View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 [89] 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120
  1. Clutch/Torque Converter: Frustration abounds with '66 6 cyl clutch replacement
  2. Engine: Accel oil at Walmart
  3. Clutch/Torque Converter: Clutch pedal will not adjust nor return properly.....
  4. Engine: 289 water pump
  5. Body: body to frame swap
  6. Fuel System: heat soak solved
  7. Engine: A 289 Hawk
  8. Transmission: Floor Shift For 700R Conversion
  9. Fuel System: Just a heads up...(fuel additive)
  10. Steering front stabilizer bar center link assembly
  11. Body: 1957 Silver Hawk Drivers door window regulator
  12. Speedo/Tach/Gauges speedo cable
  13. Transmission: Column shifter flight-o-matic
  14. Cool/Heat: climatizer duct hose cover
  15. Front Axle: Mustang II setup - -what's its problem?
  16. Body: Glass Tech: Repairing Scratches (Video)
  17. Body: K body trunk hinge
  18. Frame/Springs Proper ride height-'53 Commander
  19. Wheels adapters
  20. Cool/Heat: Possibly the dumb question of the week...
  21. Transmission: Need some old timer advice
  22. Interior: GT Hawk drivers bucket seat
  23. Engine: Tired Avanti 289, 102,000 miles
  24. Other: Transport: 1962 GT Hawk
  25. Clutch/Torque Converter: Trouble removing the clutch rod
  26. Interior: Upohstery 62 Champ. PU
  27. Brakes: Power brake booster
  28. Fuel System: Fuel pump pressure testing an R2
  29. Wheels Wire wheel covers
  30. Other: A-Arm Bushing Fit
  31. Transmission: 63 Avanti Kickdown Rod
  32. Cool/Heat: 1961 Champ Heater Control Valve Needed
  33. Rear Axle: Seal and Bearing instlallation tool
  34. Rear Axle: which side of the pinion seal
  35. Brakes: brake pressure
  36. Engine: Air filter selection
  37. Engine: rocker shaft plugs
  38. Fuel System: 57 Silver Hawk fuel delivery problem.
  39. Rear Axle: Flanged Axle shafts bearings and seals
  40. Brakes: Brakes that don't really "lock up"
  41. Engine: What kind of a V8 engine
  42. Body: Sunvisor aluminum
  43. Transmission: 57 Golden Hawk transmission mystery.
  44. Fuel System: WTB Carter AS 1BBL Carburetor
  45. Cool/Heat: Hose routing 57Commander V8 259
  46. Other: vin #
  47. Frame/Springs BANG!!
  48. Engine: Need specification on 289 crank
  49. Other: Windshield Washer bottle
  50. Electrical: Flasher going bad or....?
  51. Wheels Stripped stud
  52. Fuel System: 8E40 Carb
  53. Brakes: When the book goes from A to C and never mentions B )(*()&*
  54. Engine: spark plugs 289
  55. Brakes: Brake rebuild
  56. Engine: Isky ST5 specs
  57. Brakes: Leading shoe vs. Trailing shoe
  58. Transmission: Please confirm....
  59. Transmission: 63 Lark 2 Door easy Overdrive question
  60. Electrical: Gas Gauge
  61. Fuel System: '49 Champion won't start after running great for fifteen miles
  62. Engine: 570 Head cc
  63. Wheels 5E12 Tire restoration
  64. Drive Shaft '48 Commander U-joint #'s
  65. Fuel System: I need pictures of throttle linkage on a '61-'64 Champ truck with the overhead valve six engine
  66. Engine: Rear Motor Mount Differences on Standard Transmission Cars
  67. Fuel System: 62 GT Hawk fuel line location
  68. Body: don't think so, but gotta ask
  69. Ignition: cant get car to idle after new vacuum advance.
  70. Fuel System: 61 Lark Carb Mixture Screw.
  71. Front Axle: King Pin Bushing / Bearing Tool
  72. Engine: Avanti hesitation on a hot restart
  73. Electrical: 105 degree heat and the weirdness that ensued!
  74. Body: Original seat belt anchors?
  75. Engine: 289 eng rebuild update.
  76. Other: need advice conserning paxton sn89 supercharger
  77. Speedo/Tach/Gauges Speedo Cable
  78. Fuel System: PCV Function?
  79. Clutch/Torque Converter: Clutch rods
  80. Body: truck glass install help.
  81. Rear Axle: 49 studebaker rear differential, new brakes, parking brake FOR SALE!!!
  82. Electrical: Brake Lights
