View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Steering Pulling
  2. Transmission: speedometer gear
  3. Electrical: Windshield wiper motor 1962 Lark, it's dead
  4. Engine: I'm a sucker for Harbor Freight Tools
  5. Brakes: Anyone heard of this rebuilder?
  6. Interior: 1962 Lark: seatbelt shoulder harness question
  7. Body: Front bumper 54 vs 56
  8. Body: 63 Avanti windshield
  9. Paint: White Sand
  10. Other: Lionel Stone Accessories
  11. Engine: Bummer... crack in cylinder wall
  12. Rear Axle: T Cab Axle Splines
  13. Engine: Oil pressure.
  14. Engine: Loosing Oil in my Lark.
  15. Engine: Random pistons
  16. Transmission: T 10 Question/Clarification
  17. Other: Two bad relays, two bad switches and six months later, I have found the short...
  18. Other: 57 Silver Hawk VIN
  19. Paint: Color of PH, bottom of car, floorboards
  20. Steering kingpin bearing and bushing tools
  21. Body: Glue for gluing hood insulator
  22. Brakes: Brake Fluid Loss
  23. Fuel System: Fuel pump on Chevy V8 in a Lark How much Clearance is OK??
  24. Fuel System: Carb advice needed
  25. Cool/Heat: R-1 water manifold
  26. Engine: '63-'64 Avanti Water Pumps
  27. Brakes: Brake line fitting size, '58L-K9
  28. Speedo/Tach/Gauges Speedometer cable for late 55
  29. Wheels Wheel Size Question (AGAIN)
  30. Fuel System: Looking for rebuildable Stromburg WW 6-122 carb
  31. Clutch/Torque Converter: Diaphram Clutch Install & Driving Results
  32. Brakes: Brake fluid reservoir Hawk GT 1963
  33. Steering Control Valve Connection... wrong size?
  34. Electrical: Power Window motor restore shops
  35. Interior: 1963 Radio Push Buttons - How To Lighten?
  36. Brakes: dust caps
  37. Engine: super charger belt
  38. Interior: Wanted Truck Seat....
  39. Body: M-15 & m-5 body to frame?
  40. Body: 63 Avanti rear glass
  41. Body: Avanti door hinge re-inforcement
  42. Other: Dampner hub & pullies
  43. Cool/Heat: Any Information or experience with the A/C Unit that Bob Helms has on his web site?
  44. Engine: 62 GT leaking oil (more than usual)
  45. Paint: Dupont paint chips online
  46. Ignition: Polarizing the Generator
  47. Cool/Heat: Pump Pressure?
  48. Cool/Heat: Radiator sizes
  49. Body: Door ID plate
  50. Front Axle: Home-made Kingpin bushing & A arm spreader tools
  51. Engine: The camshaft break-in run on my rebuilt 259 had a couple of glitches
  52. Ignition: Distributor ID : Mopar conversion?
  53. Interior: Installing new "cat whiskers" in doors
  54. Transmission: Parts sources for R-10 OD?
  55. Steering 1955 Horn Ring and Emblem
  56. Transmission: 64 crusier with 61 auto trans surging?
  57. Fuel System: 40 champ no fuel
  58. Steering '51 steering parts on a '50
  59. Speedo/Tach/Gauges Tach wiring....?
  60. Transmission: Auto trans ID help needed
  61. Ignition: Distributor I.D.
  62. Drive Shaft 48 Champion drive-shaft ?
  63. Speedo/Tach/Gauges Canadian vs. US speedometer mechanism.
  64. Transmission: Saginaw 4 Speed
  65. Engine: what size and year
  66. Electrical: 61 Hawk horn issue
  67. Ignition: 40 distributor swap
  68. Frame/Springs 63 Avanti rear bumper
  69. Interior: Recommended carpet glue
  70. Engine: Viscous Drive Fan???
  71. Exhaust Different Mufflers vs. Chambered exhaust - Opinions please
  72. Cool/Heat: Fan blade assembly
  73. Paint: Frame & Engine Paint Question
  74. Body: Where are the locations of all the drain holes?
  75. Ignition: 1965 Cruiser V8 engine, photos that show spark plug wire "looms".
  76. Ignition: Delco window distributor into C/K?
  77. Electrical: 49 champion electrical question
  78. Cool/Heat: New cross flow radiator and cold air intake
  79. Body: Mounting side rearview mirrors on '62 Hawk
  80. Body: Rare Technical Bulletin on Door Adjustment
  81. Brakes: Disc brake squeal
  82. Transmission: 5 speed into a 62 hawk that has a 4 speed
  83. Cool/Heat: water pump
