View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119
  1. Engine: Timing Procedure for OHV 6
  2. Fuel System: 3588S Carb Choke rod end quesiton
  3. Body: Replication of existing rubber part.
  4. Engine: Intake and exhaust manifold gaskets
  5. Clutch/Torque Converter: pic needed
  6. Speedo/Tach/Gauges Wiring tach on Golden Hawk
  7. Electrical: 1950's black light dashlights
  8. Engine: Crank hub bolts
  9. Other: '53 Studebaker Champion Sedan ID plates
  10. Engine: tips/tricks
  11. Other: Servicing The Power Steering/Rear End
  12. Transmission: T86 Transmission - Floor Shift Conversion?
  13. Wheels anybody still widening wheels?
  14. Transmission: 1950 Champion With Stuck Transmission
  15. Transmission: Gear Clashing
  16. Ignition: Neutral safety switch?
  17. Transmission: Overdrive Problems
  18. Frame/Springs Transplanting Stude car front suspension to truck frames????
  19. Frame/Springs 1952 Champion 2 dr to convertable frame x brace
  20. Electrical: Overdrive relay Operation
  21. Interior: Windlace ??
  22. Front Axle: Ford Aerostar front end under a Stude car?
  23. Electrical: Avanti (Delco) AM/FM Radio Parts
  24. Wheels White Wall Radials
  25. Rear Axle: rear leaf spring modification help???
  26. Speedo/Tach/Gauges Inoperative speedo
  27. Brakes: 56J rear drum replacement on Dana 44
  28. Fuel System: Engine coughs when shifting
  29. Engine: 65/66 Chevy Baker Engine Mounts
  30. Exhaust dual exhaust fitment on 58 Packard Hawk
  31. Clutch/Torque Converter: tightening bolts on torque converter
  32. Engine: Crunching numbers
  33. Electrical: Horn Wiring
  34. Body: Convertible 1947 Dome light
  35. Transmission: M5 gearshift knob pick up 1946
  36. Engine: Attention Mike VV - aluminum filled exhaust bowl
  37. Engine: Studebaker Oiling
  38. Drive Shaft Driveshaft for Explorer rear axle ?
  39. Cool/Heat: V-8 water pump...
  40. Frame/Springs GT Hawk frame wanted
  41. Engine: chevy engine swap sb chevy in a gt hawk
  42. Body: loose exterior door handle
  43. Exhaust 1965 Wagonaire dual exhaust question
  44. Frame/Springs surface rust - POR-15
  45. Brakes: Hill Holder won't let go
  46. Fuel System: 58 PH Super Charger box question
  47. Body: Doors off?
  48. Electrical: Starter Noise
  49. Body: Keys for the locks
  50. Transmission: missing transaxle gears
  51. Electrical: 62 GT Clock out of control
  52. Steering Power steering fluid 62 gt hawk
  53. Wheels Champ pickup tire pressure?
  54. Other: Flushing The Cooling System
  55. Electrical: starter relay wiring
  56. Engine: timing gear fit 259V8
  57. Rear Axle: Let's Try this Again, Dana 44 Ring & Pinion Question
  58. Electrical: 63 Avanti Power windows
  59. Electrical: Avanti right front signal lamp
  60. Body: Rust holes in the floor pan.
  61. Speedo/Tach/Gauges speedo
  62. Fuel System: Lead Substitute
  63. Steering PS Reservoir lid
  64. Front Axle: Chrome upper outer control arm bushings
  65. Body: Retractable antenna
  66. Body: 63 Champ Door fit
  67. Fuel System: Avanti gas tank filler
  68. Interior: Seatbelts with shoulder harness, '64 Daytona, FOUR door
  69. Steering Converting Column Shift to Floor Shift
  70. Clutch/Torque Converter: Need another torque converter sometime in the future
  71. Body: Champ truck floors
  72. Body: 1952 K2 converted to a Convertible (Tacoma)
  73. Wheels Chevy Drum Conversion
  74. Transmission: 48 Champ O/D trans
  75. Electrical: Gas gauge 57 silver hawk
  76. Engine: Oils of yesteryear
  77. Engine: Quench, deck ht. and dished pistons
  78. Electrical: Wanted: generator and regulator 62' Stude
  79. Electrical: Running wires under the Avanti- using PVC Conduit: anyone have any experience with this?
  80. Other: New Avanti tech articles available - For your information
  81. Brakes: Front brake drums for 49 Champion
  82. Transmission: O/D solenoid
  83. Brakes: Check valve
  84. Interior: Carpet/ Rubber Floor Matt
  85. Engine: 51 Champion, faltering on hills
