View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 [73] 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Other: Fuel. Non-ethanol gas - does it make a difference?
  2. Interior: Steering column bushings
  3. Engine: Engine break-in question.
  4. Paint: 40 Champ Paint info
  5. Interior: Day-Night interior rearview mirror repair {help}
  6. Cool/Heat: AC effects on engine temps ??
  7. Electrical: Electrical questions on conversion Lark to Chevy V8
  8. Speedo/Tach/Gauges How to read 1957 President Temp Gauge?
  9. Interior: 66 Cruiser dash overlay
  10. Electrical: sticking voltage regulator ??
  11. Brakes: Better brakes for a Champ pickup
  12. Body: Champ pickup guys....questions, questions, questions!
  13. Interior: Paint color to match Interior Paint
  14. Brakes: Brake fluid dilemma
  15. Rear Axle: Flanged Axles in October Turning Wheels..
  16. Electrical: Avanti wiring question
  17. Brakes: Recommendations for Hydrovac Brake Booster Rebuilder
  18. Speedo/Tach/Gauges Fuel gauge and heat gauge 62 Lark
  19. Cool/Heat: Leaking Heater Control Valve in '81 Avanti
  20. Other: Still plenty of STUDEBAKER technical work to do in SOUTH BEND!!!
  21. Engine: Pictures of Engine - Finally making some good progress
  22. Steering 1956 Champion wheel alignment specs please?
  23. Electrical: Front turn signal light on GT Hawk
  24. Body: K Body Window Rollers
  25. Speedo/Tach/Gauges 56 Champion Guages......how do they read???
  26. Engine: what parts will swap and what won't
  27. Engine: Engine pulling options
  28. Fuel System: I knew our Avanti had a gas vent...........but.............
  29. Engine: Oil consuming
  30. Engine: How to attach a vacuum guage to a 6 cyl
  31. Engine: Oil pressure question
  32. Engine: More HP from 63 Avanti
  33. Transmission: What type of ATF??
  34. Electrical: 6V to 12V Conversion (Blower Motor)
  35. Engine: problem with 89 avanti
  36. Rear Axle: Leaking differential
  37. Engine: 232 replacement options
  38. Cool/Heat: Air conditioner
  39. Interior: Headliner - repairs and cleaning?
  40. Frame/Springs Built a chassis tilter then made it into a rotisserie.
  41. Cool/Heat: If it works, should I fix it?
  42. Engine: choke heater mystery - '63 OHV 6
  43. Fuel System: Fuel Sending Unit Identification
  44. Engine: '61 Lark VI oil filter
  45. Brakes: Hydrovac help please
  46. Body: 1957 Silver Hawk
  47. Other: Windshield and rear window rubber
  48. Electrical: 61tach
  49. Interior: gt hawk wood grain
  50. Wheels 1954 3r-6
  51. Transmission: Gas Pedal Pressure On Studies With 200R & 700R Transmissions
  52. Body: Champ Sliding Window Drains
  53. Speedo/Tach/Gauges Need temperature gage
  54. Body: 50 Commander Side Mirror vs. 53 Super-Vue Side Mirror
  55. Ignition: Can't get right ignition
  56. Interior: Headliner and Windlace Help 1948 LC
  57. Engine: Newly rebuilt 259 engine knock
  58. Interior: Gas Pedal
  59. Body: Location and size of access hole for suspended gas pedal
  60. Engine: How I Fixed An Excess Oil Pressure Problem
  61. Steering What other steering wheels fit 56 Champion??
  62. Other: Need Welder Recommendation
  63. Engine: Please advise: Engine oil
  64. Wheels Need new Front and Rear wheel bearings for 1963 Lark 8.
  65. Brakes: 63 Avanti Rear Drums rust tight in 1 yr?
  66. Ignition: Electronic ignition conversion kits
  67. Body: How To: Add power door locks
  68. Front Axle: King Pin Upper Bearing, Greasing Problem Solved
  69. Transmission: installing overdrive
  70. Other: Windshield Wiper Blades
  71. Engine: 52 Champ 6 oil pressure relief valve
  72. Body: -55 sedan hood & front fenders
  73. Engine: Stuck oil relief valve NEED HELP
  74. Transmission: Will the available TH350/400+ adaptor plates work with BOP models with another adaptor?
  75. Electrical: Ideas? Alternator quit (again)
  76. Engine: Best Gasket Compressed Thickness
  77. Engine: 289 oilsmoke
  78. Fuel System: The light bulb finally went on!
  79. Engine: Champion Exhaust Valve Color
  80. Speedo/Tach/Gauges Need Temperature Gauge and sending unit values
  81. Rear Axle: Axle End Play - definition & advice