  83. Rear Axle: Buttercup gets a new rear axle
  84. Speedo/Tach/Gauges 58 Silver Hawk
  85. Body: Body bolt #2 twisted off in hole
  86. Brakes: hub puller
  87. Fuel System: Looking for a carb spacer for my 52 Champion
  88. Engine: Oil pressure relief valve location
  89. Fuel System: Anyone have a spare Carter 715S carb?
  90. Steering Maximum Power Steering Pump Shaft End Play
  91. Engine: 1964 289 V8 "stumbles"
  92. Engine: Removing Camshaft
  93. Other: Not Sure What's Going On Here
  94. Steering Power Steering Pressure Hose Routing from Pump
  95. Other: windshield
  96. Brakes: That little copper thing:-)
  97. Transmission: Shifter problem (1960 Champ)
  98. Cool/Heat: A/C
  99. Fuel System: Fuel Sending Unit
  100. Engine: Rods/wires in cylinder head water jacket
  101. Transmission: Overdrive not working
  102. Electrical: over chargeing
  103. Cool/Heat: 58 Silver Hawk Hoses
  104. Engine: SI Front Cam bearing does not have oil groove
  105. Steering Parts
  106. Body: 53 hood
  107. Body: Funky window rollers
  108. Speedo/Tach/Gauges New Gauges
  109. Front Axle: 2R5 Straight Axel Disc Brakes
  110. Transmission: Transmission adapter
  111. Brakes: Power Brake incidence
  112. Interior: instument bexel
  113. Rear Axle: Rear end set up
  114. Speedo/Tach/Gauges 1965 Daytona Sport Sedan
  115. Body: Lark eyebrow bolt removal
  116. Frame/Springs Contradictions
  117. Speedo/Tach/Gauges oil line to gauge
  118. Ignition: Distributor swap?
  119. Interior: Gt hawk glove box door
  120. Speedo/Tach/Gauges Looking for a M Clock
  121. Brakes: Steel-Tech Front disk brake brackets
  122. Wheels Tire size and wheels
  123. Other: Steering wheel puller
  124. Wheels need some help with a 62 Hawk
  125. Other: Need a 1950 Champion Coupe steering wheel
  126. Body: Replacing Belt Molding on a '59 Lark Regal Hardtop
  127. Wheels Mystery 5" Avanti Style Wheel
  128. Cool/Heat: 1963 Champ Pickup Radiator
  129. Cool/Heat: Running hot
  130. Engine: Oil Grade for 232
  131. Interior: How do the seat bottoms attach to floor in the rear ( 1955 c body president 2 door)
  132. Engine: 289 advice
  133. Steering 61' Lark 6 cyl with Manual Steering.........Now hard to steer!
  134. Engine: ZDDP level and film strength
  135. Engine: Oil breather/fillers: is one better than the other?
  136. Body: Avanti door (window) rattle
  137. Body: Speedster window rollers
  138. Body: P/N 291214 Plate #1 bolt reinforcement
  139. Interior: Headliner Source
  140. Frame/Springs Looking For A "good" Frame Diagram For Avanti
  141. Body: 64 Wagonaire roof rack screws
  142. Ignition: tryin' to hot wire the 40
  143. Fuel System: Carter WCFB Question
  144. Engine: Motor rebuild on a 169
  145. Engine: Does anyone have a good 169 for sale?
  146. Transmission: 57 Commander overdrive
  147. Other: Convert R5 vac. wipers to elec. wiper?
  148. Electrical: Looking for a Light Switch for 1954 Commander
  149. Frame/Springs Body bolt holes do not line up
  150. Other: Bumper jack identification resource?
  151. Transmission: dg 250 wont shift to high
  152. Exhaust Exhaust leak
  153. Other: Windshield wiper ghosts.
  154. Engine: Valve Cover Gasket Installation Help
  155. Brakes: Rear Emergency Brake Cable
  156. Other: Does anybody have a "farily decent" 37 Dictator for Sale ?
  157. Electrical: Intermittent Wipers
  158. Engine: wanted: seals for 186 C.I.D. engine
  159. Front Axle: J-2044 tool
  160. Brakes: Roll control torque specs
  161. Ignition: 40 champion ignition switch question
  162. Fuel System: 1964 Hawk w/ 289ci, 2bbl question
  163. Other: starting issue in lark
  164. Engine: Need new carb on 289, Any suggestions?
  165. Body: K car Flippers----
  166. Paint: Paint: Engine Color for 61 Hawk
  167. Body: 1957 Silver Hawk Fins
  168. Interior: Getting rid of mouse odor
  169. Body: Photos of trunk opening rear panel C/K
  170. Ignition: Is even a little each year too much?
