View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 [74] 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Body: Finally into the Speedster ... #3
  2. Other: ID for Production Order for 50 Champion?..
  3. Speedo/Tach/Gauges 1956-58 sedan Speedometer problems
  4. Clutch/Torque Converter: automatic transmission converter
  5. Engine: aluminum cyl head, champion six
  6. Body: Door window repair- 1950 Champion
  7. Steering 1966 wagonaire front subframe question
  8. Body: Would you weld new Rocker Panels in before removing body or after putting it back on ?
  9. Engine: What is the factory color of the 289 cu in engine for a '63 Avanti R3?
  10. Brakes: 2R10 pick up rear wheel bearing nut wrench
  11. Frame/Springs Any rivets needed besides for front crossmember? (while I'm ordering....)
  12. Engine: New Lifters for 259, 1955
  13. Fuel System: Avanti Style Fuel Tank installation
  14. Brakes: Hawk brakes
  15. Engine: plug wire length
  16. Engine: Oil Pan Removal
  17. Body: Chrome mounting drilling templates needed 1955 C- President
  18. Steering 1950 Commander/LC Steering Column
  19. Engine: 259 with Paxton blower, would this make an R 1.5?
  20. Body: New door window glass-1950 Champion
  21. Steering Jacket bearing spring seat
  22. Body: Question for you bodymen types
  23. Steering '59 Silver Hawk PS conversion
  24. Engine: Too pretty to bolt on!
  25. Electrical: Where can I buy a replacement power window switch?
  26. Ignition: Can someone identify this distributor?
  27. Steering Worn Ross TL sector shaft pins
  28. Engine: motor and trany for sale
  29. Clutch/Torque Converter: Throwout bearing part number
  30. Interior: Rear bench seat upholstery
  31. Fuel System: Fuel Sender For '56 Power Hawk
  32. Cool/Heat: 6 volt blower motor motor
  33. Other: drivers side window on na 62 lark daytona hard top
  34. Steering bushing or bearing
  35. Engine: Need a little help here guys
  36. Transmission: Overdrive Testing
  37. Electrical: 6 to 12 volt
  38. Steering How to ID tie rod ends?
  39. Body: Need help installing Starlight Coupe rear windows
  40. Frame/Springs 1951 2R5 rear leaf shackle bolts
  41. Cool/Heat: Looking for some help with Heater (climatizer) for 49 2R5
  42. Other: General Safety Questions
  43. Transmission: Are linkage components the same?
  44. Body: The edge behind the front wheels...
  45. Body: Cowl Sections and Upper Rear Panels
  46. Body: '55 fish mouth grill and parking lights..
  47. Cool/Heat: Temp gauge
  48. Body: 64 hawk hood bumpers
  49. Other: chassis number 1939 coupe express
  50. Cool/Heat: Radiator Hoses with a 4.3L V6
  51. Engine: 63 Avanti R2 4 Speed: RPM
  52. Interior: 1962 Hawk bucket seats swap?
  53. Engine: Rebuilt Avanti Engine Is Pretty Tight
  54. Front Axle: Serious alignment issue
  55. Engine: Wet plugs on flathead 6, probably dumb question...
  56. Body: 1929 dictator
  57. Frame/Springs New front springs for 1957 President with air.
  58. Fuel System: Locking Gas Cap removal
  59. Brakes: Disassembling A 'No-Rol' Hill Holder
  60. Exhaust Torqueing a wobble extension
  61. Engine: Fixing a rear main leak
  62. Body: Lark Door Adjustments
  63. Steering avanti II power steering help
  64. Body: 1953 tail light question
  65. Engine: Freeze Plugs, and Motor Mounts
  66. Body: Can someone help Me identify this roof rack?
  67. Fuel System: NOS 1957 Hawk WW Stromberg
  68. Engine: 63 Avanti broken throttle link-Part #1539610-need part
  69. Electrical: '63 Wagonaire, 259 :Prestolite "bendix" doesn't kick out to engage flywheel
  70. Electrical: avanti tach renew
  71. Other: New guy,can you help me identify these?
  72. Cool/Heat: heater valve
  73. Steering Need some help with my 56 Champion
  74. Fuel System: Edelbrock 1406 carb problems
  75. Interior: 51 Champ front seat
  76. Electrical: Battery Covers
  77. Brakes: Brake Drums
  78. Fuel System: Which Air cleaner? Edelbrock 1403 on 259 in C/K
  79. Engine: Engine miss diagnosis
  80. Frame/Springs Moog CC665 on an Avanti
  81. Transmission: BW Overdrive transmissions...
