View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Steering 1956 Steering boxes and columns interchange question
  2. Steering 1974 Avanti Steering Column Source
  3. Fuel System: 4BBL choke heat tubes
  4. Body: Golden Hawk floor pans both replaced FINALLY!
  5. Transmission: what purpose would this hole have, access for transmission assembly?
  6. Frame/Springs Rear Spring Bushings
  7. Body: will a 51 trunk lid fit a 50 starlite coupe
  8. Engine: intake won't hold torque
  9. Other: 62 Lark pedals
  10. Frame/Springs 1947 M5 rear spring bush removal.
  11. Fuel System: 1961 Hawk-Gas Tank or Guage or ??
  12. Fuel System: 2575S Carter WCFB Carburetor Problems
  13. Electrical: Tachometer
  14. Fuel System: Avanti R1 3540S Carter base gasket source?
  15. Electrical: Replacement headlight buckets and fender lights for 63 GT Hawk?
  16. Engine: Scrap rebuilt 283?
  17. Engine: 58 intake question
  18. Cool/Heat: Clutch Fan& Blades
  19. Engine: Jet Thrust Engine Mount
  20. Frame/Springs One way to make simple traction bars for a Studebaker
  21. Other: AC on a 289 question
  22. Exhaust A low buck exhaust system under my '55
  23. Cool/Heat: Water pump ?
  24. Body: more 50 starlight coupe questions
  25. Steering Anyone know what this is? Old style tilt steering perhaps?
  26. Body: C-K vs 53/54/55 Sedan Outer Front Fenders
  27. Body: New rubber keeps R/Q windows from sealing
  28. Transmission: Daytona engine mounts
  29. Steering Power Steering Conversion
  30. Brakes: Wheel cylinder rebuilding.
  31. Brakes: Disc brakes draqgging
  32. Fuel System: What would cause oil to get into the air filters on an R2 engine?
  33. Engine: Leaking core plug (Champion 6)
  34. Steering First long drive in GT and didnt go well- violent shake at 45 (see video)
  35. Other: Commander Deluxe or Commander Land Crusier
  36. Electrical: STA-KON type terminals needed
  37. Exhaust 1962 Lark with a Chevy 350: dual exhaust or stay single?
  38. Engine: rebuilding specificaitons for a 1961-64 in line l-head engine
  39. Paint: Lexol all over primered car
  40. Engine: Carb Question : 2bbl or 4bbl?
  41. Body: Position of hood insulator C/K
  42. Other: Minnesota/Wisconsin folks: recommended Chrome vendors?
  43. Interior: 1954 C/K Dash
  44. Engine: Partial-Flow Oil Filter Plumbing
  45. Fuel System: Throttle Linkage
  46. Other: what color glass should I get
  47. Exhaust Exhaust routing under a Lark type
  48. Engine: Heads Question
  49. Other: Zinc plating
  50. Body: Holes in trunk
  51. Cool/Heat: Coolant recovery tank?
  52. Speedo/Tach/Gauges Vacuum Gage?
  53. Body: 74 Avanti body repair after Hog Troughs
  54. Steering King pin removal question?
  55. Engine: Clipper HD fan question
  56. Interior: Horn Ring Removal - 50 Champion
  57. Cool/Heat: GT Hawk Radiator Options
  58. Engine: CASO dilemma: Rings and bearings vs bore it and new pistons, etc. ?
  59. Engine: Weight of Flathead Six?
  60. Ignition: Distributor Lock Plate
  61. Engine: T-10 conversion...Crankshaft bolts to flywheel
  62. Speedo/Tach/Gauges Fit question for a modified Avanti
  63. Body: 1950 holes in the body for Front bumper mounts --
  64. Transmission: '64 Daytona - 700R4 swap, tunnel clearance, driveshaft
  65. Cool/Heat: Will the expansion tank empty?
  66. Wheels My Hawk has wire wheels - Thunderbird!
  67. Body: Door hinge phillips screws- alternatives to adjust door?
  68. Electrical: Fuses...what fuses?
  69. Cool/Heat: 289 overheat!
  70. Engine: R-1 Harmonic Balancer same as 289?
  71. Body: 55 Champion
  72. Engine: Prestolite Distributor
  73. Clutch/Torque Converter: How to solve a REALLY stuck clutch problem and bleed your brakes at the same time
  74. Brakes: Master cylinder rebuild kit
  75. Body: Another source for cage nuts
  76. Frame/Springs Mystified.. help please
  77. Frame/Springs Front spring identification
  78. Cool/Heat: Current Radiator Technology & Pricing
  79. Fuel System: Fuel Filler
  80. Body: rust behind vent, front fender, bulletnose
