View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
  1. 1952 rubber parts
  2. Borani wire wheels
  3. Avanti rear axle gear ratio
  4. head gasket sealant
  5. Fun Stude Pictures
  6. 51 windshield in a 50?
  7. contact info on new C/K grills?
  8. Turn signal retro fit for my 50
  9. Would these work?
  10. after market rims for 50 Champion?
  11. Wheels for 62 half ton
  12. hawk 58-61
  13. installing Champ hood
  14. power windows
  15. Electronic points
  16. 63 Hawk GT Leaf Springs
  17. Clock fuse
  18. Pilot Bearing Removal
  19. 1-wire 6 volt alternator hookup
  20. Vacuum advance
  21. 51 coil springs
  22. Update on new Avanti chassis
  23. Aluminum Intake Manifold
  24. spark plug wire channel?
  25. 53 weather stripping?
  26. '57 six question
  27. Truck Part Number Help?
  28. Studebaker in St. Louis 81
  29. Heater On All the time
  30. vin number help
  31. Generic Wiring Harness....
  32. Quick solder question
  33. Timing for Studebaker Lark
  34. Horn Bar Removal
  35. Carburetor Help!!!!!!!
  36. 13" Cobra brake project back on track
  37. Recommended oil
  38. too much blowby.
  39. Transmission... Flight-o-matic? Powershift?
  40. Timing Question V-8
  41. Help identify part number
  42. Rust / fuel tank.
  43. Crank Case Breather
  44. Stearing box lube
  45. strait 8
  46. studebaker champion 6
  47. 2 piece driveshaft support removal
  48. Avanti door hinge adjustment
  49. 53 champ brakes
  50. mpg with studes
  51. 57 Golden Hawk clock
  52. frame good?
  53. Starter help!
  54. driveline switch - wagon to sedan
  55. Need some quick help -- no run
  56. Trunk undercoating
  57. speeds of the r series
  58. '54 Studebaker Carpet Colors - Help Needed!
  59. 1928 Dictator
  60. '63 Avanti questions for the "tech heads"
  61. 1952 studebaker champion fuse box
  62. Front brake hoses - GT hawk
  63. Hooking up 2R6 master cylinder/gas tank
  64. 55 Trim wanted
  65. Wiring help please
  66. flightomatic parts/advice
  67. Paint question
  68. Need help with a 58 Commander flightomatic
  69. 57 Provincial- Disc Conversion
  70. 1952 studebaker champion
  71. Avanti Side Panel Trim
  72. Repainting flourescent pointers in 1964-1966
  73. 50 champion brake problem.
  74. Door lock help needed!
  75. Wheel and tire help
  76. Oil Filter Question
  77. When is frame too far gone?
  78. Fuel pump oil leak
  79. T5 Hawk
  80. Generic Disk Brake Question
  81. vibration dampenr
  82. Found!! - Fram Oil Filter Setup for Champion Six
  83. Bleeder Size
  84. Disc brake kits for 3E-8E trucks
  85. M5 Front End Assessment
  86. resistor
  87. My disc brake configuration
  88. 56 Champion overdrive won`t engage
  89. New half shafts for rear suspension
  90. 50 Champion freeze plug
  91. 38 Studebaker President
  92. Brakes 57 silver hawk
  93. new guy
  94. Hawk GT Tach driver Inst'l-anyone done it?
  95. Got any seatbelt installation tips?
  96. My tach is stuck at 3000 rpm ....
  97. adding AC to R2 Hawk
  98. Wheels on ton 49 Studebaker
  99. r-2 distributor
  100. Convertible Top Motor
  101. Dana 44 twin trac change over..
  102. 57 Provincial brake install report.
  103. Carter Carb
  104. Haunted Transmission
  105. Windage tray for 170 engine
  106. drums and rims
  107. Paint Color & Weather stripping
  108. 6 vplt to 12 volt inverter
  109. seat screws?
