View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 [88] 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Electrical: Where do I route the back up light switch wiring harness for a 64 Lark HT with 4 speed ?
  2. Electrical: What in the %$%*@#!
  3. Electrical: No brake light on R side 61 Hawk
  4. Brakes: Severe brake pull to left and steering problems
  5. Brakes: M5 parts in the uk.
  6. Rear Axle: TT Gear Lube
  7. Steering 63 Avanti Pressure and return hose routing
  8. Electrical: Stop lamp will not light.
  9. Brakes: Hydrovac Cylinder Oil ?????
  10. Electrical: 61 Lark -- turning the steering wheel and the horn goes off-- started today!
  11. Interior: 64 horn button
  12. Engine: My new 62 GT Hawk
  13. Cool/Heat: what type of rad cap to use & is it a pressurized system
  14. Cool/Heat: Cooling smoking off on top of valve cover
  15. Transmission: Please help identify this transmission.
  16. Engine: Pause when accelerating
  17. Paint: Did Studebaker have a 1959 color Baltic Blue?
  18. Other: 1957 Transtar restoration.
  19. Fuel System: suitable carburetors for supercharger
  20. Clutch/Torque Converter: Is it necessary to dial indicate the bell housing when changing 6 cylinder engines or transmission
  21. Brakes: Stop Light
  22. Wheels wheel studs
  23. Rear Axle: TT Rear Axle Visual Identification
  24. Transmission: '52 Commander Shift Linkage Adjustment??
  25. Engine: Crank case seal
  26. Engine: 289 teardown
  27. Transmission: Sharing this great O.D. tip
  28. Electrical: Dome light removal
  29. Brakes: Brake caliper trick
  30. Frame/Springs '63 Avanti Coil Springs
  31. Engine: Calling Jack Vines.. Stude Head Mods on the HAMB ??
  32. Body: 50 champ
  33. Body: Chrysler Sebring Convertible Front Seats
  34. Interior: Dome light how do remove it in my 1961 Lark
  35. Steering 1953 power steering
  36. Paint: Plastic Protection?
  37. Engine: camshaft???
  38. Electrical: Parasitic electrical drain
  39. Exhaust Heat Riser Valve
  40. Transmission: Yes my od on my Champion again.
  41. Other: 1955 Studebaker Rear Windows interchangeable
  42. Interior: Vanity drawer 1964
  43. Paint: 1961 Lark Paint Color " Autumn Haze "
  44. Wheels If I can not find, what is close?
  45. Engine: What is this, and how concerned should I be?
  46. Transmission: How NOT to put in a Scotsman trans/driveshaft
  47. Paint: 60-64 Truck Parchment White
  48. Engine: Adjusting valves
  49. Engine: Champion timing cover leak.
  50. Cool/Heat: Heater fan speed resistor
  51. Paint: H20 Hard or Soft??
  52. Other: windshield washer bag
  53. Brakes: Wheel cyclinders
  54. Body: Rust Hole or Drain Hole?
  55. Exhaust New exhaust system
  56. Brakes: ABS on a Studebaker
  57. Engine: Chevolet 350
  58. Engine: Flywheel for 1962 289 hawk engine
  59. Steering Steering knuckle arm interchange?
  60. Paint: Speedster paint questions
  61. Other: mystery Avanti part
  62. Electrical: LED lamps & flashers
  63. Wheels Tire preservation
  64. Front Axle: Avanti Control Arm Measurements
  65. Speedo/Tach/Gauges GT Hawk Tach Accuracy
  66. Transmission: 64 Cruiser..
  67. Fuel System: fuel pump, 170 vs 245
  68. Clutch/Torque Converter: starter bolt
  69. Steering Need Bendix power steering control valve parts
  70. Steering Steering wheel removal
  71. Ignition: I either figure out the distributor or I install my LS engine!!!
  72. Speedo/Tach/Gauges Speedometer gear
  73. Interior: Looking for picture of how the brake light switch mounts to the parking brake 1965/66 cars
  74. Fuel System: R1 Intake Manifold Qestions
  75. Steering Finally have the Astro Box conversion finishied ???
  76. Transmission: What's wrong with T86
  77. Body: How to.. 1962 Lark Regal wagon
  78. Interior: Rear seat question.
  79. Body: material under drip molding
  80. Drive Shaft Noise/resonance in drive shaft
  81. Electrical: 1960 Lark 259 - Where does this little red wire go???
  82. Rear Axle: Rear axle housing cover gasket.
