View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 [71] 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124
  1. Other: Windshield sprayers
  2. Brakes: '50 champion master cylinder
  3. Body: Studebaker factory flyer #232, dated January 28, 1954 entitled "Studebaker Side Molding Kits"
  4. Exhaust I have a real silly question.
  5. Body: 1947 Champion Convertible rear fenders
  6. Engine: Freeze plugs, expansion plugs, casting plugs, or whatever you want to call them
  7. Transmission: Wwyd?
  8. Fuel System: avanti restrictor fitting
  9. Body: Front Body Mounts
  10. Wheels Need a wheel
  11. Engine: Adjustable cam drive, gear cover
  12. Transmission: 1953 automatic Transmission fluid type?
  13. Interior: Bullet Nose Convertible Picture Request
  14. Fuel System: Chrysler 318 fuel pump compatability
  15. Body: fiberglass front fenders 54 CK
  16. Body: Door
  17. Electrical: Light Bulb for Rear Tail Light
  18. Interior: Knob for windshield wiper switch - Part No. 652737X1
  19. Steering What size is Avanti steering wheel nut?
  20. Fuel System: Carburetor rebuild kit question
  21. Fuel System: Spacer between carb and intake manifold?
  22. Transmission: 63 Lark Flightomatic noise
  23. Electrical: Battery tender
  24. Transmission: speedo drive gear.
  25. Brakes: 51 Champion brake cylinders
  26. Interior: Trunk Springs
  27. Body: Installing right hand mirror mount on 2R5 pickup
  28. Fuel System: Fuel pumps
  29. Body: missing puzzle peice
  30. Body: Taking the cab off of my M 5
  31. Fuel System: Carb Rebuild Question
  32. Transmission: Best overdrive transmission for lark with 259 v8?
  33. Interior: 53/54 gage cluster wanted
  34. Cool/Heat: Rebuilding Radiator
  35. Speedo/Tach/Gauges Need a speedometer gear
  36. Electrical: What happened to my gauges?
  37. Fuel System: 1956 golden hawk dual 4 carter carb ID tags
  38. Steering Where to find a puller J-5664
  39. Exhaust blue smoke
  40. Transmission: DG250 won't shift into top
  41. Electrical: Do I have a bad starter relay? 55 Champion
  42. Interior: GT dash overlay
  43. Rear Axle: What does the 45 C tag on a differential tell me?
  44. Speedo/Tach/Gauges Temperature Gauge Suddenly Pegs!
  45. Fuel System: Vapor Lock at the SDC Nationals
  46. Engine: Manifold mess
  47. Ignition: Deeply recessed plugs on 55 Champion engine. Is this right?
  48. Cool/Heat: Got the compressor---where does the oil filter go?
  49. Fuel System: Rubber fuel line
  50. Interior: 53 Interior Windshield molding attachment?
  51. Electrical: Starter Bendix Retreat
  52. Interior: Starting to clean interior - don't want to ruin anything
  53. Speedo/Tach/Gauges Round vs. Square Tach Sender
  54. Brakes: Questions on brakes,clutch starter
  55. Body: Trunk hinge fix
  56. Engine: Gears, cover, in case anyone's curious...
  57. Electrical: Electric Fuel pump
  58. Interior: Avanti carpet
  59. Body: headliner-64 wagonaire
  60. Paint: P5636
  61. Body: Trunk Lid 1948 Commander
  62. Body: M-Series Cab Stand
  63. Engine: How HOT is too Hot?
  64. Electrical: Rewiring an Avanti II 1974
  65. Frame/Springs Sagging Front Suspension
  66. Other: Air conditioner
  67. Interior: Headliner trim bows 62 hawk
  68. Ignition: Pertronics on my commander.
  69. Transmission: Automatic transmission Model DG-250-M
  70. Electrical: Can anyone give me the answer??
  71. Body: Stuck window
  72. Electrical: A favor, 1974 Avanti fuse box diagram
  73. Fuel System: Quick tip after sitting a long time.
  74. Body: Need '51 rear gravel deflector
  75. Brakes: 66 disc brakes
  76. Clutch/Torque Converter: how to identify 6 volt starter and flywheel.
  77. Engine: Another reason for low oil pressure
  78. Ignition: Distributor cap question
  79. Body: Floor Boards and Seat rails
  80. Wheels 15" 58 Hubcaps
  81. Brakes: brake light
  82. Fuel System: 36 Dictator fuel pump dead or electrical problem?
  83. Engine: Fan Dia.?
