View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Brakes: Master Cylinder part number 1561611 66 Comander
  2. Engine: Oil Pressure 289
  3. Engine: The Real Reason For Low oil Pressure in My R-2 Avanti
  4. Interior: Headliner Material Question
  5. Front Axle: Control arm rebuild tools
  6. Electrical: How do I know if the generator is charging? Do I polarize the gen before starting? 55, c-body 2 dr
  7. Other: Steering wheel beyond repair?
  8. Ignition: Starting Problem
  9. Rear Axle: strength and durablity of the rear
  10. Engine: OHV 6 spark plug length
  11. Body: 57 Hawk Fin Fit - requesting Photo of tail light area
  12. Brakes: Brake wheel cylinders
  13. Electrical: Did they ever Make a 6 volt timing Light ,or are they universal?
  14. Body: Stupid Question , are all 55 steering wheels two tone in color? 2dr president c-body
  15. Rear Axle: 39 CE diff interchangibilty
  16. Brakes: Rebuilding Wheel cylinders - Red Rubber grease: where to get? Is Dielectric grease same/OK?
  17. Body: Trying to ID some bumper guards
  18. Electrical: Is there a seprate wiring harness under the dash of a 55 president ( 2 dr c-body)
  19. Frame/Springs Do lot of you put the stude on jack stands for the winter?
  20. Rear Axle: Is the Flange axle ,basically a 1 piece axle?
  21. Body: 1951 Convertible Door Window Assembly
  22. Fuel System: BBR1 633S Carb Parts
  23. Ignition: Pertronix Parts List for Champ 6 and V8s
  24. Electrical: Voltage regulator question
  25. Body: Sheet metal for a '66 Daytona?
  26. Engine: V8 Engine parts compatability
  27. Body: 50 starlight coupe trunk
  28. Brakes: Brakes pulling to the right.
  29. Engine: Valve guide sizes
  30. Transmission: '57 President Transmission performance evaluation
  31. Brakes: Hill Holder dilemma....?
  32. Electrical: Wiper motor 12 volt / 12 volt conversion 1952 Champion?
  33. Body: Can anyone help Me decode these VIN #'s?
  34. Electrical: Basics......
  35. Body: M5 Pickup truck VIN / ID # location
  36. Paint: Modern paint codes?
  37. Body: Rear quarter windows, 1953 Commander 2 dr Starliner
  38. Exhaust 63 Avanti Headers?
  39. Transmission: 64 Station Wagon 6 cyl.
  40. Electrical: trunk light wiring
  41. Brakes: Dual MC conversion on '56 Sky Hawk
  42. Engine: Chevrolet to Studebaker V8 swap.
  43. Body: 1964 Cruiser Side Trim Removal
  44. Engine: 289 Crankshaft
  45. Interior: I have a radio question???
  46. Shocks Shocks and ride height
  47. Front Axle: ANYONE EVER INSTALL MUSTANGii SUSPENSION FRONT SUBFRAME FROM HOT RODS AND BRAKES
  48. Interior: interior paint color for 58 Packard Hawks
  49. Engine: R-series dipstick
  50. Body: 63 hawk grill surround
  51. Engine: Coating Process for Head and Intake Gasket
  52. Body: Safety catch (hook) on '59 Lark hood
  53. Body: body panels
  54. Body: Replace hood springs on 58 Golden Hawk to eliminate Hold up Bar??
  55. Engine: Avanti Engine Upgrade
  56. Engine: Avanti Soft Plugs...
  57. Cool/Heat: radiator mounting 48 champ
  58. Body: 56-58 kick pad retainers
  59. Engine: 1955 President "Speedster" Thermostat
  60. Body: Decode this VIN please.
  61. Fuel System: Carb to EFI
  62. Transmission: 58 Packard transmission woes
  63. Engine: oil pressure guage
  64. Brakes: Rear Turner Disc drag- Ideas to fix or adjust it?
  65. Transmission: Flight-o-matic Transmission locking up when shifting from low to high!
  66. Rear Axle: 1949 2R5 Axle Seal Identification
  67. Electrical: Back up lights
  68. Body: Windshield Install - got it done!
  69. Engine: Custom cam help.
  70. Body: 60 Hawk rear fender HELP !
  71. Electrical: Fuse for the dash-light?
  72. Brakes: Pre war brake shoe and hardware
  73. Body: ? for those who have installed rear quarter windows in K body cars
  74. Steering bellcrank and bracket...when to rebuild?
  75. Engine: Oil Pan interchange.
  76. Transmission: 1960 Lark, 6 cylinder, 3 speed OD bellhousing color
  77. Electrical: Grounding the voltage regulator