  82. Cool/Heat: Identify heater core
  83. Other: McCulloch VS57 Supercharger questions
  84. Body: rear fender spears
  85. Electrical: Horns on a 6 volt
  86. Other: '51 Commander VIN
  87. Electrical: Under hood and under trunk lid lights
  88. Steering My 1963 8E 5 Champ needs a king pin overhaul. Help please.
  89. Electrical: -55 Champion WiringDiagram/ElectricalScheme
  90. Brakes: Bleeding drum brakes
  91. Transmission: 1946 OD solenoid removal
  92. Body: Search for inside rear window trim
  93. Frame/Springs Need Quick Answer Rear Axle U-Bolts 1957 President
  94. Engine: Which head bolts need sealant (if any)? 1955 259 V8
  95. Interior: '63 Avanti Red Metallic Vinyl
  96. Engine: 289 head gaskets
  97. Cool/Heat: aftermarket radiators?
  98. Steering lower outer a arm threaded bushes
  99. Ignition: Pertronix Install Today
  100. Clutch/Torque Converter: Separating trans from a stuck engine
  101. Brakes: hydrovac
  102. Clutch/Torque Converter: T-56 in a 74 Avanti Part 1 - Clutch Hydraulics
  103. Shocks aftermarket coil over shock mounts.
  104. Brakes: Sludge in the master cylinder? - 63 Avanti
  105. Body: 1950 Hood latch mis aligned ? ... by about an inch whoops
  106. Frame/Springs Shockwaves for Stude front suspension???
  107. Fuel System: Rochester 4 Jet on '57 President Classic
  108. Cool/Heat: Replacement Heater Cores & Blower Motor
  109. Fuel System: carb problems
  110. Ignition: Correct Vacuum Advance For Window Type Delco Distributor
  111. Rear Axle: Ratio in 64 wagon with 259 and overdrive
  112. Other: Technical Talk- Milaca
  113. Engine: Engine Turn Over After 20 Years
  114. Rear Axle: bolt in later model diff for 39 CE?
  115. Rear Axle: 55 champion rear axle question
  116. Steering front end allignment
  117. Engine: How much can you mill the 259 heads?
  118. Fuel System: Avanti Storage and Gasoline fumes
  119. Brakes: Brake drum turning
  120. Cool/Heat: Flushing Block and Radiator
  121. Electrical: Speedster wiring harness
  122. Electrical: Gauges from 6 to 12 volt
  123. Electrical: turn signal problem 63 lark wagonaire
  124. Engine: steel shim head gasket question
  125. Ignition: Petronix problem.
  126. Electrical: Petronix problem.
  127. Electrical: 64 GT R1 and R2 Wiring Harness
  128. Speedo/Tach/Gauges Speedometer
  129. Other: M5 Bumper
  130. Electrical: generator to alternator
  131. Body: Rocker panel
  132. Fuel System: Ultimate Fuel Return Line For A Stude
  133. Body: Door alignment theory
  134. Engine: leak at the oil pump
  135. Body: Mercedes Seat Bottom In A GT Hawk Bucket Seat
  136. Body: 1946 right rear door latch
  137. Engine: how much can you mill off a champion flat six head?
  138. Steering Need a .810 dia. king pin reamer
  139. Electrical: how a starter works
  140. Wheels What are the tire options for a 1954 3R 6-12 pickup truck
  141. Electrical: Horn button needs new wire
  142. Engine: Engine questions, 64 Cruiser?
  143. Body: C-K Rear Fender Reproduction?
  144. Transmission: Lark VI 4 speed?
  145. Engine: starter bolts for '37Dictator
  146. Interior: Armrest
  147. Engine: 289 rebuild
  148. Body: Working with wooden dollies and hammers
  149. Steering Lower control arm repair (57 GH)
  150. Body: 1966 Cruiser Differences from 63-64 doors and Windows?
  151. Electrical: Cadillac 4note horns on a 57 Silver Hawk
  152. Electrical: + & - on the coil...
  153. Fuel System: Direction of Float arm in Gas tank
  154. Clutch/Torque Converter: Wanted '65/'66 chevybaker flywheel
  155. Body: Rocker moldings 64 gt hawk and clock repair
  156. Engine: 170 OHV valve adj. problem HELP!
  157. Engine: Slick Street Stuff motor mounts
  158. Fuel System: 1405 edelbrock carb
  159. Transmission: Pawl for 1955 Studebaker
  160. Electrical: 50 Champion Dash Switch Removal
  161. Fuel System: 50 Champ Fuel Sending Unit Resistance Range
  162. Body: Avanti Tail Lights
  163. Ignition: Key Switch Removal, When Key Is Lost
  164. Fuel System: Jetting a Stromberg
  165. Fuel System: 1961 Lark Manual Choke hardware/mechanism
