View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Engine: Oil Use
  2. Body: reply from Andy at the Studebaker Museum
  3. Electrical: Electrical Overcharge with '63 Hwk
  4. Steering Bending the rod?
  5. Electrical: Avanti neutral safety switch
  6. Engine: camshaft bushing tool
  7. Transmission: If I wanted a T5 for my 259, which one should I get?
  8. Clutch/Torque Converter: Clutch diameter
  9. Engine: Sea Foam
  10. Engine: 259 Engine Rebuild Kits that are offered at SI
  11. Electrical: 62 Hawk ammeter wire around
  12. Cool/Heat: R 134 retrofit
  13. Wheels Radial Tire Size for Hawk
  14. Electrical: My 6v to 12v conversion experience
  15. Body: K body vent window pivot question
  16. Electrical: 1962 Lark turn signal circuit keeps blowing fuses.
  17. Body: 1952 Commander
  18. Wheels What valve stems?
  19. Engine: Studebaker Cruiser 1963
  20. Engine: What to make of this engine ID #?
  21. Frame/Springs Sagging Daytona
  22. Body: Broken Hinges on 51 Champion Convertible Top
  23. Wheels New Replacement Wheels for Hawk
  24. Drive Shaft 64 hawk u-joints
  25. Body: Can you weld the Chrome Trim Strip tabs back in place? (57 K-Body)
  26. Paint: Tip o' the Day
  27. Cool/Heat: Oops! I forgot to take pictures
  28. Drive Shaft Driveshaft yoke depth
  29. Cool/Heat: Need some radiator help
  30. Engine: My project Avanti
  31. Body: C-K Windshield
  32. Brakes: DOT 5 Issues
  33. Fuel System: Fuel sending unit
  34. Interior: Minnesota/Wisc guys: Upholstery recommendation in Twin Cities metro area for Hawk interior?
  35. Paint: 1954 Shoshone Red - any late model cars with a close match ?
  36. Fuel System: Supercharger Noise Complaints?
  37. Drive Shaft Hijacked : Driveshaft yoke depth
  38. Brakes: Stop light switch drips
  39. Fuel System: Spring Tensioner vs. Turn Buckle Tensioner For the Idler Arm Pulley--Avanti R-2
  40. Brakes: Upgrading my Lark's brakes and steering
  41. Rear Axle: How to replace the felt washer on an outer wheel seal?
  42. Engine: Pinging & Running On.
  43. Ignition: how to hotwire
  44. Other: Temp Gauge wiring
  45. Body: Can this bonnet (for Golden Hawk hood) be saved?
  46. Engine: Oil paths
  47. Transmission: Dipstick and tube for 2-speed automatic
  48. Body: Inner Fenders
  49. Body: ? 1955 Part Numbers ?
  50. Fuel System: Jet size for Champion 185 carb?
  51. Transmission: 75 Avanti, 700R4 tranny removal...pull engine????????
  52. Engine: Replacement engine
  53. Other: It runs!
  54. Engine: Ignition marks 1/2 rev. off
  55. Cool/Heat: Jeopardy,..Id that Radiator for 20 "thank you's"
  56. Engine: Timing variation
  57. Drive Shaft '65 Daytona, Pinion Angle "Broken Back" configuration???
  58. Engine: 9.8 miles per gallon?? : (
  59. Body: THE answer for removing undercoating.
  60. Fuel System: anyone tried one of these sending units?
  61. Transmission: Automatic Transmission Shifter
  62. Engine: Spun rod reasons?
  63. Interior: correct color for armrests in gold Golden Hawk???
  64. Interior: 51 Champion Instrument Panel Installation
  65. Front Axle: Front end alignment with radial tires
  66. Fuel System: Surging when hot
  67. Frame/Springs wondering if I know what part i'm looking for?? 58 Champion
  68. Engine: One thing leads to another
  69. Paint: Hawk Valance color
  70. Exhaust Parks pipes fit (just about)
  71. Engine: Broken Exhaust Valve #2
  72. Electrical: not charging
  73. Brakes: Brake noise
  74. Electrical: 1962 Lark sedan: my back up lights are 'dummies'.
  75. Engine: Unexpected shut-off.
  76. Transmission: How much noise is normal for an automatic?
  77. Exhaust Headers for 65 Commander
  78. Transmission: 51 Champion, OD only kicks back intermitently
  79. Transmission: OD question.
  80. Engine: 1939 Studebaker ambulance engine
  81. Brakes: Help ID piston kit
  82. Fuel System: Carter carb
  83. Wheels What set back to clear 63Avanti Disc brakes?
