View Full Version : Tech Talk
- Transmission: Transmission Removal
- Brakes: jeep master cylinder
- Electrical: LED Bulbs
- Transmission: 63 Avanti transmission repair
- Engine: Springs & Lifters
- Electrical: Universal wiring kit
- Other: Hawk dash overlay refinish
- Engine: Another Problem
- Engine: Nearly Done (Pictures the rebuilder's sent me)
- Body: Window regulator
- Electrical: Continung electrical saga 1956 President.
- Fuel System: Avanti Gas smell in car - 63R1406
- Engine: Taking A 289 Out Of Mothballs
- Engine: 259 V8 Question
- Body: 1957 Silver Hawk Hood and Fender Fitment
- Body: Adjusting 51 LC trunk lid
- Engine: 259 connecting rod length, head question
- Engine: 289 Stude Engine wanted-Nebraska
- Electrical: 1950 Champion Wiring Schematics
- Electrical: No Rear turn signal
- Engine: 48 landscruser
- Fuel System: Carburetor and Choke Pipe Questions
- Engine: 289 crank snout length
- Electrical: 1966 Ignition Keys
- Engine: 65/66 timing mark
- Wheels tube wheels
- Engine: 64 OHV 6 cylinder pistons
- Electrical: Wiring help
- Other: Rust penetrant. The Best!
- Rear Axle: Cork rear axle grease seals
- Shocks Edelbrock IAS vs Koni Shocks
- Electrical: Power seats
- Cool/Heat: Heater hose connection to where?
- Engine: Valvoline oil
- Body: 58 2 dr hardtop photo? driver doorglass ' flipper seal'
- Wheels radial tires
- Wheels Hubcap mounting clips
- Interior: grill for rear radio speaker
- Body: Removed the windshield on my 60 Champ...
- Brakes: Brake Shoe Numbers
- Fuel System: carburator
- Interior: Avanti "cardboard" Material-What to use?
- Body: Fenders Hood and Misc Sheet Metal Picture
- Paint: 1957 Silver Hawk 289 V8 Engine Paint Colors
- Cool/Heat: '66 283 V8, upper radiator hose
- Other: 1962 Hawk mods
- Engine: Stuck Distributor
- Speedo/Tach/Gauges intake manifold pressure guage
- Electrical: intermittent discharge
- Body: Pulling The Steering Wheel
- Interior: Plastic Horn Button Installation
- Electrical: 57 Silver Hawk issues
- Transmission: Replacing a Damaged PARK Position Pawl
- Speedo/Tach/Gauges clicky speedo 62 HAWK
- Wheels Wheel stud thread size
- Interior: Door panel clips
- Engine: Head bolt
- Other: Gaskets
- Body: Avanti body support during frame off
- Other: POLE: The types of Web sites you like/ do not like for your parts needs
- Cool/Heat: heat and air unit
- Frame/Springs leaf springs
- Frame/Springs lark and hawk parts that are interchangeable
- Brakes: 1953 champion CONVERSION TO DUAL MASTER CYLINDER WITH POWER BOOSTER
- Brakes: Opinions needed about brake switch after MC conversion
- Electrical: Distributor question
- Engine: For anyone signed up to buy a roller cam...
- Engine: Engine reassembly notes:
- Rear Axle: Rearend Installation
- Transmission: T5 transmission into 59 Silver Hawk V8
- Electrical: Pertronix Ignitor - Elec. Ignition 1569P6 Studebaker
- Engine: Studebaker Cast Iron - "Is It Really Better?"
- Electrical: Distributor shaft loose
- Brakes: Master cylinder rebuild
- Electrical: I know it's not rocket science, but how is it possible??
- Electrical: Tach wiring
- Electrical: Gauges
- Fuel System: 56 Sending Unit
- Electrical: Avanti wiring harness
- Brakes: E-brake cable.
- Transmission: Transmission fluid in OD transmission?
- Engine: For those buying roller cams...
