View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Electrical: Starter question
  2. Paint: door sill weatherstripping question
  3. Electrical: Connector needed for temp. sending unit
  4. Engine: Need Advice and/or opinions on stuck valves
  5. Engine: Changes between years for 289 engine
  6. Engine: 289 Air Filter
  7. Body: replacing firewall boot for brake pedal
  8. Electrical: Turn signals ceased working 62 Hawk
  9. Fuel System: Carb kit number
  10. Cool/Heat: A/C system
  11. Electrical: Turn signals
  12. Electrical: Hesitation -- better but not quite perfect
  13. Brakes: Parking Brake
  14. Paint: Paint code for 1950 Commander
  15. Steering 63 vs 64 Hawk Power Steering Hoses
  16. Electrical: electrical problem, melted a terminal
  17. Engine: List of bolts
  18. Brakes: Master Cylinder Brake Fluid Sensor
  19. Engine: Any advice on fixing my 57 Golden Hawk
  20. Transmission: 1962 Hawk GT auto trans won't hold in PARK
  21. Interior: Window regulator assembly lubrication?
  22. Interior: 1964 Wagonaire
  23. Electrical: 50 Commander generator adjustment arm
  24. Body: Lower front window run - felt replacement
  25. Frame/Springs Removing Front Springs
  26. Fuel System: Airtex 6 volt fuel pump {reviews}/ alternative manufacturers
  27. Clutch/Torque Converter: Using a standard transmission in an M series with V-8
  28. Engine: Tune up assistance, and suggested replacement parts.
  29. Fuel System: Gas tank sealer remover?
  30. Frame/Springs Mystery Shocks - 50 Commander Coupe
  31. Steering Power steering for a '52 Land Cruiser??
  32. Transmission: automatic transmission conversion
  33. Brakes: Banging Sound
  34. Engine: Restored Stude ran... won't now!
  35. Transmission: 4L60E Tranny In A V8 Stude?
  36. Body: Looking for a doors on technique tool to clean front door channel
  37. Wheels studebaker hawk wheel covers
  38. Electrical: Where's the turn-signal stuff on the diagram for -55???
  39. Rear Axle: What rear came on a 52 Commander Hardtop?
  40. Steering How many rollers in 53 Stude steering worm gear?
  41. Rear Axle: Track--'49 Champion convertible
  42. Steering What other steering wheels fit Studebaker?
  43. Ignition: distributor
  44. Transmission: Is It Ok To Hold Second Until 40 By Choice
  45. Brakes: Need brake components...quick!
  46. Brakes: Parking Brake Cables for a 64 Daytona convertible
  47. Electrical: Brake and Directional Lights no workey on 62 GT
  48. Brakes: What Master Cylinder will work with turner disc kit
  49. Brakes: disk brake items
  50. Body: Need Chrome Trim 1937 Studebaker Sedan
  51. Other: Recent Questions with Good Answers never acknowledged!
  52. Engine: Detailing an engine compartment for 1958 GH and 1964 259 Wagonaire
  53. Electrical: Back in trouble again "electrical issues"
  54. Cool/Heat: under seat !
  55. Interior: Removing Door Trim Panels
  56. Wheels Zip Van Wheels
  57. Fuel System: Idle tubes
  58. Engine: Nels Bove's email address
  59. Speedo/Tach/Gauges Super Lark Tachometer Location
  60. Ignition: No Keys
  61. Wheels Wheel ID and tire dating
  62. Wheels Wheel stud direction?
  63. Fuel System: Supercharged 1957 Golden Hawk Fuel Pump woes
  64. Steering Worn Threads in A- Frames Revisted
  65. Engine: Rocker Arms, new vs old
  66. Other: Hidden Antenna
  67. Engine: 52 Commander ?
  68. Engine: Will the finned aluminum head for the 170 ever make a comeback?
  69. Engine: oil breather cap
  70. Brakes: Brake cyl corrosion
  71. Brakes: Turner Brake email address
  72. Engine: Edelbrock Car
  73. Body: Hawk Hood Installation
  74. Ignition: pertronics ign system /hot
  75. Electrical: Question on 1947 Champion Radio
  76. Rear Axle: 2R5 rear end confusion
  77. Ignition: Here is a weird one.
  78. Electrical: No load flashers for LED bulbs?
  79. Electrical: My Shorts !!
  80. Other: Heavy grease
