View Full Version : Tech Talk
- Electrical: Flasher ??
- Rear Axle: V8 Differential
- Engine: Which v8 to use in a 1961 Lark
- Other: wiper motors
- Fuel System: Tools required to rebuild '50 9G Carburetor ?
- Fuel System: Avanti Gas Tank refurbishment -
- Electrical: Who repairs radios?
- Interior: Avanti Console Trim Removal
- Engine: Head Gasket replacement on a '48 Commander
- Interior: Instrument Plates: Same for '64 Daytona/Challenger?
- Engine: Daily Driver 170
- Electrical: Instrument upgrades
- Cool/Heat: Saturn spoiler on Avanti II?
- Engine: Rear cam plug
- Steering Alignment ? '64 Daytona
- Brakes: Hill Holder Linkage Parts
- Engine: Need Head Gasket for '63 289
- Exhaust Drivers side exhaust pipe route?
- Steering Avanti Power Steering Hose Source
- Other: Dual Antenna "Upgrade"
- Ignition: Plug Wires recommendations?
- Engine: Engine oil weight for a new rebuild?
- Front Axle: spindles
- Electrical: 52 Champion won't start
- Cool/Heat: Physics queston
- Engine: Anything special about a truck 259?
- Brakes: need help with a part number or part
- Fuel System: June 2013 HRM Article
- Engine: Studebaker Engine Test Start
- Cool/Heat: Looking for bottom radiator hose for 58PH
- Engine: Supercharger tension pulley 89 Avanti
- Clutch/Torque Converter: Torque Converter repair
- Electrical: Wiring I.D. Help Please
- Speedo/Tach/Gauges 1955 President Speedster Tach
- Interior: Options offered
- Engine: Oil Pump gears
- Frame/Springs Let Me Recommend You Check Your Avanti Engine Frame Mounting Area
- Body: '63 Hawk Front Fender Attachment
- Engine: Surprize find
- Body: Help Identifying a Champ 6E-T6?
- Fuel System: Need help on installing a AFB Carb on my 63 GT Hawk 289
- Body: 1947 Studebaker Champion
- Engine: Wrong engine timing on 289
- Brakes: Stiff Pedal "Speedster"
- Fuel System: TBI fuel system conversion
- Interior: Door Lubricant
- Body: Hawk GT. Hood Kinks
- Front Axle: Need inner grease seals 50 champion control arms
- Engine: Ignition timing marks??
- Body: 54 hood problem
- Body: 59 Lark Starting Over!
- Engine: 47 Champion Valves
- Steering Oil for the steering box
- Engine: Bad oil filter mounting
- Fuel System: Red Kote experiences?? and new progress
- Fuel System: Fun supercharger fact
- Brakes: Need Steeltech Brake Help
- Clutch/Torque Converter: Clutch problems
- Electrical: Generator oil
- Body: Bracket use?
- Fuel System: Accelerator linkage for a Cathcart dual carb on '59 Lark wagon
- Brakes: Hard pedal
- Cool/Heat: Heater core screen
- Paint: Hubcap coloring
- Engine: Oil line question
- Clutch/Torque Converter: Hydraulic Throw out Bearing
- Body: Fender Emblem Sealing
- Engine: New engine oil pressure
- Interior: Shifter knobs
- Steering 50 Champion Steering box wire
- Cool/Heat: A/C Connections
- Rear Axle: TT twin traction 23 / 44 interchange
- Electrical: Is it a bad generator, wire, or voltage regulator?
- Fuel System: Carter WCFB butterfly opening
- Brakes: Frozen bleeder screws rant
- Brakes: All new but...
- Electrical: 59 Lark Wagon installing electric windows
- Engine: OIL USAGE in old cars
- Engine: Ok it's 2013, not 1963
- Brakes: Yet Another Disc Brake Conversion.
- Front Axle: Eliminate Front Coil Spring Spacers?
- Engine: Air cleaner on Sixes
- Brakes: 1966 Master Cylinder replacement?
- Brakes: Putting finned drums on the 55 President
- Frame/Springs Another... MOOG CC-655 front spring question
- Electrical: Wiring diagrams
- Clutch/Torque Converter: Need a part, can anyone help.
