View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 [87] 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Engine: Wispy ticking out of 52 Champion
  2. Interior: Is my seat fabric correct?
  3. Front Axle: 50 Commander king pin rebuild
  4. Fuel System: '51 Gas Filler Neck Hose
  5. Wheels rims
  6. Engine: Grommits for the valve cover ( Do I use permatex on grommits to install on valve covers)
  7. Interior: rubber floor mat for 49 2R16
  8. Other: 48 pickup windows
  9. Engine: Vibration Damper puller bolt size?
  10. Brakes: Rear brake bulb number for 64 Lark?
  11. Engine: Oil pickup tube
  12. Interior: Headliner question
  13. Brakes: Stiff Brake Pedal/No Fluid to Rear Cylinders? (Solved)
  14. Brakes: Satisfied Customer With SI's Repro Hydrovac
  15. Engine: One Way Pistons
  16. Drive Shaft Has Anyone Swapped A Two Piece Driveshaft for a Single Shaft?
  17. Speedo/Tach/Gauges Gt Hawk Dash shell color
  18. Brakes: Help with stiff pedal
  19. Body: I need a good picture of the inside of a 1950 taillight
  20. Engine: Vacuum Readings, R2
  21. Engine: 1963 avanti tach erratic
  22. Interior: How to remove horn button on 63 avanti
  23. Body: Dog Dish Hubcaps on the Gran Turismo Series?
  24. Rear Axle: Studebakers West Flanged Axles
  25. Engine: new pistons
  26. Wheels American Racing Torque Thrust II for 1962 GT Hawk
  27. Body: 53 C/K grille paddle mounting
  28. Brakes: brakes/Avanti.....homemade set-up
  29. Rear Axle: 57 Commander rear axle shaft puller
  30. Fuel System: No Fuel Flow
  31. Body: 61 Lark Grill Fit a 60??
  32. Cool/Heat: Radiator Fan
  33. Electrical: These new TINY jump start units
  34. Interior: I need 2 Headliner bow barrel clips
  35. Engine: Slow crank after running...
  36. Front Axle: 1961 Front End Rebuild
  37. Fuel System: Water in Fuel??
  38. Engine: self-rebuild
  39. Fuel System: '55 Commander with Stromberg carburetor
  40. Electrical: 1950 Champion wiring harness
  41. Brakes: Rear brake question (57 Hawk)
  42. Brakes: This Drum fits what?
  43. Cool/Heat: Replacement heater motor
  44. Engine: Fix old engine or build new one? Opinions please
  45. Transmission: Overdrive play
  46. Electrical: Powershift start and backup switches???
  47. Wheels 17 x 7 wheels on my lark
  48. Engine: Placement of the HT leads on the distributor cap help please.
  49. Fuel System: Lark V-8 starts ok, then stalls
  50. Body: Window runs: long turns ???
  51. Electrical: Horn stopped on 1954 Starliner with Power Steering (PS)
  52. Brakes: hot brakes / 64 cruiser
  53. Exhaust Header flange kit for Champion six
  54. Fuel System: Fuel pump with vacuum pump
  55. Exhaust What??!! Harley fishtails??
  56. Electrical: Generator lamp at high RPM's
  57. Engine: Champ motor mounts
  58. Body: 57 Hawk front fenders needed (or advice on mine...)
  59. Engine: oil pan capacity
  60. Body: Need L and R door glass for C Coupe.
  61. Engine: Unusual V8 distributor rotor question
  62. Wheels tire codes
  63. Electrical: AIR Switch Conked Out
  64. Fuel System: Vapor Lock
  65. Engine: My Lark has been on the shelf for over a year
  66. Body: Removal of rocker moldings on '52 Commander.
  67. Interior: Wagonaire rear seat back
  68. Fuel System: Sending unit PN#1540262
  69. Brakes: brakes/Avanti.....homemade set-up
  70. Cool/Heat: Blower motor replacement
  71. Electrical: Lark Dash Lights not working
  72. Engine: Oil pressure resistor
  73. Ignition: 1961 silver hawk delco distributor vacuum advance
  74. Body: Hood Ornament
  75. Engine: Casting stamp
  76. Steering Power Steering seem pretty sloppy???
  77. Engine: Adjustable cam timing gears, last one
  78. Cool/Heat: How much coolant to drain to replace temp sensor
  79. Interior: New seat vs. old seat
  80. Engine: Looking For Parts Champion Six Engine
  81. Engine: darned block plugs wont move:(
  82. Steering 48 Champion Steering Wheel Removal
  83. Electrical: Replacement for Avanti II power antenna
  84. Body: Fuel Door 1962 GT Hawk
  85. Transmission: Flight-O-Matic Down Shifting
  86. Electrical: Stereo for Champ
  87. Body: 50 champion vs 50 commander
  88. Ignition: 350 spark plugs
