View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 [86] 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Electrical: Starter Problem on Champ
  2. Engine: Questions about motor weight and poss. fit
  3. Engine: Avanti r2
  4. Fuel System: Supplemental electric fuel pump for R2 Hawk
  5. Transmission: Later model powershift on a 55 259?
  6. Engine: Engine identification help
  7. Engine: Did the overhead valve six ever come with a full flow oiling system?
  8. Interior: Anyone put 60's era Hawk bucket seats in their 1959 Lark
  9. Engine: Engine head off! Help with oil pump removal.
  10. Steering proper way to align pitman arm on steering gear
  11. Transmission: looking for trans cooler
  12. Engine: Stromberg Aeroquad Carbs
  13. Brakes: 50 Land Cruiser brake cylinders
  14. Electrical: Looking for radio knobs
  15. Engine: lark knock?
  16. Fuel System: aluminum intake for v8
  17. Frame/Springs Frame interchangeability 39-40-41 Champion
  18. Fuel System: Gas Gauge for '57 Golden Hawk
  19. Electrical: Mallory Avanti R2 recurve conversion
  20. Engine: Swapping a Studebaker OHV six into a '52 Champion
  21. Electrical: LED dash light bulbs
  22. Rear Axle: Axle keyway length
  23. Wheels Tires that fit Avanti almost right.
  24. Engine: Head bolt torque
  25. Engine: Head bolts question + followup
  26. Engine: Another leak question
  27. Cool/Heat: 53 Radiator Hoses. HELP
  28. Electrical: 6volt Systems - A vote for keeping them
  29. Exhaust Headers
  30. Engine: Test fitting intake and such
  31. Engine: Adapting a pcv system to a Stude
  32. Engine: More 289 questions
  33. Rear Axle: Grinding noise in rear
  34. Brakes: Who knew?...........not I
  35. Engine: SBC swap into my E7 truck
  36. Frame/Springs Springs and shackles: how do they really work?
  37. Body: Do all of the front bumpers shake?
  38. Fuel System: Rust in gas tank
  39. Cool/Heat: Underseat heater
  40. Fuel System: Gas tank drain plug
  41. Frame/Springs 41 frame
  42. Drive Shaft Rear U-Joint by way of Pinion Seal Replacement 62 GT Hawk
  43. Other: Firewall TAG Numbers
  44. Cool/Heat: Radiator Interchagne
  45. Other: windshield swap
  46. Steering Saginaw power steering question
  47. Engine: engine id help
  48. Speedo/Tach/Gauges 700R Speedo Cable For OEM Stude Speedo
  49. Cool/Heat: Fan shrouds for modified 53/55 C/K
  50. Ignition: 6 cyl. Initially ran like a top but wont start now, ignition problem!
  51. Frame/Springs '37 President Planar suspension spring question
  52. Body: Does anyone reproduce prewar weatherstrip?
  53. Steering 1954 Commander Saganaw Power Steering (PS) hose
  54. Ignition: Bad new condensor for ignition on Avanti
  55. Body: Bulletnose Rocker Panel Trim Installation
  56. Ignition: Pertronix upgraded Delco vs. dual point Prestolite
  57. Electrical: 63 Lark Clock Fuse
  58. Rear Axle: '62 Hawk Pinion Dust Flange
  59. Exhaust Stainless Steel Hardware
  60. Engine: 61 Lark Valve Questions
  61. Steering Trouble removing taper key from steering knuckle!
  62. Interior: 63 Avanti rear 1/4 window latches
  63. Fuel System: Key broke off in locking gas cap. Need your help.
  64. Brakes: Aftermarket Front Discs
  65. Exhaust exhaust '63 hawk
  66. Other: mpg question
  67. Rear Axle: 55 champion
  68. Electrical: Conecting the re-wired wiper-motor...
  69. Fuel System: Correct resistance for Studebaker fuel level gauge
  70. Fuel System: Low fuel pressure to the Carb?
  71. Engine: main pulley bolt
  72. Transmission: aluminum transmission
  73. Speedo/Tach/Gauges '50 Commander Speedometer: How do you lube?
  74. Electrical: '50 Commander: 2 issues--horn and directionals
  75. Frame/Springs coil spring questions
  76. Body: Avanti Upper Body Measurements
  77. Body: Probably need 2 Hawk fenders - advice?
  78. Steering Saginaw Power Steering in 59 Hawk? Good or bad idea?
  79. Exhaust next exhaust question GT Hawk
  80. Exhaust Flathead six exhaust header
  81. Ignition: Distributor Pinch Bolt Size?
  82. Wheels A 3D file of a wheel assembly (perhaps)
  83. Engine: 289 oil pan sealing
