View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 [79] 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Fuel System: Do I need a pressure regulator?
  2. Engine: 66 283 engine parts
  3. Electrical: Alternator wiring
  4. Steering How to install a power steering pumb
  5. Brakes: Brakes -- No pressure one time...
  6. Interior: suggestions for speaker, or stereo in 49 truck?
  7. Electrical: 1965-1966 Temperature Sending Unit 283 V/8
  8. Interior: Replacing '53 Commander C/K bench seat w/buckets
  9. Electrical: 1960 headlight switch
  10. Engine: Firing order
  11. Interior: Headlining
  12. Speedo/Tach/Gauges Aftermarket tach install
  13. Body: Bumper Bolts 56 Commander
  14. Engine: V-8 YOUR R SERIES / PACIFIC N/W by JunkYardDog
  15. Body: GT Hawk window rattle
  16. Frame/Springs Frame Swap?
  17. Ignition: Electronic Ignition
  18. Wheels Avanti Mag Wheels
  19. Body: 62 hawk cowl trim
  20. Brakes: brake pedal bushings
  21. Frame/Springs Traction bars
  22. Speedo/Tach/Gauges Speedometer Issues
  23. Fuel System: Starting Issues
  24. Engine: 57 289 cyl head removal
  25. Body: Window regulator lube recommendations?
  26. Engine: Working on the Lark's 570 Heads- Now with Flow Numbers
  27. Body: Door rattle
  28. Cool/Heat: radiator
  29. Steering Avanti (1974) Ross steering shaft seal needed
  30. Electrical: Best replacement 6v Pos Ground voltage regulator.
  31. Cool/Heat: 54 pick up overheating
  32. Engine: V8 259 Rebuild
  33. Transmission: Another overdrive question
  34. Transmission: Dumb question, answer and feel smart!!!
  35. Exhaust Making headers
  36. Transmission: 1964 Flightomatic
  37. Engine: converting to pcv system on 58 Hawk
  38. Cool/Heat: Heater fan motor, cover missing, suggestions???
  39. Fuel System: Idle Jets needed
  40. Steering 66 steering box modification
  41. Engine: Fan shroud for a 170
  42. Engine: 62S-F4 --170 distributor
  43. Electrical: Starter Swap 60 Lark VI Stick
  44. Transmission: First Drive with Overdrive in a Studebaker
  45. Electrical: bench testing generators
  46. Electrical: Wiper speed
  47. Ignition: What model # Autolite vacuum advance 52 Champion
  48. Other: Glass, Surprise when I opened the garage.
  49. Ignition: Distributor cap
  50. Ignition: Urgent help Please! 63 Avanti Igniter
  51. Other: Hankook whitewall tires
  52. Body: '62 Hawk has floppy vent windows...I don't want floppy windows...:(
  53. Electrical: 12 Volt wiper motor with a 6 volt system?
  54. Steering Can "play" in steering box be adjusted?
  55. Engine: Motor oil thoughts?
  56. Fuel System: gas cap and venting
  57. Body: 1953 passenger side wing window
  58. Transmission: 1961 Lark Automatic Tansmission Fluid.
  59. Fuel System: Calling all Studebaker Avanti owners!
  60. Cool/Heat: Adding air conditioner pulley to crankshaft
  61. Transmission: overdrive
  62. Steering LARES CORP - Cambridge, MN - power steering pumps
  63. Fuel System: Can it be done, and if so at what cost??
  64. Steering Avanti (II) Steering Coupler - Rag Joint Replacement + Steering box Upper Seal Install
  65. Other: Ever need a hole drilled that needs to be accurate and you only get one shot
  66. Transmission: Location of floor shift fiberglass cover plate
  67. Engine: oil pan install
  68. Brakes: Turner Brake M/C Install problem
  69. Cool/Heat: Never Been There Done That {?} { 6 volt aux cooling fan} 55 President
  70. Body: Avanti Fiberglass Repair
  71. Fuel System: Poll on fuel pump usage
  72. Electrical: Will this voltage regulator work on an Avanti? 65 amp correct?
  73. Clutch/Torque Converter: clutch will not disengage
  74. Drive Shaft My Welding Skills (or lack therof)
  75. Paint: peeling chrome
  76. Body: Early versus Late Lark Front Fenders
  77. Rear Axle: Dana-Spicer 23
  78. Transmission: 52 Champion Overdrive
  79. Body: Window Crank Knob Replacement
  80. Rear Axle: 1963 Lark v8 - How to Install Inner Seals??? Please help!!!
  81. Body: Door lock cylinder. Repairable or not?