  82. Steering Power Steering Groan
  83. Engine: Help me understand crankcase ventilation on a champion flathead
  84. Speedo/Tach/Gauges Speaking of light bulbs...
  85. Body: Removing stainless
  86. Engine: 1 year won't start Champion 6V
  87. Frame/Springs What is this?
  88. Engine: 259 2 barrel backfiring upon hard acceleration
  89. Cool/Heat: 55 radiator
  90. Transmission: Need to replace my Hawk Transmission
  91. Engine: precision engineering Machine shop murdered my freshly cut 259
  92. Electrical: 64 Daytona dash lights???
  93. Other: Corvette frames under Avanti Bodies!?
  94. Transmission: 1950 Commander DG200 trans question
  95. Shocks Air shock fitment
  96. Wheels Will this wheel /tire combination work on a 55 President hardtop?
  97. Engine: 56 Champion Oil filter
  98. Transmission: For anyone considering a GM transmission
  99. Fuel System: Supercharger started to sound louder
  100. Brakes: low pressure then stiff pedal
  101. Body: 56 Champion 4 door door rubbers??
  102. Transmission: Fuel economy numbers
  103. Rear Axle: TT rear ends
  104. Transmission: Need a clutch release shaft for my 62 Daytona
  105. Transmission: 700R4 transmission swap to 64 Stude
  106. Engine: 6 cylinder overhaul
  107. Electrical: Lark Horn Ring
  108. Electrical: iPods?
  109. Electrical: Overdrive Solenoid Swap (6V to 12V)
  110. Engine: supercharger
  111. Engine: Composite Gaskets
  112. Front Axle: Alignment question
  113. Fuel System: Will an AFB work on a WCFB intake?
  114. Wheels Ordering chrome steelies.........what offset and max width can I go with?
  115. Transmission: Adding OD to a 3 spd
  116. Transmission: 4 speed in a Lark?
  117. Engine: '63 Avanti
  118. Engine: 289 engine
  119. Body: C-K '53-'58 rear decklids
  120. Fuel System: Carburetion Primer
  121. Paint: Paint restoration article in PHR
  122. Electrical: 6 volt Starter
  123. Transmission: Best Rear Axle Ratio To Use With 700R Or 200R Transmission
  124. Engine: Carter WE
  125. Cool/Heat: Trans cooler for 289 Champ
  126. Body: Part number and availability
  127. Body: vent rubber problems
  128. Speedo/Tach/Gauges Misfire when sender installed
  129. Electrical: 1946 Champion Overdrive kickdown switch.
  130. Electrical: Turn signals backwards, help!
  131. Steering 62 Hawk - removed steering wheel - reattach
  132. Fuel System: Still isn't running right
  133. Brakes: No power brake reserve
  134. Frame/Springs GT Hawk Ride Height
  135. Electrical: 6volt to 6/12conversion
  136. Engine: 259 crankshaft
  137. Wheels Wheel stud specifications.
  138. Body: Vent rubber DESPERATE! Picture needed
  139. Transmission: Need help with an overdrive kickdown switch diagram - 12V 3-wire solenoid
  140. Clutch/Torque Converter: My flywheel just lost a tooth ---Not a good day
  141. Brakes: Stuck Front Drum - 1946 Champion
  142. Cool/Heat: Where is heater control valve ( 55 president coupe)???
  143. Engine: 245 Commander / Power-Plus Six - rod bearings ?
  144. Body: Vent door on right front fender ??55 president coupe
  145. Engine: Schooler Camshaft
  146. Electrical: Battery Issue ?
  147. Frame/Springs GT Hawk vs Golden Hawk
  148. Electrical: Turn Signal Flasher Found Kudos
  149. Wheels Ok- who has added longer wheel studs to Stude rear end and how did you do it.
  150. Electrical: Left Direction Tell Tale light on when headlights are on.
  151. Transmission: Thrust washers?
  152. Body: Installing Front and Rear Glass / 55 Commander Rap Around Glass
  153. Frame/Springs cutting coil springs
  154. Cool/Heat: water pump 48 champ
  155. Electrical: Is there any reason to reduce voltage to the headlights from 6 to 4 volts?
  156. Brakes: 1957 Silver Hawk Disc Brake Conversion
  157. Body: "painted" chrome
  158. Fuel System: Ethanol dilemmas
  159. Other: Please Help ... I need to document if 1963 Factory Glass in Avanti would have been Safety Glass OR ?
  160. Rear Axle: Whining sound
  161. Drive Shaft shortening & balancing
  162. Steering Kinda Urgent - Front Sway Bar issue - '63 Avanti
  163. Body: Replacing window flipper trim
