View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120
  1. cooling fan
  2. Pertronix and Overdrive?
  3. power steering
  4. I've got no power captain!
  5. Hill Holder question
  6. 1929-30 Commander GJ 6 Cyl - Hershey lock
  7. Rear shoes for disc brake cars?
  8. WHEEL BOLT PATTERN? help
  9. help 1950 champion horn
  10. New brake drums - rear T-Cab
  11. 1949 commander Fresno, CA
  12. original radio
  13. lights
  14. '51 Champion parts needed
  15. wire color
  16. Original Paint or not
  17. bezel screws
  18. Hawk GT License Tag /Square bolts? ?
  19. Auto trans. buzz in Park & Rev.
  20. avanti tear up
  21. Differential Oil & Flush Questions
  22. defroster motot
  23. steering column
  24. Shock Absorbers ??
  25. NEEDED: 54 Commander/Starliner Front Bumper
  26. 49 Champion Six - Pan Gasket
  27. Sebring Convertible Front Seats
  28. .20/20 ?
  29. Looking for mechanic for a 2R10
  30. 1953 Loma Gray Interior
  31. 2R5 Stude Truck 1949
  32. 58 flightomatic
  33. 289's
  34. Dumb question - fuel filter '61 Lark
  35. Delco radio ID's
  36. 63 Lark engine ID ??
  37. Mystery oil
  38. Stude Avanti radiator
  39. Wierd wiper parking
  40. Got my Daytona (289) heads back
  41. Price for piece of mind
  42. serial numbers
  43. Need a '63 Lark Speedometer
  44. Gas tank rust repair?
  45. r-2 Avanti AC
  46. Wind Lace
  47. T-85,T-86 Overdrive Question.......
  48. Power steering Control Valve
  49. GT Mustang to 13" Cobra brake Avanti upgrade
  50. reducing picture size - help!
  51. wireing of turn signals
  52. DEEPNHOCK Machine Shop Sutting Down Temporarily
  53. Hood insulator pad question
  54. How difficult to replace steering box
  55. NoRol Unit for 51 Stude Champion
  56. Making things right.
  57. I hope Jerry won't mind.....
  58. vapor lock cures
  59. Differential install for 48-52 Champ/Commad
  60. member selling out--Vehicles/parts
  61. '55 President 4-door rear vent window rubber
  62. I desperately Need Two parts
  63. tri-star placement
  64. Gas Tank Sending Unit - 51 Champ
  65. Will this hub puller work?
  66. Calling Mr. Dick Steinkamp
  67. Flushing the gas line?
  68. OK, i feel dumb, how do I open this hood?
  69. rim paint
  70. Anyone need a 259 and FOM cheap?
  71. parts wanted
  72. carb
  73. 1950 Studebaker Champion front brake adjusters
  74. Brake cylinder goo
  75. 6 volt battery booster???
  76. Is this a Studebaker engine? (w/ pics)
  77. 56-59 hawk
  78. Course No. 101--Dana 44, Please Help
  79. Torque converter
  80. Carb Rebuider
  81. Captain, we've got no power.
  82. Upgraded Steering on Hawk
  83. '60s Wheel Width
  84. Drum brake springs
  85. Carb Re-build
  86. commander bumpers?
  87. studebaker bumpers...w / photo
  88. Avanti front turn signal question
  89. parts
  90. Question about brake bleeding with hydrovac
  91. Headrest Needed
  92. 1952 Commander VIN number
  93. Total Seal
  94. Rear axle key position
  95. 64 GT Hawk shocks
  96. GOtta Glue some rubber-63 GT HAwk
  97. Champion head bolt torque pattern?
  98. Intake and Exhaust Manifold Paint. 51 Champ
  99. Pictures of Avanti on rotisserie?
  100. 64 GT Hawk center grill
  101. vacuum wipers & fuel/vacuum pump
  102. Help with floorboard
  103. REEDSVILLE DATES CHANGED PLEASE READ
  104. Hawk Hydrovac brakes
  105. Grease seal brake bearings
  106. Foam & broken nuts?
  107. Seal on front drum bearing
  108. horns
  109. Modified Hydrovac for dual master cylinder
  110. Brake pedal frame stud
  111. email postings
  112. Tire question
  113. Looking for Studebaker V8
  114. 15" X 6" wheel rims
  115. OD Trans. Rear Seal
  116. R2 heads
  117. What buffer to buy
  118. Steering Wheel Rebuild
  119. 62 - 63 - 64 GT Hawk window regulators
  120. Bodywork Question
  121. pinion seal leaking
  122. Lark clock
  123. Ring Specs
  124. 60 Hawk Spark plug question
  125. Dana rear end, nut Torque
  126. Overheating? 1963 GT 289
  127. R2 Avanti for sale
  128. Avanti timing
  129. Hazard lights/flashers for 1963 Avanti
  130. 60 Lark 4 Dr. LR Quarter
  131. 1950 Champion motor help needed
  132. Distributor Upgrade
  133. options for fluids in 64 Hawk
  134. bellhousing alignment?
