View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 [78] 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Cool/Heat: Avanti R2 additive in the antifreeze
  2. Body: C&K Cowl Seal - placement
  3. Interior: Windlace estimate
  4. Engine: Just thought I'd pass this on...(machine shop)
  5. Electrical: bench testing 3 wire wiper motor and color?
  6. Electrical: springs for the wiper motor brushes
  7. Rear Axle: Mystery Rear End
  8. Engine: UGH!!! rust in a BAD place
  9. Body: 1963 JT Engine Badge Location
  10. Steering Eaton Pump Reservoir Vent Question
  11. Other: M5 frame tag and title
  12. Steering Slick Street vs. OEM Steering Gear
  13. Interior: 1964 cruiser parts
  14. Brakes: Turner Brake Help
  15. Engine: Aluminum Timing gears?
  16. Clutch/Torque Converter: Installation preferences....
  17. Clutch/Torque Converter: Installation preferences....
  18. Electrical: 1963 Avanti Power Windows
  19. Frame/Springs 1965 leaf springs
  20. Electrical: 1964 Wagonaire
  21. Frame/Springs Control Arms & coil springs assembly
  22. Transmission: Trans swap
  23. Ignition: 12v Distributor on 6v car
  24. Body: Model Numbers
  25. Ignition: electronic distributor
  26. Transmission: What year was T10 4 speed available?
  27. Body: 64 4 door Door lock tumblers and springs
  28. Transmission: Later model 5 speed manual trans swap
  29. Engine: Engine knock on a daily driver
  30. Body: 1961 Lark Bumper Removal Problem
  31. Body: Adding a Sunroof to a 1961 Lark
  32. Rear Axle: Best ratio behind a 700 r4
  33. Exhaust Looking for a Header for a 185
  34. Frame/Springs removing 1950 champion coil springs
  35. Engine: stuck oil prv need help
  36. Steering 56 commander steering wheel needed
  37. Engine: 259 Crankshaft question.
  38. Fuel System: Propane (LPG) conversion, anyone converted a Studebaker?
  39. Cool/Heat: interior defrost hoses
  40. Engine: R harmonic balancer-Advice wanted.
  41. Other: Need 1935 President Emblems and Hood ornament
  42. Transmission: 700 R4 conversion
  43. Engine: Oil spray from dipstick tube
  44. Body: How tight do I make the crimp nut on the bottom of vent window? 55 c body
  45. Transmission: T5 Durability Behind 289
  46. Cool/Heat: Air conditioning 63 gt hawk
  47. Wheels ID my tires: Coker, Diamond Back, other?
  48. Fuel System: Ethanol additives
  49. Fuel System: edelbrock carb
  50. Ignition: Spark Plug Failure?
  51. Paint: Air Brush
  52. Electrical: Beginner's Book
  53. Electrical: Rewired 51 Land Cruiser - help with a problem
  54. Engine: Avanti ingests SBC - T56 combo
  55. Cool/Heat: Not a Studebaker, but....
  56. Body: C Cab door latch problem
  57. Other: K body quarter window regulator guide
  58. Brakes: Need 63 Avanti Power brake booster or equivalent
  59. Cool/Heat: York AC seal
  60. Other: Shifter Problems!
  61. Interior: How's about these for a Lark seat swap?
  62. Steering Steering Wheel Swap
  63. Exhaust Which manifild to use???
  64. Ignition: Vacuum advance Delco Window-type distributor on Stude V-8's
  65. Fuel System: WW Carb strip down
  66. Body: 1958 Packard Hawk decklid questions
  67. Electrical: 56 Commander Cyclops
  68. Ignition: 6V Coil Primary Circuit
  69. Body: C Cab door latch detent?
  70. Cool/Heat: Temperature gauge test?
  71. Interior: Windlace for 57 HT - Do you need the extra strip on this model?
  72. Body: C cab inside door handle mechanism problem
  73. Transmission: T 5 transmission into my 55 coupe.
  74. Front Axle: king pin rebuild
  75. Front Axle: Commander 1939 Front suspension help
  76. Front Axle: 1939 Commander front suspension help
  77. Brakes: Emergency brake removal/repair?
  78. Other: Windshield washing fluid foot pump.
  79. Transmission: Avanti T56 Rear Mount and Shifter Position
  80. Electrical: 1963-1965 Dash Switches
  81. Interior: Instument Mount Plate
  82. Steering Horn Wire in Steering shaft, 58 Hawk
  83. Engine: 63 Hawk GT low power
  84. Electrical: Ignition Switch
  85. Ignition: spark plugs
  86. Other: 1963 Avanti Engine Comp. and Interior Decals, Plates, Tags?