  84. Electrical: Electrical overcharge with '63 Hawk (05-22-20120) FOLLOW-UP
  85. Electrical: rewiring horn
  86. Transmission: 5 speed trans in 64 Champ - Stude?
  87. Engine: Piston 'Oil' Rings
  88. Engine: What do you seal head gaskets with?
  89. Wheels Wheel spacers?
  90. Electrical: Need Delco starter brush holders
  91. Engine: Machined aluminum timing gear covers
  92. Engine: OHV 6 Head
  93. Engine: Distributor
  94. Engine: Prewar President N.O.S. standard bearings
  95. Body: 1948 Commander Body Parts
  96. Electrical: 1964 commander fuses
  97. Brakes: 50 Champion Front Disks
  98. Body: 50 champ question
  99. Body: weather strip installation - 51 Champion Starlight
  100. Body: Power Window 55 ,2 door president
  101. Ignition: '64 Avanti wiring
  102. Paint: '62 Green Metallic Poly formula?
  103. Electrical: mystery wire
  104. Speedo/Tach/Gauges Broken Clock
  105. Cool/Heat: Aluminum Radiator for 64 Avanti ????
  106. Rear Axle: Brass flakes after flushing
  107. Steering steering wheel install
  108. Engine: Dip Stick Length
  109. Other: What Are Folks Cleaning Their Tools With?
  110. Other: Hawk pop out rear vent windows
  111. Interior: Dashboard restoration
  112. Body: Need help, 55 Champion trunk adjustment & stainless trim below windshield
  113. Ignition: Basic Timing pointer question for '63 289
  114. Body: Seat Belt Installation Tips?
  115. Interior: Source for '60 Lark Arm Rests?
  116. Electrical: Front fender lights on 63 Avanti
  117. Body: another 50 champ question
  118. Wheels 62 GT Hawk New wheels need your opinion
  119. Fuel System: Stuck needle valve
  120. Cool/Heat: Wrong fan, right fan
  121. Electrical: 12 volt wiper motor needed
  122. Transmission: '48 Champion Gear shift knob thead size?
  123. Body: Avanti Trailer Hitch
  124. Interior: Glove Box Lock Removal/Installation
  125. Body: TT emblem location for '63 Wagonaire?
  126. Brakes: Self Adjuster Part Numbers...
  127. Engine: starting after rebuild
  128. Brakes: Packard Hawk brakes - Hydrovac
  129. Other: Headlight access
  130. Rear Axle: Dana 27 shaft removal
  131. Engine: Will 259 heads work on my 289?
  132. Engine: holes in Avanti intake manifold
  133. Electrical: windshield wiper motor
  134. Engine: Starting ???'s
  135. Transmission: OD solenoid
  136. Transmission: T-85 Tranny Rear Seal; Making Do
  137. Speedo/Tach/Gauges Pinion Gear
  138. Body: Lighting accessories...
  139. Interior: Avanti AM/FM Radio Bracket
  140. Ignition: 232 Questions
  141. Engine: PS6xxx engine - what to do with it?
  142. Transmission: Trans problem or something else
  143. Body: Front flipper spring orientation
  144. Electrical: '51 Signal Question
  145. Interior: How do you separate Ash Trays (57 Hawk) for re-chroming???? and E-brake handle?
  146. Engine RPMS
  147. Body: how to remove window crank
  148. Engine: AHHH what did I do/not do/ do wrong
  149. Interior: Intallation of Vanity
  150. Electrical: 1931 President
  151. Other: Load capacity
  152. Transmission: 700R4, Edelbrock Carb. Throttle Rotation
  153. Cool/Heat: Could someone do me a favor?
  154. Electrical: tachometer for 48 champion
  155. Cool/Heat: 64 air conditioning
  156. Brakes: 55 Presdient Coupe - Front Brake Shoes
  157. Fuel System: Water in Carburetor
  158. Interior: 1962 Lark 3 point seat belts
  159. Fuel System: Electronic Fuel Injection Up & Running
  160. Electrical: Adjusting headlight aim
  161. Steering Ever use this alignment tool? Looking for tips on its use....
  162. Electrical: "Flashing" Headlights
  163. Engine: Adjustable cam gear drives finally on sale
  164. Speedo/Tach/Gauges Broken speedometer cable
  165. Engine: Stude roller cams offered
  166. Engine: Manual Choke / Carb Problem
  167. Engine: 1955 president 259 head crack on intake wall passage
  168. Engine: Thermostat # ?
  169. Rear Axle: "NEW" NOS VINTAGE Axle sets on E Bay
  170. Transmission: Problems installing Tremec TKO