  78. Fuel System: 4 Jet Carter 4 barrel carbs
  79. Brakes: Brakes
  80. Engine: Adding oil filter to 170 OHV
  81. Engine: Exhaust header for 170 ?
  82. Electrical: Horn location in '59 Lark
  83. Transmission: Overdrive seal
  84. Fuel System: Finally, a METAL air cleaner adapter ring!
  85. Engine: Mild cam for a champion six
  86. Body: 62 studebaker 2 door lark daytona hardtop
  87. Wheels 1947 M15a-20 tire help
  88. Brakes: Lark brake shoe interchangability?
  89. Body: vent window not fitting K body
  90. Body: Lark Convertible hog trough replacement
  91. Brakes: Jaguar brake parts interchange
  92. Body: Vent window: K body vs '51-52 Convertible
  93. Body: 58 PH fin strip joiner?
  94. Brakes: 65 Master Cylinder
  95. Rear Axle: Differential whine
  96. Brakes: Manual 11" Drum brakes
  97. Interior: Glove Box Door Information Sheet. 47 M16
  98. Brakes: Brake line Flushing.
  99. Fuel System: Cutting pipe on a "StudeMopar's" Thermo-Quad..
  100. Body: Rust issues
  101. Fuel System: Thermoquad Carb
  102. Body: More vent window ?s K bocd
  103. Other: Vendor from South Bend
  104. Brakes: Trying to get motivated
  105. Engine: Piston ring question
  106. Engine: Core Plug Popped Out
  107. Engine: sbc low(ish) oil pressure
  108. Body: Anti vibration weights in '59 Larks
  109. Brakes: M5 front
  110. Other: Whats this worth in your world ?
  111. Electrical: Correct Speakers
  112. Fuel System: Dropping gas tank 53 Coupe
  113. Ignition: Distributor Identification
  114. Body: Tail gate spring
  115. Brakes: Leading and Trailing Brake Shoes.
  116. Interior: How do i remove panel by rear seat on my -55 4-door sedan?
  117. Fuel System: Throttle linkage??
  118. Engine: Seized Engine Update
  119. Paint: Paint restoration
  120. Body: 54 Coupe Quarter Window Repair/Restoration
  121. Paint: In general: is it better to repaint the original color?
  122. Brakes: 1951 2R5 brake shoe retainers & e-brake cable
  123. Brakes: Disc brakes on a 51 Champion
  124. Engine: V8 Camshaft Dimensions Needed
  125. Electrical: Generator cut-out connection
  126. Engine: Early STUDEBAKER
  127. Electrical: Need a Battery Box for my '62 Hawk
  128. Shocks 1959 Studebaker Lark- Rear Leaf Spring and Shocks
  129. Body: NEW GLASS OR USED? 55 President C Body Coupe
  130. Engine: Block Prep for Bonneville Engine
  131. Wheels Making white walls into black wall tires
  132. Rear Axle: How to pull a rear axle
  133. Engine: Correct Plug Wires
  134. Fuel System: 4BBL Carburetor Questions. Help Me identify these carbs Please!
  135. Fuel System: ...Another 4BBL for identification..........
  136. Interior: Who can Identify these rubber floor mats?....Years please!
  137. Fuel System: Super lark fuel return line
  138. Frame/Springs Ride height 55 C-K
  139. Brakes: Bleeding a Hill Holder
  140. Brakes: Anybody have any experience with this eBay seller? (Brake Hoses)
  141. Ignition: Delco distributor parts missing
  142. Interior: 55 Pickup seat back hinge
  143. Wheels front wheel grease seal/retainer
  144. Brakes: M5 Pickup brakes
  145. Engine: C-cab V-8 front motor mount spacers
  146. Engine: Crankshaft pulley bolt
  147. Fuel System: Commander Fuel Pump
  148. Wheels Whitewall Repair
  149. Body: Undercoating
  150. Body: How to remove Avanti body from frame
  151. Engine: V/8 (car) special starter bolts needed
  152. Cool/Heat: avanti a/c
  153. Interior: headrests
  154. Transmission: 259 v8 3 speed swap to a 5 speed
  155. Engine: Valley cover
  156. Electrical: Avanti radio static
  157. Electrical: fuses
  158. Interior: Lights + ignition switch=years? (pic)
  159. Body: Question: Rear window U channels with rear vent window--how long? 5 feet should be enough.
  160. Engine: CCing heads
  161. Engine: golden hawk fan shroud
  162. Engine: questions identifying Stude v8
  163. Electrical: P and l terminals on flasher
  164. Transmission: 1st gear start?
  165. Interior: Horn button ID?
