View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120
  1. Wheels Is anyone running P215/75/R15 tires on an 1963 Avanti?
  2. Brakes: brake fluid
  3. Electrical: Thumping Electrical Wiper Motor Unit
  4. Interior: Looking for page 24. Shop manual 59-64 body contents.
  5. Steering Leaky Power Steering
  6. Frame/Springs A Arm Bushings
  7. Body: How To Install 1963 Column Shift Knob?
  8. Ignition: Spark modifier
  9. Body: water leaks at windows
  10. Transmission: T90B or T85C?
  11. Engine: Valve covers 245 cu in.
  12. Body: 62 GT Hawk rear grille attachment "nails"
  13. Electrical: Power window woes
  14. Wheels Tire size
  15. Speedo/Tach/Gauges 63 Avanti Tach question
  16. Interior: 63 Avanti Interior mat colors?
  17. Clutch/Torque Converter: FLYWHEEL----REMOVAL 1961 lARK 6 CYL
  18. Body: Wanted: C Body Drip Rail Mouldings
  19. Body: Wanted: 56-61 Front Fender Front Inner Sheet Metal
  20. Interior: Seats from GT to Lark?
  21. Electrical: Cable Length
  22. Interior: Reclining Seat Mechanism
  23. Transmission: GM trans and 6 cyl engine
  24. Engine: 62 GT 289 running again (for 20 seconds)
  25. Front Axle: replace front suspension
  26. Electrical: Mini starters available for 289?
  27. Steering Upgrading steering on '60 Lark
  28. Rear Axle: Rear Axle End Play Question
  29. Body: Zip Van Door
  30. Engine: 1964 South Bend Skybolt Six Air Cleaner Orientation and Decal Placement
  31. Brakes: Remove in rear brake drums.
  32. Electrical: '51 Defroster motor bearing replacement
  33. Transmission: '63 tranny with '53 linkage
  34. Frame/Springs 1947 M5 Front Leaf Springs
  35. Body: Door Corner Seal
  36. Cool/Heat: What kind of cooling fan are you running?
  37. Body: Frt. fender needed
  38. Wheels 63 Avanti rims
  39. Body: dash removal 50 champion
  40. Wheels need rims
  41. Body: SH arm rest screws
  42. Engine: Thermostat in... still running hot!
  43. Electrical: Battery Install
  44. Engine: Oh poo!
  45. Electrical: Starter Solenoid/electrical question
  46. Fuel System: Question on sealing screws that mount the fuel sender to the tank.
  47. Electrical: Voltage Regulator, 60' Lark
  48. Wheels Alternate Wheels..Food for Thought
  49. Other: Studebaker Auto Parts on EBay
  50. Body: Location and years of serial number on frame?
  51. Engine: Need a PCV system for a 64 Hawk ??
  52. Fuel System: Fuel Pump dilemma
  53. Rear Axle: Rear axle diagnostic assistance please
  54. Fuel System: i have a 65 cruiser with a 283 thunderbolt; looking for suggestions on 4bbl carb options
  55. Engine: Harmonic balancer
  56. Frame/Springs Flat Beds
  57. Engine: V8 swap for a 1948 landcruiser
  58. Engine: oil pressure relief valve
  59. Fuel System: Zero Vapor-Lock Sure Is Nice, Thanks To Fuel Injection !
  60. Transmission: Adjusting throttle linkage on a TH350
  61. Transmission: What to do? 66 transmission
  62. Transmission: Correct Oil for Overdrive
  63. Engine: Oil Filter question
  64. Brakes: A brake Question in three parts. for my 50 Commander
  65. Body: trunk floor and driver/passenger front floors/62 GT Hawk
  66. Brakes: 56 Hawk brakes
  67. Frame/Springs Securing car for truck transport also radial or bias tires for a '54 commander??
  68. Interior: interior color
  69. Interior: 62 hawk headliner/windlace
  70. Cool/Heat: 62 Hawk air-conditioner
  71. Brakes: 62 hawk power booster/master cylinder
  72. Interior: 62 Hawk seats
  73. Engine: Intake Manifold torque and cup washers
  74. Frame/Springs add a leaf to hawk springs
  75. Paint: Bordeaux red
  76. Engine: Advice? Suggestions for Engine Rebuilder for 289 V8 in Mpls/St.Paul area?
  77. Body: Tips on best sequence for body, windshield, instrument panel and trim reinstall?
  78. Frame/Springs Cup Washers For Upper & Lower 'A' Arm Bushings
  79. Electrical: Overdrive solenoid voltage?
  80. Body: Leaky drip rail
  81. Brakes: PRIMARY AND SECONDARY SHOES ??? 55 Presdent Coupe
  82. Electrical: AC-2125 Factory/Dealer Accessory turn signal 51 Champion
