View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. Fuel System: AC 4142 fuel pump inlet/outlet valve question
  2. Engine: couple radiator questions
  3. Electrical: Auto-tune (wonderbar) radio
  4. Engine: Engine numbers...what do I have
  5. Ignition: No spark after changing coil,points,condenser,ballast resistor
  6. Fuel System: Gasoline in tank for winter storage
  7. Electrical: Windshield Wiper for C/K
  8. Engine: Cast Iron Repairs
  9. Transmission: Ford AOD behind Studebaker V8?
  10. Transmission: Delay
  11. Other: Progress on Buttercup
  12. Engine: Stromberg WW - Odd problem
  13. Transmission: 1951 Champion Gear Ratio
  14. Electrical: Door interior light switch gasket?
  15. Clutch/Torque Converter: question about a stock 4 spd shifter shaft on a hurst shifter
  16. Fuel System: Carter WE 661S Carb
  17. Electrical: wipers and switch
  18. Electrical: Dome light
  19. Exhaust change in exhaust pipe size
  20. Electrical: How to test a wiper motor....
  21. Steering Box Lubrication
  22. Ignition: Idle Madness
  23. Engine: 62 Lark 289 engine in a 57 Silver Hawk 289
  24. Body: Avanti Manual Windows
  25. Ignition: delco dual point settings
  26. Rear Axle: Homemade case spreader
  27. Other: Air Conditioning
  28. Engine: Bolt snapped off in engine block?
  29. Ignition: Vacuum Advance (Vacuum control)
  30. Wheels Need cheap tires for '47 m15
  31. Electrical: Studebaker wont start!!!!
  32. Transmission: Governor
  33. Engine: R1 Differences ?
  34. Frame/Springs QA 1 coil overs
  35. Brakes: Dual master cylinder
  36. Brakes: After forty four years...........
  37. Body: Hood release cable repair
  38. Frame/Springs ....... and decent running 289 from..... (movie)
  39. Fuel System: air and fuel too lean?
  40. Brakes: Tired of pumping the brake pedal on my Land Cruiser
  41. Wheels Please help with rim problem...
  42. Cool/Heat: One thing in common with flathead Fords...
  43. Rear Axle: Changing ratios in a tt
  44. Transmission: Switch back to 53 tranny?
  45. Body: Has anyone ever put a 47-49 champion front end on a 1950 champion frame?
  46. Body: Window Channel
  47. Transmission: Champ 3-Speed Trans
  48. Transmission: Gearbox not shifting
  49. Electrical: Help with Avanti II
  50. Brakes: lining
  51. Brakes: Sinister Threads
  52. Front Axle: 50 Champion steering link concern
  53. Electrical: 32 volt fuse
  54. Engine: Oil Leaking from the thermostat housing
  55. Electrical: Instument lights
  56. Engine: Excellent running 1951Sudebaker 6cyl engine-bellhousing and transmission.Complete carb to trans.
  57. Brakes: Wheel cylinder help
  58. Brakes: Power brake booster/dual master cylinder conversion on Lark types?
  59. Engine: 1963 259 studebaker engine - Good deal?
  60. Brakes: Storing wheel cylinders?
  61. Fuel System: stomberg vs weber
  62. Rear Axle: Two into one...
  63. Steering Steering wheel removal?
  64. Engine: 1950 Champion engine swap: 169 to 185?
  65. Clutch/Torque Converter: 1962 Lark sd 170 with a 3 on the tree
  66. Ignition: Correct Dwell for Prestolite Dual Point R2?
  67. Frame/Springs Trailer hitches
  68. Fuel System: Tired of Being "Gassed"
  69. Engine: Oil Drips for a 61 Lark 6 cyl OHV
  70. Brakes: 53 chassis parts interchange to a 48?
  71. Speedo/Tach/Gauges Replacement Tachometer
  72. Wheels Should I buy these Wheels and tires?
  73. Brakes: Hub Hubub!
  74. Electrical: 6v - 12v
  75. Brakes: Still good to use?
  76. Brakes: Do not like
  77. Engine: 62 Hawk Oil Pan Gasket
  78. Engine: more power OHV 6
  79. Brakes: Brake Fluid
  80. Electrical: light problem
  81. Electrical: Fuel Gage pegs
  82. Body: Small parts needed for 53 hood
  83. Electrical: Lark won't start, just rapid clicking
  84. Engine: crankshaft
  85. Engine: Intake Manifold Gasket installation
  86. Electrical: Partial 6/12 volt conversion
  87. Cool/Heat: Deep neck radiator cap
