View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120
  1. Electrical: 1954 Commander Wiring and Fuse Help Please
  2. Engine: Update on damaged crank threads.
  3. Brakes: Power Brakes
  4. Engine: Oil Pump Cover
  5. Fuel System: 232 Engine - Just Messin'
  6. Fuel System: 61 Lark Fuel Tank Sprung a Leak
  7. Body: How can I restore my serial number tag?
  8. Electrical: Turn signal/brake light/steering issue
  9. Engine: 1949 2R10 Motor and Tranny
  10. Frame/Springs What front end is this?
  11. Speedo/Tach/Gauges Diameter of ammeter 1961 Hawk
  12. Electrical: By the shift linkage on the steering column?
  13. Rear Axle: rear axle info
  14. Speedo/Tach/Gauges Re-facing a 1964 Lark Tachometer
  15. Engine: One more item for your rebuilder checklist
  16. Other: 1953 studebaker champion engine compartment decals
  17. Body: Part Id
  18. Electrical: 53 Champion, distributor wires on outside
  19. Engine: Air Cleaner???
  20. Fuel System: 2 x 1 intake for 6 cylinder
  21. Front Axle: shocks
  22. Front Axle: front shocks
  23. Frame/Springs GT Front Springs
  24. Steering This don't look right
  25. Body: Roto-Lokit
  26. Steering looking for a Saginaw gearbox/column jacket
  27. Steering '51 and '52 vague steering. join in as I sort it outů.
  28. Body: Door won't shut properly
  29. Body: 61 Convertible Window Seals Help
  30. Engine: frost/expansion plugs
  31. Brakes: Brake shoes
  32. Transmission: Tips needed from guys that's been down this road before
  33. Electrical: 1954 Horn Diagram or Pictures anyone?
  34. Front Axle: UGH!!! Pickle Fork????
  35. Electrical: Powermaster Alternator
  36. Cool/Heat: Removing Bezels
  37. Body: transtar hood to 2R?
  38. Frame/Springs Frame replacement
  39. Frame/Springs Torque Boxes
  40. Body: woody conversion
  41. Steering Power steering for my hawk
  42. Other: '51 Motorola radio
  43. Engine: High oil pressure: What is the danger?
  44. Body: Bumpers
  45. Other: Acorn Nut
  46. Other: 53 Studebaker engin decals
  47. Body: 1950 Champion Starlight Windshield
  48. Steering 1950 Champion hubs
  49. Steering '48 Steering gear
  50. Engine: Engine chugs and shakes on cold start
  51. Body: 62 lark hood brace or is it 63?
  52. Body: fender welt?
  53. Body: 1950 C Cab defroster vents flow cold air
  54. Cool/Heat: Did the 1954 Starliner use a heat deflector under the seat?
  55. Wheels Lincoln/Mercury Rims
  56. Shocks Best shocks for extra firm ride on Avanti
  57. Fuel System: Stromberg WW Driveability Issue
  58. Brakes: Master cylinder rod extension
  59. Brakes: Emergency Brake Cable Clips
  60. Brakes: Front E brake cable for GT hawk
  61. Transmission: Popping sound
  62. Engine: intake/exhaust manifold for a 1955 champion 185.6 flat head 6
  63. Cool/Heat: Compressor pulley
  64. Electrical: 1964 Daytona Wagonaire's directional signals stopped working.
  65. Body: '64 Daytona Barrel Clips for Trunk Emblems
  66. Engine: valve guides
  67. Rear Axle: rear axle seals
  68. Engine: offenhauser valve covers
  69. Body: Window problem
  70. Cool/Heat: 58 commander heater hose routing
  71. Electrical: Changing from 6 volt pos ground to 12 volt neg ground.
  72. Frame/Springs Whats this called, does anyone sell them & how is it removed :D
  73. Body: Not using stainless trim around Avanti windshield
  74. Interior: How many headliner bows are in a 55 2door c body
  75. Engine: Oil Pan Removal.
  76. Transmission: putting chevrolet overdrive to studebaker engine
  77. Cool/Heat: Thermostat part number
  78. Electrical: Dash Gauge Readings
  79. Cool/Heat: Radiator cap, not thermostat!!!
  80. Body: Rear fender seams
  81. Brakes: Help me shoot two birds with one stone, thanks!
  82. Transmission: What bell housing should I use? T-5 swap.
  83. Speedo/Tach/Gauges Is there any hope for my clock?
  84. Body: 1957 Provincial station-wagon taillights.
  85. Engine: distributor question