  84. Frame/Springs 1950 Commander Lubrication Chart
  85. Body: 67 Avanti Door Seals
  86. Engine: Im building a MONSTER.
  87. Body: Hood Compatability
  88. Engine: Anybody got a AC 3311 oil filter new or used? May 62 ongoing
  89. Steering saginaw steering box
  90. Fuel System: Intermittent Gasoline Leak
  91. Frame/Springs Everyone has an opinion, but..........
  92. Interior: Seat Compatibility
  93. Body: '61 Champ tailgate
  94. Body: welding up holes
  95. Engine: Keystone Stamp
  96. Electrical: Suggestion for brake light
  97. Other: 50 champion restoration/engine transmission swap?
  98. Speedo/Tach/Gauges Source for indicator light covers?
  99. Electrical: Has anybody installed an ELECTRICAL oil pressure gauge in a Studebaker?
  100. Body: PDF Test
  101. Clutch/Torque Converter: Torque Specs
  102. Interior: cat whisker install
  103. Interior: Wagonaire dash moldings
  104. Front Axle: Flipping spindels
  105. Brakes: Proper orientation, does it make a difference?
  106. Body: 1962 Studebaker Hawk GT-How do I open the hood?
  107. Brakes: Same 1962 Hawk
  108. Body: PDF Test II
  109. Other: Things To Do After You Bought That Studebaker
  110. Engine: Spects on 39 engine 6 cylinder oil,points,head tourque and timming
  111. Electrical: Turn Signals - Again
  112. Electrical: Replacing '64 Commander switches with Hawk toggles?
  113. Steering looking 4 saginaw manual steering box/parts 53 champion
  114. Engine: lark engine swap
  115. Fuel System: Gas Gauge for 1976 Avnti 2
  116. Electrical: installing 4-way or hazard flashers
  117. Other: Wiper Conversion: How To convert vacuum to electric with opposable wipers
  118. Paint: Engine Paint
  119. Fuel System: Fuel level sending unit, left or right?
  120. Engine: Timing marks
  121. Body: Has Anyone GT Hawk Torque Boxes From Classi Enterprises?
  122. Fuel System: 63 lark gas tank for 65-66?
  123. Body: Help ID unknown long sill plates SOLVED
  124. Steering Eaton Roller pump rotor direction?
  125. Body: power window regulators?
  126. Interior: Seat Belt Installation
  127. Electrical: 6 volt OD relay source
  128. Exhaust Dual pipe drone
  129. Body: Window and Weatherstrip U Channels
  130. Wheels original Avanti wheel dimensions
  131. Fuel System: Fuel Pressure Regulator
  132. Engine: T Cover Seal Tech
  133. Body: 64 Daytona Hardtop Quarter Window Belt Line Seal - Help Needed
  134. Cool/Heat: Avanti coolant question
  135. Front Axle: Missing spec?
  136. Electrical: Radio keeps cutting out for a half second
  137. Steering Pitman arm alignement
  138. Fuel System: 57 GH Fuel Pressure Question
  139. Cool/Heat: Oil Fill Pipe Removal For Freeze Plug Change
  140. Engine: 232 timing gear cover/1957 259, will it fit?
  141. Body: Avanti rubber
  142. Engine: What ARE the different V8 pushrod lengths?
  143. Transmission: questions 53 starlight with a 64 drive train
  144. Ignition: How do I identify point 1 on distributor cap v8 55 E7?
  145. Cool/Heat: Hawk Lower Hose
  146. Exhaust 289 headers
  147. Body: 83 Avanti II Moonroof
  148. Other: Wind Lace Restoration and RBS Carb Question
  149. Engine: Motor Mounts and Bell Housing Mounts 1962 GT Hawk
  150. Engine: Packard V8 large crankshaft bolt
  151. Engine: R2 crankcase vent leak-it's baaaack!
  152. Engine: Cam vs. Oil Pump
  153. Cool/Heat: Water Pump Copper Washers
  154. Wheels Wheel Cover Concern
  155. Drive Shaft 1925 Standard 6 EU
  156. Exhaust Dreaded drone finally gone.
  157. Fuel System: Leaking fuel
  158. Engine: Engine & gear change mechanism interference on 1057 Silver Hawk, LHC
  159. Body: 53 starlight trim levels
  160. Speedo/Tach/Gauges Speedo pinion
  161. Transmission: Herman Thoms fixed my transmission leak on the phone!
  162. Body: Part # for 57 Hawk turn signals
  163. Other: 41 Commander Rubber
  164. Exhaust Flathead six exhaust header
  165. Transmission: 3 speed overdrive
  166. Engine: Help me get the correct motor mount, please (putting SBC in 57 Hawk)
  167. Body: 1961 Hawk need your help on equipment code.
  168. Interior: 1934 Dictator dash removal HELP