  171. Engine: Engine-weight & gearbox
  172. Fuel System: Hesitation and sputter on acceleration
  173. Electrical: Copper washers on gas tank sending unit
  174. Electrical: Avanti power windows
  175. Engine: R-1 Engine Particulars
  176. Transmission: Strange Vibration
  177. Interior: '28 President needs "original mohair' headliner- any donater vehicles out there?
  178. Body: Need help identifing what looks like a 1926 Big Six Studebaker
  179. Fuel System: 1960 Lark Carburator
  180. Brakes: Brskes Lock up issues
  181. Transmission: T5 transmission adapter to Studebaker V8??
  182. Body: Hope this helps someone else-HOOD FIT 57 SH
  183. Electrical: Avanti ign switch wiring help
  184. Steering power steering conversions for 53-54 ???????
  185. Wheels Later Model Studebaker Wheels
  186. Engine: 28 dictator motor assembly questions
  187. Transmission: Gears jumping
  188. Brakes: Need used l/r drum 55 president coupe
  189. Engine: 1950 Champion Engine Runs Hot
  190. Cool/Heat: Alum. Radiators
  191. Steering Front Crankshaft Seal
  192. Electrical: Turn Signal Issues
  193. Engine: Champion Valve Adjustment
  194. Other: 1963 lark wiper arm
  195. Fuel System: Fuel Tank Problems
  196. Transmission: Fix for T85 tailshaft seal
  197. Paint: 1959 Hawk paint ?
  198. Frame/Springs Is there a bolt removal secret?
  199. Engine: Is it possible to put an r4 intake on a259.
  200. Engine: Governor Repair
  201. Fuel System: Gas Gauge
  202. Engine: Engine block number VK321
  203. Engine: 289 r-2
  204. Fuel System: Heat Riser Mod, To Intake Manifold
  205. Wheels 14 inch rim ?
  206. Engine: Need to buy a HD water pump but have a question
  207. Engine: 55 Studebaker Champion wont start when hot....
  208. Transmission: Clutch source & reccomendations
  209. Engine: follow up - holes in intake manifold
  210. Speedo/Tach/Gauges pinion gear
  211. Engine: serial number ? LS795
  212. Steering Steering bellcrank bearings/ bushings
  213. Engine: Oil restrictors to the heads
  214. Fuel System: By popular demand!
  215. Ignition: R2 plug selection
  216. Cool/Heat: GT overheating
  217. Fuel System: 1930 Studebaker Commander Carburettor
  218. Brakes: DOT 5 (Silicone) Brake Fluid
  219. Engine: Waterpump Fan flange bolt spacing
  220. Rear Axle: Dana 44 numbering question
  221. Electrical: Need a little more help
  222. Frame/Springs Delrin Bushings
  223. Engine: How to remove oil-fill tube
  224. Exhaust F/S: 1959-1964 Studebaker NOS V8 Front Single Exhaust Pipe
  225. Transmission: T-90 shift fork oil seals
  226. Cool/Heat: 1962 Lark Chevy V8 radiator?
  227. Transmission: 700R4 TV Cable adjustment - NOT
  228. Drive Shaft centre support querie
  229. Frame/Springs Leaf spring tip inserts and bushings
  230. Body: Lark convertible body braces
  231. Transmission: How to prepare new-in-box 1959 transmission?
  232. Frame/Springs How do I correct: Left side of car is 1-1/2" lower than right side.
  233. Brakes: '63 wagonaire brake MC
  234. Engine: good and stuck 6cyl :-(
  235. Brakes: rear disc brakes
  236. Engine: How much torque before front pully bolt snaps off in crank?
  237. Transmission: Automatic Transmission on '64 Commander Will Not Shift into 2nd or Reverse
  238. Electrical: Internal Distributor wiring
  239. Rear Axle: URGENT PROBLEM- axle shaft won't go all the way in on reassembly
  240. Frame/Springs 65 Commander Rear Leaf Bushings
  241. Other: Radio Removal
  242. Steering Steering box, replacement or rebuild?
  243. Engine: Aftermarket air cleaner
  244. Cool/Heat: Source for new Aluminum Studebaker radiator
  245. Electrical: Does anyone know where these wires go?
  246. Body: Avanti Door Hinge Saga Resolution
  247. Transmission: Avanti T-5 Shifter Offset
  248. Electrical: Removing stock Avanti tach - Keep some wires connected?
  249. Exhaust Exhaust leak on the 65
  250. Frame/Springs NOS Lower Control Arms 64Hawk
