View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Wheels Interesting wheels for you Avanti or Hawk or...
  2. Exhaust Headers with a SBC
  3. Engine: 1955 259 engine
  4. Auto Rotisserie
  5. Steering Paging SweetOldBob and his steering rack setup.
  6. Engine: what are the tough rebuild parts to find (if needed) for a 289 for 57 Golden Hawk?
  7. Engine: Number 10 or Number 30 Oil 1948 Commander
  8. Clutch/Torque Converter: clutch won't return
  9. Engine: PCV valve / Breathers
  10. Engine: 66 Clearance issues
  11. Other: Rear Springs on a 64 Cruiser?
  12. Engine: 4.3 engine swap in 66 commander
  13. Steering Mechanical power steering...
  14. Engine: PCV Connection ?
  15. Body: Update: first floor panel and mount finally welded in!
  16. Electrical: Replacement wiper motor 54 Champion coupe.
  17. Electrical: starter solenoid
  18. Engine: oil pressure relief valve in 170
  19. Body: Polishing Advice
  20. Interior: Map Light
  21. Exhaust Planning for dual exhaust.
  22. Engine: small dents in 289 Valve Covers: repair hints?
  23. Engine: '63 Avanti R1 : stripped head bolt? Seriously?
  24. Engine: In car piston removal
  25. Interior: 50 Champion front seat- was replaced?? What are correct options?
  26. Transmission: automatic transmission fluid
  27. Engine: engine rebuild-replace-
  28. Electrical: Brake lights on 51
  29. Wheels 1948 champion wheels
  30. Engine: Tips for 289 build for mileage/reliability? Planning stage, future project.
  31. Interior: 49 2R5 Bench seat
  32. Paint: Seek Formula for Safford Cream or Ivory Mist
  33. Engine: I hope the valves are to tight,.
  34. Shocks Lark Rear Shock Mount Question
  35. Engine: First look at 289 engine internals; are these original Stude pistons and valves?
  36. Body: Floor Boards
  37. Brakes: 1962 lark front springs replacement / brakes pull left
  38. Engine: Oil Filter
  39. Paint: paint colors-engine compartment components
  40. Cool/Heat: Radiators...
  41. Engine: Re-Torqueing V8 Heads
  42. Paint: paint color formula
  43. Cool/Heat: Overheating issue in Winter?
  44. Fuel System: 4 barrell carb
  45. Engine: New GT owner with sprak plug wire routing problem
  46. Engine: Need to stop smoking
  47. Body: Wagonaire Tail Lamp Gaskets
  48. Engine: Roller cams
  49. Cool/Heat: Honeycomb Rad?
  50. Body: windshield trim removal question for 58 Pres
  51. Body: Hood Hinges
  52. Steering Grant kit 4291
  53. Body: Rocker panel and lower fender for 50 Champion
  54. Paint: Rust converters
  55. Frame/Springs 40 Commander front end question
  56. Body: Squaring up the Champ...
  57. Engine: Valve cover paint
  58. Engine: Starter Bendix
  59. Electrical: Need a vacuum advance
  60. Steering Power Steering Reservoir Cover Gasket
  61. Engine: Fish Bittin'!!
  62. Engine: camshaft install in new rebuild question.
  63. Other: 1939 Studebaker Commander imported to Norway
  64. Engine: Rocker Ratio
  65. Engine: Dual Point Distributors
  66. Brakes: It seemed so simple......
  67. Engine: The questions just keep coming - filler block 259 (not your SBC)
  68. Speedo/Tach/Gauges Crazy speedo
  69. Engine: Stude Parts in Other Brand Engines
  70. Electrical: On the coil, Negative goes to the distributor on a 289 R2?
  71. Paint: Correct color for 58 Packard Hawk Engine
  72. Brakes: Warning! Raybestos BH4900
  73. Electrical: Can a coil for breakerless ign. be used on a breaker system?
  74. Clutch/Torque Converter: V8 Truck v. Car Flywheel
  75. Body: Can I put 52 champion starliner body on 51 4 door frame?
  76. Transmission: T-86 question
  77. Transmission: starter for 200 4R
  78. Steering steering bell crank
  79. Engine: Excessive Deck Height
  80. Engine: Pistons in blown engines
  81. Brakes: updating brakes to disc-54 champion coupe,
  82. Engine: Another dreaded spark plug question
  83. Transmission: "Free-Wheeling" Mechanism
  84. Frame/Springs Roll Cage/Bar