  88. Interior: c-body 3 point seat belts (new photos)
  89. Paint: Base/clearcoat question
  90. Wheels Eibach wheel spacers
  91. Interior: Hog Ring Pliers
  92. Transmission: O/D slow to DISengage
  93. Fuel System: Fuel Pressure and Vapor Lock Solution. 57 Goldie
  94. Drive Shaft Dash Pot
  95. Speedo/Tach/Gauges Speedo repair
  96. Transmission: Vibration at 30 MPH.
  97. Engine: Is this a 289?
  98. Engine: My 52 champ what would you do? rebuild or not?
  99. Body: Just a test
  100. Engine: crankshaft rear seal
  101. Body: hood opener on 65 Commander
  102. Engine: Advice on oil pump- Helical or straight gears
  103. Fuel System: 1962 lark Parts hunting
  104. Engine: 280 Engine Problems
  105. Engine: Studebaker racing engine for sale on eBay
  106. Frame/Springs rear spring bushings
  107. Steering painting steering wheels
  108. Wheels What rims can I use on a 58 Transtar 3/4th ton?
  109. Electrical: Radio cuts out when power window activated...
  110. Other: Will these hinges fit?
  111. Fuel System: Tank Removal on 57 Hawk
  112. Brakes: Need parking brake parts for 57 hawk.
  113. Steering Hawk Steering redo - clean sheet solution?
  114. Shocks Type of shocks absorbers used on the President models 1929 to 1933
  115. Engine: 63 Avanti enhancements - estimated hp??
  116. Engine: Starter-Ring Gear-Flywheel interface
  117. Cool/Heat: engine casting plugs
  118. Electrical: best horns?
  119. Transmission: OD solenoid direction of operation
  120. Body: Hood Prop retainer Clip?
  121. Engine: Temperature sending unit
  122. Interior: 1961 Lark Interior
  123. Transmission: Oil for a T-86 with over drive
  124. Cool/Heat: Anyone have pics of A/C pulley assembly?
  125. Body: My stainless fender trim.
  126. Cool/Heat: 55 vs 63 Avanti water manifold
  127. Wheels 2R5, 1951 pickup
  128. Body: 1957 Golden Hawk Side Grille Assembly (inlets) needed
  129. Wheels 1947 M15A...who mounts their own tires?
  130. Frame/Springs remove bracket when installing batwing?
  131. Brakes: Hill Holder
  132. Paint: 55 Coraltone
  133. Transmission: T86 Won't go into 3rd gear
  134. Engine: Weight of a 259 V8?
  135. Frame/Springs Champion springs under a 259
  136. Transmission: Overdrive question
  137. Interior: Dash pad overlay.
  138. Frame/Springs Rear sway bar
  139. Engine: Oil spill / spray problems
  140. Transmission: in and of overdrive
  141. Cool/Heat: Radiator and water pump
  142. Transmission: Changing from 2 wire OD Sol 6v To 3 wire 12v
  143. Electrical: Color of tach sender wire?
  144. Brakes: brake drum specifications
  145. Drive Shaft Bushing at end of FOM tailshaft?
  146. Other: Help naming parts?
  147. Wheels What tires are the best for my 1958 Champion Sedan?
  148. Other: old STP any good?
  149. Fuel System: 50 fuel tank drip
  150. Electrical: Charge Light for One-Wire Alternator
  151. Engine: Timing cover seal- YES AGAIN
  152. Brakes: Is it feasible to install a swinging brake pedal on a 1959-60 Lark type?
  153. Paint: Engine paint plan
  154. Engine: Offenhauser 1190
  155. Clutch/Torque Converter: Losing clutch adjustment - '64 Commander
  156. Wheels Spare tire mount for truck
  157. Electrical: At least she made it work this morning
  158. Engine: Oil Pressure Relief Valve Setting
  159. Transmission: Shifter collar 1550901P
  160. Body: barrel clip-to-emblem install or reverse
  161. Rear Axle: Dana 44 Pinion Depth Adjustment
  162. Rear Axle: Dana 44 Gear lube capacity
  163. Ignition: Play in the distributor cam?
  164. Brakes: Master Cylinder Rod
  165. Frame/Springs best method of swapping front springs
  166. Steering To '52 ragtop here: maybe you can come up with an Astro van Saginaw PS conversion?
  167. Electrical: Delco Window-type Distributor Cap
  168. Frame/Springs shackle/rear spring bushings
  169. Cool/Heat: What's this for?