  86. Electrical: What is the amperage of the thermal fuse used in the cigarette lighter of a 1964 Wagonaire?
  87. Electrical: Antenna location on '54 Commander Starliner
  88. Engine: oil pan removal 50 champion starlight
  89. Rear Axle: 50 Champion rear axel swap
  90. Body: 51 2R5 front & rear glass
  91. Front Axle: 50 Champion 4 lug to 5 lug
  92. Ignition: Ignition switch removal
  93. Body: Stainless body trim and upper trim
  94. Engine: Torque?
  95. Body: 57 golden hawk resto update
  96. Electrical: gas tank sender wiring harness needed
  97. Fuel System: 1160XBH10...pad gasoline tank -felt 10"long...mean anything?
  98. Ignition: wiring ballast resistor
  99. Other: Greetings
  100. Transmission: need help with paint color on OD and transmission T96
  101. Fuel System: 2X1 Intake manifolds
  102. Steering 1951 Steering Column Manual VS. Automatic
  103. Engine: Oil pressure loss after warm up
  104. Speedo/Tach/Gauges Cyclops Speedometer Indicator
  105. Engine: 1950 2R5 1/2 Ton - Help a newby out?
  106. Wheels 53 hubcaps
  107. Fuel System: R-1 Carburetor
  108. Brakes: R series truck brake pedal travel
  109. Body: Another engine paint question
  110. Shocks Adjustable front shocks.
  111. Brakes: Help with wheel noise
  112. Engine: Bypass vs full flow
  113. Body: Undercoating
  114. Engine: Valve Setting Question on SIX CYLINDER OHV 170
  115. Engine: detonation chewed a piston top?
  116. Engine: Type of oil and oil filter
  117. Engine: Type of oil and oil filter
  118. Electrical: Changing Buttercup to 12 Volt system
  119. Transmission: 1961 lark 3spd over drive questions
  120. Body: What's it mean to "Nose" a Stude hood?
  121. Steering GM power steering pump
  122. Engine: piston ring check with head off
  123. Body: Die cast trim and emblems
  124. Engine: Rear Engine Mount
  125. Other: Santa brought me a Champ, now I need help with it.
  126. Electrical: Jump Starting : Alternator and Generator
  127. Ignition: 6volt pos grd distributer
  128. Brakes: You may not know:-)
  129. Brakes: Jim Turners contact info.
  130. Fuel System: 57 Commander...Stromberg WW6-117
  131. Body: Wiper arm identification?
  132. Body: Door latch rattles and floor creaks...
  133. Electrical: starter won't budge 40 Champion
  134. Brakes: Studebaker disk brake pads........
  135. Cool/Heat: Compressor Brands
  136. Body: Door seal replacement
  137. Fuel System: The more I cleaned on that Carter the more attractive a 1406 looked
  138. Engine: Crankshaft end play
  139. Fuel System: 1964 Avanti R2 Fuel Filter
  140. Steering Santa let me Down.
  141. Frame/Springs Frame Rust
  142. Electrical: '54 Commander - How do the start switch and solenoid work?
  143. Engine: 170 OHV Cams
  144. Wheels What wheels fit a 63 Lark?
  145. Engine: Oil Change
  146. Engine: Locking washer for Harmonic Balancer bolt
  147. Fuel System: 61 Lark Choke to Manifold Connection
  148. Electrical: Paging Bud.......radio question
  149. Transmission: 1965/66 Chevybaker Bellhousing, OD T86 and Batwing for sale?
  150. Engine: TIP: Which way does crank rotate: Check water pump fan!
  151. Transmission: 1962 Lark transmission options
  152. Electrical: 1962 Lark radio
  153. Electrical: Wireing harness replacemaent
  154. Fuel System: fuel pump rebuild
  155. Engine: 1950 2R engine swap
  156. Body: Distance between Lark firewall mounts and Champ frame
  157. Transmission: Professional rebuild !!!
  158. Ignition: Delco Window Distributor Advance Plate
  159. Body: Springs for fuel filler door?
  160. Cool/Heat: Radiators
  161. Transmission: 4-speed transmission for 230 ci Chevrolet Six
  162. Speedo/Tach/Gauges speedometer cable
  163. Electrical: '54 Starliner Dome Light - Source, Pics, Info, Anyone?
  164. Body: Rear fender removal 1965 commander
  165. Body: Box Restoration
  166. Transmission: color of trans oil
  167. Steering Column Electric Power Steering (EPS) for my Hawk?