  84. Exhaust Is there a y pipe out there
  85. Body: underhood insulation Lark 1961
  86. Electrical: E3 plugs... any opinion?
  87. Electrical: alternator alternatives
  88. Body: 42 champion panels
  89. Rear Axle: 44 dana tt rearend
  90. Other: Repair estimate
  91. Body: F-body rear window regulator R&R
  92. Interior: Door panel clips
  93. Brakes: Access to '50 Master Cylinder
  94. Electrical: Pos bat terminal fell on my coil
  95. Body: Right front fender for a 14a 1947 commander
  96. Clutch/Torque Converter: Tranny I-R-Dumb award!
  97. Engine: wonderful horrible engine swap
  98. Electrical: removing points
  99. Body: lark convert body
  100. Cool/Heat: Radiator water level.
  101. Fuel System: No fuel to carb
  102. Fuel System: fuel pump
  103. Cool/Heat: R-12 substitute
  104. Electrical: lost a screw in the back of the distributor
  105. Brakes: 1950 champion self adjusters
  106. Engine: quiero comprar un motor v8 studebaker
  107. Engine: Leaky intake manifold
  108. Fuel System: Soooooooooo discouraged already!
  109. Body: vin #'s and paint codes
  110. Body: Lark automatic floor shift location, Lark bucket seat bracket/riser and the console
  111. Transmission: Slow going into reverse
  112. Body: Help with trunk springs
  113. Cool/Heat: a/c compressor is hit by the fan blade
  114. Fuel System: WFCB choke / high idle adjustment
  115. Engine: Engine identity, truck or car ?
  116. Fuel System: fuel gauge
  117. Engine: Further Front Caster Comments/Questions
  118. Electrical: Neutral safety switch
  119. Interior: Front door glass for 52 Champion/ moleskin replacement
  120. Transmission: Commander Starlight coupe 53 - Auto trans gear lever
  121. Transmission: Shift Linkage Needed
  122. Rear Axle: The Dana 44
  123. Body: Hood prop bolt
  124. Brakes: Adjusting Brakes
  125. Engine: I think I scewed up my original post. Please reply with any comment or observation
  126. Brakes: Bending brake lines
  127. Body: broken windshield wipers
  128. Electrical: Temp gage wiring
  129. Electrical: '62 Hawk GT Front Fender Running Lights
  130. Body: 64 hawk stainless mlds
  131. Electrical: Wiper motor interchange
  132. Fuel System: carburetor: what am i missing or doing wrong????????
  133. Electrical: True confession time
  134. Fuel System: Need gas tank for champion!!
  135. Body: Gaskets
  136. Transmission: putting an auto in the hawk
  137. Cool/Heat: Sealing screws for water pump and water manifold...
  138. Cool/Heat: AC Condenser
  139. Transmission: T-10 backup switch
  140. Ignition: Help with starter switch on a 49' champion
  141. Brakes: Need parking brake cable help
  142. Brakes: Transtar V8 3E7, finally got it home from Butte, Mt
  143. Body: 59-64 parts book does not call for headliner bow end clips for C and K models.
  144. Wheels Aftermarket wheels on a Champ
  145. Cool/Heat: 63 Avanti Fan Shroud
  146. Body: Avanti Windshield Frame Repair
  147. Engine: surging under steady speed conditions.
  148. Speedo/Tach/Gauges New speedometer gear at tranny
  149. Body: 50 champion, rear fender to body seal
  150. Rear Axle: Differential re-build?
  151. Clutch/Torque Converter: 11" clutch
  152. Engine: Valve Adjustment for 49' Champion
  153. Ignition: Wanted
  154. Transmission: ATF Level Check
  155. Interior: front seat adjusters for 58 Champion
  156. Engine: Oil pressure line
  157. Front Axle: Quickie Kingpin Question?
  158. Steering Quickie steering box question?
  159. Ignition: Points and plug wires.
  160. Engine: Draft tube for sale out there?
  161. Steering Internal part #'s?? for early saginaw box
  162. Body: I'm on a mission to verify my P.H. unobtainium
  163. Front Axle: King Pin bushing too small ??
  164. Electrical: Windshield motor replacement w/ Subaru
  165. Engine: Wanted: manifold for 49' champion
  166. Brakes: Front brake kit
  167. Engine: should have asked before I bought it, but can someone tell me about this intake ???