  169. Body: door latch spring
  170. Body: weather stripping
  171. Frame/Springs Lifting a Champ
  172. Engine: How do you know you have R1 heads
  173. Rear Axle: Rambler Dana 44
  174. Engine: 289 valve covers
  175. Interior: Is front carpet standard for '49 Champion Regal Deluxe trim line?
  176. Fuel System: Avanti R2 fuel pump question
  177. Body: Avanti rubber for trade
  178. Steering Power steering fluid leak
  179. Body: How Much does the body weigh on a 57 Silver Hawk?
  180. Engine: V8 pushrod wear theory and practice
  181. Electrical: rewiring 54 starliner
  182. Engine: Stuck Pistons
  183. Electrical: Junction block at Front of Radiator
  184. Body: My Daytona's Floors are going to be replaced
  185. Transmission: OD quit working. Need diagnosis suggestions.
  186. Engine: Did I get hosed with a smile???
  187. Body: A-pillar repair
  188. Body: 63 Avanti seat hold down bolts
  189. Engine: Port Matching Avanti Intake
  190. Engine: Stude engine identification
  191. Body: latch sping follow up
  192. Body: Need a set of trunk hinges and latch for my 57 Golden Hawk
  193. Transmission: DG 200 transmission in 1954 Commander Starliner
  194. Engine: Studebaker 289 valve lash
  195. Interior: radio removal from Avanti with air-conditioning
  196. Electrical: Can you still buy a 6volt regulator at a FLAPS?
  197. Exhaust Left side exhaust manifold & power steering
  198. Rear Axle: Tapered axles
  199. Interior: Dash pad : Vinyl coloring ; problem ??
  200. Interior: Avanti rear courtesy or dome lights
  201. Body: C Body "GT" Project
  202. Frame/Springs Avanti coil springs
  203. Fuel System: Ethanol in Gasoline Article
  204. Engine: How Much Distributor Advance: 289 Hawk
  205. Transmission: floor shifter in 53 champion with 289 flight o matic
  206. Transmission: Help needed to identify Flightomatic
  207. Steering Saginaw gear lube for power steering box
  208. Fuel System: Gas tank needed for 59 lark vi
  209. Clutch/Torque Converter: Excessive Freeplay
  210. Brakes: Need Right Rear Wheel Cylinder for 59 4E7 1/2 ton pickup
  211. Rear Axle: flanged axle with tapered axle brakes?
  212. Frame/Springs 64 Wagonaire 289 auto: need correct length of rear spring schackles
  213. Electrical: Electrical Supply House Information Request
  214. Fuel System: Avanti upper bellcrank bracket position
  215. Engine: Dressing a 259 as a 232 (my money; my car)
  216. Engine: 1934 Dictator 6 engine
  217. Ignition: 63 Avanti Starter or Battery problem
  218. Wheels Radial Tire Size for '49 Champion?
  219. Body: 63 Avanti only Head Lamp Rim
  220. Other: finally pix of my 50 before & after(well almost complete
  221. Body: 1953 c/k doors
  222. Rear Axle: Dana 44 Bearing Noise
  223. Electrical: Fuse panel
  224. Engine: Purpose of rubber tubing?
  225. Body: Packard Hawk fin overlay
  226. Electrical: Wiring gremlins...
  227. Transmission: T 90B Overdrive for truck
  228. Interior: Speedster horn wire
  229. Engine: 1961 289 oil lines
  230. Rear Axle: replace an open carrier with a twin traction?
  231. Interior: Bucket Seats.
  232. Paint: Final Prep.... ?
  233. Steering Need a studebaker mechanic in Central Massachusetts
  234. Engine: pulley for belt wont come off
  235. Clutch/Torque Converter: Clutch adjustment issues - T5 conversion [resolved]
  236. Brakes: 64 convertible master cyl info needed
  237. Wheels Large offset wheels on coupe?
  238. Body: Where does this emblem go?
  239. Brakes: 61 Hawk Master Cylinder Y
  240. Transmission: Flightomatic Transmission Overhaul Blog
  241. Body: 53-54 CK grille shell repair
  242. Other: 61 lark 4 door
  243. Steering Need steering column: 48 Champion or equivalent
  244. Brakes: hard pedal
  245. Transmission: 1961 ohv 6 cyl: Need info on 3 spd tranny vs: 3 spd with OD
  246. Steering Land Cruiser spindle question
  247. Body: Are 63 and 64 Radiator Core supports the same??
  248. Brakes: Possible upgrade of 1948 commander brakes to 1963-64 Champ truck brakes?
  249. Engine: Engine Plugs wont budge!
  250. Engine: Removing Crankshaft