  81. Engine: 57 Hawk 289 Oil pressure drops after it runs for awhile
  82. Body: Suggested Lube for trunk hinges
  83. Ignition: coil mounted condenser 6 volt 55 V8 259
  84. Other: The windshield wipers are finally working but...
  85. Electrical: Avanti Slow Cranking
  86. Body: Lark Wagon & Convertible Front Support
  87. Body: 61 Hawk fin molding and trim mounting
  88. Electrical: 57 Commander tail lamps
  89. Engine: Paper filter to fit 55 V8 4 barrel oil bath air cleaner?
  90. Transmission: Transmission Cooler for Flightomatics
  91. Exhaust Do the R1/R2 Headers fit both LHD & RHD
  92. Body: 1953-54 Bumper same C/K vs. Sedans??
  93. Wheels 5E12 original tire size
  94. Speedo/Tach/Gauges Speedo Pinion selection with 205 X 15 tires....
  95. Ignition: What the heck is this?
  96. Brakes: 64 hawk front calipers
  97. Brakes: Diameter of bleeder ball in disc brake caliper?
  98. Steering Torque spec.
  99. Ignition: H14Y Spark Plugs
  100. Cool/Heat: Avanti new radiator
  101. Interior: Champion vs Commander Clocks
  102. Engine: 4 barrel intake for ??????
  103. Electrical: Any tips?
  104. Fuel System: Question about a 1962 WCFB carb
  105. Frame/Springs Early Lark Frame Dimensions
  106. Transmission: Need help with transmission leak/gusher
  107. Engine: Oil and Valve Cover Gaskets
  108. Body: Bondo and Politics
  109. Fuel System: Choke adjustment
  110. Brakes: Speaking of Parking/Emergency Brakes
  111. Body: CE fender patch....
  112. Fuel System: Installing a manual choke cable
  113. Rear Axle: rear axle question
  114. Transmission: DG-200 leaks badly after sitting
  115. Body: I need chrome
  116. Electrical: 64 Cruiser V-8 electrical problem
  117. Transmission: Reverse lock out
  118. Brakes: Floor-mounted brake pedal to suspended?
  119. Fuel System: What is this?
  120. Steering size of steering box output shaft
  121. Brakes: Hanging brake pedal question
  122. Cool/Heat: GT Hawk A/C receiver drier replacement
  123. Fuel System: Lesson learned .... check your fuel lines often
  124. Steering power steering ram/cylinder mounting to frame measurement
  125. Frame/Springs How many blades?
  126. Electrical: 1974 Avanti Wiring Harness
  127. Body: Need some help identifying this stuff.
  128. Electrical: Studebaker 6 volt V8 Starter Bendix Nose Differences
  129. Interior: 64 interior
  130. Body: classic floor pan instal
  131. Clutch/Torque Converter: 1961 Studebaker Champion Pickup Flywheel Ring Gear???
  132. Engine: New Carb
  133. Body: 55 CK hood
  134. Cool/Heat: Radiator Neck
  135. Engine: Why 2 Oil Fillers?
  136. Transmission: Fluid Leak
  137. Body: Window won't roll up all the way
  138. Body: Manual window regulator needed - Driver's door '63 Avanti
  139. Engine: supercharger belt installation
  140. Engine: Changing Valve Springs for PSMCDR
  141. Exhaust 63 Avanti 4 1/4 Exhaust with 700R4 Trans?
  142. Cool/Heat: GT Hawk Radiator Hoses
  143. Rear Axle: Dana 44 3.07 gears
  144. Engine: Intake Manifold Gaskets
  145. Engine: Oil Cap pops off
  146. Rear Axle: Need Help on Fluid Types
  147. Transmission: 700R4 "one wire" convertor lock-up (understanding)
  148. Engine: Stock Valve Spring Pressure?
  149. Body: 64 Cruiser
  150. Engine: Overhaul or Rebuild
  151. Body: Bumper sticker
  152. Other: Speedster tires
  153. Body: Throw away paint guns
  154. Brakes: Hill Holder
  155. Steering 60 Lark Power Steering
  156. Clutch/Torque Converter: Clutch questions
  157. Transmission: Trying to ID Packard Transmission
  158. Body: Fender Mount Bolts
  159. Transmission: 5E12 T-10 swap
  160. Exhaust Best valve cover gaskets? Interchange with Chevy?
  161. Engine: Pancake or Coffee Can????
  162. Electrical: Faulty dimmer, or faulty connection?
  163. Body: Does anyone have a 55 body manual ,and can check a part number?