  87. Engine: End cap / con rod nt lay out ?
  88. Electrical: High Beam Indicator
  89. Steering power steering
  90. Steering threads on steering shaft damaged 58 Hawk
  91. Cool/Heat: Need Radiator Advice
  92. Body: Driver's side inner fender replace
  93. Cool/Heat: What radiator cap pressure and engine temperature is acceptable? Champion 185ci
  94. Engine: Road draft tube vs. PCV system
  95. Clutch/Torque Converter: Pressure plate finger adjustment
  96. Interior: Wet interior
  97. Engine: Which valve springs to use
  98. Brakes: rebuild front calipers?
  99. Engine: 6 cylinder smoke
  100. Electrical: Avanti window relay
  101. Body: Door Seals
  102. Fuel System: 1963 Daytona Hardtop OEM fuel system treatsie of a historical and technical nature......
  103. Other: What brands of tires did 1960's Studebakers come equipped with when new?
  104. Clutch/Torque Converter: Starting a big six on an engine stand
  105. Wheels 53 commander wheels and tires
  106. Engine: oil filter line routing help
  107. Engine: Engine Code Help
  108. Body: Lark wiper arm bases
  109. Rear Axle: Twin traction oil or additive??
  110. Other: Twin Traction Warning Decal Location
  111. Fuel System: Thought I was there....
  112. Paint: 63GT Hood Behind Front Grill & Lower Scoop Flat Black?
  113. Other: Needed: Recommendation for BEST place to acquire parts for 1963 Lark v8
  114. Brakes: Rear drums not taper fit?
  115. Wheels Tire fitment on Flight Hawk
  116. Paint: Paint Code For 1962/63 Silver Mist Poly?
  117. Body: 1962 Hawk chrome
  118. Body: Vent window rubber seals and "U" channels 55-58 Y body sedans
  119. Electrical: Alternator for Avanti....What will work while factory alternator is rebuilt?
  120. Transmission: Weight of flight-o-matic
  121. Speedo/Tach/Gauges speedo cable
  122. Ignition: Hard start with 6V pertronics.
  123. Cool/Heat: AC/heat for 59 lark
  124. Engine: LONG or DEEP sump ?
  125. Steering saginaw power steering query
  126. Brakes: brakes lock up
  127. Engine: Help with re-birth
  128. Electrical: Printing Service Bulletins
  129. Engine: R series valley covers
  130. Engine: Tuning help 6cyl OHV
  131. Ignition: Mallory Unilite....
  132. Fuel System: Lark VI glass bowl fuel pump
  133. Electrical: Where can I get repair parts for my overdrive solenoid?
  134. Brakes: Dana 27 and Dana 44 Braking Question
  135. Steering Power Steering Chatter
  136. Frame/Springs wagonaire is getting a 383 sbc
  137. Wheels 14" wheel application
  138. Exhaust Intake and Exhaust
  139. Electrical: HMMM Dont know why this happened in my 50 commander.
  140. Engine: oil filter
  141. Engine: trouble shoot bottom end question
  142. Interior: 1953-54 coupe arm rest direction
  143. Fuel System: sending unit
  144. Brakes: 1955 Power brakes
  145. Electrical: Generator not generating
  146. Steering No power steering after pump rebuild
  147. Brakes: Homemade Drum Hub Puller
  148. Interior: Would shorter 55 C/K E-brake handle work well for 57 Golden Hawk?
  149. Electrical: Help with Turn Signal issue - 62 Lark
  150. Engine: Rocker Arm Cover Torque?
  151. Electrical: Turn Signal Flasher Question
  152. Body: Avanti Moonroof
  153. Fuel System: Gas pedal/rod from gas pedal to throttle linkage
  154. Transmission: OD cable
  155. Other: Hood latch pull
  156. Brakes: Disc Brake conversion 1950 Stude 1/2 ton
  157. Clutch/Torque Converter: crankshaft/flywheel bolts
  158. Rear Axle: Avanti Brake Drums Rubbing After Bearing Repack
  159. Body: Hawk hood prop rod clip p/n 299777
  160. Body: gap between rear fender and body in front of fin - 1960 Hawk
  161. Transmission: Early Father's Day gift! Transmission Upgrade
  162. Body: Avanti Front End Height
  163. Steering Saginaw steering update
  164. Engine: Any difference between the 4R and 4E 6 cyl.
  165. Other: Fuel Mileage
  166. Interior: Regal Dash Glove Box
  167. Rear Axle: Dana 44 Axle Lengths
  168. Transmission: Speedometer adapters, pinions, extensions, oh my!