- Electrical: One trick and a little horn tone help needed
- Electrical: Radio Powerup Help
- Engine: R-1 carb question....
- Cool/Heat: Summit radiator
- Fuel System: Carburetor hook-up
- Frame/Springs Front Spring Question
- Speedo/Tach/Gauges Speedo Quitting
- Electrical: Turning Signal fuse? ('66 Commander 4door)
- Body: Need help installing fender welt.
- Fuel System: 58 Golden Hawk Fuel Pump Question?
- Other: Always Check Your Engine For Leaks
- Body: 2R5 Cab Spring Tension
- Engine: Exhaust Crossover
- Engine: 3/8-16 plugs at front of engine (behind generator)
- Brakes: 50 Stude brake part needed
- Brakes: Alcohol flush
- Transmission: No Reverse
- Frame/Springs '50 Commander spindles
- Fuel System: Need to buy a new tank 62 lark
- Ignition: Distributor curve for 259
- Transmission: proper T-10 4 speed lubricant?
- Body: fibreglass 53 - 54 hoods
- Engine: Description of "full flow motor"
- Electrical: Light-switch switching...
- Brakes: '53 and back brakes vs '54 and later?
- Electrical: Condensers, ammeter, alternator and grounds
- Engine: help with a 169.6 flat 6 balancer
- Fuel System: Gas tank info.
- Interior: Width of Lark bucket seats
- Steering power steering for 48 Champion
- Drive Shaft Brain pick....
- Engine: 1948 M15A Champion Rear Main Seal
- Interior: opinion
- Electrical: 1959 silver hawk
- Engine: R & R Rear main seal and oil pan gaskets ??
- Interior: seat belt questions
- Engine: Clone R3 Heads Get Fitted for Titanium Valves
- Engine: Knock ? fuel pump?
- Brakes: 62 Lark
- Transmission: First gear start control valve
- Body: Trunk Alignment and Lock
- Body: Avanti power window alignment
- Engine: Fan belt sizing for a 1938 commander
- Fuel System: Stromberg Carby
- Drive Shaft Optimal driveshaft length
- Transmission: 64 Daytona, no reverse
- Cool/Heat: Temp gauge Gremlins...
- Body: air deflector panel for '63 wagon - fixed
- Fuel System: NEW Single-Barrel Carburetor Available
- Fuel System: Electric Fuel pump & pressure switch...again
- Body: 1963 Studebaker Daytona Hardtop fenders and crossmember question
- Other: twin traction stickers for dash
- Transmission: 66' 283v8 2 or 3 speed?
- Fuel System: Electric Fuel Pump Selection
- Ignition: Distributor stuck?
- Brakes: Brake pedal won't depress, at all, GT Hawk??
- Body: GT Hawk Script and Birds
- Electrical: Studebaker Avanti Wiper Motor Arm Clip?
- Interior: replacement solution for Wagonaire headliner?
- Engine: 283 oilpan...which one?
- Clutch/Torque Converter: Ruined fly wheel and starter drive.
- Transmission: T-86 overdrive parts question
- Fuel System: Nice Looking early WCFB Phenolic Insulator (Ebay) 4/29/2013
- Body: Champ Fender to Firewall
- Body: 63 lark trunk seal
- Engine: Dual Needle Boost Gauge
- Body: 58 PH fender signal "wings" gold or chrome?
- Electrical: Newport Wipers install
- Frame/Springs 59 Lark Leafspring Replacement
- Engine: Air cleaner orientation
- Frame/Springs Just a progress report on my '63 Daytona's crossmember
- Brakes: e-brake lamp switch.
- Wheels What'll fit???
- Brakes: power brakes
- Steering Early (saginaw integral) vs. Late (Bendix) Power Steering
- Frame/Springs Spring time in California
- Speedo/Tach/Gauges Champ Speedo cable question
- Brakes: e-brake foot lever indicator lamp switch -?'64 park brake
- Body: gt hwk fender
- Engine: 169.6 flat 6 help again please
- Body: Can anyone identify the badge on the Grill of this Studebaker?
- Cool/Heat: Is there a fix for this or am I in trouble?
- Cool/Heat: Lower radiator hose - needs a coil spring or not?