  81. Brakes: Hot rods & brakes supplier feedback?
  82. Brakes: How hard is it to change the Master Cylinder and the Brake Cylinders?
  83. Frame/Springs add a helper leaf-by studeman
  84. Paint: Clear Coat Paint
  85. Brakes: Brakes - id required for brake drums
  86. Electrical: Power Surges while driving
  87. Brakes: 50 starlight brake shoe question
  88. Transmission: Scraping noise inside tranmission when coasting/decelerating (video)
  89. Steering Part to replace steering wheel
  90. Electrical: Wiper motor Questions:
  91. Frame/Springs Who has installed a HD Front Sway Bar in a Hawk? Advice needed.
  92. Front Axle: kingpin extra zerk
  93. Engine: Low Oil Pressure 62 Hawk 289
  94. Interior: Getting windows to roll up and down.
  95. Engine: Oil Pressure and Bearings
  96. Interior: Seat Belts on 61 Lark 5
  97. Cool/Heat: Stat housing?
  98. Electrical: Brake Lights and Turn Signals PROBLEM
  99. Steering A arm spreader- why needed?
  100. Steering 3 on the tree stump removal
  101. Other: Ideas for removing cured RTV
  102. Fuel System: Carburetor Installation
  103. Engine: Engine Identification
  104. Ignition: 52 Champion Carter intermittent flooding / voltage drop, weak spark when starting
  105. Electrical: wiring
  106. Electrical: Climatizer wiring
  107. Electrical: 1966 wipers not working
  108. Steering Steering Pump,..when is it worn out?
  109. Fuel System: Gas tank
  110. Transmission: Use what I've got? : 66 FOM & 62 259???
  111. Fuel System: Pesky Stromberg Carburetor Story
  112. Interior: Window Channel and Window Regulator.
  113. Fuel System: 1951 Studebaker Commander fuel pump.
  114. Electrical: 1953-55 Fog Lamp parts schematic?
  115. Exhaust center exhaust port
  116. Frame/Springs Coils
  117. Brakes: power brakes
  118. Drive Shaft Driveshaft lengths! 46 29/32 " really?
  119. Body: Adjusting Door Latch
  120. Electrical: A RATS nest!
  121. Engine: Maby a stupid question...
  122. Body: wipers & fin caps
  123. Body: Best patch panels?
  124. Body: Rear window glass won't fit on 53 Commander
  125. Shocks 64 hawk shock absorbers
  126. Steering Slick Street Stuff suspension with Stude steering linkage?
  127. Brakes: Brake pedal, throttle pedal
  128. Fuel System: stainless fuel line
  129. Brakes: Brake pedal adjustment
  130. Steering Power steering questions and help!!!
  131. Steering 52 Champ idler arm (Rebuild it ?)
  132. Frame/Springs 1965 cruiser
  133. Steering "O" ring clearance in king pin bushings?
  134. Fuel System: Fuel Sender
  135. Cool/Heat: Hawk A/C
  136. Body: 1964 Hawk Trunk Lock Assembly Needed
  137. Cool/Heat: measurement from sanden compressor
  138. Cool/Heat: Is this stock Avanti?
  139. Cool/Heat: Slightly different A/C question NOW WITH PICTURES
  140. Other: Can supercharger fluid get into the air filters on an R2?
  141. Steering Power steering problem - 63 Avanti
  142. Electrical: Questions about Tachometer and Vacuum Gauge Connections-57 Golden Hawk
  143. Frame/Springs 1962 Lark rear leaf springs.
  144. Fuel System: 56 Hawk fuel tank question
  145. Fuel System: Carter AS part needed
  146. Frame/Springs anybody ever install rear end below springs, 50 starlight
  147. Steering Upper kingpin bushing/bearing
  148. Drive Shaft Drive shaft 16 teeth
  149. Brakes: what master cylinder is this
  150. Electrical: '62 GT Hawk popping "Lights" CB
  151. Ignition: timing help on a 1947 m-5
  152. Speedo/Tach/Gauges oil gauge bleed?
  153. Brakes: '62 GT Hawk power drum brakes
  154. Engine: oil filter proper plumbing, 1947 M-5
  155. Interior: Lark Window Side Channel.
  156. Brakes: Brake pedal way up high on my M5. Why? [Updated 4/1]
  157. Frame/Springs Heavy duty anti-sway bars
  158. Clutch/Torque Converter: Pilot bearings on 39 commander
  159. Fuel System: 51 Commander Fuel Pump
  160. Fuel System: 245 six 2 barrel
  161. Body: 51 Commander Rust issue
  162. Body: 1948 Studebaker Land Cruiser Front Fender
  163. Front Axle: New lower pins
  164. Transmission: 58 Hawk V8 auto swap to V8 4 speed