  170. Interior: I'm going to try to rebuild my dash pad for my 62 Lark
  171. Body: Anyone know what these are for?
  172. Electrical: Headlight switch positions
  173. Body: Need some posting picture help!~
  174. Brakes: Rivets???
  175. Transmission: Transmission change
  176. Engine: Studebaker Champion 1953
  177. Engine: 1953 Studebaker Champion
  178. Cool/Heat: Under or overdrive on water pump
  179. Brakes: Do you find the same?
  180. Steering Steering column blues...
  181. Cool/Heat: Radiator...
  182. Electrical: Slow Starter????
  183. Fuel System: Who is using what to seal gas tank?
  184. Brakes: 1947 Champion Emergency Brake rear Cable
  185. Other: hypothetical/practical restoration order
  186. Brakes: Brake Pad
  187. Ignition: Distributor setting
  188. Engine: For the what it's worth column...
  189. Rear Axle: Part ID help request CANCELLED
  190. Paint: Repairing the Lark's rusted battery tray
  191. Engine: 6 cyl intake manifold
  192. Ignition: Question about 51 champion distributor's octane selector and ground wire
  193. Electrical: Need all Light fixtures for 1959 1/2 ton pickup E7
  194. Steering Steering Wheel Adapter Needed
  195. Electrical: head light adjustment
  196. Wheels What is the backspacing you have used on a 60/61 Lark?
  197. Electrical: Alternator Upgrade on R1 Avanti with Air Conditioning?
  198. Fuel System: changing 2bbl to 4bbl carb
  199. Electrical: 53 commander radio
  200. Steering Steering column confusion....
  201. Brakes: Anyone have Turner Disks on a '63/'64 Champ 1/2 ton?
  202. Interior: Weatherstrip at front edge of front doors
  203. Engine: Supercharger oil drain Location
  204. Electrical: Where does the tach wire pass through the firewall?
  205. Steering Power Steering; rebuild
  206. Steering 1965 commander suspension
  207. Engine: Confused about Engine serial number vs Identification plate
  208. Electrical: Melting wires, smoke signals, Avanti
  209. Body: 1948 Land Cruiser
  210. Body: 63 champ floor boards
  211. Steering Anyone put 63 lark Power Steering in a 55 CK?
  212. Body: need pic of trunk lid weatherstrip
  213. Other: Need '35 Dictator vacuum wiper motor assembly
  214. Rear Axle: Rear Hub Wobble
  215. Transmission: Od transsmision
  216. Transmission: Install order
  217. Wheels Avanti II Alloy Rims
  218. Other: Cutting Torch
  219. Cool/Heat: Drip tray gasket?
  220. Engine: Problems carrying vehicles (ignition settings)
  221. Speedo/Tach/Gauges Directional signal indicators on dash ('53 Commander)
  222. Brakes: J-2979 wheel bearing nut wrench
  223. Body: Grill surround on ebay for GT
  224. Shocks moog tie rod ends
  225. Engine: Oil Leaking Into Crank Pulley
  226. Electrical: neutral switch wiring
  227. Engine: Studebaker Avanti Race Engine (New)
  228. Body: Gravel Guards
  229. Rear Axle: 53 Rear end
  230. Brakes: brakes and drums
  231. Fuel System: Stromberg EX-23: Sticky choke valve
  232. Engine: isolater mounts
  233. Steering I went Astro for the Speedster
  234. Body: 1959 c cab toe boards
  235. Frame/Springs Heidts cross-member kit?
  236. Engine: Oil bath filter material
  237. Ignition: 1951 2R5 Starting problem
  238. Engine: 62 lark 6 cyl crank case breather tube question.
  239. Brakes: Method of putting a new stud in a used brake drum.
  240. Body: Rubber running board cover rejuvenation?
  241. Brakes: Educational article on brake fluid from Hemmings
  242. Front Axle: Front suspension design
  243. Brakes: They look beautiful!
  244. Engine: Coolant Chambers in the 170 Champion
  245. Speedo/Tach/Gauges Ford-Chrysler or GM Electric Fuel Gauge
  246. Body: 1963 Avanti, how to remove stainless B pillar exterior trim?
  247. Speedo/Tach/Gauges Instrument Cluster Removal
  248. Drive Shaft 1957 Studebaker Hawk drive shaft issue
  249. Interior: Air vents on 56 Power Hawk
  250. Frame/Springs cutting rear spring bushing inner sleeves...