  164. Other: LARK VI REGAL makes TICKING SOUND
  165. Fuel System: My studebaker starts hard
  166. Steering Avanti Power Stering
  167. Other: Must keep parts
  168. Rear Axle: Covette Rear End
  169. Front Axle: 4x4
  170. Engine: Lifters
  171. Other: Stude radio
  172. Front Axle: Installation of control arm outer pins and bushings
  173. Fuel System: fuel tank sending unit
  174. Brakes: tricks for bleeding brakes
  175. Electrical: Avanti Radio
  176. Fuel System: Avanti R-1 Air Filter Cartridge WIX 42063
  177. Brakes: Zip Van Rear Brakes ????
  178. Other: New Power Window Regulators
  179. Brakes: 1951 Champion, 1964 Commander brakes?
  180. Body: 1957 Silver Hawk nuts
  181. Brakes: 1957 Studebaker Silver Hawk brakes
  182. Body: Wood grain
  183. Interior: Garnish
  184. Fuel System: Modern Carburetor
  185. Transmission: Help required - 1938 Commander -Vacuum assist gear change adjustment
  186. Brakes: Searching for Jim Turner
  187. Paint: Want to tidy up some in the engine room
  188. Body: ID code breakdown
  189. Steering power steering
  190. Clutch/Torque Converter: ...How hard is it to find...
  191. Electrical: Assuming...............
  192. Frame/Springs An introduction and a 6E7 leaf spring question
  193. Other: Cutting wheel recommendation
  194. Electrical: Fix my horn please
  195. Fuel System: electric fuel pump : 1963 Lark V8
  196. Body: Champ Long Bed
  197. Frame/Springs Need help with a part #
  198. Engine: Need help ,carb post that hold's air cleaner
  199. Speedo/Tach/Gauges Before I start tearing the gauge cluster/dash apart......any tips?
  200. Interior: Good Upholstery Shop in Chicago Area??
  201. Engine: 245 commander pcv?
  202. Transmission: overdrive - removal governor
  203. Wheels Tire mounting help
  204. Brakes: Bad Master Cylinder?? Hard pedal
  205. Body: Could a welder build up material on door lock(starwheel) 55 coupe
  206. Interior: Kick Panels for 47-52s
  207. Frame/Springs 63 Lark Rear Springs
  208. Fuel System: Fuel tank parts for 58H, differences
  209. Electrical: Need 62 Lark Fan Blower Motor That Turns Other Way
  210. Body: Dum Dum is Really Sticky Stuff
  211. Frame/Springs Frame Options and Two Post Lift
  212. Ignition: Tachometer
  213. Rear Axle: Rear Axle Ratio 1947 Champion convertible
  214. Engine: Avanti Valve setting
  215. Electrical: Turn Signal - Rewire or Replacement?
  216. Cool/Heat: Hawk passenger side vent door
  217. Frame/Springs Don't Hold Your Breath Waiting for the New AME Studebaker Chassis
  218. Electrical: 20 amp Overdrive fuse blows
  219. Electrical: Radio noise suppression capacitors: current part numbers?
  220. Fuel System: fuel tank modifacation?
  221. Engine: Braided Stainless Oil Lines, FINALLY
  222. Electrical: Installation Location AC-3225 Underhood Light
  223. Frame/Springs Fact or Fiction
  224. Engine: Help do I put sealer on Champion 6 front plate gasket (RN 8011 by Interface)
  225. Interior: Softening stiff vinyl
  226. Ignition: ... IN-OP on the crank damper...
  227. Body: 1960 Hawk Side Trim Removal (Bottom of Fin)
  228. Front Axle: '63 Wagonaire - front suspension rebuild questions
  229. Brakes: Brake pedal mounted brake switch
  230. Other: Reflectors
  231. Body: Hawk grille stools: source?
  232. Ignition: The Condenser Episode
  233. Speedo/Tach/Gauges 1957 Silver Hawk speedometer
  234. Transmission: T10 story
  235. Transmission: 1st gear starts in FOM
  236. Engine: '63 Avanti Super Charger
  237. Electrical: Spark Plug Tester.
  238. Body: Rubber for top/front of Avanti door
  239. Steering Please explain camber adjustment - outer pin
  240. Frame/Springs Top A-arms & king-pin
  241. Exhaust 51 Champ 350 conversion
  242. Electrical: Wiring a chevy motor in a lark
  243. Paint: What compound to use?
  244. Body: 62-63 convert
  245. Fuel System: Avanti fuel line question
  246. Transmission: 63 Champ Questions
  247. Body: update: Gas Pump fall into Golden Hawk trunk finally fixed!
  248. Body: Seat Belt anchors for 57 Golden Hawk- COMPLETE!
  249. Steering Finally into the Speedster.... #1 Steering
  250. Body: Finally into the Speedster.... #2 Dash