  82. Engine: engine and trans
  83. Other: where does the vin plate go
  84. Transmission: Overdrive problem
  85. Ignition: Distributor rotor identification
  86. Transmission: Alternative Auto floor shifter
  87. Transmission: Easeist way around the short tailshaft/two piece driveshaft issue
  88. Body: Source for the acme thread bolts?
  89. Transmission: Enlighten me on the specifics of OD, and show me a wiring diagram.
  90. Engine: What You Should Know Before You Trash Your Stude Motor For a Crate Motor
  91. Electrical: Avanti windows - UGH!
  92. Engine: Distributor will not enter into correct position
  93. Brakes: FS brakes from my 52 champ.
  94. Transmission: Grinding into gears
  95. Fuel System: Sprung for a sender
  96. Transmission: Interpretation of transmission numbers
  97. Engine: Replacing rear crank seal.
  98. Engine: HELP! Oil Assembly 259cid
  99. Engine: It runs....BUT...it runs rough and won't idle
  100. Fuel System: Throttle springs
  101. Steering Rather confused... Baffled more like it. (Tie rod ends)
  102. Cool/Heat: Lark Radiator Question
  103. Fuel System: Supercharger facts or myths?
  104. Rear Axle: Rear differential ratio
  105. Front Axle: 63 Lark, some questions
  106. Cool/Heat: Daytona Climatizer
  107. Brakes: 1950 Wheel cylinder piston
  108. Steering 1963 Steering Wheel Horn Rubber
  109. Front Axle: Clunking sound
  110. Body: Replacement of '53 K body door glass frame rollers
  111. Body: Can it be welded?
  112. Interior: Avanti Headliner
  113. Brakes: 64 Sude Daytona 289 Master cyclinder
  114. Engine: 57 hawk motor to rebuild or not to rebuid
  115. Engine: Is a '57/'58 Golden Hawk block different from a same year Silver Hawk
  116. Fuel System: Vapor Lock
  117. Ignition: Converting to electronic ignition
  118. Engine: oil pressure
  119. Engine: Big end shell spining in rod -------- Why
  120. Rear Axle: R/E-10,11, 12 Timken J-3299 pinion puller - buy or borrow
  121. Electrical: Avanti Horn Steering Bar
  122. Brakes: Power brake booster
  123. Engine: Information wanted on my Studebaker motor
  124. Engine: 1951 champion engine rebuild
  125. Front Axle: 1964 hawk front end
  126. Transmission: Overdrive wiring
  127. Engine: Distributor vacuum line
  128. Cool/Heat: Puzzling overheating
  129. Engine: Having trouble identifying this rebuilt Studebaker engine
  130. Interior: interior finishes & color
  131. Electrical: oh dangit...
  132. Fuel System: Fuel boiling problem
  133. Brakes: Brake fluid?
  134. Fuel System: 289 intake manifold gasket question
  135. Wheels Size Bolt Pattern
  136. Fuel System: Carter Electric Pump
  137. Wheels Did Studebaker stamp any identification marks an their original wheels?
  138. Engine: DANGER!! I've been thinking.....
  139. Engine: Cadillac Intakes on Studebaker Motors
  140. Engine: Does 66 DAYTONA 283 Have An Oil Pressure Sensor?
  141. Drive Shaft Installing new rubber cushions in shaft support
  142. Body: 58 PH trim and bumper questions
  143. Body: hood
  144. Cool/Heat: Avanti water pump
  145. Wheels Mystery Hubcap
  146. Cool/Heat: Thermostat housing question...
  147. Body: Hood - to cowl rubber seal: Install !
  148. Transmission: Overdrive Governor
  149. Electrical: Power window relay circuit
  150. Engine: Type of engine
  151. Body: Speedster halo
  152. Paint: Paint suggestions please--
  153. Steering advice about steering column
  154. Cool/Heat: Oh boy I need help fixing a problem
  155. Electrical: On Avantis & other Studes
  156. Engine: Engine idles low, eventually dies
  157. Other: New to me 62 GT Hawk
  158. Transmission: transmission grinds in first and reverse
  159. Cool/Heat: warm engine having issues restarting in hot weather
  160. Engine: Missing tooth on the ring gear
  161. Other: CD Manual error!
  162. Body: Inner/outer Rocker panels
  163. Engine: Not gonna assume
  164. Electrical: 63 Champ Turn Signals
  165. Transmission: trans/diff
  166. Engine: initial start up after rebuilding engine
  167. Brakes: Avanti brakes on a Daytona?
