hawk: Scratching, chipping, chirping noise
  134. Ignition: Ignition switch for a 1951 Studebaker Champion
  135. Rear Axle: I need a pair of good used rear hubs for a '54 to '64 Studebaker Dana 44 axle
  136. Steering '61 vs '63 T-cab front ends. What is the difference?
  137. Electrical: Dash Wiring Pains, Now With Pix Of New Overlay
  138. Fuel System: Powerjection III
  139. Speedo/Tach/Gauges Need Fuel Gauge for 1961 Lark
  140. Body: Time to replace the door hinges?
  141. Front Axle: Aerostar front suspension used under pickup
  142. Frame/Springs Need help about my 1928 FA Cabriolet Studebaker President Eight
  143. Brakes: Brake Light Switch 56 Commander
  144. Body: Power Window Rollers
  145. Ignition: Help! 259 V8 No start after Valve Adjustment
  146. Engine: metal noise
  147. Exhaust Restoring 1936 President.
  148. Frame/Springs best way lower front 50 champion
  149. Body: 53/64 Rear Fender Bolt Clips
  150. Engine: low oil pressure
  151. Brakes: Hypothesis...
  152. Engine: tapping noise
  153. Clutch/Torque Converter: Hole In 289 Bellhousing
  154. Other: Upper control arm.
  155. Engine: Engine overhaul
  156. Engine: Indy car project: should my 57 lb flywheel go on a diet?
  157. Interior: Hoping someone can post a picture of an original 1950 champion seat cover
  158. Electrical: Steering column gear selector switch
  159. Cool/Heat: Lark V8 heater hose, what goes where?
  160. Clutch/Torque Converter: 63 Avanti trans question
  161. Engine: Avanti R2 normal idle vacuum reading?
  162. Engine: Valve Guide size? BOOBOO UPDATE
  163. Rear Axle: Which Rear End?
  164. Body: 61 GT HAWk with fins/wings
  165. Front Axle: Upper control arm outer pin
  166. Transmission: Avanti Power Shift downshifts at speed
  167. Front Axle: land cruiser front spndles wrong size
  168. Other: Crankcase ventilation
  169. Fuel System: Boost referenced fuel pump issue 57 GH ?
  170. Cool/Heat: 63 Lark Heater Core Replacement
  171. Steering 1964 Lark Steering Column Question
  172. Engine: Flathead 6 for M5 needed in NC/SC
  173. Other: Barn find in KS. But what did I find?
  174. Paint: Colour codes
  175. Body: Need C/K trunk lid in Tampa
  176. Rear Axle: Lube For Twin Traction
  177. Steering Fair price for Avanti parts?
  178. Body: Trunk pan steel size
  179. Frame/Springs Aftermarket availability of shocks and springs
  180. Steering center bellcrank bushings
  181. Body: Beltline weatherstrips
  182. Electrical: Brain Pick
  183. Other: A Weird Little Vibration...???
  184. Rear Axle: Forum influence
  185. Other: 1961 Hawk on ebay
  186. Electrical: In search of 1948 M-5 starter...Autolite MZ-4090...desperate!!!
  187. Body: How do I get the hood open on a '63 Avanti??
  188. Engine: Looking for a running 185 L-Head Engine.
  189. Other: vin number plate
  190. Brakes: Master cylinder residual valves
  191. Brakes: Where is hydrovac located?
  192. Exhaust damaged exhaust manifold
  193. Engine: cam and crank tools
  194. Interior: 53 coupe front seats.
  195. Paint: Fan & Pulley Color
  196. Steering Need Help for Control Valve leaks !!!!!!!
  197. Steering Straight axle advantages
  198. Drive Shaft Need New Splined Yoke for '63 4-Speed
  199. Engine: 56J Spark Plug Swap & Compression Check Results
  200. Engine: what would you do? 232 or 169?
  201. Engine: R1 Swap In My 64 hawk???
  202. Body: Front sheet metal alignment 53 C
  203. Wheels New Coker Tires Rubbing on Rim
  204. Rear Axle: Bent/Cracked Axle
  205. Electrical: Hawk Fuel Gauge
  206. Wheels Wheel/Rim compatibility
  207. Electrical: Need wiring harness
  208. Electrical: Are Alternator Regulators Adjustable?
  209. Electrical: Emergency brake warning light
  210. Transmission: 1964 Commander t86 transmission. Need parts
  211. Body: 1950 2R5 parts WTB and for sale
  212. Body: Front wheel trim
  213. Steering erratic steering
  214. Clutch/Torque Converter: Transmission/clutch issues.....1961 lark 6 cylinder
  215. Transmission: TC Lockup On 700R & 200R Transmissions
  216. Fuel System: Need help for a friends 1960 Studebaker lark
  217. Body: Window gap 62 GT
  218. Brakes: New SI Brake Drum (56-66 V8 Fronts cars) measurment needed
  219. Other: Restoring a '61 Lark Wagon from CA for the Northeast
  220. Frame/Springs GT Bat Wing Needed
  221. Brakes: 1950 Champion Brake issue causing me concern
  222. Engine: air filter
  223. Engine: engine noise
  224. Rear Axle: Bone Head Mistake, Now need advice
  225. Frame/Springs Bat Wing for 1953 Commander HT
  226. Electrical: negative ground tach
  227. Frame/Springs H.D. Front Sway Bar
  228. Transmission: Borg Warner 3 spd. overdrive.
  229. Exhaust Tell me the ways........
  230. Fuel System: Stromberg WW Rebuild - '54 Commander Coupe
  231. Brakes: I need one or a pair of factory disc brake calipers, either rebuilt or new
  232. Rear Axle: '63 Avanti rear axle ratio
  233. Electrical: 6V to 12V ? ? Overdrive solenoids...
  234. Brakes: 1940 President Brakes
  235. Wheels Mustang Wheels on 63 Lark 2 door
  236. Electrical: Defective Ammeter?
  237. Fuel System: Surging carburetor - possibly solved
  238. Drive Shaft Driveline Noise on Heavy Acceleration
  239. Speedo/Tach/Gauges '63 Avanti - Removing Gauge Overlay?
  240. Other: Metal to metal adhesives
  241. Engine: Draining the block
  242. Ignition: Points trouble
  243. Body: 1965 Cruiser, installation of weatherseal on rear doors
  244. Clutch/Torque Converter: Slight "pop" when I press the clutch pedal
  245. Body: Is this a C/K trunk lid?
  246. Ignition: New HEI distribitor
  247. Speedo/Tach/Gauges new gas gauge
  248. Electrical: turn signals
  249. Rear Axle: 2 speed rear end questions
  250. Fuel System: Carb leak at base plate. Why?