  164. Electrical: Generator question
  165. Rear Axle: Rear end question for '51
  166. Ignition: Tune up specs
  167. Fuel System: Three fuel pumps PROGRESS UPDATE
  168. Brakes: Parking brake handle spring, 1947 Studebaker Champion
  169. Electrical: Starter drive question
  170. Brakes: pickup change
  171. Electrical: Head light switch
  172. Engine: Freeze plug depth
  173. Steering Avanti pitman arm
  174. Brakes: Looking For Front Brake Drums
  175. Steering Need 64 Hawk PS Pressure and Return Hose Routing Picture!
  176. Engine: mounting V8 on engine stand
  177. Body: Repairing kinked hood corners
  178. Electrical: Avanti window angst - over!
  179. Rear Axle: Dana 44
  180. Body: Replaced trunk seal track
  181. Body: East coast bumper plater
  182. Transmission: LEAK - Gear Selector Shaft HELP
  183. Body: Windshield needed for CK
  184. Engine: Is this the oil pressure relief valve?
  185. Body: 1959 scotsman hood emblem for pickup
  186. Electrical: 62 Hawk turn signals
  187. Steering 2R5, 1951 pickup
  188. Fuel System: Carburetor or timing
  189. Transmission: Overdrive article
  190. Steering Steering gear lube?
  191. Other: 60 viewing tech forum, 68 viewing general forum
  192. Rear Axle: Off road truck use
  193. Steering Ball joints
  194. Transmission: Stude 4x4s
  195. Ignition: '63 Hawk Distributor swap to convert to electronic
  196. Brakes: wagner lockheed part # FC-4073
  197. Brakes: Double flare tool and tubing bender
  198. Engine: Six Cylinder Noises
  199. Speedo/Tach/Gauges Speedometer screw?
  200. Rear Axle: Dana 44 TT stop blocks
  201. Engine: engine cleaning
  202. Fuel System: What Is The Throttle Return Check (Dash Pot) I Don't Have One
  203. Speedo/Tach/Gauges In-dash Tachometer
  204. Shocks Plainar suspension Houdaile front shocks 1948????
  205. Transmission: lubricant for 63 Avanti 4 speed?
  206. Body: Installing trunk rubber seal on a 61 Lark
  207. Electrical: Radio/Electrical Question
  208. Clutch/Torque Converter: Emptying the converter...
  209. Engine: Rebuild
  210. Steering Steering gear coupling
  211. Electrical: 8V battery in an M-5 won't stay charged
  212. Engine: Major Problem
  213. Wheels wire wheels
  214. Speedo/Tach/Gauges replacements for S/W gauges.
  215. Electrical: Dome Light
  216. Steering Remove steering wheel
  217. Engine: Where is the temp sending unit on 60's 289?
  218. Paint: When to weatherstrip
  219. Transmission: Reverse Lockout for Hurst Competition Plus Shifter
  220. Electrical: Where is the power lead for the radio on a 64 six harness?
  221. Steering Steering Gear Lubricant
  222. Body: 1978 Avanti Rear quarter window seals
  223. Transmission: A slight leak
  224. Ignition: pertronix ll on Avanti 63 - r1
  225. Fuel System: Good deal on a Edelbrock 1403
  226. Transmission: Need info on 3 speed transmission
  227. Fuel System: throttle bellcrank sticks.
  228. Cool/Heat: What are the "low" and "high" impedances for temperature sender 1545220?
  229. Body: 57 Golden Hawk fenders
  230. Ignition: starter options
  231. Wheels studebaker wheel interchange
  232. Transmission: T86 Front transmission seal
  233. Wheels Correct wheel/rim paint color -'64 Commander
  234. Engine: 6cyl flat head or 63 orginaly
  235. Body: 57 hawk body mounts
  236. Fuel System: 50 Commander - Choke Conversion
  237. Wheels 53 Commander Tires/Wheels
  238. Paint: Wheel color for 1960
  239. Body: Front fender mounting.
  240. Brakes: mismatched brake shoes on 55 Champion
  241. Wheels Racing Wheels
  242. Steering Weird power steering lockup -- Avanti
  243. Engine: Piston ring size
  244. Paint: Painting front outer parking light housing
  245. Other: Window regulator
  246. Body: hawk power windows
  247. Engine: 289 heads to 259 block
  248. Body: Moulding clips
  249. Engine: Engine Swap Question
  250. Engine: linkage spring
