View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Transmission: Tranny change from automatic to later 3 spd od
  2. Other: Warning Credit Card Fraud
  3. Wheels black brush mags
  4. Rear Axle: Dana 44 Rear end
  5. Body: Staples in splash guards neccesary?
  6. Transmission: Slick St. Stuff automatic floor shifter
  7. Engine: engine bay reassembly
  8. Body: CK Coupe quarter panel removal
  9. Shocks Tube shocks for M5's
  10. Body: CK quarter panel replacement
  11. Frame/Springs Upgrade on a 1953 Commander frame
  12. Other: Tire size
  13. Engine: 259 Rebuild
  14. Frame/Springs Front suspension parts
  15. Fuel System: Fuel spraying out of the accelerator pump
  16. Speedo/Tach/Gauges 64 daytona wagonaire speedo
  17. Interior: 64 daytona wagonaire interior.......
  18. Other: 1987 Avanti Convertible top
  19. Engine: Golden Hawk head gasket question
  20. Electrical: On a 63 Avanti, Do I need to polorize the voltage regulator
  21. Paint: remove doors and rear fenders?
  22. Body: Cutting Out my first floor (57GH); mystery piece, what do I do with it?
  23. Engine: 4 corners engine
  24. Body: 53 C quarter/rear windows
  25. Speedo/Tach/Gauges 53 studebaker champion
  26. Body: Trunk Lid on left side ,is it a bad hinge?
  27. Interior: Rear Package Radio Speaker Grille
  28. Fuel System: Carburetor on a 66 daytona with 283 v8
  29. Electrical: I tossed the dice..............and lost:-(
  30. Cool/Heat: Lark cooling redux
  31. Fuel System: Completely random fuel tank failure mode
  32. Body: Wanted: 1947--1949 rear fender gravel shields.
  33. Paint: Avanti 1001 Update
  34. Engine: R-1 Oil pan capacity
  35. Engine: R series engine oil pans
  36. Rear Axle: I have a hole in my 1950 Commander axle
  37. Electrical: Avanti owners, I hope to not have to bother you again. Starter solenoid?
  38. Electrical: Starter thrust washer
  39. Transmission: 62 Hawk
  40. Body: Body to Frame bolt kits? Available, or go shopping?
  41. Body: Molasses rust removal?
  42. Transmission: 23 tooth speedometer pinion gear
  43. Other: Painting.
  44. Body: quick check: is this the right way to remove/replace front body supports?
  45. Frame/Springs K member questions
  46. Body: Coupe Express Box info
  47. Engine: The Eagle has Returned to the NEST
  48. Engine: Motor mounts for SBC
  49. Engine: flex plate
  50. Brakes: Installed 54 brake drums on a 49 champion
  51. Cool/Heat: Upper Radiator Hose for Studebaker Avanti
  52. Fuel System: fuel pump
  53. Interior: Headliner Replacement in 1957 Silver Hawk
  54. Engine: Car wont start! Please Help
  55. Electrical: Starter idiot?
  56. Fuel System: LT-1 in an Avanti II
  57. Engine: Aluminum timing gear question
  58. Other: Identify jacks
  59. Body: Installing new Classic front body support arms- a couple questions
  60. Engine: Front and Rear Seals on my 1963 289 Full Oil Flow Studebaker Motor
  61. Front Axle: Champ truck
  62. Other: 1950 window
  63. Frame/Springs Looking for a 1953 Frame
  64. Frame/Springs spring change for stance
  65. Speedo/Tach/Gauges speedo cable
  66. Steering t cab steering
  67. Body: Loose trim & less than perfect paint
  68. Electrical: 75 Avanti physical route of dome light/cigar lighter circuits
  69. Rear Axle: ford exploror rear end ( rant in the end sorry)
  70. Steering Upper inner Pin seal interchange 1950-51-52-?
  71. Engine: Engine & Transmission Replacement
  72. Engine: The one piece I thought was good...
  73. Electrical: '51 Turn Signals
  74. Brakes: Heads Up Bendix Disc Brake Owners (Read This One)
  75. Fuel System: Choke cable knob?
  76. Speedo/Tach/Gauges Gauge panel colors?
  77. Fuel System: fuel sender problems
  78. Engine: Front and Rear seal Questions again.
  79. Electrical: Identify engine component
  80. Paint: 1966 283 engine color?
  81. Brakes: Turner Brake Squeel
  82. Body: Confirm assumption about 'squaring up' and fitting doors in K-body Hardtop WITHOUT WINDOWS