  85. Engine: Vacuum Advance with Dual Point Disrtibutors
  86. Engine: Oil Capacity
  87. Engine: Head gasket install question
  88. Other: Driver side window dosen't want to stay up.
  89. Body: 55 commander
  90. Transmission: Removing T-86
  91. Engine: No oil pressure
  92. Body: Avanti vent windows
  93. Other: Engine and transmission number question
  94. Paint: fender seal
  95. Electrical: What did I damage?
  96. Brakes: 53 commander pedal wont keep pressure
  97. Engine: Are there any quality contact points available anymore?
  98. Engine: Engine identification
  99. Transmission: Flightomatic bellcrank-to-throttle linkage adjustment
  100. Body: Attach Trim Clips/Tabs
  101. Interior: Reclining front seats
  102. Engine: Question' dial indicating a 6 cyl?
  103. Transmission: 62 Hawk
  104. Cool/Heat: Pressure or non-pressure cooling system on '51 champ?
  105. Engine: Rear main crank seal
  106. Other: 2R5 pickup part
  107. Body: 51' Commender front clip?
  108. Electrical: Help with Avanti wiring diagram
  109. Body: Installing window regulator in 1966 Cruiser
  110. Fuel System: Avanti fuel line outside diameter
  111. Engine: Oil filter setup
  112. Cool/Heat: 1975 280Z radiator in 1960 Champ.
  113. Transmission: Air Cooled Automatics
  114. Interior: Hawk Dash - Is this Aluminum Oxidation?
  115. Electrical: Headlight/Tailight Multi Switch
  116. Other: Aerodynamic Flow Resistance of Studebaker Cars
  117. Transmission: Will not go into third gear
  118. Rear Axle: Rear axle seals
  119. Brakes: Hydrovac and dual master cylinder
  120. Fuel System: 58 Packard Hawk carb box tube
  121. Cool/Heat: 58 AC related
  122. Engine: Valley ribs in block casting
  123. Body: Top Fender Trim
  124. Engine: Oil line restrictor
  125. Engine: Is there a trick to putting on supercharger belts??
  126. Electrical: Resistor Pictures Please
  127. Electrical: how long?
  128. Wheels Stude dog dish on brand X wheels
  129. Engine: down draft tube
  130. Drive Shaft 700r4 Swap with the 2 Piece drive shaft. Help please.
  131. Paint: inside paint
  132. Frame/Springs I know this has been discussed, but need advice please..
  133. Engine: Is this normal for a newly rebuilt Champion 185?
  134. Engine: Over bore
  135. Brakes: brake line bleeding
  136. Brakes: New brake shoes longer than old ones?
  137. Engine: problem with timing?
  138. Electrical: Voltage reducer
  139. Other: Spark Plugs
  140. Wheels 1959 Hawk Wheel size.
  141. Body: M5 Doors on an M16 cab?
  142. Wheels Can I use a 225/70/15 tire on a 5" wheel?
  143. Paint: What color should I paint my 53
  144. Engine: 4 barrel change
  145. Electrical: Grounded AVANTI 1964
  146. Engine: Removing an engine
  147. Brakes: 10 inch rear drum?
  148. Rear Axle: FLANGED 44- outer axle seal differences and pictures.
  149. Engine: Well, The fish bitein' soga is over.
  150. Transmission: Direct Interchange?
  151. Transmission: Auto Tranny Can Bell Housing and Torque converter be installed w/o Tranny?
  152. Electrical: Wireing harnes and front windhield for my 58 Hawk,
  153. Drive Shaft Trans spacer and driveline angles
  154. Fuel System: SI Mechanical Fuel Pump
  155. Engine: 61 lark Run ON
  156. Transmission: Draining a torque converter
  157. Electrical: Wire Harness Clips
  158. Engine: Did Studebaker ever put a bigger cam in an R-2??
  159. Other: 53-57 Roll up antenna I D
  160. Fuel System: Bendix WW
  161. Other: Paint: Standardized List of Colors
  162. Engine: Which V8 camshaft do I have?
  163. Brakes: Do I really need this troublesome hydrovac?
  164. Exhaust Question for Avanti Headpipe Experts
  165. Paint: Exterior P.H. Colors
  166. Transmission: DG-200 Valve Block/Body for 1st Gear Start
  167. Transmission: DG-200 Sprag / Freewheel Orientation
  168. Drive Shaft rear motor mount question
  169. Other: 53 starlight VIN
  170. Cool/Heat: Water neck replacement part
