View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Avanti Trunk Release Problem
  2. 53 Starliner Frame
  3. Headers
  4. Yikes! I've got a key problem.
  5. $hrome Bumpers
  6. Avanti Radiator Resevoir
  7. Resident Rodents
  8. '46 Studebaker Pickup
  9. Overdrive Installation
  10. Pilot Bearing ?
  11. Champ Truck wheel alignment specs
  12. Good place to get an engine rebuilt?
  13. Prewar Round Muffler Construction
  14. Changing an open diff to TT
  15. 1962,lark, front seat
  16. Caddy Tripower
  17. Power steering pump
  18. E Brake boot replacement
  19. Found a great site for filters purchase's.
  20. Stude frame question
  21. 1917 Studebaker body color
  22. 5 and 6 Blade Fans
  23. Lark gas cap wanted
  24. 62 Rear Seats
  25. 1963 R-2 Gran Turismo Hawk
  26. Hydraulic Lifters
  27. Rocker switches?
  28. Help/advice to set up Hill Holder-50 Champion
  29. Electric Wiper Repair
  30. PARK BRAKE HANDLE PAWL & SPRING C&K CARS
  31. 1940 6cyl fuel pump
  32. Main Bearings for 259 cu
  33. headliner
  34. Tranmission Fluid & air box
  35. Automatic Trans rebuild kit
  36. Rear Quarter/Body Panels
  37. Information for a automatic Transmission 1951 Stud
  38. Information for a automatic Transmission 1951 Stud
  39. Partial Flow Oil Filters
  40. 4 Barrel Air Cleaner
  41. Engine noise
  42. 53 crankcase ventilator
  43. Gas Shocks & Radial Tires ???
  44. 4spd clutch support
  45. Where are the water jacket drain plugs on the V8's
  46. Adding a link
  47. 1961 Hawk....limited tag on dash
  48. another stude tech site
  49. Vented oil cap?
  50. standard transmission 3 spd overdive
  51. rubber hood bumpers
  52. left and right vent doors
  53. Pics of the drivetrain mock-up in my '54
  54. Any tips on drip rail trim re-install?
  55. Black light dash illumination
  56. Rear Bumper GT hawk
  57. Wierd open in gauges
  58. 2R5 seal source or crossover # ?
  59. Windshield Washer Instructions/help needed
  60. 63 avanti/ Chevy 350/ headers
  61. Parts game
  62. Lifter noise, No! Was Distributor slop.
  63. 2r5 truck rear axle gearing
  64. digital clock
  65. Oil Pressure Problem
  66. 61 Lark Engine Color
  67. Next part
  68. 50 stude noise
  69. more low end
  70. Antenna location
  71. Wiring challenge - Starlightchamp
  72. 47 commander convertible-questions
  73. A/C question (ebon?)
  74. Engine color for a '53 - 6 cyl.
  75. Avanti Rubber Plugs
  76. source for leaf springs
  77. bumper guards
  78. 53 Studebaker Red
  79. Air-conditioning a 1963 R-2 Avanti
  80. Where is the VIN nr om my Wagonaire 1965
  81. Rear End Gear Ratio for Mileage
  82. Sputtering Lark
  83. painting parts on 63 Cruiser
  84. Expressly Avanti
  85. C Cab wiring harness for a 2R-10
  86. Spare Tire on 2R-10
  87. 2R-10 Rubber
  88. Seat belt anchor location in 53K
  89. engine v 424435 what year ? etc.
  90. R1 --- is this true ?
  91. Differential Application Question
  92. DOES ANYONE HAVE SERIAL # 61V8822 ?
  93. 63 Hawk Tach Trouble Shooting/Repair
  94. Headers for a Hawk?
  95. Engine swap help needed
  96. 1953 studebaker 4 door champ.
  97. Engine ID help
  98. NOSR Water Pumps, Fuel Pumps, Oil Seals, Brake Cyl
  99. 4 lug to 5 lug conversion
  100. Oil Pan Gasket
  101. Supercharger or fuel injection?
  102. Trunk lock operation
  103. swinging lock covers
  104. Lark Front Fender Comparison
  105. Lark with power disc brakes
  106. steering
  107. Lark engine color
  108. removal of water stains in upholstery ?????
  109. fresh air vent on the passenger side broken ??
  110. Trunk lock modification - cable release.
  111. 62-3 Hawk console
  112. Parts
  113. Lights with mind of thier own
  114. can you identify my engine?
