View Full Version : Tech Talk
- Steering PS cylinder
- Cool/Heat: Need fix for Heater Hose connections
- Brakes: We goofed, 1940 brake cylinder
- Wheels New shoes and road worthy soon!
- Wheels Nissan EZE Fill Tire System
- Body: Do a drivers door mirror, yea or nay?
- Other: Studebaker sales/book historians- service letter question
- Engine: How does the oil fliter fit up ?
- Other: Washer Pump Pic
- Brakes: 63 GT Hawk Disc Brakes
- Body: How to attach rocker panel trim strip? Needs a "spring clip", not OEM clip.
- Paint: how many "whites" were available in 1963
- Drive Shaft Cleveland an Spicer U joints
- Interior: Wool upholstery cleaning
- Engine: Supercharger Belts
- Engine: 62 Hawk - Fan hits shroud on right turns
- Rear Axle: Replacement Rear End
- Body: 64 hawk
- Electrical: Strange Solenoid Problem
- Ignition: Plug lead layout ?
- Other: La Carrera Pan-America Road-racing
- Body: Need to know where to mount Avanti interior rearview mirror
- Interior: 1937 Coupe Express seat connection
- Transmission: Ford Pattern to Chev Pattern Compatibility
- Body: Bullet nose repair
- Electrical: Starter Current Draw
- Front Axle: How to: lower suspension
- Body: 1951 Commander parts compatibility with 1950 Champion
- Exhaust Hawk sounds sick :(
- Fuel System: AFB Springs for Avanti R2
- Rear Axle: dissy & assy instructions for the flanged axle Dana 44
- Cool/Heat: V8 water pump clearance spec?
- Body: GT Hawk Window Channel Liner
- Steering Steering column bolts
- Engine: SILICONE ON HEAD GASKETS
- Other: Urethane Bushings for Avanti Front and Rear Sway Bars
- Ignition: Pertronix Problems In A Delco WINDOW-Type Distributor
- Engine: valves
- Ignition: Help on Points
- Brakes: Pumping brakes
- Engine: Adjustable cam gear / cover set
- Other: 1958 Supercharger
- Fuel System: Edelbrock Problem
- Wheels Avanti wheel bolt pattern
- Fuel System: Edelbrock for my R2 Avanti.. (Sigh)
- Steering separate steering column on 62 gt hawk
- Shocks Needing rear shocks on 61 Lark Conv
- Engine: full flow vs. partial flow?
- Brakes: Front disc brake kit opinion
- Steering steering wheel fails to center
- Cool/Heat: Harrison Radiator
- Transmission: What would cause a failure of the needle bearings in the cluster gear?
- Wheels 15" Wheel availability
- Cool/Heat: Late Hawk heater/defroster assembly
- Fuel System: Is my Carb original and What air breather can I get?
- Ignition: Need help with spark plug sets- 1955 commander 259
- Engine: Just for fun, test your diagnostic skills . . .
- Interior: Avanti II Recaro Seats
- Fuel System: Winter Storage
- Brakes: Brake Cable attachment
- Ignition: 51 Champion Timing Mark Question
- Electrical: NAPA Part # for '63 Lark V8 Starter Solenoid?
- Engine: '52 Engine Removal
- Engine: V-8 or 6 swap?
- Other: Cloth Covered Weatherstrip
- Transmission: Speedo gear / tooth
- Body: Carb linkage and screw size
- Transmission: Tansmission swap for a 170 OHV
- Interior: Knob Function on 2R5 dash
- Engine: To tame 13:1 compression on a 60's built Stude V8
- Engine: Valve Spring Height Correction
- Engine: Valve Stem Seal Preference
- Engine: Oil Pressure Question
- Rear Axle: Zerk fittings?
- Steering R&R Steering wheel
- Other: Mismatched serial numbers advice
- Fuel System: Anyone ever able to shatter an installed fuel pump?
- Brakes: Adjusters?
- Rear Axle: 65' Commander Rear End
- Electrical: Lighting brighter or better bulbs?
- Other: White wall tires
- Fuel System: Gas sending unit for a 51
- Other: '63 R2 Hawk oil capacity?
- Interior: 47-52 Door Panels Question...
