View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 [85] 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Transmission: Transmission Service
  2. Electrical: Signal Light Question - Flashing Too Fast
  3. Engine: OIl pan paint
  4. Fuel System: I need the air cleaner retainer
  5. Speedo/Tach/Gauges modern gauges in R5 truck???
  6. Engine: 1959 259 from 64 wagonaire into 54 stude hdtp
  7. Interior: Would this radio fit a 64 Avanti?
  8. Body: T-Cab Fender attachment area - replacement
  9. Brakes: Mechanical Brake Light Switch Install
  10. Paint: 1955 Champion
  11. Cool/Heat: Measurement please?
  12. Engine: Piston Ring Fit
  13. Steering Removal of steering box
  14. Engine: Ford 302/AOD into a Lark type?
  15. Electrical: Battery size for 1963 Champ w/289
  16. Engine: I found this crankshaft, how can I identify it?
  17. Fuel System: Leaking Carburetor Bowl
  18. Ignition: AUTOLITE DISTRIBUTOR, 6 CYL Lark
  19. Transmission: Floor shift conversion done and in place
  20. Frame/Springs Need batwing advice
  21. Transmission: Found a transmission guy in Gettysburg
  22. Engine: Pistons
  23. Paint: Wagonaire side trim
  24. Steering Any other columns fit ?
  25. Transmission: Help with logic on OD Solenoid Please
  26. Speedo/Tach/Gauges Clock ideas - replace or convert?
  27. Wheels What width are stock '63 Avanti rims?
  28. Cool/Heat: Ordered new aluminum radiator today...
  29. Frame/Springs 40 champion shock conversion
  30. Fuel System: 54 c/k fuel tank (spring mount)
  31. Body: Headlight rim to body screws-1955 Studebaker Commander Custom 2 Door Sedan
  32. Engine: 10 mpg
  33. Exhaust any aftermarket headers for our engines?
  34. Body: Roof band
  35. Body: Gasket between tail light housing and body - 1954 Commander - should there be one?
  36. Electrical: Voltage reducer for a 6 volt clock on 12 volts - yes or no?
  37. Body: Front inner fender panels-C K body
  38. Body: Class Glass Fiberglass front fenders-Stude C/K
  39. Transmission: t96 overdrive trans
  40. Engine: A question on selling pistons with or without rods
  41. Engine: Lark V8 swap?
  42. Speedo/Tach/Gauges 1950 2R5 Temp Gauge
  43. Front Axle: Tie Rod/Reach Rod
  44. Electrical: Battery Replacement
  45. Fuel System: Edelbrock Carburetor Need Help
  46. Steering Gear Assy
  47. Wheels Powder coating rims? thoughts requested
  48. Steering Avanti Steering box cover
  49. Engine: 1963 289 with auto trans into 1950 Commander?
  50. Interior: 1961 Hawk bucket seat foam
  51. Brakes: No brakes
  52. Body: 55 fan shroud
  53. Engine: Engine Installation
  54. Transmission: no overdrive
  55. Interior: Metallic upholstery in 1959 Silver Hawk - available anywhere?
  56. Electrical: 1956 Champion Starter Motor problem......
  57. Engine: ROD BEARING HELP! and PlasticGuage
  58. Fuel System: Universal In tank fuel pump system
  59. Fuel System: Carter WE diagram?
  60. Brakes: Commander Brake Drums
  61. Steering Santa let me Down.
  62. Engine: 66 Cruiser Engine Identification
  63. Steering Need power steering hose for 57 Golden Hawk
  64. Other: Camshaft Storage
  65. Body: 1963 Gt Hawk quater panel replacement.
  66. Brakes: hanging pedals 50 champion
  67. Transmission: GM Transmission Adapter Kit Issues
  68. Interior: before I seal up the interior...
  69. Interior: 63 GT Hawk interior
  70. Engine: R1 Engine Breather Tube Questions
  71. Engine: Another..for what it's worth
  72. Fuel System: Fuel Tank
  73. Steering Removing the power streering from a 1962 lark V8
  74. Engine: 1950 Commander with automatic engine/transmission removal
  75. Rear Axle: axle bearing noise?
  76. Brakes: Bendix brake booster disk brake sounds?
  77. Fuel System: Need Help With Carb Please
  78. Clutch/Torque Converter: Engine/trans. swap
  79. Brakes: Bendix Brake Booster Repair, Master Cylinder Repair
  80. Rear Axle: Avanti R2 Power shift rear Axle Ratio
  81. Electrical: Headlight switch '63 Hawk Repair
  82. Steering What fits the '53 Champion steering column"