  84. Fuel System: Electric Fuel Pump Installation
  85. Other: Tool Question, Vibratory Tumbler
  86. Paint: 1960 Studebaker Lark 60V-L6
  87. Engine: Engine performance for a 55 speedster
  88. Engine: Wagonaire engine...mystery?
  89. Electrical: 63 Avanti wiper switch replacement
  90. Exhaust 60s - header pipe to manifold gasket
  91. Engine: Using a little oil...
  92. Electrical: 59 & 60 Larks: What's the difference...
  93. Steering Control valve
  94. Engine: low compression
  95. Ignition: pertronix
  96. Electrical: Power Window Switch / 57 ford thunderbird intrechange ? For Avanti's
  97. Electrical: Has anyone had their Power Window Motor Rebuilt For Their Avanti ?
  98. Electrical: Dash light resistor
  99. Engine: Road draft tube
  100. Engine: stuck valves in the 40
  101. Body: Station Wagon door for convertible?
  102. Engine: 66 283 throttle part needed
  103. Electrical: Wiper switch quandry
  104. Body: Wagonaire-Installing the Windshield
  105. Brakes: Which drums for my 52 Commander
  106. Clutch/Torque Converter: No clutch?
  107. Interior: Window Channel
  108. Body: studebaker ventilator release
  109. Paint: POR15 coverage?
  110. Fuel System: Use of Cadillac intake manifolds.
  111. Steering 56 golden hawk pressure hose power steering
  112. Body: 57 Silver Hawk Fin question
  113. Frame/Springs 63 Avanti Front Springs Question
  114. Body: door skins for 54 C/K
  115. Frame/Springs Will CalTrac Bars Fit The Hawk Frame/Springs?
  116. Electrical: Windshield washer wiring - '64 Commander
  117. Body: body panel
  118. Speedo/Tach/Gauges accessing fuel gauge on GT
  119. Body: Undercoating Removal - What Method Works Best?
  120. Brakes: master cyclinder
  121. Body: Window regulator grease
  122. Exhaust Heater valve spring
  123. Brakes: Aggravating banjo bolts
  124. Engine: I'm getting old/clumsy/dumb to be working on these things
  125. Interior: Best sound upgrade ever
  126. Engine: synthetic oil and zddp?
  127. Electrical: No rear turn signals or Brake lights
  128. Body: 55 to 53 conversion
  129. Interior: Stinkyville
  130. Cool/Heat: 1952 radiator retro question
  131. Engine: engine color for 40 champion
  132. Cool/Heat: Mountng SI's Radiatior Overflow Kit in a Cruiser
  133. Engine: WTB Throttle linkage
  134. Cool/Heat: Radiator repair???? Silver seal vs barges??? Or none
  135. Steering Steering Column Options
  136. Rear Axle: Rear axle shimms on my 65 commander
  137. Paint: Valve cover yellow for '63: Is John Deere yellow close?
  138. Brakes: Left hand thread brake drum interchangeable with right?
  139. Steering PS spraying fluid, plugged vent? Avanti
  140. Body: 55 taillights on a 53 c/k?
  141. Steering Studebaker reach rod 1542005
  142. Exhaust Can I live WITHOUT a HEAT RISER? 61' Lark, 6 cylinder OHV.
  143. Steering ram seal kit
  144. Frame/Springs 58 sliver hawk frame
  145. Electrical: Radio cable for an Avanti
  146. Transmission: Help to ID OD transmissions
  147. Interior: dash pad installation
  148. Electrical: Engine coil and now re-wiring the Lark.
  149. Body: Need a door rebuild at hinges
  150. Body: Hot-rodding a tailgate window lift motor.
  151. Rear Axle: 65 Commander Rear-end
  152. Body: Just Thinking Out Loud
  153. Fuel System: Fuel Pump Kaput
  154. Interior: 57 Hawk Dash Removal
  155. Engine: Auto choke heater tube for '63 OHV 6 ???
  156. Body: Vent window rivets????
  157. Transmission: 700R4, '65 Daytona, Crossmember Clearance
  158. Transmission: Pickup overdrive transmission?
  159. Electrical: No charge
  160. Cool/Heat: radiator drain
  161. Fuel System: Fuel pump won't shut off
  162. Clutch/Torque Converter: 8E Champ clutch adjustment
  163. Body: Were mirrors an option on a 58 Golden Hawk?
  164. Body: Door keys lost how do i get replacements???
  165. Body: Where do I find Zip Van serial plates?
  166. Engine: why is the lark running so rough?
  167. Transmission: 3 speed trans