  83. Brakes: Vacum
  84. Body: Rear Window Replacement 64-66 Lark
  85. Electrical: Directional Signal Problem
  86. Electrical: Horn
  87. Clutch/Torque Converter: crank flange/flex plate
  88. Body: Wire harness routing
  89. Other: '62 Hawk questions
  90. Electrical: headlight circuit breaker
  91. Electrical: wiring a car
  92. Engine: 57 Golden Hawk head gasket questions
  93. Engine: Composition or Metal Intake Manifold Gaskets?
  94. Frame/Springs Has anyone ever used Poly frame bushings for rear springs?
  95. Paint: Painting cars
  96. Engine: Champion Oil Fill Tube
  97. Engine: What's the difference between '63 OHV 6 car & Champ truck cylinder heads?
  98. Electrical: Let The Games Begin
  99. Exhaust 55 President State Sedan Ultravision
  100. Electrical: Prestolite Alt. replacement
  101. Interior: Seat belts.
  102. Fuel System: Electric fuel pump
  103. Body: 1932 Studebaker Flatbed 1.5
  104. Engine: Reuse head bolts?
  105. Electrical: Stop Light Switch -- Dual M/C
  106. Steering Upper outer pin orientation question 55 K body
  107. Body: Head Liner Tightning
  108. Engine: Just a Big Thank You Forum Members
  109. Wheels 1947 half ton pickup rim and tire size?
  110. Other: Help with Tail light
  111. Frame/Springs Patterns
  112. Electrical: Display temperature doesn`t work
  113. Engine: Avanti R2 question
  114. Rear Axle: Tag on the diff cover
  115. Engine: 289 Torque Specs
  116. Fuel System: Are there any direct replacement carbs for an R2?
  117. Steering Steering parts for 63 R2 Avanti w/o PS
  118. Electrical: If you think you can, hell you can!
  119. Body: welding-primer and POR-15 type primer- how to best use when welding rusty floor/rocker areas?
  120. Body: Will front door glass on 52 Landcruiser fit a 52 Champion 4dr?
  121. Cool/Heat: C/K radiator clearance question
  122. Engine: Champion overhaul
  123. Electrical: Distributor interchange question
  124. Engine: 1940 Champion engine swap
  125. Frame/Springs Rear Spring Covers 1950 Land Cruiser
  126. Brakes: Avanti Master Cylinder Rebuild Kit
  127. Frame/Springs Moog CC655 Front Springs In A 56J
  128. Engine: How bad is it?
  129. Engine: distributor rebuild
  130. Paint: 1953 champion
  131. Other: windshield
  132. Engine: Avanti PCV Valve Hose Size?
  133. Other: Windshield washer bag???
  134. Other: how to install windshield reveal molding on 1948 land Cruiser 1 pc windshield
  135. Transmission: What Kind of Shifter is This?
  136. Engine: 170 flat head 2R5
  137. Engine: Need a good pic of the left side of the 170 flathead
  138. Fuel System: Fuel pump
  139. Engine: V/8 Head Redesign
  140. Brakes: Broken drum
  141. Electrical: Generator Low Voltage at Idle
  142. Interior: 60 Champ Dash
  143. Engine: Power Steering Fluid.. what to use?
  144. Transmission: Many Thanks & Shop Manual Question
  145. Rear Axle: Dana-Spicer, supplier
  146. Shocks Avanti 1001 shocks vs production shocks
  147. Engine: 1956 289 C.I. Horsepower Ratings
  148. Engine: No 289s for '59 ?
  149. Engine: R/3 Carb.
  150. Clutch/Torque Converter: Final Chapter, A Happy Ending..............
  151. Engine: Engine swaps into 47-49 champion cars without changing front suspension
  152. Other: Welding Question
  153. Body: '64 Daytona Trunk Seal
  154. Engine: Oil filter delete
  155. Engine: Full flow, spin on Oil Filters
  156. Engine: Oil Pressure Relief
  157. Engine: Air Filtration
  158. Engine: firing order for flathead six...
  159. Body: 55 Commander battery
  160. Electrical: Need help with H.E.I. equipped Stude.
  161. Engine: question from a rookie
  162. Engine: Was 259 or 289 The Better Engine?
  163. Speedo/Tach/Gauges Ac 3253
  164. Transmission: Pulling a Fligh o matic
  165. Electrical: Wiring a 51
  166. Transmission: T86 trans and a truck bell housing fit a 51 champion?
  167. Electrical: bendix
  168. Speedo/Tach/Gauges Quiver