- Engine: Gaskets and valves 1962 lark
- Engine: 259 compression
- Engine: Our 232 Engine Needs Some Help
- Exhaust Old School Mufflers
- Paint: Trunk Color for 53
- Body: Any advice on removing dents HERE? Lucky day comes to an end with a BANG
- Fuel System: Stromberg throttle not fully open
- Engine: Rebuild vs. new engine. 1962 lark. 6Cyl. 169. Ci
- Brakes: Parking brake cable dilemma NEED HELP
- Body: Bad window regulator?
- Steering 57 GH Power Steering Gear Quesion
- Transmission: close ratio vs wide ratio - T10 4 spd
- Engine: pull motor for rear main seal?
- Body: My 59 Hawk has body/frame issues
- Transmission: 63 Avanti R1 Transmission Problem, powershift
- Interior: Starlight coupe carpet
- Body: Questions on Avanti hood latches
- Ignition: Just fried a Pertronix
- Cool/Heat: Noisy A/C Clutch Bearing?
- Rear Axle: 2R10 Axle nut wrench size
- Brakes: Turner rear brake kit on 1963 Avanti R2
- Body: 55 coupe trunk latch
- Other: Spare Tire Hold Down for a '50 Champion
- Body: Removing rear top moulding, Golden Hawk
- Fuel System: fabbing a suspended gas pedal for a Lark six using 62 & 66 parts
- Body: Hinge pin replacement
- Engine: 1954 Studebaker 3R6-12 Engine ID
- Body: what will 1950 Champion front end fit?
- Engine: 289 Oil Pump
- Interior: need help with Speedster dash restoration
- Exhaust 55-58 Chassis book need pics
- Ignition: Setting the timing on a 170
- Clutch/Torque Converter: Truck clutch & brake shoe #'s ?
- Electrical: How to remove the turn signal switch.
- Cool/Heat: AC Idler Pully
- Engine: oil pan gasket
- Engine: Radiator for a 1959 V8 Silver Hawk part #
- Cool/Heat: Olympus Avanti radiator fan and shift console cooling fin for the Avanti
- Engine: engine stumbles
- Transmission: Help me re-assemble the overdrive to my T96 transmission?
- Transmission: Flight-o-Matic Length
- Ignition: 1960 Lark v8 ignition help
- Other: Lark VI Pulley failure
- Brakes: Need help finding rear brake levers and brake pad clips.
- Engine: -55 Champion six bearings
- Fuel System: Persnickety Commander 6 carb?
- Transmission: GT Hawk transmission problem
- Brakes: brake drum interchange ?
- Engine: Engine build and two speed axle
- Transmission: Trans fluid/check??
- Exhaust I6 manfold leak - second time around...(update with pics)
- Steering Conversion from power to manual steering - 1960 Hawk
- Electrical: TURN SIGNAL SWITCH NEED WIRING DIAGRAM 1955 President C Body
- Body: I am confused about my N.O.S. parts
- Steering Astro Van Power Steering in a 54 Wagon
- Steering quick steering arms
- Ignition: Ignition switch diagram
- Clutch/Torque Converter: Gears are jumping out, manual gearshift
- Engine: Engine size question
- Transmission: Using a 1965 Studebaker tranny with a 1964 engine?
- Body: Cruiser door window frame question
- Steering steering improvements for 1965 commander
- Fuel System: Replacement Carburetor
- Brakes: Dual Master cylinder for 1962 Lark
- Engine: Correct Stude Part Number for the Avanti PCV Valve?
- Clutch/Torque Converter: Clutch Slippage
- Electrical: Avanti tail light bulb replacement
- Other: Dual wipers on 39-46 Champion
- Brakes: front calipers
- Fuel System: '63 GT Hawk Gas Gauge
- Fuel System: Standard V8 fuel pump on a R-1?
- Engine: 6-volt to 12-volt conversion (was: Wow its funny.)
- Electrical: amps rating headlight relay Auto-Lite HRB-4201
- Engine: Idle speed
- Engine: 1950 Flathead 6
- Body: 1950 Studebaker Champion hood
- Fuel System: Fuel line and filter questions
- Electrical: starter solenoid second bolt location? PICTURES ADDED
- Engine: backfiring 259
- Engine: Heater flow chart
- Frame/Springs muffler scrapes
- Fuel System: gas mileage
- Body: Stone / Gravel shield question for Coupes
- Ignition: Need dist drive gear pin. What & where?
