View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Fuel System: Question on Avanti gas tanks, the vent tube.
  2. Body: Hood Prop Rod On Hawks With Factory Equipped AC
  3. Frame/Springs '64 Daytona Hardtop vs '65 Daytona Sport Coupe
  4. Transmission: GT Hawk Transmission Problem
  5. Body: 58 PH Trim, stock or not?
  6. Body: Wagonaire license plate / tailgate interference
  7. Front Axle: My 1961 Lark
  8. Interior: Glass Damage from Armor-All?
  9. Steering Control arm seals.
  10. Other: wiring for windshield wipers
  11. Brakes: Aftermarket disc brakes
  12. Fuel System: Testing Fuel Pump
  13. Other: Convertible- top emergency procedure??? 1951 Champion
  14. Electrical: Right Front Turning Signal Stopped Working
  15. Cool/Heat: 1953 LC Radiator replacement options
  16. Electrical: I say dash has to be pulled!!
  17. Engine: 1964 259 V8 trouble.
  18. Cool/Heat: coolant recovery tank
  19. Rear Axle: Optimum rear axle ratio
  20. Engine: Ignition timing
  21. Rear Axle: Type 44 TT rear End Question
  22. Rear Axle: dana 27 VS dana 44 whats the diference?
  23. Interior: 58 PH carpet install
  24. Engine: Drain Plug Gasket
  25. Body: Window Regulator Cores for Rebuilding?
  26. Engine: won't idle in gear continued
  27. Brakes: Master cylinder leaking
  28. Speedo/Tach/Gauges Speedo head making noise
  29. Wheels 64 Daytona wheels color
  30. Brakes: Hill Holder, dual master cylinder, Turner disks questions
  31. Wheels Whitewall width
  32. Electrical: Hate to ask...........but I will anyway:-)
  33. Body: 63 lark trunk latch
  34. Electrical: What wiper-motor fits?
  35. Engine: Looking for advice
  36. Rear Axle: Dana 44, swapping yokes
  37. Rear Axle: What size is the nut on a tapered rear axle?
  38. Fuel System: 3 Duces
  39. Exhaust Too Hot to touch
  40. Transmission: Can you swap out tail shafts, on a T86
  41. Frame/Springs GT Hawk Rear Springs
  42. Brakes: SS Braided Rear Flex Hose
  43. Engine: Valve springs
  44. Cool/Heat: Radiator flush?
  45. Exhaust Heat Riser
  46. Body: Fuel door spring attachment tips?
  47. Frame/Springs Avanti Leaf Spring liners
  48. Body: Window felt help
  49. Body: Hawk front Right side window regulator
  50. Fuel System: Carb switch
  51. Frame/Springs champion lowering springs
  52. Transmission: DG200 transmission rear seal
  53. Fuel System: 2 1 bbl carbs needed.
  54. Wheels Wheels and Tires Again!
  55. Body: Looking for 1951 "Commander" Hood Script!
  56. Fuel System: Ported, Non-ported, And "Timed Vacuum"
  57. Engine: Waking Up a '56 289
  58. Cool/Heat: Avanti Aluminum Radiator W/ elec Fan and Shroud
  59. Electrical: Wiper Motor Wiring question
  60. Engine: Startup issue - 66 283
  61. Other: lark pedals in C/K body
  62. Engine: mysterious high idle
  63. Steering Avanti Power Steering: Disconnecting Reach Rod from Bell Crank ('Still a Newbie!)
  64. Engine: Holley Terminator FI
  65. Transmission: T85 question. (Jack Vines?)
  66. Engine: pullys
  67. Transmission: 56 3spd W/Overdrive
  68. Interior: difference between 53 and 54/55 seats
  69. Brakes: Parking brake issue
  70. Cool/Heat: Heater Control Valve
  71. Engine: Obsessed with Sixes
  72. Cool/Heat: 1955 V8 radiator?
  73. Electrical: Right front turn signal STILL!!!
  74. Fuel System: 1955 Fuel Pump/Fuel Delivery Issues
  75. Electrical: Power windows
  76. Engine: 259 push rods, with or without oil passages?
  77. Engine: Commander (Land Cruiser) head gasket - which side is up?
  78. Frame/Springs Installed control arms on the Speedster
  79. Interior: Dashboard Conditioner/Preserver
  80. Steering ASTRO steering box
  81. Electrical: Generator or Alternator
  82. Engine: Avanti motor mount install
  83. Fuel System: Is there a best location for electric fuel pump ?
  84. Fuel System: Air Cleaner Bracket
  85. Other: strange vibe