  169. Brakes: parking brake cable
  170. Engine: Those hollow dowel pins - block to head
  171. Engine: Stude roller cams comming along nicely..
  172. Body: Body tag: "NOT JACKED" What's it mean?
  173. Rear Axle: Hub keyslot crack
  174. Engine: Journal diameters?
  175. Engine: OK, what does a studebaker V8 really weigh and leaf spring rate
  176. Drive Shaft How much is acceptable?
  177. Engine: Top of piston relative to deck height on 259's
  178. Wheels stupid lug nut question help!
  179. Body: door rubber install
  180. Engine: 1932 St Regis
  181. Fuel System: Fuel system
  182. Engine: What is the point gap on the dual points in an Avanti?
  183. Engine: Is there a PCV valve in there?
  184. Engine: What oil filter is on a 64 Hawk?
  185. Body: Weight differential -Wagon vs sedan
  186. Engine: Oil flow controller
  187. Speedo/Tach/Gauges recomendations from experienced owners
  188. Body: 1961-66 Door handle number
  189. Wheels Left-handed lug nuts
  190. Engine: Integrated Generator + Power Steering Pump
  191. Speedo/Tach/Gauges Making R2 tach work with Pertronix and MSD ignition
  192. Other: weight of a 1951 studebaker starlight coupe
  193. Other: Best rust penetrant ! I am not selling or shilling. Just want to pass it along
  194. Steering Power Steering Problem.
  195. Rear Axle: 61 Lark VertWhat rear end will fit?
  196. Body: Update Avanti R1001 and R 1002
  197. Brakes: Master cyl kit, 63 Lark split system
  198. Transmission: leaking seals
  199. Fuel System: CARB Adjustment
  200. Speedo/Tach/Gauges Avanti Speedometers
  201. Body: Help! How to deal with broken(??) nut INSIDE the frame, for 57 Hawk floor support member?
  202. Clutch/Torque Converter: Crossover/interchange part number
  203. Exhaust Side pipes
  204. Body: Wanted: Gravel shields
  205. Interior: Window Handles 50 Champion
  206. Exhaust 1965-66 Stude 283 exhaust mainfold question.
  207. Engine: Oil flow controller
  208. Body: Truck Bed Covers
  209. Body: Butyl vulcanizing tape
  210. Frame/Springs 63 Avanti Frame ???
  211. Electrical: Headlights?
  212. Other: How far back did Studebaker Use Frame Numbers and Where?
  213. Engine: Full Flow Block Oil Filter Base
  214. Brakes: Disc rotor Thickness 63 Avanti
  215. Engine: How Many Holes???? (Stude V8 Torque Plates)
  216. Body: Windshield issue
  217. Fuel System: demensions of 54 champion gas tank,
  218. Body: Avanti 1001 Restoration Update
  219. Transmission: O.D. Disassembly Help
  220. Engine: Push rods needed and other info.
  221. Interior: 57 Golden Hawk Headliner
  222. Transmission: Column to floor shift conversion in 1954 Studebaker Champion ?
  223. Other: Best MPG for '64 Champ?
  224. Engine: Spark Plug Wires for a 63 Avanti R2
  225. Rear Axle: 1956 Golden Hawk Differential Assembly
  226. Transmission: !956 Golden Hawk Standard Transmission
  227. Brakes: m5 brakes
  228. Electrical: 12v ?
  229. Wheels 15 x 6 OE wheels with 3.25 backspace ?
  230. Interior: Headliner/windlace question
  231. Transmission: Best gear shifter for a TH350 in a 1962 Lark
  232. Body: 53 Grill shells
  233. Body: Installing Quarter Panels on '64 Hardtop
  234. Electrical: Head lights - regular or halogen?
  235. Electrical: Took The Plunge...........I am now prepared!
  236. Engine: Lark flathead in an M series??
  237. Transmission: Parking pawl
  238. Exhaust Block HUgger headers and Avanti downpipes
  239. Transmission: DG150 floor shifter kit?
  240. Interior: seat base
  241. Transmission: T86E 1A Help needed
  242. Body: 53 hood spring brackets
  243. Speedo/Tach/Gauges need to replace speedometer cable
  244. Paint: Spray Gun
  245. Transmission: 1962 Lark Transmission & R/A options
  246. Exhaust 1956 Dual Exhaust
  247. Rear Axle: My axle ratio?
  248. Exhaust exhaust with chevy small block
  249. Engine: Is number one the drivers side front cylinder
  250. Other: Merry Christmas and a Happy New Year to All!!!!