  89. Front Axle: Did I do damage?
  90. Engine: Identifying 289 V8 ?
  91. Fuel System: Champion flathead six two-barrel intake manifold
  92. Electrical: Turn signal wiring - 54 starliner
  93. Engine: 259 won't start
  94. Rear Axle: 49 stude truck 486 gears ????
  95. Rear Axle: Rear axle interchange
  96. Engine: Need some help with a Champion Flat Head 6 inline.
  97. Exhaust 1955 Champion 6 Cylinder Exhaust Manifold
  98. Fuel System: V-8 Fuel pump item number?
  99. Engine: 289 v8 setup for street and strip ???
  100. Body: rear bumper
  101. Frame/Springs champ frame
  102. Speedo/Tach/Gauges 63 Lark Speedo is frozen
  103. Electrical: Starter HELP!!!
  104. Brakes: 60 Champ brake conversion issue
  105. Other: am/fm radios
  106. Cool/Heat: Stant thermostat number for 1550844 housing
  107. Front Axle: Should I follow suggestion??
  108. Front Axle: front wheel bearings...what's going on?
  109. Body: Which doors will fit on a 1957 Golden Hawk
  110. Fuel System: Fuel filter AC2987 kit
  111. Ignition: Is there a difference between autolite and prestolite distributers
  112. Body: Towing with a classic car
  113. Cool/Heat: radiator leak
  114. Body: Front and Back Windshield Stainless Trim Installation on a Silver Hawk
  115. Body: GT Hawk tail light housing disassembly?
  116. Cool/Heat: Modern Champion Radiator
  117. Transmission: transmission dimensions
  118. Fuel System: 1962 Lark gas cap, vented or non vented
  119. Frame/Springs 62 gt hawk/rear springs
  120. Engine: Finned Valve Cover on Avanti
  121. Cool/Heat: 1955 Speedster climatizer and heater hoses routing schematic-diagram please!!!
  122. Brakes: 1950 Commander Master Cylinder
  123. Steering Looking to rebuild Steering box for 59 4E7 Part # 679250
  124. Body: Hardtop door glass removal (glass from frame)
  125. Other: 1948 Studebaker Commander 4door
  126. Engine: Wix 51050 built in restrictor 1961 289
  127. Engine: Chamfer Cylinders?
  128. Steering Speedster power steering
  129. Fuel System: Return fuel line restrictor fitting on Avanti
  130. Steering Anyone have an opinion on a SlickStreetStuff front suspension for my '53?
  131. Engine: part flow to full flow conversion
  132. Engine: Chaine drive starter
  133. Brakes: 63 Avanti Master Cylinder and Booster Conversion
  134. Transmission: Flight O Matic rear extension housing
  135. Other: rookie questiion
  136. Transmission: 64 Powershift
  137. Ignition: Mallory Distributor from Dave T. trouble.
  138. Body: Broken Bonnet Cable on 1964 Cruiser
  139. Paint: Modern touch up paint to come reasonably close to Concord Blue?
  140. Steering Avanti rack and pinion
  141. Engine: Antifreeze sticker placement
  142. Steering Steering gear 56 Champion
  143. Electrical: Dash Toggle Switches
  144. Drive Shaft 56 Champion 4 dr rear drive shaft
  145. Body: New to the forum...Trying to I.D. correct year of 2R15 Pick-up !?
  146. Brakes: Master cylinder bore size
  147. Engine: finned valley cover
  148. Ignition: Can someone tell me the Delco part number for a Studebaker V8 "window" distributor
  149. Fuel System: Carter Carb wcfb 2214s
  150. Body: Next question: Which Fenders will fit a 57 Golden Hawk?
  151. Other: Is there a parts interchange manual for Studebakers?
  152. Transmission: Need part #520086. OD control governor gear, 15 tooth. Can you help?
  153. Fuel System: Need Stromberg carb.
  154. Engine: chebby bearings in a 289
  155. Engine: Picture Perfect colors
  156. Engine: Removing Camshaft
  157. Transmission: T-86 OD bench test
  158. Engine: 170 stumbles and backfires on acceleration
  159. Brakes: 57 Commander frt shoes
  160. Interior: clear seat covers
  161. Electrical: front chassis wiring harness
  162. Body: C/K front fenders-- fix or replace?
  163. Steering control valve/pitman arm assembly
  164. Interior: SI carpet installation
  165. Engine: Tell me about oil pressure
  166. Cool/Heat: Information on Avanti air-conditioning
  167. Cool/Heat: Freeze Plugs
  168. Transmission: Transmission interchange
  169. Interior: Headliner Bow Question
  170. Engine: How to remove valves