  115. 6 cylinder engine ID
  116. Consumption
  117. Wheel color
  118. GM motor transplant
  119. Carb repair
  120. 12V to 6V signal conversion
  121. V8 Firing Order & Valve Setting
  122. parking brake cable
  123. Dash Removal?
  124. Brake fluid
  125. 56 door interchange
  126. weatherstripping for 53 coupe
  127. interior finish
  128. Floor pan rust
  129. ebay manifold
  130. 1953 Parts: Rear window
  131. SLOW wiper motor
  132. headers for 53 commander
  133. fenders
  134. 36 OVERDRIVE - NEED HELP
  135. Trunion grease problem - Tip needed...
  136. Forward Driveshaft Removal
  137. 63 Cruiser rear drums
  138. Rear end ratio
  139. Stock Mirrors?
  140. What happened to the game Mr.Biggs?
  141. PCV valve?
  142. 289 Fuel pump Help
  143. Dual master cylinder on 64 PU
  144. water pump specs
  145. Tire Help
  146. Air-conditioning a 1963 R-2 Avanti
  147. Where is my backup light switch?
  148. 2R lower cab corner rust repair/patch panels
  149. 65-66 flanged axle question....
  150. Oil pan gasket and rear main seal ?
  151. Sluggish power
  152. Avanti emerg. brake cable & R3 manifolds
  153. Flat black?
  154. brakes
  155. 56 door hinges
  156. V-8 crank pulleys
  157. '55 PRESIDENT POWER BRAKES PLUMBING
  158. valve clearance specs for 27 Big Six
  159. 1953 Auto Trans
  160. Frame thickness, 56 wagon
  161. Engine # location
  162. Gas Tank
  163. 57 Hawk... not Gold or Silver?
  164. crankshaft id
  165. 1955 shift tube replacement
  166. Radiator Cap?
  167. I need........
  168. Rebuilding a V-8
  169. Wheel Problems
  170. Oil pan remove 48 Champion?
  171. starting
  172. 62 Hawk disc brakes? Possible?
  173. Window switch
  174. Need modern replacement for V8 valve stem seals
  175. lets talk about my dads 1960 lark shoft top
  176. 170 OHV engine power
  177. Ride height
  178. 56 wagon gas tank
  179. cam ID
  180. 65/66 V8 frame mount part #s
  181. New 2 X 2 Intake
  182. Powershift?
  183. Where can I get this tool?
  184. Rechrome mirror housing
  185. Studebaker Factory pictures
  186. Studebaker Photos Link--Opps
  187. Brake Drums... Help!!
  188. Modern replacement Stude F suspension??
  189. AFB Idle Question
  190. swapping '50 champ rear axles to 55
  191. Installation Placement Photos '63 GT
  192. Overall Lengths
  193. engine color
  194. Avanti Body Work + Wheels
  195. Trying to get my Lark fender straight
  196. Ballast Wire
  197. 1940 Headliner
  198. Manifold gasket
  199. Disk Brake Wheel Painting (63)
  200. Raw gasoline shooting out of carburator
  201. '54 Champion Sedan Photos Needed
  202. steering wheel adapter
  203. regulator
  204. Avanti Heater Core
  205. 51 Champion 6 cyl w/OD
  206. 1962 gt hawk radio
  207. 41' Commander Lug Pattern?
  208. Brake Parts
  209. Radiator problems- need part
  210. Tires
  211. Commander motors
  212. Need a short brake line replaced
  213. Tell-tale lights
  214. 63 GT Hawk Trunk Sill
  215. New Wheels
  216. 61 HAWK TEMP GUAGE SENDING UNIT
  217. Temp Sender for 60 Lark
  218. Offenhauser intake/engine question
  219. changing transmissions
  220. Door switch problems
  221. Power windows!
  222. Another one back on the road
  223. Cutting, Chopping, Stretching - how to..???
  224. Water pump
  225. Heater core
  226. 1961 HAWK DASH RADIO SPEAKER
  227. Avanti II ignition problems
  228. spin-on oil filter adapter
  229. pot metal molding
  230. M5 Pick up front end and brakes
  231. 63 champ ?
  232. Flathead compression
  233. 48 CHAMPION FUEL PRESURE?
  234. Fender welt color
  235. EXISTING 58 GOLDEN HAWKS?
  236. Stude Heads
  237. Trans. bleed back problem - BW 3 band Auto. Trans.
  238. tires
  239. transmission/accelerator linkage
  240. transmission
  241. Tool question - home garage lift? anyone have one?
  242. mileage
  243. Working on new Avanti frame
  244. WTB: A/C crank pulley
  245. Tool Suggestion for Flaring SS brake lines
  246. Question about engine miss only when warm
  247. T cab front clip mount
  248. Skytop installation
  249. What Year?????
  250. You read it first in Turning Wheels