  168. Brakes: Excessive???
  169. Wheels Redundant, yes...necessary, absolutely!!! HELP!!!
  170. Engine: engine over heating
  171. Engine: Hydrostatic cooling fan drive
  172. Front Axle: When will I know?
  173. Interior: Calling all artistically inclined
  174. Steering Power Steering Control Valve-hose positions
  175. Body: Windshield question
  176. Engine: 1962 289 Gasket Set
  177. Ignition: Tuning, timing and carburation
  178. Cool/Heat: Evaporator Bezels
  179. Transmission: Changing to overdrive Transmission
  180. Brakes: 1952 brake drums needed
  181. Interior: Adjusting wire
  182. Steering Still there (front end alignment)
  183. Brakes: 50 land cruiser to champion brake swap
  184. Transmission: 52 hard top.
  185. Brakes: Revival of a 1949 2R5 Truck
  186. Steering 62 gt hawk power steering pump
  187. Electrical: 57 Silver Hawk wiring help
  188. Body: Stratoline vs. Stratoview
  189. Steering Pre 57 steering wheel adapters.
  190. Other: New Beginnings for '51 Champion
  191. Body: Daytona floor pans
  192. Interior: Seat belts for a CHAMP
  193. Brakes: Checking brake fluid level - What's your method?
  194. Fuel System: rubber fuel filler hose
  195. Front Axle: Front wheel play 52 commander.
  196. Transmission: Where can i get schematics for flightomatic?
  197. Transmission: Colum Standard shift linckage adjusting gauge?
  198. Brakes: '66 flanged axle drums???
  199. Body: Needed: Dash Molding (left end piece) for '53 Commander
  200. Electrical: Is my generator going?
  201. Brakes: Snapped Wheel Cylinder Bleeder
  202. Electrical: Bad Solenoid or Key Switch?
  203. Electrical: They are now naked, but how do I dress them?
  204. Interior: Colour of the carpet of a 1947 Champion Regal Deluxe
  205. Engine: v8 engine ID#
  206. Fuel System: Gas tank float question...
  207. Engine: Rebuild time, suggestions needed for better R-1 economy
  208. Brakes: Will the experts please sign, er, I mean weigh in :-)
  209. Engine: 259 valve oil seal ?
  210. Brakes: rear drum removal
  211. Body: responses on 57 hawk roof
  212. Engine: R1 camshaft has smaller lobes than the one in my golden hawk
  213. Transmission: Borg Warner T-10/rear axle ident. for 62 gt hawk
  214. Body: Avanti body
  215. Ignition: What can I expect for MPG on my Speedster ?
  216. Body: 57 hawk roof
  217. Interior: Studebaker International windlace - does it have the extra width already added?
  218. Fuel System: throttle hesitation
  219. Paint: Rust Converter
  220. Engine: kxet 49 champion oil leaks.
  221. Frame/Springs Who is doing these conversions?
  222. Engine: PCV Valve
  223. Engine: Yet another question to ask your engine builder
  224. Transmission: Powershift and 1st gear start...?
  225. Interior: Molded rubber flooring - DIY?
  226. Ignition: Studebaker distributor and Oldsmobile distributor
  227. Body: '56 Hawk door striker
  228. Engine: Pulley hub installation
  229. Body: Does part #303041 fit a 63 gt hawk
  230. Exhaust Heat riser valve stuck: any easy ways to free it up?
  231. Speedo/Tach/Gauges Avanti gauges
  232. Body: 1964 challenger 2 door rocker help needed
  233. Transmission: Shift Indicator dial
  234. Body: Power Windows in my Hawk
  235. Drive Shaft Drive shaft support bearing number...? ++ followup
  236. Cool/Heat: Good outlet for replacement radiator?
  237. Body: Power Trunk Release in my Hawk
  238. Brakes: No Brake Lights
  239. Electrical: Block of wires on radiator fan shroud
  240. Engine: Cloverleaf engine
  241. Engine: 351 Windsor VS. 331 hemi
  242. Other: Vent Window Pivot Repair - Any Ideas?
  243. Fuel System: Carter carb vacuum fittings
  244. Body: Templates for GT brake reservoir and A/C
  245. Engine: Oil Pump Body question
  246. Body: Door keys
  247. Interior: carpet
  248. Brakes: new shop equipment
  249. Ignition: Tach and Delco distributor
  250. Engine: 259 to 289 conversion