  171. Electrical: Starter trouble. Delco-Remy 1107748 Vs Autolite MDU-7005
  172. Engine: Engine Idle RPMs
  173. Electrical: 63 Avanti Power Windows
  174. Engine: 63 Avanti R2 Fluids/Oil
  175. Transmission: Got me a question with fitment
  176. Body: speedster assembly question
  177. Steering 57 Transtar Steering Box Interchange
  178. Rear Axle: 63 lark Standard up dating rearend
  179. Other: Two Questions.
  180. Clutch/Torque Converter: My clutch may not be working correctly. Any ideas or thoughts are welcome.
  181. Fuel System: Fuel sending unit
  182. Transmission: another speedometer driven gear question.
  183. Engine: Valves
  184. Body: So I am getting to the next step ...... Rust
  185. Steering 1950 Champion steering
  186. Body: 59 box on 54 frame
  187. Transmission: My 52 Champion OD Wont engage. Now what do I do?
  188. Fuel System: Inertia switch
  189. Interior: GT chrome headliner bows into a '53?
  190. Rear Axle: 57 Commander axle bearing
  191. Brakes: 62 gt hawk rear brake drums
  192. Electrical: 63 Avanti windshield wiper switch
  193. Ignition: converting an R-1 dist. to an R-2
  194. Brakes: 57 Commander rear drums
  195. Body: How to line the rear window pocket on Speedster
  196. Transmission: What lube should be used in T86 w/OD
  197. Body: 1957 Golden Hawk hood opening latch
  198. Transmission: o.d. gear stud lark1961
  199. Fuel System: 1957 Commander Gas Problem?
  200. Transmission: second gear problem 3 speed T86 transmission 2R10 truck 1950
  201. Brakes: Warped rotor?
  202. Rear Axle: ford,mopar rear in a 2r5 ??
  203. Ignition: Setting points according to the book?
  204. Transmission: Flluid
  205. Cool/Heat: Coldest AC
  206. Brakes: Rebuild Brake Booster
  207. Paint: This spray on 3M Paint Defender stuff is GREAT!
  208. Electrical: Remote Control Door Lock Ridiculously Easy To Install
  209. Wheels 1964 GT wheel color
  210. Interior: 1966 Cruiser Headliner
  211. Brakes: drum removal
  212. Front Axle: stude 2r5 pickup, 1951
  213. Ignition: Top Dead Center and firing order
  214. Speedo/Tach/Gauges Making An OEM Tach Compatible With Modern Electronics
  215. Transmission: Shifter lever parts missing
  216. Electrical: Tricks for improving positive ground on lights
  217. Engine: Chroming Valve Covers, Cad plating.
  218. Rear Axle: Removing axles
  219. Transmission: Overdrive modification
  220. Engine: V8 Intake manifold gaskets
  221. Electrical: 51 studebaker champion wiring
  222. Body: Locking doors on 57 pickup
  223. Cool/Heat: Heater Control Valve
  224. Ignition: Spacer or no spacer
  225. Other: Replacement antenna for 64-66
  226. Body: Finding my fuel gauge
  227. Steering 2R5, 1951 pickup
  228. Clutch/Torque Converter: converter aligning tool j-6310
  229. Body: SS trim for Avanti windshield molding
  230. Brakes: Parking Brake Cable Rubbing Exhaust Manifold
  231. Brakes: Turner Discs for M5 Pickup -- Anybody done this changeover?
  232. Brakes: Dual master cylinder install with Hydro-vac
  233. Body: Roof - same for 56 2 door sedan vs 62 Lark 2 door sedan?
  234. Other: 1952 Studebaker champion serial number help
  235. Engine: rocker arm
  236. Frame/Springs Camber.
  237. Electrical: Temp gauge pegging
  238. Electrical: Charging system on 63 Lark with prestolite alternator
  239. Other: Locking gas cap tech help
  240. Rear Axle: WTB Complete Dana44 rear w/4.10 or 4.56
  241. Transmission: 1962 Lark - original 3 speed automatic transmission - long delay before engages into gear
  242. Fuel System: 1962 Lark - 259 cub. in. V8 - sluggish accel., stalls after warming up, won't start for an hour
  243. Fuel System: Modfied Needle & seat
  244. Brakes: hand brake question
  245. Electrical: How to install LED lights in Avanti tail lights
  246. Electrical: battery cable size
  247. Brakes: RAD Ideas : Mustang GT and Cobra brake adapter bracket update
  248. Body: Glass window replacement on rear flip out windows of 58 Silver Hawk
  249. Clutch/Torque Converter: I cant get my car to shift in to reverse?
  250. Electrical: Where do I route the back up light switch wiring harness for a 64 Lark HT with 4 speed ?