  168. Body: Preventing rust
  169. Engine: sending unit
  170. Ignition: Sparkplugs 49 Champion
  171. Interior: So, where are we getting our carpet now?
  172. Steering Discovered a New Steering Unit Rebuild Service
  173. Other: How do you get the rear windows 58 G.Hawk to work
  174. Engine: Crank Race Prep
  175. Rear Axle: Rear axle nut torque
  176. Steering How to replace steering fliud-63 Hawk GT?
  177. Exhaust Hawk Tailpipes
  178. Electrical: Horn relay, of all things...
  179. Electrical: Ammeter always shows a slight charge while driving/idling '63 Hawk
  180. Transmission: T-96 6 cyl. trans/ throw out bearing question and Super T-10 Conversion
  181. Interior: Headliner Insulation
  182. Electrical: Another 6v to 12v conversion
  183. Engine: Cartridge Oil Filter Lines
  184. Engine: Head Identification Quandary
  185. Electrical: Generator to alternator..
  186. Engine: Steel line info for Oil filter hookup questions
  187. Transmission: 5spd overdrive
  188. Body: Rear License Plate Mounting on 1957 Silver Hawk
  189. Engine: Oil Pressure too low or ????
  190. Other: Metal Rescue
  191. Body: 57 GH Rear Windows
  192. Shocks FLAPS part number
  193. Electrical: 55 President switching to 12v
  194. Electrical: 6 Volt battery charge problem
  195. Transmission: transmisson
  196. Fuel System: '63 Lark V8 starves for fuel.
  197. Cool/Heat: Avanti clutch fan
  198. Fuel System: Dual Carb Balance Port Screeching
  199. Other: Cleaning small metal parts.
  200. Fuel System: Need to replace my gas tank.
  201. Body: 58 PH deck lid hole for Continental cover kit
  202. Body: Core support question
  203. Body: Hawk hinge springs question
  204. Other: Rust Removal with Spooge Tank
  205. Engine: Adjustable cam timing gears and two piece gear cover on the way..
  206. Body: Door Drains
  207. Brakes: turner brakes
  208. Transmission: '63 Avanti Auto Trans/Bell Housing Alignment
  209. Electrical: windshield wiper motor needed
  210. Electrical: Wiper switch wiring '66
  211. Frame/Springs 56 J rear springs-now with pics
  212. Fuel System: '47 m5
  213. Other: How to attach the Avanti S/N plate?
  214. Engine: air cleaner
  215. Electrical: 1965 Commander Headlight Switch getting HOT!
  216. Electrical: Re-casting Radio push buttons ?
  217. Brakes: Left rear brake lockup
  218. Cool/Heat: Temp range Avanti got to 195 yesterday at highway speed
  219. Engine: Chevy Valve Conversion
  220. Engine: Slight tick, got worse
  221. Speedo/Tach/Gauges Speedometer repair
  222. Wheels 1948 M5 Tire size
  223. Engine: Help with Oil Pan Interference - small block Chevy in 62 Lark
  224. Electrical: Distributor Question
  225. Brakes: brake rubbin' question
  226. Fuel System: First attempt at a 1 brl - carb that is...(pics)
  227. Ignition: Distributor swap
  228. Other: Need advice for locating a windshield for a 1965 Commander
  229. Engine: Is the water pump manifold defferent on all 224 ci and 259 ci V/8 truck motors
  230. Brakes: New master cylynder for a '63 Lark
  231. Speedo/Tach/Gauges Speedometer adapter for Tremec TKO to stock Stewart Warner Speedo cable
  232. Fuel System: Needs a new home:-)
  233. Engine: Pre-oiling a 289 - should oil be visible on top end?
  234. Transmission: 64 flight omatic
  235. Wheels source for big lug wrench 2R-16 ?
  236. Wheels Tire sizes... again
  237. Engine: gasket set
  238. Rear Axle: pulling inner wheel seals
  239. Transmission: Hurst 'Synchro Lock' Floor Shifter
  240. Fuel System: Vented fuel filter
  241. Body: Dent Removal
  242. Electrical: AC System
  243. Steering From power steering to manual
  244. Brakes: Best Brake Fluid
  245. Rear Axle: Quick question
  246. Brakes: Brake lights not going off
  247. Engine: Supercharger belt
  248. Speedo/Tach/Gauges Speedometer (Revolutions Per Mile) ???
  249. Steering Power Steering Belt Tightening
  250. Frame/Springs 58 sliver hawk frame