  86. Body: Fiberglass v. steel C/K body panel weight?
  87. Body: Help! rigid window run replacement on my 63 Wagonaire.
  88. Frame/Springs 1963 Trailer Hitch Lark Daytona
  89. Brakes: Lark: How much brake fluid?
  90. Clutch/Torque Converter: broken clutch damper springs
  91. Drive Shaft T-85 in Conestoga
  92. Fuel System: electric fuel pump
  93. Body: driver door fit
  94. Rear Axle: Leftover Parts - and Check out the new Engine
  95. Electrical: Getting my SW tach to read an HEI
  96. Body: GT Glass Spec
  97. Engine: supercharger
  98. Steering New noise in my 8E pick-up steering box
  99. Electrical: Relay under dash, -55 Champion sedan
  100. Ignition: Looking for new distributor for 62 Lark
  101. Electrical: Battery Relocation
  102. Rear Axle: Oil leak
  103. Interior: golden hawk seat belts
  104. Transmission: 63, 289 into a 52 ??
  105. Brakes: Master cylinder
  106. Transmission: Shift lever removal
  107. Interior: Disconnecting gas pedal
  108. Brakes: 1963 Lark Master Cylinder Questions
  109. Engine: R1/R2 Balancer And Pulleys Hawk VS. Avanti Info Needed
  110. Speedo/Tach/Gauges speedometer and odometer quit
  111. Body: Need front fenders
  112. Body: VIN Number
  113. Shocks rear shocks for 63 Wagonaire?
  114. Body: 58 PH decklid Packard letter and bird location
  115. Electrical: horn ring
  116. Ignition: 1951 champion coil
  117. Electrical: wiper circuit breaker
  118. Engine: Interesting discussion of piston rings....
  119. Other: is there a trick to putting a sway bar in?
  120. Body: Lark Fender interchange
  121. Fuel System: New EFI system for any R-engine...
  122. Engine: 1962 Block in '64 car
  123. Engine: Does this symptom indicate a starter problem?
  124. Cool/Heat: Subject: antifreeze ... Do Not Use in cars over 10 years old
  125. Transmission: shift lever replacement.
  126. Engine: Head Chatter Marks
  127. Engine: Oil Pressure 259ci
  128. Engine: Rear Main Seal Journal
  129. Cool/Heat: Water on front crossmember - 63 Lark 259
  130. Engine: Oil Pressure guage
  131. Electrical: (Lighting) New Option For Headlights - LED
  132. Body: Hog Troughs for 52 Conversion
  133. Body: chroming pot metal
  134. Speedo/Tach/Gauges 58 Packard Hawk Dash questions
  135. Transmission: Anyone have an idea on this one??
  136. Transmission: Which mount? T5 in 53 Champion behind 64 289
  137. Other: Windshield Washer
  138. Body: 1955 president 2 door coupe Door vent windows.
  139. Transmission: 55' Automatic Transmission Service
  140. Cool/Heat: 63 /64 GT heater install in a 61 Hawk
  141. Electrical: Finding a short/electric help?
  142. Fuel System: Paxton NOVI 2000 supercharger
  143. Other: Windshield Washers on my '50
  144. Fuel System: R4 Dual 4s
  145. Clutch/Torque Converter: Pressure Plate Retracting Spring
  146. Body: '64 Hawk hoods
  147. Front Axle: '54 C/K front suspension vs. '64 Cruiser front suspension
  148. Other: 1964 drag or pro street Grand Turismo for sale
  149. Body: Side Window Adjustment?
  150. Body: Cowl Tag
  151. Body: Outside mirror attachment - Lark
  152. Frame/Springs Seeking Parts & Info regarding 58-61 & 62-64 C-K Rear Spring Brackets (Front)
  153. Rear Axle: M16 outer rear wheel seal
  154. Electrical: Best ignition coil
  155. Transmission: T-90B verses T-86
  156. Exhaust Is there a sniffer for this?
  157. Electrical: Heater fan motor issues
  158. Engine: engine rebuild
  159. Fuel System: (1963 v8) Lark suddenly died in traffic!!!
  160. Fuel System: 10% Diesel in the fuel tank???
  161. Body: Filling & purging convertible top hydraulic system?
  162. Ignition: Prestolite or Autolite?
  163. Fuel System: Supercharger part needed
  164. Paint: Before/after photos if you have them
  165. Supercharger Question - Expert Needed
  166. Steering Avanti II Power steering: A tale of two pumps and four hoses
  167. Interior: Avanti Headliner Replacement
  168. Engine: Supercharger Question - Expert Needed
  169. Transmission: Transmission is blocked