  166. Brakes: 1955 Speedster Brakes - Anticreep Necessary?
  167. Brakes: Brake drums
  168. Body: 1951 Convertible Window Weatherseal
  169. Other: 1949 Studebaker 2R5 Pickup Restoration, custom build
  170. Transmission: CASO 4 speed questions
  171. Exhaust Cherry Bombs or Smittys or ?
  172. Exhaust Odd pipe on ebay: what's it for?
  173. Engine: Rebuild
  174. Speedo/Tach/Gauges Avanti Digital Dash
  175. Body: 1958 Packard Hawk front Bumper
  176. Body: 1950 champ rear window removal
  177. Engine: Help Please! M5 distributor and oil pump install
  178. Brakes: 1940 Commander brakes, hill holder and Dot 5
  179. Engine: Oil Leaks
  180. Body: 1958 Packard Hawk
  181. Fuel System: Mopar AFB's?
  182. Front Axle: Front suspension, does this look right?
  183. Engine: 289 rotation direction?
  184. Ignition: How to ID correct Delco window dist.
  185. Frame/Springs Leaf Spring tubing for bushings HELP NEEDED
  186. Engine: a non Studebaker air-cleaner...
  187. Body: Hog troughs....
  188. Body: 50 Champion body to 51 champion chassis
  189. Other: Studebaker Time Fillers
  190. Body: 1963 Lark trunk lock question
  191. Rear Axle: To toss or not to toss ?
  192. Steering Steering column
  193. Brakes: Need help Identifying emergency brake cable
  194. Brakes: Rear drum removal
  195. Cool/Heat: Can you help ID this air unit? It's in a 1954 Studebaker 3R 6-12 pickup
  196. Body: what are the dimensions of 52 comander
  197. Other: Cruise Control
  198. Fuel System: E-15 Fuel .... Do Not Use This In Old Cars Not Prepared For It
  199. Other: What is it?
  200. Electrical: Dome Light Lense Mounting 55 President C Body
  201. Brakes: Turner parts question
  202. Engine: Will the same head fit both the 170 and 185 CI flathead champions?
  203. Fuel System: Gas tank to filler pipe connection?
  204. Body: Windshield replacement caulking/bedding (also, dash removal needed?)
  205. Brakes: Only $312 For Disc Brake Setup (This Time)
  206. Brakes: Rear Brake cable
  207. Drive Shaft Driveshaft Slip Yoke
  208. Electrical: Avanti Brake Light Problem
  209. Other: Best anti fog solution
  210. Steering changing the steering setup when installing IFS front end???
  211. Other: General question about "problem parts"..
  212. Other: M Series restoration.
  213. Cool/Heat: Improve the defroster
  214. Body: Hawk Horn Mounts
  215. Steering Sticky Steering G.T. Hawk
  216. Body: Lifting a 1962 Champ pickup?
  217. Steering I want to pull the steering wheel ( 55 ,2 dr , C body
  218. Body: 58 PH hood holes
  219. Ignition: from 6-volt pos. ground to 12-volt neg. ground & Mopar electronic ignition...
  220. Body: Trim clips
  221. Clutch/Torque Converter: 74 Avanti Clutch Master Cylinder Mount T-56
  222. Engine: How to make or where to get oil flow restrictor
  223. Steering Center Bellcrank Bushings/bearings
  224. Engine: Vacuum Leaks: Carb, Manifolds
  225. Body: 1962 Lark Rattling Doors
  226. Brakes: 51 Champion disc brake upgrade
  227. Engine: Transplant 62 Hwk 289 to a 63 Hawk with seized engine
  228. Engine: Oil filter options on a 64 259
  229. Exhaust Dual Exhaust for a 283 V8 '66 Daytona
  230. Brakes: tailights and pedal travel
  231. Other: power window motor problem....
  232. Cool/Heat: ranco heater valve
  233. Electrical: Start Circut
  234. Other: clear coat center hubcaps
  235. Brakes: Wheel Cylinder Use antiseize or grease?
  236. Transmission: t-5 or f150 five speed ford transmission swap
  237. Body: 2r10 pickup restoration
  238. Front Axle: Repro Versus NOS Upper & Lower 'A' Arm Bushings
  239. Engine: 289
  240. Rear Axle: Rear Axle Ratio
  241. Body: Rubber Installation on the channel or channel edge?
  242. Engine: 259 rebuild
  243. Other: 49-53 +++? Truck parts available.
  244. Rear Axle: Tough 44 R/A replacement (was to toss or not to toss)
  245. Interior: 1952 k2 hard top converted to a convertable
  246. Engine: fuel pump for a 48 M5 pickup
  247. Body: Fiberglass fenders for the 39 CE
  248. Engine: Stuck engine
  249. Body: Fender vent actuator
  250. Body: what works on the Coupe Express from the commander?