  83. Cool/Heat: Need to get a spare upper radiator hose for my modified 1957 Studebaker Silver Hawk
  84. Fuel System: carburetor stall
  85. Electrical: Avanti windshield washer wiring diagram?
  86. Electrical: I think I fried my horn relay
  87. Ignition: Distributor Question
  88. Body: friend needs 57 Silver Hawk right front grill piece
  89. Steering Grant steering wheel adapter 4291 for 62 Lark, 61 Hawk is 62-64 hawk the same shaft
  90. Steering steers lika truck 63 hawk
  91. Fuel System: Idle adjustment on Stromberg WW-6-117
  92. Engine: 1960 Champ 259
  93. Wheels Other kind.
  94. Engine: 259 Head gasket
  95. Fuel System: OK, what did I do wrong?
  96. Electrical: Shizzam damn!
  97. Wheels Spare wheel color
  98. Paint: Powder Coating Valve Covers
  99. Wheels 1949 2R16 Dump Bed: Where to mount the spare?
  100. Engine: 1927 commander big six starter clutch
  101. Ignition: Delco Window for 61 Question
  102. Cool/Heat: How can I tell if the correct radiator is in my 1957 Studebaker Hawk
  103. Body: GT Hawk Window Regulators
  104. Rear Axle: Rear Transaxle Oil Spec.
  105. Fuel System: Vacuum pump troubles
  106. Engine: Teach me about Daytona's
  107. Engine: Engine Swap
  108. Steering Can it be done?
  109. Exhaust Applying heat proof paint to exhaust manifolds and intake manifolds
  110. Cool/Heat: Possibly adding a coolant recovery bottle to my Hawk's radiator
  111. Engine: Manifold vacuum switch for McCulloch supercharger.
  112. Engine: 59 289 engine identification?
  113. Brakes: Turner Disc Kit just installed
  114. Paint: Paint Failure
  115. Fuel System: Fuel pump?
  116. Clutch/Torque Converter: Need help, stuck clutch
  117. Body: Truck/car covers again
  118. Interior: Repro Mirror stem recommendations ('64)
  119. Engine: ID-ing a 245 vs 169 aluminum cylinder head
  120. Frame/Springs Champ 1/2 Ton Towing Capacity
  121. Body: ourside mirror mount
  122. Engine: LS Chevy into '60 Lark - The Slow Swap
  123. Cool/Heat: Part # help needed
  124. Body: Window "flipper" mechanism
  125. Rear Axle: What is the best way to center rear axle in car?
  126. Rear Axle: 1963 Avanti rear swaybar bushings (U-bolt mounted one) from 1993-2002 GM F-body (Camaro/Firebird)
  127. Interior: '85 Avanti Sunroof
  128. Engine: Can't get the cyl head off
  129. Paint: Chassis Colors
  130. Brakes: Removing rear wheel studs
  131. Transmission: I am gonna need help with this.
  132. Engine: HAPPY CAMPER!! full flow conversion DONE.
  133. Steering Avanti Grant steering wheel adapter FREE
  134. Electrical: Fuse location
  135. Cool/Heat: 3 core or 2
  136. Body: Installing door weather seals on '66 Cruiser
  137. Body: 1953 c coupe taillight housing to body gasket
  138. Brakes: Bleeding Brakes Questions ????
  139. Speedo/Tach/Gauges 1959 silver hawk gauge replacement
  140. Electrical: Instrument Lights
  141. Front Axle: steering and suspension
  142. Ignition: Ignition wire set
  143. Fuel System: R2 Carburetor fitting Dave Thibeault Carb
  144. Fuel System: R2 Carburetor fitting Dave Thibeault Carb
  145. Rear Axle: Rear Axle Outer Seal
  146. Engine: sweet little 62 two door
  147. Clutch/Torque Converter: 4 spd clutch linkage
  148. Ignition: Timing Issue
  149. Transmission: T10 Driven Speedometer Gear
  150. Brakes: Where's the fluid going?
  151. Steering Hawk Help Please!
  152. Speedo/Tach/Gauges 1961 verus 1962 Lark Clocks
  153. Exhaust Heat Riser Valve
  154. Brakes: gasket between greaser diverter(?) and front backing plate
  155. Ignition: Loose Delco distributor rotor
  156. Body: Body on rotisserie
  157. Engine: 61 Lark Issues
  158. Electrical: Re-starting issues
  159. Body: stude 2r5 pickup, 1951
  160. Engine: Modern Gasoline Jinx?
  161. Fuel System: Vented gas cap question
  162. Cool/Heat: 63 avanti radiator
  163. Body: Windshield Leak
  164. Brakes: Easy brake question
  165. Engine: motor mounts
  166. Ignition: Shimming the Delco Window Distributor
  167. Transmission: Reverse 'Lock Out' Switch