  170. Engine: will this work?
  171. Fuel System: Day dreaming out loud: MegaSquirt
  172. Cool/Heat: C/K radiator installation
  173. Ignition: Pertronix or T-bow conversion?
  174. Electrical: flasher wiring
  175. Electrical: Grounds: Where are they, and how many are there??
  176. Electrical: Wiring for Stop/Tail/Rear Signal sockets--'63 Avanti
  177. Ignition: Pertronix 1183 ballast resistor?
  178. Engine: A discussion of flat tappet cams and lifters
  179. Engine: Motor Mounts
  180. Fuel System: 58 PH carb box color?
  181. Speedo/Tach/Gauges 1960 Lark dash
  182. Drive Shaft Drive shaft needed
  183. Body: TT emblem on 58 PH decklid
  184. Cool/Heat: climatizer
  185. Electrical: Quickie '51 question for the day #1: bulbs
  186. Engine: Quickie '51 question for the day #2: fuel line
  187. Fuel System: Gas Tank Needed
  188. Transmission: Gears slipping?
  189. Engine: 6 Cylinder Engine ID Question
  190. Exhaust Help with brass nuts.
  191. Rear Axle: MoPar guy says why not??
  192. Brakes: HydroVac
  193. Engine: Lark Motor Mounts-Frame Mounts V8 vs I6
  194. Clutch/Torque Converter: 56 Power Hawk on the mend.
  195. 1946 stude pick up electrical
  196. Frame/Springs Buick (GM) front spring installation on Sat.
  197. Rear Axle: Axle shaft oil seal needed!
  198. Exhaust Champion Headers Wanted
  199. Body: 56 commander parkview wagon trim needed/info
  200. Electrical: Need source for Wagner brushes
  201. Frame/Springs spring bushing experts?
  202. Fuel System: Avanti/Mopar Fuel Filler
  203. Engine: valve covers for a 259 4 barrel V-8
  204. Engine: oil pump and grounding questions
  205. Fuel System: Intake Manifolds
  206. Engine: Lark VI motor rebuild
  207. Body: 59 silver hawk
  208. Body: 59 silver hawks parts
  209. Engine: Oil pressure gauge
  210. Interior: Instrument rebuild
  211. Engine: '63 Lark v8 - Currently has 2BBL. Would a 4BBL be THAT much better? If so, where to find a manifold?
  212. Other: Door Locks 1963 vs 1964
  213. Electrical: Jim needs help
  214. Transmission: T96 trans leaks
  215. Fuel System: My chugging Avanti
  216. Interior: Need part number or description - pillar cardboard
  217. Body: 1947 Studebaker Champion
  218. Brakes: 50 Champ Brake Build Up Pressure and Lock Wheels
  219. Other: Has Anyone Tried The Dustless Blasting System Yet
  220. Rear Axle: End play in rear axle shaft
  221. Frame/Springs Question (and funny observation)..
  222. Engine: timing covers 6 cylinder (Lark 63)
  223. Frame/Springs Question (and funny observation)..
  224. Electrical: Battery for 58 Hawk
  225. Body: Floor pannels rocker pannels and hog trough re-enforcement -body aligment K-2 Convertible/ Conver
  226. Engine: Info for anyone that bought my adjustable gear drive..
  227. Electrical: 232 12volt grounding question
  228. Other: 1964 Avanti Red, also GM Pompein Red and GM Honduras Maroon
  229. Paint: 1964 Avanti Red, also GM Pompein Red and GM Honduras Maroon
  230. Wheels Rim Failure (55 c body)
  231. Electrical: Power window - Relay question
  232. Fuel System: Holly Truck Avenger Carb
  233. Engine: 1965 Studebaker 283 engine
  234. Engine: 1946 stude pick up M5
  235. Body: Skirts
  236. Cool/Heat: Car cooler
  237. Frame/Springs coil springs for a '50 Champion
  238. Transmission: NOS in box 59-63 Overdrive Control Govener with 2 NOS Control Switches
  239. Cool/Heat: 58 Packard Hawk AC
  240. Cool/Heat: 58 Packard Hawk with ac cooling fan spacer
  241. Ignition: 63 Avanti R2 Mech Advance of the Mallory Distributor from Dave T.
  242. Transmission: Powershift tranmission cooling line routing?
  243. Other: Door Striker Plate
  244. Frame/Springs Restomod Using Lincoln Town Car Chassis and Drivetrain
  245. Engine: Valve Lubrication Avanti R2
  246. Electrical: 51 Champion Temperature Sending Unit
  247. Fuel System: 8E5 fuel tank size.
  248. Other: Windshield Washer
  249. Cool/Heat: Expansion tank for 60 Hawk
  250. Electrical: delco distributor advance weights