  83. Rear Axle: Dana 44 on Jeeps
  84. Electrical: Cheap volt drop
  85. Interior: Arm Rests
  86. Rear Axle: Swap Flanged Axle internals to tapered axle housing
  87. Interior: Decoding interior trim alphanumerics on production order
  88. Body: Stainless Daytona moldings
  89. Body: Mounting Script - clips?
  90. Brakes: 50 Land Cruiser brake shoes
  91. Wheels American Racing Salt Flat Mag wheels on a Lark
  92. Engine: Avanti Engine in a 63 Daytona Hardtop
  93. Engine: oil pan gasket
  94. Engine: 1955 Champion Engine Rebuild
  95. Body: Hawk top chop
  96. Body: hawk convertible?
  97. Body: 3 D printing
  98. Steering 1955 tie rod
  99. Other: 1952 truck 2R5 rims
  100. Speedo/Tach/Gauges My clock
  101. Electrical: 12 volt blower and wiper motor for 54 Champion?
  102. Cool/Heat: Avanti Radiator Question
  103. Fuel System: what's it called?
  104. Transmission: FOM Transmission rebuild.....WOW!
  105. Transmission: 1952 Champion Gearing?
  106. Fuel System: I think I need a new fuel pump
  107. Other: Question about My original 51' Commander Starlight frame
  108. Other: 1963 avanti r2 purchase
  109. Transmission: Flight - a - Matic slipping
  110. Engine: Ford 239 Flattie in a 51 Starlight?
  111. Electrical: 1963 Gt Hawk Clock
  112. Cool/Heat: Hawk Lower Hose
  113. Engine: 1950s Studebaker V8 blue/green/turquoise engine paint??
  114. Steering 82 Avanti Steering Issues, Fuel Smells, and more
  115. Electrical: Replacing Wiper Switch on '64 GT Hawk
  116. Electrical: Any way to change the source?
  117. Body: 55 Sedan vs. C/K Front Clip Parts Interchange
  118. Engine: V8 Starter Bolts Automatic vs. Stick
  119. Ignition: Missing Parts for Autolite 1GC 4802 distributor for 1950 2R11 truck, looking for vendors
  120. Transmission: 1960 Lark VIII Trans Rebuild?
  121. Engine: R1 Fuel Filter Bowl Empties on Engine Start-up ???
  122. Shocks shock mounting plate
  123. Body: Has anybody used this trim from ebay on Hawk fins?
  124. Electrical: starter solenoid
  125. Other: TECH: Proper Use of Hand Tools
  126. Body: studebaker 2R grille info
  127. Electrical: Dash bulb replacement on a '52 Commander/Land Cruiser clock
  128. Fuel System: Carburetors in New Smyrna FL
  129. Fuel System: Testing '51 champion fuel guage
  130. Brakes: Adding a Hill Holder to a 2R5 Truck
  131. Body: Classic Enterprises GT Torque Box Installation in 53-61
  132. Engine: 1961 silver hawk 289 build
  133. Fuel System: Vapor Lock 62 GT Hawk 289 V8 2bbl Stromberg
  134. Cool/Heat: source for the defrost vent boots that go under dash for the 39 CE
  135. Electrical: Battery - acting strangely
  136. Cool/Heat: Engine running cool?
  137. Fuel System: Carter AFB thottle shaft bushings?
  138. Interior: How to anchor rear pillar grab straps
  139. Cool/Heat: 289 Engine Block Flush
  140. Interior: electric windows
  141. Steering Size of pitman arm nut on Avanti
  142. Frame/Springs Replacement springs on my 1961 Lark VI 6cyl auto. 2 door sedan
  143. Drive Shaft 63 Lark Universal Joint
  144. Shocks Ready for spring
  145. Other: '64 Daytona Trunk Lock
  146. Transmission: Avanti Powershift
  147. Fuel System: 57 Commander fuel lines
  148. Steering Broken steering wheel Hawk
  149. Steering 50 champion tie rod ends
  150. Transmission: How do I route the speedo cable???
  151. Steering 50 champion chassis parts catalog
  152. Exhaust Catalytic converter - please don't jump down my throat
  153. Body: Body Weight
  154. Fuel System: 1957 Hawk 289
  155. Cool/Heat: '64 GT + AC question
  156. Engine: Why is my spark so weak.
  157. Exhaust Heat Riser Position??
  158. Speedo/Tach/Gauges Speedometer gear needed
  159. Interior: '50 clutch and brake pedal pad replacement
  160. Shocks Just bought air shocks on ebay
  161. Body: 51 Tail Light Question
  162. Body: 62 Hawk Trunk Grill
  163. Shocks front shock installation
  164. Wheels Bolt Pattern for 1988 Avanti
  165. Engine: Backfire through carburetor