  168. Speedo/Tach/Gauges Another speedo pinion issue; worn teeth
  169. Rear Axle: 1962 Gran Turismo Running gear under My 51Commander
  170. Electrical: Did I damage my regulator?
  171. Cool/Heat: Recharging the AC
  172. Brakes: Power brake booster oil?
  173. Engine: 62 Lark getting a 259
  174. Body: need help with core support mounting 53 champion C
  175. Front Axle: King Pins
  176. Frame/Springs Rear Leaf Spring Issue
  177. Body: 1949 Champion Bumper jack set
  178. Ignition: help with pertronix for 56 Power Hawk
  179. Cool/Heat: Radiator overflow on 56 Power Hawk
  180. Interior: Carpet/Acc. pedal fitment....?
  181. Cool/Heat: Air Conditioning Brackets/radiator question
  182. Body: 64 Lark Daytona side moulding clips?
  183. Brakes: Looking for service in Seattle
  184. Brakes: 57 Commander
  185. Ignition: Requesting NOS starter solenoid & under dash switch
  186. Rear Axle: 77 Avanti axle
  187. Ignition: Distributor Grounded ?
  188. Wheels New Halibrands (ish)
  189. Rear Axle: Procedure for pressing on bearing on tapered axle shaft?
  190. Speedo/Tach/Gauges speedo cable
  191. Other: 1959 Lark Restoration
  192. Engine: Need picture of decal on 1958 - 259 oil filter housing
  193. Body: Seeking Minnesota Glass installer for rear windows 1950 Starlight Coupe
  194. Brakes: 57B Backing plate differences
  195. Clutch/Torque Converter: Shift pattern reversed 1962 Hawk
  196. Front Axle: Tie Rod Ends
  197. Body: 1962 Spare Tire cover Carpet ??
  198. Electrical: 1955 Sedan Radio Question
  199. Engine: 1959 Lark rough running
  200. Ignition: Dist. exchange
  201. Electrical: I need a wiring harness
  202. Brakes: Rear brake lines
  203. Body: Speedster trim
  204. Engine: Alternative oil?
  205. Body: Unity S6 Spotlight to fit 49 Champion 2D Sedan
  206. Engine: Oil filter install on 185?
  207. Engine: How do you remove a Champion oil pump?
  208. Steering Power steering for a '51 or '52 Studebaker
  209. Engine: SI Avanti Piston Fit
  210. Brakes: Master cyl. for Turner 61 Lark
  211. Transmission: Help Transmission Rear Oil Seal
  212. Rear Axle: How to cut special felt seals - 1928 GB rear axle (and 2R16,17,28,38!)
  213. Body: Vin # ID
  214. Speedo/Tach/Gauges Temp Guage Wire
  215. Engine: Why I picked a 305 instead of a 350
  216. Other: '63 Avanti A/C Quit
  217. Ignition: 61 Lark Cylinder point gap.
  218. Steering Bell Crank Pivot
  219. Engine: Hot Super Charger
  220. Electrical: TW "tech tip" assistance
  221. Engine: does anyone make new-stock rear main seals for the '48 Commander big six? PN:525945?
  222. Speedo/Tach/Gauges Gauges Again
  223. Cool/Heat: Aluminum Radiator for 64 Daytona
  224. Rear Axle: Felt washers
  225. Brakes: Has anyone tried this kit?
  226. Transmission: 700r4 won't shift out of low.
  227. Cool/Heat: 1964 Avanti
  228. Body: More Speedster help needed!
  229. Drive Shaft Studebaker Drive Shaft Help Please
  230. Electrical: Avanti Ignition Switch Weirdness
  231. Transmission: Need OD solenpiod upper contact assembly
  232. Steering How hard to add power steering?
  233. Brakes: 1960 Lark VI parking brake arm, rear drum
  234. Engine: paxton sn93 in place of sn60 for avanti r2?
  235. Transmission: Noise in flight-o -matic
  236. Steering Idler arm for 1950 Champion
  237. Steering Installing new bushings in Upper A-Arm
  238. Fuel System: avanti r2 carb identification
  239. Electrical: Dash light wiring
  240. Brakes: Shoe orientation 57 Commander V8
  241. Engine: Avanti R2 engine/steering oil/fluid
  242. Rear Axle: Rear hub removal - just sayin' thanks
  243. Brakes: Brakes coming on when hot?
  244. Engine: Dip stick tube
  245. Electrical: Steering column wires
  246. Engine: Any one using an oil additive called "Power Punch"?
  247. Cool/Heat: Sanden A/C Compressor on 1964 289 - what do I need?
  248. Electrical: Drop in Alternator replacement for Prestolite generator on 1964 289?
  249. Engine: Would synthetic blend oil do this?
  250. Transmission: T10 Speedometer Driven Gear