  83. Fuel System: Wire from Distributor to back of Carburetor
  84. Ignition: Distributor problem... this can't be right
  85. Wheels Disk Brake Wheel
  86. Electrical: Alternatior/Voltage Regulator Problem 1963 Avanti conversion to 1988 Toyota Tercel Alternator
  87. Speedo/Tach/Gauges Fuel Gauge - Strange goings on...
  88. Engine: What is a better gasket cork or rubber and why?
  89. Interior: Heat treat stainless trim
  90. Interior: headliner bows
  91. Electrical: Avanti power windows
  92. Other: '41 Champion horn problem
  93. Cool/Heat: Anyone went with Straight water Versus Antifreeze and recorded difference?
  94. Cool/Heat: 51 Champ Temperature Gauge
  95. Engine: Break in Oil
  96. Body: removing door trim panel
  97. Fuel System: gas tank
  98. Fuel System: Original tank
  99. Frame/Springs We are all genius individuals.............but still take note!
  100. Fuel System: Carb/Manifold issue?? M16 big six 170cu 2.8L 94hp
  101. Steering Interchanging early and late bellcranks
  102. Engine: engine removal
  103. Wheels That Crazy Avanti Lug Nut Question....Again?
  104. Fuel System: R2 Carb Metering Rods and Jet Sizes
  105. Engine: Help With Champion Engine
  106. Front Axle: Handling modification (frt. suspension)
  107. Paint: Were door latches painted or cadmium plated?
  108. Body: 51 Starlight Coupe passanger side mirror mount
  109. Steering Rebuilding 61 Hawk Power Steering Pump Heres Some Stuff I Learned
  110. Body: '63 versus '64 sheetmetal
  111. Cool/Heat: 1964 Commander Fan Shroud
  112. Electrical: Fan Switch Part Number
  113. Ignition: Distributor rebuilder?
  114. Interior: Too tall for seat
  115. Engine: Camshaft Specs.
  116. Fuel System: 64 2bbl to 4bbl Edelbrock
  117. Body: Bumper Guard installation issues
  118. Cool/Heat: Temp sensor...
  119. Engine: 66 Commander Inline 6 Engine Knock VIDEO
  120. Body: Wanted: C-Cab bottom Seat....
  121. Brakes: Has anyone changed a Disc. brake hawk to Drum Brakes 1963 -1964
  122. Cool/Heat: C-Cab and "vintage air" air conditioning
  123. Interior: Avanti interior install - great photo help
  124. Body: Bubbles on Avanti body
  125. Fuel System: Installing a blow through electric fuel pump on an Avanti
  126. Transmission: '63 Avanti Flex Plate Renforcement Ring - Correct Installation
  127. Fuel System: Car wont start after Carburetor rebuild
  128. Body: 53 hood latch install question
  129. Cool/Heat: A/C sight glass leaking- need replacement
  130. Clutch/Torque Converter: Torque Converter Cover 55 President vs 62 GT Hawk?
  131. Rear Axle: A new leak!
  132. Other: (Safety) Top Ten Safety Errrors
  133. Fuel System: gas smell
  134. Speedo/Tach/Gauges Temp Gage and sender
  135. Body: Trunk Lock
  136. Transmission: 12V O/D solenoid?
  137. Fuel System: Need a carburetor for my '62 Lark...
  138. Fuel System: Tank float sealant
  139. Frame/Springs 1960 lark frame swap
  140. Fuel System: What carb do I need? (Champion)
  141. Engine: Supercharger 101
  142. Brakes: 51 Champion master cylinder
  143. Electrical: Looking for picture of both sides of the fuse holder in a 63-66 Lark
  144. Electrical: Studebaker Avanti owners with digital camera..........
  145. Engine: Braided Stainless Oil Pressure Lines
  146. Electrical: New Wiring Harness Installation on 60 Lark Convertible - UPDATE = DONE!
  147. Body: wing window glass
  148. Cool/Heat: Defroster cable
  149. Interior: 62 hawk headliner bows HELP
  150. Steering Replacing TL steering box in 1955 c-coupe with SL steering box.
  151. Body: 41 Stude Champion Body Plate
  152. Drive Shaft U - Joint From Nate's Cross Referance. Help?
  153. Body: Avanti battery brace
  154. Steering power steering
  155. Rear Axle: All locked up!
  156. Other: Need Glass!
  157. Frame/Springs 1947 Champion convertible frame - same as a 47 4 door champion?
  158. Brakes: Yeeow, What caused this? Photos
  159. Fuel System: vapor lock
  160. Brakes: 2r-16A wheel cyls?
  161. Electrical: constant drain on the battery