  166. Frame/Springs GT Hawk Frame Chart / Center Floor Brace Location
  167. Wheels Interchange info needed for '37 President wheels
  168. Shocks front shock lower mount
  169. Body: I have a question and will send a Brand new 59-61 Period correct Voltage regulator To the first Two
  170. Fuel System: Airtex 4227 pumps
  171. Interior: C-Body vs GT Rear Seat
  172. Fuel System: An electron powered fuel pump
  173. Engine: freeze plug or not???
  174. Electrical: Wiper wiring help
  175. Engine: Oil pump gear-to-cover clearance experience ??
  176. Transmission: Rear Transmission Mount
  177. Interior: Explain how this happens?!?!?
  178. Frame/Springs Chassis question
  179. Engine: I've got a leaky (freeze/core) plug
  180. Other: Removing Bolts!
  181. Engine: Rebuild of 1953 Champion 6
  182. Rear Axle: 1959 Lark VIII Regal Rear end questions!
  183. Fuel System: Natural gas conversion?
  184. Engine: 63 V8 valve cover gaskets question
  185. Steering Tie rod end nut removal
  186. Cool/Heat: I need a water pump for a 1935 Dictator
  187. Body: Surface Rust, What's Next
  188. Brakes: It fits (Wilwood)
  189. Exhaust 1967 chevy into 54 studebaker hdtp. drivers side exhaust manifold
  190. Frame/Springs Adding a rear leaf.
  191. Electrical: Alternator bracket
  192. Engine: 1952-1953
  193. Wheels Wheel question?
  194. Paint: Paint adherence problem
  195. Other: Help with Blaunpunkt radio?
  196. Brakes: My master cylinder may be on the way out
  197. Exhaust Welded Exhause Manifolds to fit McKinnons into 60s Studes
  198. Other: What do you think of Life-Time permanent oil filters?
  199. Brakes: Cracked 59 4E7 Drum
  200. Electrical: 55 stude president, can you convert two prong turn signal flasher to a three prong turn signal flash
  201. Interior: Help with Bearing Retainer on Front Seats
  202. Electrical: 1954 commander fog light switch
  203. Rear Axle: Rear axle ratio and model of a 4 door 6 cylinder 1964 Commander
  204. Steering When 65 isn't enough, what do I do?
  205. Cool/Heat: 1954 Defroster Y splitter
  206. Fuel System: low idle rpm setting
  207. Electrical: Maybe Ed Reynolds can answer about 55 turn signal flasher ?
  208. Engine: 52 V8
  209. Electrical: Tail Light pots or reeflectors 1947 Champion
  210. Fuel System: truck will not start
  211. Other: Golden Hawk VIN Decipher
  212. Fuel System: The Daytona Parts universal carburetor
  213. Engine: Engine length
  214. Shocks Shocks again
  215. Brakes: 50 Land Cruiser wheel cylinders
  216. Transmission: I need a floor shifter for a T86 with overdrive
  217. Engine: What is the correct length for the dip stick?
  218. Engine: Adjustable cam drive
  219. Engine: Avanti Freeze Plugs
  220. Cool/Heat: water pump
  221. Steering 1964 wagonaire kingpins
  222. Interior: Studebaker Bus
  223. Body: Missing VIN Plate
  224. Electrical: Adj time 61 Hawk clock
  225. Steering 1954 Saginaw overhaul
  226. Ignition: Stuck ignition switch- new one on me
  227. Wheels Pulling wheel drum
  228. Electrical: 1925 Standard Six Duplex Phaeton headlight bulb replace
  229. Brakes: Front drum to disc conversion on 4E7
  230. Wheels Whats todays equivilent ?
  231. Wheels Wheel Hubcap Question
  232. Engine: Avanti 327 trouble
  233. Ignition: Button beside clutch
  234. Engine: oil change interval on a 200 mile per year car
  235. Engine: Dual carb. Intake
  236. Frame/Springs Replacing 1961 Lark rear springs
  237. Paint: the color "Flamingo"
  238. Brakes: Brake shoe orientation
  239. Clutch/Torque Converter: replacing clutch on truck
  240. Cool/Heat: Heater Valve
  241. Rear Axle: Avanti axles and alternate suspension
  242. Body: 53. 54 sedan or wagon hood wanted (SoCal)
  243. Fuel System: 2bbl to 4bbl
  244. Speedo/Tach/Gauges odometer not working
  245. Cool/Heat: The 62 A/C Project
  246. Other: A 1948 Restomod ?
  247. Rear Axle: Radius rods
  248. Body: 1963 avanti how to install the grille
  249. Engine: Super Charged Fuel Pump
  250. Electrical: Starter Problem on Champ