  110. What's this tube?
  111. 4 bbl intake question
  112. Sludgy Engine [:0]
  113. 57 Taillight
  114. Avanti Gtech results w/4 wheel Mustang GT brakes
  115. A.M. F.M. Converter.
  116. Cat Whiskers
  117. V8 block water jacket drain plugs
  118. Valve cover gasket
  119. Stude part of AMC? Whaaaa??
  120. Engine Rebuilding
  121. 48 CHAMPION
  122. Help Needed - Hood/Trunk Emblem Painting '54 Champ
  123. Overdrive
  124. fuel gage resistance range for c-cab
  125. Tank part num. 1552818
  126. 56 wagon paint question
  127. Motor oil...
  128. Oil in Rad.coolant
  129. Has anyone weighed a Studebaker Avanti frame?
  130. Amp Gauge Reading
  131. OD Won't Disengage
  132. HELP M5 1948
  133. Turn Signal Switch
  134. Engine Paint Scheme for 52 Studebaker
  135. Modification to Corvette C5 Calipers for Avanti
  136. Look what I found while polishing the Avanti diff.
  137. Head work?
  138. What size V-8
  139. Gas leak in '63 Lark R1
  140. Red Spark Plug Wires
  141. STARTER SWITCH
  142. The near mythic 185 Ohv 6
  143. selling info
  144. the sceptre model
  145. 56 wagon back-up lights/ Lark????
  146. Transmisson Weight?
  147. What engine is this?
  148. Headliner??
  149. Rebuilding 289
  150. oil pressure on 170 OHV
  151. Plug heat range
  152. 1949 Champion Radio
  153. 1939 Champion Shift
  154. Door Seals
  155. 63 Hawk Firewall Brake Fluid Reservoir-??????
  156. oil leak on flathead six
  157. More about engine numbers please
  158. White wall width
  159. Radiator
  160. Any '40 Champ window regulators?
  161. Valve covers
  162. 259 in a GT ??
  163. Electrical ?
  164. 337 speed records
  165. Question about slow wipers
  166. NG SERVICE BULLETIN CD
  167. 37 Studebaker
  168. OEM partial flow oil filter opinion poll
  169. 57-65 Wiring diagrams on CD
  170. Hooters Free Trip..No wifes
  171. brake lights
  172. Mysterious disappearing gasoline
  173. water pumps/engine running hot
  174. Power Bakes
  175. power windows
  176. Mini-tubs photo
  177. Vintage Air brackets, which pulleys?
  178. Speaking of oil pressure.......
  179. Found a Carter carb... Jeff, can you help?
  180. 6 volt or 12
  181. Champ fender compatibility
  182. need oil pan - 50 land cruiser
  183. 1928 dictator
  184. Block Black?
  185. pulling V8 engine
  186. Carburater Exchange
  187. mirrors for cruiser
  188. WTH!?!? Question about steering stops ...
  189. Float drop
  190. Order of disassembly
  191. Rocker swapping
  192. Flex Plate
  193. overdrive
  194. 51 Champ Business Coupe drive train changeover
  195. 48 champion
  196. Bendix fuel injection
  197. More head questions?
  198. polarity/grounding
  199. transmission oil
  200. Cruiser radio shook its guts out
  201. Rear wheel squeak
  202. Studebaker Engine
  203. Performance suspension for Avanti
  204. Engine spark plug wiring
  205. How to straighten grill bars
  206. 28 Dictator
  207. Truck bed swap?
  208. 56 wagon on e-bay
  209. Avanti Bumpers
  210. How Much is a Core Engine Worth?
  211. tachometere woes
  212. Fiberglass fenders
  213. Sumitomo 2 1/4" calipers on Avanti
  214. Need tips for dial indicating Champ 6 bellhousing
  215. Shift Indicator
  216. Adhesive for under carpeting
  217. torque specs
  218. Engines
  219. Photos of Bendix Fuel Injection (DeSoto)
  220. Windshield Wipers
  221. need parts
  222. Complete Ignition lock Switch for 63 Hawk
  223. Late 30's door hinge adjustments....
  224. grille covers
  225. Engine maybe frozen?
  226. Repair Shops
  227. '55 PRESIDENT REAR SHOCKS
  228. Help! broke wire at voltage regulator
  229. Note to bshaw, administrator
  230. 6V to 12 V conversion
  231. horn voltage
  232. DG 250 auto transmission
  233. Performance
  234. Jim Turner's T-Cab disc brakes
  235. How would I upgrade brakes to a dual system?
  236. Transmission Probs
  237. 1928 Engine
  238. Loose cinchbolt?
  239. wiring harness
  240. ford engines in studebakers
  241. 6 cyl OHV engine
  242. 2-barrel adapter for 169?
  243. dash colors
  244. RICH 48 CHAMPION
  245. Transmission, What is this?
  246. Vapour Lock 289 V8
  247. 63 Lark wiper switch wire colors, locations needed
  248. Original condition
  249. Speedster Rear Springs
  250. 55 k body