  162. Brakes: Power brake booster conversion
  163. Steering Avanti power steering hose routing
  164. Other: AC Oil Bath Air Cleaner Decal
  165. Frame/Springs 1929 Studebaker/Erskine Leaf spring bushings
  166. Electrical: Vaccum Advance for 61 Lark 259 -289
  167. Body: '63 Avanti Auxiliary Battery Support
  168. Other: How much is my car worth?
  169. Interior: Need Screw Size
  170. Brakes: 49' Champion Master Cylinder Help
  171. Frame/Springs Bind in Front Suspension
  172. Paint: Vinyl Dye vs Vinyl Paint
  173. Brakes: Disk Brake Conversion for Champion???
  174. Body: Avanti Rear Glass Removal Advice
  175. Clutch/Torque Converter: Clutch Linkage
  176. Fuel System: Connecting test vacuum gauge?
  177. Engine: Stamping auto-lite tags
  178. Body: 1964-5 Studebaker Daytona Exterior Trim Questions
  179. Interior: Wavy door panel repair
  180. Ignition: Colorado emissions test
  181. Engine: Water pump question for Studerich and others
  182. Fuel System: Question about what gas to use.
  183. Body: body to frame bolt torque?
  184. Body: wing glass
  185. Engine: need help on 56 packard v-8
  186. Transmission: 1947 Champion convertible
  187. Other: Wanted: Scotsman style hubcaps for 58 champ sedan
  188. Other: Steering wheel mount doesn't seem right
  189. Speedo/Tach/Gauges Tricky Problem
  190. Fuel System: Vapor lock
  191. Ignition: Beat-up by my ignition switch
  192. Cool/Heat: Heater block off
  193. Transmission: 289 / Bell Housing / BW T10 - '61 Hawk
  194. Cool/Heat: 57 Silver Hawk Artic Air A/C
  195. Steering For a better handling M5
  196. Rear Axle: Type - relation - 2R5 truck series
  197. Brakes: M series modified brakes
  198. Interior: Installing new carpet on '57 Silver Hawk
  199. Steering Power Steering Pump
  200. Interior: Which of these is correct Steering Wheel center emblem for Golden Hawk??
  201. Fuel System: 53 gas tank vent?
  202. Electrical: 62 hawk alternator conversion
  203. Body: Door latch adjustment... help
  204. Body: Adjusting a door gap
  205. Speedo/Tach/Gauges Speedometer pinion question
  206. Engine: Lionel Stone Accessories
  207. Speedo/Tach/Gauges Removing speedometer cable from the firewall-- HELP
  208. Brakes: Brake drum rust
  209. Brakes: 1950 champion brake questions
  210. Fuel System: Inside a 1955 President gas Tank??
  211. Exhaust 289 Exhaust Questions
  212. Brakes: Dot 3 or Dot 3 Synthetic ?
  213. Body: Hood Alignment
  214. Engine: engine ID
  215. Ignition: Start up noise
  216. Interior: bmw e39 seat replacement into 62 hawk
  217. Other: Feeling every bump
  218. Interior: Lark bucket seats
  219. Electrical: Guages
  220. Body: Avanti seat slider
  221. Body: Front fenders? Fenders?
  222. Fuel System: Carter 1Barrel Carburator Question on 61 Lark VI
  223. Transmission: Reliability of early automatic transmissions?
  224. Speedo/Tach/Gauges How to identify speedometer driven pinion gears? Who's got 'em?
  225. Steering steering wheel crack repair
  226. Body: Cleaning aluminum trunk cover
  227. Body: Back Seat Straps on Headliner
  228. Transmission: Is there an OD Trans that will bolt in? (65 Commander)
  229. Transmission: T-14
  230. Transmission: Reverse went out!
  231. Body: GT Hawk Hood Prop - Did I loose something?
  232. Fuel System: Gas Line Size
  233. Engine: Almost no oil pressure
  234. Interior: Ebay seat covers
  235. Engine: Rough idle- any guesses
  236. Brakes: Park Brake Cable Differences
  237. Exhaust Need a heat riser
  238. Engine: 289 progress
  239. Cool/Heat: I NEED A Alumimum Radiator
  240. Exhaust broken exhaust manifold bolt
  241. Engine: Is it worth the effort?
  242. Cool/Heat: Need help with radiator mounting
  243. Exhaust dual exhaust question
  244. Cool/Heat: 55 fan shroud into a 53?
  245. Brakes: Front drums on a 55 Commander cp
  246. Clutch/Torque Converter: Seperating engine from tranny
  247. Rear Axle: rear end ratio
  248. Body: Hawk Trim Needed
  249. Electrical: Hawk Headlight Switch
  250. Engine: conversion questions