- Speedo/Tach/Gauges 1966 Commander Speedometer repairs?
- Drive Shaft U-joint replacement help needed
- Frame/Springs Leaf Spring forward pivot position
- Transmission: Commander 6 Automatic Question...
- Brakes: Parking brake handle relocate
- Rear Axle: Does a rearend with TT use the same axle
- Interior: 58 Hawk door panel install
- Transmission: Strange noise
- Engine: sixteen thousand valve clearance 170cu in flat 6
- Brakes: brake shoe hold down clips
- Engine: Valve Oil Seals for bronze Guides
- Brakes: Bleeding the system again...
- Ignition: Airtex distributor conversion for Prestolite (Autolite)
- Exhaust Fear!
- Interior: Lark Windlace core diameter?
- Electrical: Anyone seen this on their 1950 Commander
- Speedo/Tach/Gauges Lark tachs?
- Body: Nitpick
- Engine: 1950 Champion 170cu.in dip stick question
- Body: 62-up Lark trunk hole plugs?
- Engine: Best way to tell if motor is stuck?
- Brakes: "55 Speedster Hard Pedal, To No Pedal
- Front Axle: Aerostar front end into 2R5
- Engine: Fan shroud
- Frame/Springs Front spring rear hanger bolt
- Brakes: Wheel cylinder for a 1938 commander
- Ignition: Pertronix II Versus Original Pertronix
- Fuel System: 2 barrel vs. 4 barrel carburetor
- Engine: bad timing gear
- Rear Axle: Possible Rear End problem
- Body: radiator baffle
- Body: 1960 Hood ornament clarification
- Frame/Springs I am stll looking for s gt hawk frame
- Frame/Springs I am stll looking for gt hawk frame
- Steering Power steering noise (whine)
- Frame/Springs Spring Time in California: UPDATE
- Fuel System: PCV Valve for an Avanti R2
- Interior: Avanti II headliner install
- Body: cowl weatherstriping installation on a 1953 c coupe
- Wheels Hubcaps 1951 Champion
- Electrical: Switching to a chevy Alternator
- Body: '63 wagonaire tailgate window run ?
- Fuel System: Easiest way to remove and replace the Fuel Sending Unit on a Studebaker Avanti?
- Body: 1964 Wagonaire Tailgate Window Mechanism
- Steering Power steering hoses
- Engine: core plugs
- Fuel System: Carburetor Adapter Block
- Other: 1964 Wagonaire rear window stopped in the closed or up position.
- Fuel System: How to remove the Fuel Pump Bowl on a '53 Landcruiser
- Body: 58 PH radiator baffle and seal
- Engine: distributor questions
- Body: Mirror holes
- Electrical: Confused. Engine was stalling, but now seems fine.
- Engine: Avanti mystery.
- Paint: 1961 Hawk running gear paint
- Engine: Avanti R series engine articles from 1963
- Other: 61 Lark Striker Plate
- Engine: 170 cu.in manifold question
- Fuel System: Must prime the carb to start - questions about siphoning, fuel lines and tank
- Electrical: Commander switches...
- Engine: crankshaft bolt
- Fuel System: Fuel pump install
- Body: Rear Passenger Window Adjustment
- Body: Getting a stuck Avanti trunk open
- Engine: R1 Starter vs Regular Starter
- Engine: 259 Stude HP/ How Much?
- Brakes: 10 lb. residual pressure check valve failure
- Steering won't turn short
- Speedo/Tach/Gauges Location and specific number
- Engine: Building R2 Daytona-- water manifold troubles
- Cool/Heat: Overheating, or close to it!
- Electrical: Rebuilt Delco Generator
- Fuel System: A word on Viton needle valves and our current fuel.
- Other: '53 Grill Trim pieces
- Transmission: Popping out of Gear
- Body: '53 Taillight Mountings
- Transmission: Transmission replacement
- Wheels 15-5 rims for Speedster Wheel Covers - Need Tubes?
- Fuel System: How do I adjust idle speed on this carburetor ('84 Avanti)?
- Electrical: 55' pickup. Pos. or neg. ground?
Powered by vBulletin® Version 4.2.4 Beta 2 Copyright © 2019 vBulletin Solutions, Inc. All rights reserved.