- Interior: Rusty Seat Frames
- Frame/Springs Dana 70hd
- Front Axle: Rubber O-Ring vs Cork gasket
- Other: Summit Penetrating Oil
- Transmission: Transmission mounts
- Cool/Heat: Trans Cooler was robbing my airflow
- Electrical: No Power to Distributor
- Fuel System: Check valve?
- Engine: 54 6 cylinder motor and trans into a 50 champion ???
- Engine: V.A. in question
- Engine: NOS Oversize Pistons For 289
- Electrical: Ground Wire on generator 1956 Sky Hawk
- Transmission: Overdrive problem
- Electrical: Is it live, or is it Memorex?
- Body: Hardtop Joys In Life....Not!
- Engine: Manufacturer
- Other: horn button/ ring removal
- Electrical: horn button and rewiring
- Rear Axle: Companion flange to pinion shaft witness mark. What if I forgot?
- Speedo/Tach/Gauges What is the correct speedo gear for my '50 Starlight, Std w/od. ?
- Electrical: Can I ditch the Voltage Regulator?
- Fuel System: 4 Hoses on a fule pump
- Electrical: can it be built?
- Engine: PCV Valve ?
- Body: Serial number plate
- Other: 2001 turning wheels
- Other: CASO amber bulbs
- Speedo/Tach/Gauges speedometer removal
- Electrical: Car will run only by keeping the key over to start
- Body: 79 Avanti 11 restoration
- Engine: Engine Done, Ready to Come Home (Pictures the rebuilder's sent me)
- Engine: Air Filter for 66 Stude V8
- Speedo/Tach/Gauges Where to repair/rebuild speedometer cable
- Engine: 3 flathead six engines.... new to studebaker... trying to ID?
- Steering Lark Saginaw to 53 C/K
- Body: factory paint
- Engine: Need Thin Head Gaskets For 259/289
- Interior: air conditioner panal
- Engine: Starter shims - 62 Hawk 289 4 speed
- Body: '64 Daytona rear 1/4 install
- Engine: Oil Pressure for Champ. 6 cyl.?
- Electrical: 55 president troubleshooting generator
- Engine: Oil Pressure is Low 1962 Hawk 289CID
- Clutch/Torque Converter: Got a question on a 62 Hawk
- Transmission: DG-200 Troubleshooting Question 1st/2nd Gear Start Identification
- Frame/Springs Bushing Dilemma
- Interior: Avanti Seat Material?
- Body: 1962 & 1963 GT Grill Mesh Interchangability
- Engine: More Hot Rod engine parts...
- Rear Axle: wtb dana 44 TT
- Steering Power steering darting
- Body: Will front bumper from 1947-48 Champion fit 1950 Champion?
- Fuel System: Offenhauser 2706 dual carb intake for the flathead 6
- Electrical: Remove horn ring 57 Silver Hawk
- Transmission: auto trans
- Engine: What color is the intake manifold on a 289 engine
- Front Axle: Part #'s for a arm bushings ??
- Engine: Ca Lobe Measurement
- Engine: Line Boring
- Body: Wagonaire roof
- Rear Axle: I have a lead on a 1965 Ford 8" rear end, anything I need to watch out for?
- Engine: Jet thrust
- Engine: Bore Centers
- Cool/Heat: Thermostat Bypass Hole
- Fuel System: Fuel pump rebuilding
- Transmission: 1953 champion column shift problems
- Body: hints on removing the large Philips screws for door hinges?
- Electrical: Update
- Fuel System: Multiple Carbs
- Electrical: Defroster switch.
- Engine: studeabake crate engines
- Engine: Fitting 383 chev crate motor to 64 cruiser
- Engine: Saginaw PS pump mounting {photo needed}
- Wheels the widest 59/60 lark wheels for the rear
- Body: floor seam?
- Interior: Exhaust Fumes in Avanti
- Fuel System: Intake manifold
- Electrical: jump pack
- Engine: thanks for information
- Transmission: To Install 700R Or Keep The T85
- Cool/Heat: thermostat woes
- Wheels any professional tire/ wheel guys here?
- Fuel System: Fuel pick up tube---55 Commander cp.
- Steering "What it is"---- help identify- please
- Engine: Question for an engine expert
- Fuel System: Turbo
- Body: Hood dimientions and weight?