  165. Transmission: Lark 4 Speed
  166. Engine: Aluminum Intake
  167. Ignition: 62 grand turismo
  168. Transmission: BW transmission (Auto) dimensions
  169. Fuel System: Fuel Injection To Avoid Vapor Lock
  170. Steering 65 Daytona Bell Crank
  171. Wheels 55 coupe wheels
  172. Interior: Glove box trim removal
  173. Fuel System: fuelpump 6-cyl & V8...
  174. Engine: Water Pumps: Clearance and the Late V-8s
  175. Brakes: '52 2R5 Emergency brake
  176. Steering 47 M-5 , Ross steering box, Need steering box repaired,parts or replaced?
  177. Body: Window bolts???
  178. Transmission: i think it's the linkage?
  179. Engine: Is this really the Chevy V-8 I have in my 66 Daytona?
  180. Speedo/Tach/Gauges Tach Sending Unit Picture
  181. Body: Avanti door weather strip
  182. Speedo/Tach/Gauges Stewart Warner Restoration Supplies?
  183. Other: List of superseded part numbers???
  184. grille surround
  185. Fuel System: Avanti II intake manifold
  186. Body: Lark door alignment?
  187. Body: Hawk Fins
  188. Engine: Tune-up?
  189. Body: Hawk trim removal
  190. Fuel System: Stromberg WW on a 259
  191. Body: Avanti Door alignment tricks?
  192. Electrical: Amp Fluctuation
  193. Rear Axle: Timken Diff ??
  194. Body: Avanti window mechanicals
  195. Body: Rear Bumper Brackets
  196. Steering Tie rod shape?
  197. Wheels New Tires 57 SilverHawk
  198. Engine: Valve adjustments, 6 cylinder, 170 eng.
  199. Cool/Heat: Question on water system
  200. Engine: Avanti engine questions for Mike V, Jack V, Mr Meyer? Ted?
  201. Frame/Springs 51 Champion spring swap: how long will it take?
  202. Engine: tool to spin oil pump of stored 259
  203. Transmission: FYI seals,ujoints
  204. Engine: flathead 6 leaking coolant
  205. Cool/Heat: radiator rebuild
  206. Other: How hard is it to rebuild a '63 supercharger orange whirly thing?
  207. Engine: 1953 Commander V8 dipstick length?
  208. Paint: 1957 Silver Hawk...what color is this?
  209. Engine: size of front crankshaft bolt
  210. Engine: '51 V-8 serial number location
  211. Engine: 289 Balancer Bolt
  212. Other: windshed wiper mechanism 63 Avanti
  213. Interior: Cardboard panel between back seat and trunk
  214. Engine: Solid Lifters Ticking on 289 V8
  215. Body: Hawk Hood to Cowl Gap
  216. Electrical: Wagonaire tailgate window motor/Avanti window motor
  217. Brakes: Brakes almost completely locked
  218. Front Axle: 55 C-body wheels
  219. Fuel System: Air Cleaner for 1957 Silver Hawk with Carter WCFB
  220. Engine: Adjusting valves by sound
  221. Engine: Rebuilt 289 Back In And The GT Is On The Road
  222. Engine: 289 kickdown linkage
  223. Ignition: Electronic Ignition on a Lark VI
  224. Wheels Steelies for front disk brakes
  225. Steering Power Steering & Pressure Hose
  226. Wheels 57 SilverHawk wheel identification
  227. Cool/Heat: 1955 President Coupe - Advice and Parts Search
  228. Fuel System: Carb Dash pot?
  229. Transmission: Cost to rebuild a 55 Speedster Transmission?
  230. Frame/Springs Crack on bottom of frame near spring tower
  231. Frame/Springs Upper control arm removal on a 1962 Lark
  232. Speedo/Tach/Gauges 1957 silver hawk 289 tach sending unit
  233. Body: Stude Truck Bumper Guards
  234. Ignition: 1964 Commander Distributor
  235. Other: 1964 Commander Trunk lock
  236. Exhaust transtar muffler questions
  237. Steering Power steering leak
  238. Transmission: How viable is a swap from manual to automatic transmission
  239. Engine: 1966 6cyl. Oil filter location
  240. Transmission: OD simplified wiring?
  241. Wheels Wider tires
  242. Interior: Climatizer or dash assembly order.
  243. Rear Axle: Gearing
  244. Body: 1948 Land Cruiser Lower Fender Panel and Air Intake
  245. Brakes: Check Valve on Bendix Hydrovac?
  246. Body: 1951 Commander Convertible top
  247. Frame/Springs 47 vs. 49 - 58 Truck frames
  248. Body: Avanti to Avanti II body parts question
  249. Cool/Heat: Adding a/c to a 51 Starlight
  250. Steering Steering column rebuild