  171. Engine: By-Pass Flex Oil Lines
  172. Engine: 1965 283 accelerator springs
  173. Ignition: 289 Wire Set Part Number?
  174. Transmission: Transmission Screen for DG-200M in 1955 E12-22 3/4 Ton Truck
  175. Electrical: Unstable cam angle
  176. Electrical: Weird one for the record books?
  177. Fuel System: Searching for parts
  178. Other: squeak
  179. Fuel System: Avanti dashpot
  180. Body: 56 wagon door glass questions PLEASE help!
  181. Ignition: Avanti won't shut down
  182. Engine: Help
  183. Rear Axle: You can be lucky
  184. Speedo/Tach/Gauges Speedo Position in 63 Lark Question
  185. Body: Two annoying rattles gone.
  186. Ignition: ballast resister in 6 volt?
  187. Front Axle: suspension
  188. Body: Looking for the Studebaker Script for a 47 Champion nose and rear part of fender duct for rh side.
  189. Rear Axle: Champ Truck Diff
  190. Engine: Increasing horsepower 6 cyl OHV for 64 Champ
  191. Steering Steering wheel 1949 Regal Delux Champion
  192. Cool/Heat: Cool Bananas
  193. Rear Axle: Dana 44 Flanged Axle Question
  194. Body: 1964 and 65 firewall
  195. Engine: Thin layer of foil between main bearing shell and bearing cap.
  196. Brakes: brakes
  197. Cool/Heat: Climatizer heater, blower, valve, heat exchanger, air tube
  198. Body: Correct position for Hawk front fender antenna - left or right?
  199. Engine: Spark Plugs
  200. Engine: Low Oil Pressure
  201. Body: U channel 1964 Commander wont stay
  202. Paint: Need A Good Body & Paint Man In Eastern PA - Western NJ
  203. Fuel System: Wagonaire Gas Filler Water Intrusion
  204. Frame/Springs Spring shackle
  205. Engine: Flathead basics
  206. Exhaust Black Light Lark
  207. Paint: 62-63 Colors
  208. Engine: Oil filter in Chebby Baker (not 283 McKinnon?)
  209. Cool/Heat: Things I never knew about radiator caps - and my mother never told me! (long)
  210. Brakes: Looking for help near Hickory, NC
  211. Interior: Blue Hawk Interior
  212. Ignition: ignition switch needed
  213. Brakes: Front Disc Brake Warning !!
  214. Engine: Seals & Oil Pan Gasket 259 V-8
  215. Rear Axle: NEED Dana 27 or 44 with 4.10 to 4.56 ratio for 64' Wagonaire
  216. Steering Who knows the type of steering gear used on Avanti II
  217. Steering Anyone have some manual steering parts for an Avanti
  218. Ignition: '63 Avanti Ignitions Switch Options
  219. Fuel System: Carburetor mixture screw adjustment..no comments??
  220. Cool/Heat: 5-blade fan
  221. Electrical: Horn wire
  222. Frame/Springs 1959-63 Hawk Frame Dimensions
  223. Fuel System: idle problems
  224. Engine: More on Oil Filters
  225. Steering Steering Column Seal is not being reproduced, any suggestions?
  226. Paint: how to find original paint colors
  227. Wheels How to: Measuring GT Hawk wheel wells for BIG tires
  228. Wheels Split Rim fun.
  229. Interior: Removal of '62 Hawk Instrument panel
  230. Transmission: still trouble shooting my dg250
  231. Engine: Two barrel carb vs. two one barrels
  232. Electrical: How to remove cigarette lighter????
  233. Electrical: Dash gauges all misreading all of a sudden
  234. Fuel System: Electric Fuel Pump only on Hawk 289ci 2bbl
  235. Ignition: Interpreting timing mark
  236. Exhaust V8 Exhaust Reversion
  237. Body: 1962 GTHawk artifact
  238. Electrical: Radio reception
  239. Fuel System: 1949 2R5 Gas Tank Pickup Tube
  240. Shocks Champ shocks
  241. Engine: Camshaft end play
  242. Body: Looking for some help with hood and trunk release
  243. Front Axle: upper control arm bolts
  244. Speedo/Tach/Gauges *testing* tachs
  245. Brakes: master cylinder kits
  246. Body: 1947 Champion 4 door Windshield and Rear window installation
  247. Speedo/Tach/Gauges McCulloch Supercharger Gauge Wanted
  248. Cool/Heat: AC Condenser on a Convertible or Wagon
  249. Body: Windshield /rear window install
  250. Electrical: Avanti II Electric Junction Box