- Brakes: Studebaker self adjusters on a 1957 NAPCO: adjustment procedure
- Engine: distributor cap and plug wires
- Other: manual shift collar sloppy
- Interior: Problem With Window Garnish on 1948 Land Cruiser
- Electrical: 1951 2R10 12 volt???
- Engine: The '51 Commander is now together and running, but......
- Ignition: Condenser on Coil
- Engine: Ehtanol engines in the 1930
- Transmission: TRANSMISSION LEAK
- Interior: Any Ideas on how to make something look old?
- Cool/Heat: Heater valves on '64 and '65 Lark Cruisers
- Transmission: Shift lever roll pin removal
- Brakes: Remove 2R5 Emergency Brake Cable
- Fuel System: How to store a gas tank?
- Engine: Ring Gap questions
- Body: Trim removal
- Body: 62 GT side grills
- Steering M5 Steering Assembly part number 197108....HELP
- Electrical: Wiring Harness ID
- Body: Where do I get felt (for the driver's side window) 55 ,2door c-body
- Body: Hood Corner Stiffners
- Engine: Bellhousing Alignment
- Engine: Stude won't run under load
- Body: Window channel (that window slides into)55 2 door c body
- Interior: Radio static
- Engine: 50 six cylinder backfire?
- Brakes: 50 front wheel lugs
- Fuel System: Gas Tank Coating
- Brakes: 50 Starlight brake dragging
- Interior: Seat Belt anchor locations- 57 vs later Hawks with factory belts
- Engine: stud 259 v-8
- Transmission: shifting problem
- Body: Door lock on M series Problem
- Cool/Heat: Water pump rebuild, 1957 Golden Hawk
- Brakes: Master Cylinder Storage
- Transmission: Overdrive transmission
- Body: Trunk hinges
- Speedo/Tach/Gauges 62 Hawk clock
- Body: Ray Fichthorn's informaton on adjusting body to fit doors
- Brakes: 64 Cruiser Brakes
- Brakes: Brake hose code dates
- Paint: 1962 Lark - how to buff/shine?
- Transmission: 1941 transmission
- Engine: Run newly rebuilt engine
- Shocks aftermarket shocks
- Interior: 62 Hawk Passenger Side Inside Door Handle
- Fuel System: Fuel pump replacement 66' 283
- Cool/Heat: Fan Blade Installation - Torque Specs
- Other: Best place to tap manifold vac/pressure on an R2 intake?
- Ignition: Starter Removal
- Engine: Timing cover gaskets and seals
- Frame/Springs '56 through 61 Hawks
- Electrical: 62 Hawk - instrument panel gone dark
- Rear Axle: Damaged rear axle thread repair
- Interior: How to attach upholtery panels--58 Golden Hawk
- Engine: Vacuum advance for distributor
- Engine: Motor mounts
- Engine: Shim Head Gasket Sealant
- Steering Jim Lange Avanti Mods
- Transmission: T-96 Gearing question
- Engine: ENGINE IDENTIFICATION HELP!
- Engine: Has anyone notice the pcv hose's somehow attach to the valve cover of a 259 ( 1955)
- Drive Shaft D/S spline length
- Brakes: Brake lights staying on
- Engine: Rear main seal replacement.
- Transmission: Pilot Shaft
- Other: Mirror mounts for '58 Transtar
- Front Axle: What does service manual mean by "tread"
- Engine: stuck oil pressure relief valve
- Other: Maintenance on a 1951 commander land cruiser.
- Electrical: 50 Champion charging system
- Transmission: TRANSMISSION CONFUSION
- Fuel System: Copper Fuel Lines '48
- Other: Copper Vacuum Lines '48 Land Cruiser
- Engine: Brass Nuts
- Steering Removal of top of steering column, 65 Commander
- Engine: Newbie with M5 6 Cylinder Question / Advice needed please
- Interior: Dash pad repair
- Electrical: What size of fuse/circuit breaker?
- Other: Power Steering
- Drive Shaft Driveshafts
- Body: Rear side glass on 1953 Starliner
Powered by vBulletin® Version 4.2.4 Beta 2 Copyright © 2019 vBulletin Solutions, Inc. All rights reserved.