  86. Brakes: looking for some help with brakes
  87. Engine: '53 Commander dented oil pan
  88. Front Axle: lowering a GT
  89. Fuel System: Fuel Level Sender - Ohm Range
  90. Electrical: GM Internally Regulated Alternator Swap
  91. Electrical: Stewart-Warner Tachometer Sender
  92. Brakes: Stupid Question? How does Parking brake work?
  93. Engine: Another oil pan gasket question on 289
  94. Electrical: 56 hawk horn wire
  95. Transmission: Downshifted and Now Has High (Late Upshift)
  96. Steering P/S control valve
  97. Brakes: Installed Turner MC kit today
  98. Brakes: brake drum application
  99. Engine: Hawk Oil Pan Removal
  100. Frame/Springs Broken Leaf Spring on 63 Avanti - any used available
  101. Fuel System: Avanti Fuel Pump Mounting
  102. Rear Axle: '80-'85 AVANTI rear axle bearing and seal info!
  103. Transmission: 4-speed Avanti Studes..........
  104. Fuel System: Another Junk Fuel Pump
  105. Thrush Glasspack Mufflers
  106. Engine: 1964 Wagonaire Engine help
  107. Electrical: What is this???
  108. Brakes: Twin Traction Concern
  109. Body: rubber seal between door and interrior door removable window frame
  110. Body: Cowl Tag
  111. Engine: Torque and torque wrenches
  112. Interior: Engine turned aluminum dashes
  113. Other: Rattling windows and bad chrome
  114. Engine: oil leak
  115. Fuel System: gas tank sending unit
  116. Interior: seat covers
  117. Brakes: Do some trucks have the short brake shoe at the back?
  118. Brakes: 3R 6-12 pickup truck brake lights are not illuminating when I press the brake pedal
  119. Brakes: Hill Holder
  120. Fuel System: How does an R-2 fuel pump work?
  121. Other: Production order questions
  122. Engine: broken timing gear 1952 Champion
  123. Brakes: More '84-'85 avanti tech info!
  124. Interior: Replacement Interior
  125. Exhaust What is better?
  126. Transmission: Four speed transmission
  127. Interior: seat frame rust removal?
  128. Engine: Minimum safe quench?
  129. Engine: How do you install Harmonic Balancer with the engine in the car
  130. Transmission: T5 Install Help Needed
  131. Engine: Rear Main Seal?
  132. Speedo/Tach/Gauges Where does the Speedo Cable go through the firewall? 1963 Lark
  133. Transmission: Shifter
  134. Speedo/Tach/Gauges '63 Hawk - Oil Pressure Line Removal from Back of Gauge
  135. Clutch/Torque Converter: Flywheel-What does it fit?
  136. Electrical: GT Hawk rear wiring harness location
  137. Brakes: Rear Drum Install
  138. Electrical: Correct Fog Light Switch
  139. Brakes: Brake Issue
  140. Electrical: Bulb Types
  141. Engine: 289 Connecting rod lock
  142. Other: Studebaker sighting
  143. Brakes: Help - 1955 E5 Truck Brakes
  144. Body: 53 K body window help needed
  145. Electrical: Generator question
  146. Cool/Heat: 1947 Champion Defroster
  147. Body: 1949-53 2r5 bed swap
  148. Transmission: overdrive
  149. Engine: Pistons needed 30 over for a 232 V8
  150. Engine: 2 bolt valve covers on 4 bolt heads
  151. Engine: Commander engine mystery
  152. Electrical: Thinking about instaling hazards...
  153. Steering nut, washer & bolts installation....
  154. Wheels '65 Cmdr 15" Wheels needed.
  155. Interior: new seats
  156. Frame/Springs Heavy Duty Springs for a 64 Cruiser?
  157. Paint: Question About P.H. Colors
  158. Fuel System: Fuel tank outlet..
  159. Exhaust Heat Riser Spring
  160. Electrical: Wiring woes
  161. Fuel System: Has anyone tried a Daytona Parts replacement carb?
  162. Engine: Modifying a 48 Champion Convertible
  163. Brakes: Today: Turner Disc install
  164. Cool/Heat: Let's talk overheating
  165. Body: Search for rust repair panels
  166. Electrical: No brake lights
  167. Brakes: New meaning to bleed the brakes...
  168. Speedo/Tach/Gauges Dash Identification
  169. Transmission: Throttle lever pin fell out 1964 gt hawk