  168. Paint: Painting Questions Avanti Red 1964 R-1
  169. Interior: Front Bench Seat Swap ???
  170. Engine: Studebaker Valve covers for Small block Chevy
  171. Body: Cowl and RT inner fender wanted for 63 / 64 GT
  172. Other: Headlight rim
  173. Electrical: For those needing or wanting a new start on their electrical harness
  174. Fuel System: Stromberg AAU Question?
  175. Engine: help with engine ID numbers for Studebaker Thunderbolt V8
  176. Electrical: electrical
  177. Electrical: 6 volt LED bulbs
  178. Ignition: R1 Spark Plug question
  179. Body: Champ Rear Window
  180. Body: Vent Window 'U' Channel Source Or Substitute, For 'K' Body Hawks
  181. Engine: R2 vally pan breather hole
  182. Body: 63/64 GT Door Chevron Color Placement
  183. Interior: Avanti 1985 Carpet?
  184. Fuel System: Edelbrock 1403 for my 1964 GT Hawk
  185. Other: daytona lark hardtop rear drivers side window
  186. Engine: R1 Breather Tube
  187. Steering How do I spruce up the inside of the steering column?
  188. Fuel System: fuel line
  189. Speedo/Tach/Gauges Accuracy of Studebaker Oil Pressure Gauge
  190. Body: I did a really stupid thing today and damaged my vent & fender on my 51 Champion
  191. Speedo/Tach/Gauges '55 Speedster Tach
  192. Electrical: Ground cable
  193. Engine: Fan position in a Champion Six
  194. Paint: Not another paint topic??? Avanti paint blisterring...
  195. Cool/Heat: Is a gasket required for V8 water pump?
  196. Clutch/Torque Converter: Clutch does not disengage
  197. Steering Ideas for adding power steering to 49 Stude Pickup?
  198. Transmission: 1950 Commander Auto - what fluid?
  199. Interior: headliner glue
  200. Transmission: did studebaker C cab big 6 put in a T98 Trans?
  201. Body: Removing Gran Turismo Rear Quarter
  202. Transmission: Powershift help needed
  203. Fuel System: Studebaker Avanti Fuel Tank Fill Hose
  204. Engine: Strange Rattle
  205. Frame/Springs GT Hawk Rear Springs
  206. Clutch/Torque Converter: 40 champ clutch linkage?
  207. Engine: Intake block off
  208. Body: GT Hawk Side grilles
  209. Speedo/Tach/Gauges Re-numbering Speedometer Face
  210. Interior: Need A/C pics
  211. Rear Axle: 1963 Lark 8 - AT WIT'S END concerning the Rear Axle - a TRUE CHALLENGE!!!
  212. Body: 1947 Champion Vacuum Wipers Moving Backwards
  213. Engine: My engine number.
  214. Electrical: Let there be light!
  215. Frame/Springs C/K body guys...question
  216. Body: Avanti trunk lid striker
  217. Interior: Replacement or repair hawk sunvisors
  218. Engine: Rattling Noise in Front Area of Motor
  219. Paint: coatings
  220. Speedo/Tach/Gauges hooking up the tach using an aftermarket wiring harness
  221. Fuel System: Carburetor options
  222. Other: removong rust with electricity question
  223. Brakes: Hydrovac
  224. Fuel System: Carter bbr-1 6 cyl carburetor
  225. Fuel System: Drilling holes in super charged stromburg
  226. Interior: 60 lark seats
  227. Rear Axle: Differential help
  228. Body: 59 lark wagon parts interchange
  229. Brakes: Hydro-Vac Fittings Help!
  230. Electrical: Dimmer Switch Wires: Where are they?
  231. Fuel System: Champion 6 running rich
  232. Frame/Springs Rear frame horn damage repair GT Hawk
  233. Electrical: 1957 Silver Hawk Stop light bulb
  234. Ignition: ignition timing...all read
  235. Fuel System: Packard 352 4bl Carburetor
  236. Engine: 352 Packard "History"
  237. Interior: '56 President Headliner Question
  238. Engine: Engine swap out
  239. Brakes: Power Booster Test
  240. Rear Axle: Converting an Open Rear End to Twin Trac?
  241. Transmission: Replace a 3spd OD w/a later model 5 spd OD bolt up to Stude 259?
  242. Body: frame swap
  243. Electrical: Gas-meter sender...
  244. Electrical: Stop light fuse
  245. Body: 57-61 fin painted trim
  246. Ignition: Ignition Switch
  247. Body: Rear quarter glass removal 50 champion 2 door
  248. Engine: More Crankshaft questions
  249. Engine: Extra Part?
  250. Engine: Won't idle in gear