  169. Steering Steering Box Lubricant (Ross/Saginaw? -Special Grease/Gear Oil?)
  170. Speedo/Tach/Gauges Continuation of Speedo Problems
  171. Electrical: Voltage Regulator Draining Battery?
  172. Steering Removing the steering wheel in a '53 Commander
  173. Body: Hood reinforcements.
  174. Engine: Size socket needed to turn crankshaft on 51 Champion?
  175. Transmission: flight 0 matic issue ???
  176. Engine: Note on S.I. deep breather caps/filters
  177. Brakes: Hydro-Vac Replacement
  178. Wheels 17" torque thrust wheels on a '63 hawk
  179. Engine: Replacing the original R series thermo clutch & fan
  180. Body: windshield removal
  181. Exhaust Full Exhaust Installation: 1st time...
  182. Frame/Springs MOOG 655 Which way is up?
  183. Engine: 64 Commander Engine Swap
  184. Interior: M-5 U-Channel
  185. Brakes: UNsafe brake drums 52 Champion
  186. Electrical: lights??
  187. Interior: Fabrication work to add headrests?
  188. Engine: Location of #1 on distributor cap
  189. Electrical: Identifying Alternator
  190. Body: Window regulator geometery
  191. Brakes: "late" 7E7 rear brake wheel cylinders
  192. Clutch/Torque Converter: Don't you love it when you do somethng clever? Here's mine. Anything you're proud of?
  193. Other: M-series
  194. Interior: Delco Radio knobs re-cast
  195. Interior: Anyone tried these guys stuff?
  196. Fuel System: Avanti R-2 Fuel Pump Kit
  197. Steering 1950 R5 pick up Drag Link
  198. Electrical: No Turn Signals!
  199. Engine: Champion - Economiser Rebuild pricing and recommendations (MN)
  200. Engine: Need a road draft tube
  201. Engine: 49 R5 truck drive train for sale anyone interested?
  202. Interior: Upholstery Shop?
  203. Steering Steering Wheel Replacement
  204. Interior: Need help with '64 glove box door re-ro
  205. Steering Column riding up
  206. Fuel System: Dual mechanical-electric fuel pump
  207. Electrical: 52 Champion, loose wire under hood. Where does it go.
  208. Brakes: '57 Silver Hawk Master Cylinder
  209. Steering what steering boxes inter change to C K"s
  210. Interior: 63 Lark Regal Rear Seatbelts
  211. Fuel System: Help on S/C I.D. and facts
  212. Interior: Seat belts in a '63 Cruiser
  213. Electrical: Routing Antenna Cable ('64 Daytona)
  214. Speedo/Tach/Gauges need everyones help to find a part
  215. Other: Lubrication of the steering gear, transmission, and rear axle - 47 Champion and 63 Avanti
  216. Speedo/Tach/Gauges Tach for a 1959 Silver Hawk
  217. Frame/Springs 63 Wagonaire Frame
  218. Body: Hood/Cowl rubber seal
  219. Clutch/Torque Converter: Clutch choice for engine swap?
  220. Exhaust Driver side manifold question
  221. Engine: Best place to connect electric choke?
  222. Cool/Heat: 240Z radiator in Champ
  223. Transmission: '55 automatic stuck linkage
  224. Speedo/Tach/Gauges Improving gauge lighting
  225. Interior: Modern bucket seats for a Lark
  226. Clutch/Torque Converter: top hole in bell housing
  227. Steering '63 Avanti Power Steering Reach Rod - I need help!
  228. Fuel System: Fuel sender
  229. Body: Random Glass
  230. Body: 57 Hawk production numbers
  231. Engine: Oil pressure issue?
  232. Body: Driveway Paint Job
  233. Transmission: questions about my trans( 3-OD)
  234. Electrical: Wiper and Fan switch not working 63 Lark
  235. Engine: Engine...Type
  236. Transmission: Band adjusting tools?
  237. Electrical: Headlamp Part Number
  238. Body: Trunk latching
  239. Brakes: 64 sedan rear brake line
  240. Fuel System: 1952 Champion carb ANYONE have a good(great) WE carb?
  241. Cool/Heat: 53/55 Lower radiator outlet
  242. Body: Side emblem removal method
  243. Interior: Dash paint for a '50 Champion
  244. Engine: TOOL UP! How do I know it's on cyl. 1 firing position???
  245. Speedo/Tach/Gauges Transmission swap creates speedo snaffoo
  246. Brakes: Power brakes booster
  247. Other: Vibration in gas pedal at 55mph
  248. Wheels Disc Brake Wheels and Turner Brakes
  249. Interior: windlace stop
  250. Brakes: Looking for a good Hill Holder....