- Body: Questions about rocker panel install on '63 Wagonaire
- Body: Urethane sealer at bottom of door pillars?
- Paint: I love my new sanding blocks!
- Electrical: Looking for speedster fog lights
- Body: Vehicle ID number
- Engine: Top cruising speed? 55 president
- Fuel System: Proper fuel filter for 1958?
- Steering Needa Part
- Transmission: Documented 700r4 swap
- Electrical: What starter do I have?
- Steering rack & pinon
- Transmission: 1974 Avanti T-10 information
- Cool/Heat: Heater control valve??
- Engine: Crankshafts
- Frame/Springs body off
- Electrical: Refurbishing starter and generator.
- Brakes: Brake lines for 63 Avanti
- Engine: jet thrust
- Speedo/Tach/Gauges chiltons or motors for Studes
- Engine: Deep-N-Hock Follies - November 2011
- Paint: Exhaust manifold paint
- Electrical: Suddenly nothing happens when I pull on my fan control knob-- 61 Lark
- Engine: push-rods
- Steering (Machinist) Quick steering pitman arm
- Engine: 57 G.H. Air Cleaner assembly
- Engine: 259 High Compression
- Engine: Avanti oil fill amount
- Engine: 57 or is it a 58?
- Cool/Heat: Will any other heater valve work??
- Electrical: R\R wiring harness 62 hawk
- Engine: Chrome Valve Covers On R Engines
- Electrical: Dash lights out, 62 Lark, and I have no idea why
- Engine: Lifter Clearance
- Transmission: chatters in reverse
- Cool/Heat: AC pulleys/6 cyl
- Rear Axle: rear wheel bearings
- Transmission: Power Hawk gear shift stuck
- Engine: Oil Leak
- Engine: Cam thoughts?
- Drive Shaft Driveshaft Length Question: '64 Hardtop w/ 4 spd
- Engine: R1 Damper Replacement
- Engine: Starting That Old Engine? Oil Pump - Don't Cheap Out.... (CASO Warning)
- Engine: shamrock engine
- Electrical: 63 LARK headlight switch / heater / wiper switch questions.....
- Brakes: Brake pedal return spring
- Body: OK, I need help from the Stude refurb genii
- Cool/Heat: Will the universal fan schrouds work?
- Body: Update on removing the Phllips screws on door hinges (done!) and additional question (trouble)
- Body: Hinge Pins- how bad to remove? (57 GH)
- Rear Axle: 47 Champion Starlight rear end
- Speedo/Tach/Gauges Odo works, speedo not so much
- Body: Water in Trunk area 1964 Cruiser
- Front Axle: Looking for ideas for fixing this
- Body: Ordering patch panels soon. Anything else I need to know?
- Transmission: DG250 in Jaguar
- Engine: What final torque is recommended for thin gaskets on a 259?
- Exhaust Jones mufflers?
- Electrical: Gauge resistors
- Body: Found a great Stainless repair guy
- Electrical: I need a big favor from an Avanti onwer!!
- Wheels I need hub caps or?
- Steering T-cab steering
- Electrical: 63 Champ Turn Signal Fuse
- Transmission: DG250 in Jaguar clarified
- Fuel System: Gas Tank Sending Unit on 1950 Studebaker
- Electrical: Avanti Air Conditioning Puzzle
- Brakes: parking brake assembly
- Electrical: electronic ignition
- Exhaust headers
- Engine: cam shaft
- Engine: intake manifold
- Speedo/Tach/Gauges after market gauges
- Rear Axle: ID
- Brakes: disk brakes
- Engine: Valve covers 62 289 washer or no washer??
- Cool/Heat: Lower radiator hose problems
- Steering Spacers for control arm bushing replacement
- Interior: Inner windshield frame clips?
- Electrical: I need electrical help again from an Avanti owner
- Frame/Springs Frame Crossmember rivets? (where to buy?)
Powered by vBulletin® Version 4.2.4 Beta 2 Copyright © 2019 vBulletin Solutions, Inc. All rights reserved.