  168. Shocks Koni for Avanti
  169. Rear Axle: Pinion Seal removal and installation questions
  170. Clutch/Torque Converter: Truck bell housing ID
  171. Engine: Inline 6 engine NUTS?????
  172. Fuel System: carb seals????
  173. Interior: 62-64 Fiberglass GT Hawk Dash Differences
  174. Body: window weather seals
  175. Engine: V-8 Camshafts
  176. Engine: "Stump puller" cam
  177. Body: 52s Retractable Antenna is a replacement mast out there?
  178. Body: 64 gt questions.
  179. Rear Axle: 64 gt rear
  180. Speedo/Tach/Gauges 160 mph speedometer id help
  181. Interior: How to fix a cracked steering wheel
  182. Brakes: Brake Surprises - Flanged Hubs and Studebaker Discs
  183. Engine: Cam wanted
  184. Body: K- Body Drip Rail Molding wanted
  185. Other: Has anyone found a source for lead ties
  186. Interior: Stainless trim at base of front seat
  187. Brakes: Drum puller
  188. Brakes: How to convert your hydraulic brake switch to a mechanical switch
  189. Clutch/Torque Converter: T84G which clutch plate ?
  190. Engine: V8 Water Manifold Identification
  191. Fuel System: Ridiculously inaccurate fuel gauge--'66 Daytona
  192. Brakes: I really need a 533065 NOS brake cable
  193. Engine: V/8 Oil filter adapter
  194. Transmission: Trans front bearing replacement
  195. Electrical: Hawk Charging question
  196. Other: 64 Stude. Convert.
  197. Body: 64 hawk body question
  198. Body: Front Cowl Bracing 1958 Champion
  199. Interior: Window regulator
  200. Transmission: Avanti II Speedometer Cable Source
  201. Electrical: Bench test a 6V starter
  202. Electrical: Power source for headlights/park lights
  203. Electrical: GM Alternator Bracket
  204. Electrical: Replacement Electronic Voltage Regulator
  205. Cool/Heat: What does this Studebaker radiator fit?
  206. Rear Axle: Rear axle replacement - scraping noise?
  207. Frame/Springs Does anyone rebuild upper and lower control arms
  208. Engine: Engine into '51 Commander questions
  209. Cool/Heat: 2 bbl vs. 4 bbl
  210. Electrical: Hooking up a 12si
  211. Paint: Some questions about primer
  212. Body: '63 Champ Door Hinges
  213. Brakes: 64 gt power brakes
  214. Engine: Can you use a 318 mopar fuel pump on the 259 engine?
  215. Steering Bendix power cylinder
  216. Clutch/Torque Converter: Bellhousing alignment.
  217. Fuel System: 63 Avanti - R2 more questions
  218. Electrical: 50 Champion's Generator not charging????
  219. Interior: 62 GT Hawk headliner
  220. Engine: R3 Oil Breather Caps
  221. Body: How to remove the radiator core support from a 63 GT Hawk?
  222. Ignition: 62 GT Hawk key
  223. Other: Cool resto tip for you 61-62 Lark and Late C Cab truck owners
  224. Exhaust For Stude Avanti Owners..........
  225. Front Axle: Upper inner control arm bushes
  226. Body: Any Station wagon owners who have had their car painted?
  227. Fuel System: Does anyone have 1952 Commander float level specs?
  228. Fuel System: Engine stalling during hard braking
  229. Other: What year Champ?
  230. Rear Axle: Dana 44 Ring & Pinion swap questions, Carrier?
  231. Body: 1955 right grill ID help
  232. Interior: Front Vent Window Latch removal
  233. Wheels Radials or bias tires
  234. Engine: Engine Oil
  235. Shocks Advice needed
  236. Fuel System: '48 Champion carb problem
  237. Engine: Piston interchange
  238. Body: rust patching
  239. Paint: Using urethane automotive paints
  240. Ignition: Thibeault Distributor
  241. Exhaust Exhaust relief...
  242. Ignition: Starter motor rebuild, the cost
  243. Interior: How Does Accel Pedal Mount on Carpet??
  244. Fuel System: Jet size? '50 Champion Carter Carb
  245. Fuel System: Offenhauser 2706 installation info
  246. Speedo/Tach/Gauges How to test temperature gauge/sending unit
  247. Engine: Paxton compressor pulley
  248. Engine: What engine do I have?
  249. Cool/Heat: Heater hose routing ???
  250. Steering PS cylinder