  170. Ignition: No starting when warm, intermittently
  171. Brakes: Primary Brake Shoe Placement
  172. Engine: G.M. Engine Swap
  173. Cool/Heat: Bad Freeze Plugs 1956 Skyhawk 289 - 4 Barrel
  174. Fuel System: Fuel sending unit
  175. Transmission: Dried Grease in Lower Shift Bracket
  176. Transmission: What is true?
  177. Engine: 52 champion timing
  178. Body: Windshield Gasket
  179. Frame/Springs curb weight of 40 Champion?
  180. Brakes: Brake Shoe question
  181. Other: air conditioning: an idler or no idler
  182. Steering Bellcrank to Shaft Install challenge.
  183. Body: 1 ton front fenders
  184. Transmission: Steering Gear Box Lubricant
  185. Frame/Springs 5E28/7E28 Rear spring removal
  186. Brakes: 39 Commander drum and hub
  187. Wheels 14X7 wheels
  188. Electrical: Polairity Issue
  189. Electrical: backup lights
  190. Engine: Swapping V8 cylinder heads
  191. Engine: Different cylinder heads on the Studebaker Champion L head 6.
  192. Body: A little tip for installing rubber back-up lights gaskets
  193. Other: Undercoating 1953 Studebaker Starliner Coupe
  194. Fuel System: 53 Starrliner Champion 6 Cyl. Cabr return Spring
  195. Front Axle: Kingpin to ball joint suspension conversion?
  196. Frame/Springs Rear Shackle Length, '60 LArk IV
  197. Rear Axle: Need some help with the numbers for my rear pinion seal
  198. Body: Can Stainless drip rail be removed for painting
  199. Body: Can Stainless drip rail be removed for painting
  200. Engine: Manufactured/Factory Dimensions
  201. Body: Door hinge screw removal
  202. Engine: Cam Specs
  203. Body: European leather upholstery pictures. Any help?
  204. Brakes: Power Disc Brake Problem
  205. Engine: ID engine in 2R10
  206. Cool/Heat: 55 champion
  207. Engine: '63 Avanti Solid Motor Mounts?
  208. Engine: Engine swap
  209. Fuel System: Air filter element for 49 Champion
  210. Fuel System: R2 Carb Accelerator Pump
  211. Electrical: Gas gage shows way over full
  212. Rear Axle: Axle shaft difference??
  213. Ignition: Positive ground, 6V system coil
  214. Front Axle: Grinding sound
  215. Interior: 1958 President rear window deck
  216. Interior: Headliner Adhesive Anyone?
  217. Transmission: Hurst shifter
  218. Clutch/Torque Converter: Installing Flex Plate to Crank bolts???
  219. Engine: 57 Commander 259 Valve cover gskt
  220. Body: Door glass
  221. Fuel System: Idle too high
  222. Exhaust it seems obvious....NOS single exhaust install
  223. Speedo/Tach/Gauges Need pinion for DG 150 transmission 527689
  224. Exhaust 74 Avanti SBC T-56 2 1/2" Exhaust System and Undercarriage
  225. Rear Axle: Vibration solved? (kinda long)
  226. Brakes: Brake lights issues and brakes on 59 Hawk
  227. Fuel System: Lead additive needed? Gasohol longterm problems?
  228. Engine: Important changes if a 59 Golden Hawk has a 289, automatic and rear end from a 1964 Cruiser?
  229. Engine: '63 Lark 289 question
  230. Rear Axle: Auburn LSD
  231. Interior: Window Problem
  232. Transmission: Any one know of the availability of an overdrive unit for a 1937 Studie?
  233. Body: Details installing 1951 pick-up cab onto frame
  234. Body: Front fenders
  235. Engine: Replacing Head Gasket
  236. Electrical: 3EE Batteries, what else do they fit?
  237. Steering Modify bushing for Saginaw steering box.
  238. Cool/Heat: Continuing heating problems
  239. Engine: 1957 289 oil filter
  240. Engine: 289 Camshaft
  241. Fuel System: Carburetor Conundrum
  242. Brakes: 74 Avanti Brake Bleeding
  243. Brakes: Weak brakes??
  244. Engine: Crankshaft pulley nut
  245. Frame/Springs 56 Champion springs and shocks
  246. Engine: Cyl haed for lark 63
  247. Brakes: Brake Fluid Recall - DOT4 (Aug 2013)
  248. Brakes: Hydrovac In-Line, Vacuum Check Valve
  249. Steering Power Steering Ram Length Adjustment
  250. Body: Need Chrome Trim 1937 Studebaker Sedan