  135. 1964 V8 PCV Valve 1561585
  136. 64 Hawk dashboard
  137. Upper outer A arm bushing Install
  138. Carby Trouble
  139. Column shift linkage?
  140. Brake Drum Stud
  141. Aluminum Cleaner?
  142. Hawk Hood Safety Catch
  143. Valve adjust
  144. 48 Champ wheels and tire interchange
  145. OIL PLUGS
  146. P195 15 R75 Tires
  147. 53 interior
  148. How do you remove trunk lock cylinder 50 Champion
  149. Another v-8 PCV 1559379 ?
  150. 63 champ hot rod project
  151. Cam plug
  152. Starting problem
  153. Rack & pinion installs on Studebakers
  154. power steering control valve 2
  155. ENGINE I.D.-A5625/6E5408..what is it?
  156. Tranny Change-over
  157. Today's episode of the Great outer Pin Repair
  158. Heater core
  159. 60 lark engine misfire
  160. Engine Block ID
  161. Installing spring pads...
  162. wiring diagram for 51 champ dash lights
  163. Rear wheel race/bearing
  164. Engine ID & head casting numbers
  165. Help - Speedo Pinion Gear Needed
  166. POR 15 or like products????
  167. Replacement axle?? Axle saga - RESOLVED!
  168. Where to find Hawk trunk&hood hinges
  169. Lark trunk rubber
  170. Tighe Cams in Australia
  171. Tahoe Contacts/Help
  172. 51 Champ Engine Front Mount Bolt Touque Spec.
  173. Radio for 60 Hawk
  174. Speedster door floor sill mouldings
  175. Tranny Change-over "2"
  176. Using a Holley on stude v8
  177. Reasonably priced chromeing
  178. Heater frustration
  179. 49 champion front suspension
  180. Wrong Pinion Seal??
  181. Help/ brake return spring
  182. 51 Champ Propeller Shaft Rebuild
  183. 63 Avanti R2 fuel pump noise
  184. 66 engine swap
  185. 63 Gt road clearance??
  186. Headlight wierdness
  187. Hurst parts WTB
  188. Where is the best carpet
  189. Transmission question
  190. Speedo cable question
  191. Metallic noise in muffler
  192. Avanti gauges/dash cover
  193. Heavy Hawk hood. Why.
  194. Engine cradle
  195. Avanti crankshaft length
  196. Stude V8 into 2R5 truck?
  197. 1st grear shift valve body
  198. Original Stude Factory Tooling
  199. Can't get steering wheel off
  200. vibration
  201. HELP!! This a "thrust block"? How 2 reinstall it??
  202. PAL nuts - how tight is right?
  203. Running too cool, and gas odor...
  204. V8 distributors
  205. HELP dash board lights problem 1951 champion
  206. 56 inter fender / fender
  207. Overdrive relay questions
  208. Engine quits
  209. question on hawk and commander frame
  210. 62 Hawk rear springs
  211. engine rebuild
  212. engine size
  213. Shorter Reach Spark Plugs.......
  214. C-K taillight
  215. Split Brakes
  216. Loss of power up hill
  217. Anyone near York, Pa?
  218. brake problem need help!
  219. Well, the plugs finally went...
  220. problems after new exhaust
  221. territorial Cruiser
  222. 62 lark rear quarters?
  223. gas gauge
  224. Anti Creep, on brakes
  225. Power Steeriing in Hawk
  226. Avanti front bumper center rubber piece??
  227. bleed brakes, what line first?
  228. Avanti Help Needed
  229. brake problems
  230. single hole to dual MC upgrade.
  231. Carb spacer for Edelbrock 1403
  232. spark plug wire looms
  233. 65 fuel pump has me stumped
  234. Thank You All For the Great Help
  235. Parking Lights
  236. tachometers
  237. Tighe roller cam question...
  238. Felt crank seal-- Where to drill holes? Help!!!!
  239. Lower radiator hose 53 coupe v8
  240. gravel guards again?
  241. Overdrive solenoid
  242. 60 Lark Wagon
  243. The Avanti Challenge
  244. Bearing Help
  245. avanti water pump
  246. 65 Commander oil press line
  247. 57 Golden Hawk Paint Codes
  248. part numbers
  249. Polishing/Waxing the Avanti's laquer paint- UPDATE
  250. Is it possible to use an 8 volt battery ??