  166. Ignition: Source for distributor
  167. Wheels Source for wheels
  168. Steering Steering Column Setup
  169. Other: Source for oil pan
  170. Electrical: Studebaker Avanti starter solenoid
  171. Engine: Oil filter wont fit on tube
  172. Transmission: Has anyone used Marvel Mystery Oil in a Studebaker manual transmission?
  173. Body: '63 Hawk GT AC Rt vent rod? HELP!
  174. Steering Steering wheel interchange
  175. Engine: Newbie needs help
  176. Electrical: amp meter wiring
  177. Electrical: Source for ignition switch?
  178. Clutch/Torque Converter: New clutch wont disengage
  179. Other: Getting a 55 Champion to perform better at higher speeds
  180. Engine: Next on my rebuilt 259, need help
  181. Transmission: transmission/overdrive oil 1950 champion
  182. Other: Cleaning front suspension 1950 Champion
  183. Wheels Weather Checking Prevention?
  184. Fuel System: Block-off plate and line routing
  185. Interior: Headliner installation
  186. Engine: Dipwad breaks dipstick...film at 11
  187. Steering Make Note Of This! Steering Parts Rebuilder
  188. Wheels How big?
  189. Steering Steering Wander
  190. Transmission: Top shifter stuck
  191. Engine: Amazing Flow Test Results on Stude Heads
  192. Transmission: T-86 with O/D seal replacement
  193. Rear Axle: 1949 2R5 Rear Axle Vent Location
  194. Clutch/Torque Converter: part #536306 and 532051
  195. Fuel System: fuel sending unit
  196. Rear Axle: Dana 44 TT rear axle
  197. Fuel System: external fuel pump actually needed?
  198. Body: Batwing body mount on 47-52 convertibles and hardtops
  199. Electrical: fuel sender-unit, does volt matter?
  200. Engine: What is it?
  201. Speedo/Tach/Gauges Speedometer Drive
  202. Paint: '59 - '61 Hawk side grill color
  203. Electrical: Project electrical on 60 Hawk
  204. Body: Firewall replacement for chevy v-8 meeting
  205. Body: Leading the 58 PH fins
  206. Speedo/Tach/Gauges OIL pressure guage
  207. Shocks Shock ID help
  208. Other: Tires
  209. Electrical: Generator/Distributor Oil
  210. Engine: Knocking Noise Source
  211. Engine: Valve Question
  212. Frame/Springs I have inserts in my front springs
  213. Transmission: Is a tranmission cross-member needed on a 4-spd?
  214. Transmission: Transmission parts for 1-ton Transtar
  215. Rear Axle: shocks
  216. Engine: 1950 Champion Dies on Idle
  217. Front Axle: Stepped contol arm bushings
  218. Electrical: head light fuse
  219. Engine: '55 Speedster Comes Alive!
  220. Transmission: T86 1A Top shifter leak
  221. Fuel System: Stromberg 2 barrel ??
  222. Body: Hawk Vent Window Rubber Replacement
  223. Body: 62-63' Lark front fender/apron re-fit...
  224. Electrical: 53 Champion turn signal and engine wiring help needed. Please!
  225. Engine: Cylinder heads.
  226. Body: Help with truck paint color
  227. Frame/Springs Drop spindles for a '53 C-K
  228. Wheels Wheels which take the 39 hubcaps?
  229. Engine: Oil Pan Install advice
  230. Body: Bumper straightening
  231. Brakes: Brake fluid
  232. Fuel System: Triple carb questions
  233. Body: A-pillar,,,,B-pillar,,,,door adjustment??????
  234. Fuel System: Gas left in tank (1963 Avanti R1)
  235. Engine: 259 V8 Rebuild
  236. Fuel System: need help on carburetor info
  237. Electrical: Ignition switch wiring
  238. Speedo/Tach/Gauges Help-R2 tach drive with Pertronix and MSD ignition
  239. Other: 1953 Sedan Mirror
  240. Engine: leather strips under the hood
  241. Drive Shaft u-joints
  242. Need carburetor. Also a transmission question.
  243. Steering power steering for a 1956 Commander Parkview wagon
  244. Frame/Springs Flex-a-form springs
  245. Other: Correct Hardware Kits Available
  246. Fuel System: Stude V-8 Edelbrock Intake Question
  247. Rear Axle: Shop Manual Makes It Seem Involved:-(
  248. Rear Axle: What Pinion Yoke do I need?
  249. Interior: 1957 Packard Clipper Dash Pad Question
  250. Engine: Timing Procedure for OHV 6