  171. Fuel System: Fuel Pump
  172. Transmission: T 86 type E
  173. Engine: Engine Paint question
  174. Clutch/Torque Converter: Six vs V8 location.
  175. Other: solvent tanks
  176. Fuel System: vapor lock
  177. Fuel System: metering rod
  178. Paint: 1966 Color Brochure?
  179. Cool/Heat: radiator core support on 58 Packard Hawk ?
  180. Transmission: TH350 shifter into a 1962 Lark; any ideas?
  181. Cool/Heat: A/c clutch problems.
  182. Fuel System: Who rebuilds or has rebuilt carbs for '61 Lark six?
  183. Steering King Pins - '64 Hawk
  184. Wheels Halibrand magnesium wheels - new information on protecting them
  185. Interior: Rear seat belts '65 wagonaire
  186. Wheels Cragars
  187. Wheels Need help with 1960 Lark wheels
  188. Paint: 58 Parade Red paint formula
  189. Cool/Heat: I think the radiator search might be over. C K cars
  190. Engine: Oil flow controler MS-124
  191. Engine: Generator End Plate Trouble
  192. Engine: '61 Hawk - "frozen starter" ???
  193. Cool/Heat: Rear window A/C Setup on Ebay (1/22/2012)
  194. Engine: 61 Six Cylinder Oil Leaks
  195. Other: Truck Talk
  196. Rear Axle: Rear Wheel Bearings Reference
  197. Body: Window seal question
  198. Cool/Heat: 1963 Avanti R1 No A/C - radiator hose cross reference?
  199. Electrical: Wiper malfunction: Drive your Studebaker today ! Any rainy or wintry day....
  200. Wheels Hubs and drums
  201. Engine: Calculating Compression Ratio???
  202. Engine: 55 commander engine color
  203. Other: 1966 Cruiser with a 6 Cyl ??
  204. Body: C K Body weight
  205. Rear Axle: axel swap
  206. Brakes: Newbie Looking for Advice on Pulling Front Brakes to have Shoes Relined
  207. Engine: replacing valve seals
  208. Drive Shaft 1958 Change
  209. Fuel System: Using an Electric Fuel Pump on an R2 Avanti
  210. Engine: Oil Leaks: Best You've got....
  211. Engine: Can anyone tell me the timing on a 64 hawk 259
  212. Engine: 64 Champ runs but won't start
  213. Speedo/Tach/Gauges Fuel Gas Temp & Amp
  214. Interior: Rod Doors
  215. Engine: Valve spring bind?
  216. Engine: 1931 S60 Truck Engine Number Location
  217. Electrical: 50 Stude wiper motor 12volt electric needed
  218. Other: Finally found a modern radio that will fit the Baker
  219. Frame/Springs Lost and found
  220. Engine: Aluminum Valve Covers
  221. Brakes: update '40 hyd. brakes
  222. Engine: cylinder heads-exhaust manifolds.
  223. Other: Zinc etc
  224. Fuel System: Starting Over.
  225. Body: Seatbelts for 57 Golden Hawk: anchor locations while I have body off?
  226. Steering Help Identfy this part - Steering - Brake?
  227. Electrical: Spark Plug Wires. Which ones to buy?
  228. Body: Vent door springs
  229. Electrical: 1947-52 Ignition switch difference ?
  230. Steering 1960 Hawk Power Steering Leak
  231. Body: tailgate emblem
  232. Interior: Seatbelt color to best match the Golden Hawk gold vinyl?
  233. Body: Truck fender question
  234. Engine: Tech archives - A place to store Studebaker Know How
  235. Engine: OHV six on a 48 champion
  236. Brakes: Introduction and some brake issue questions
  237. Engine: Small Block Chevy motor mount location pictures (ala 65-66 McKinnon power)
  238. Other: Recalibrating torque wrenches
  239. Interior: 1931 PRESIDENT Model 80 4 door
  240. Transmission: Shift Indicator Question
  241. Fuel System: How do I get the fuel tank out of a 63 Avanti
  242. Frame/Springs Need Pillar Support Cross-member
  243. Fuel System: fuel system restoration- road draft tube
  244. Wheels Had Stock Lark Wheels Widened GOT EM BACK! New Pictures.
  245. Transmission: 63 Avanti - Is my auto transmission shifting to high?
  246. Brakes: Rebuilding Master and Wheel Cylinders
  247. Electrical: How do I set the points ??
  248. Engine: Justice Brothers Stop Leak
  249. Fuel System: WCFB 2214SA manifold gasket - I need your help
  250. Brakes: Pulling 2R10 truck rear brake drums
